09076.0101-00
09076.0101-00
    MARQUARDT(马夸特)
    MARQUARDT - 09076.0101-00 - Slide Switch, SPDT, On-Off-On, Through Hole, 9076
09076.0101-00 数据手册
Slide switches 9076.0101 Product number Business unit Product family Actuation type Output Switching function Material fixed contact Contact system Number of poles connections Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Miscellaneous Type of fastening 9076.0101 Switches, Sensors & Controls Slide switches direct catalogue miniature switch Changeover switch with OFF position in the center (SPDT - Center OFF) CuZn gold-plated Electrical life 50000 1 - pole PCB terminal, sealed with epoxy resin ≤ 0.4V A 28 V < 50 mOhm > 500 MOhm small contact distance -25 °C ... +70 °C > 500 V slide: PA, light grey cover: PA, black base plate: PA glass fiber-reinforced, gray bearing connection external connection CuSn gold-plated slide contact actuating travel 2.5 mm pcb assembly Technical changes reserved. Dimensions are not binding. Detailed specifications available on request. gold plated gold plated
09076.0101-00 价格&库存
很抱歉,暂时无法提供与“09076.0101-00”相匹配的价格&库存,您可以联系我们找货
