SERIES 1550 - SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES
UP TO 16 (4) A 250 V~ INRUSH CURRENTS UP TO 100 A
PRODUCT ADVANTAGES
Single pole and double pole rocker
switches in the same size with ratings
up to 16 (4) A 250 V~
Inrush currents up to 100 A
Excellent actuation characteristic due to
snap-action contacting system
Forced mechanical opening in the event
that contacts weld together under
extremely high switching loads
Silk matt surface with
an abrasionproof marking
High accuracy of fit between rocker and
housing
Prominent lighting by lens effect
For ambient temperatures up to
T 100/55
Simple snap-on assembly for
appliance panel thickness of
0.80 ... 5.00 mm
Tight fit in appliance cut-out due to
tolerance compensation ribs on the
switch housing
Locked terminals for safe plugging of
the connectors
SWITCHING FUNCTIONS SINGLE AND DOUBLE POLE
ST-switch
ST-switch with indicator lamp
Switch with momentary function
TERMINAL VERSIONS
Standard versions
Appliance cut-out
single pole and double pole
Quick-connect terminal 6.3 mm
Solder terminal
PC-terminal
Angled PC-terminal
VERSIONS ON REQUEST
X = panel thickness
Z
Y
Installation example
front panel
mounting plate
2.24
Appliance cut-out
X
0.8...5
Y
27.2 ±0.1
Z
12.2 +0.2
With flammability according to UL 94 V-0
For inrush currents up to 120 A
With gold contacts for low voltages
Switches with additional supports for
PCB assembly
Electrical rating
16 (4) A 250 V~
10 (4) A 250 V~ 5E4
5 / 100 A 250 V~
Inrush current ST-switches
Mechanical life endurance
Contact resistance (new state)
Insulation resistance (new state)
High voltage resistance
(new state)
Resistance to tracking
Contact gap
Insulation spacing
Protection type
Ambient temperature
terminal side
actuating side
Storage temperature
Actuating force
Flammability
Heat and fire-resistance
Material housing and rocker
Material rocker illuminated
Contacts
Terminals
Temperature rise at the terminals
(according to electrical life endurance)
Solderability of terminals
Push-on force of connectors
Approval marks
Suitable for appliances of protection class II
16 A 125 - 250 V AC
1 HP 125 V AC
2 HP 250 V AC
100 A capacitive 104 operations
" 5E4
< 100 m# (12 V, 1A DC)
> 100 M# (500 V DC between the
open contacts)
1250 V eff. (between the open
contacts)
3750 V eff. (reinforced insulation)
PTI 250
" 3 mm
" 8 mm
IP 40
-20 °C ... +100 °C no condensation
-20 °C ... + 55 °C no condensation
-40 °C ... + 80 °C
3-5 N
UL 94 V-2
850 °C (category D)
PA
PA/PC
Ag
CuZn resp.silver-plated
max. 30 K (UL 1054)
max. 55 K (EN 61058-1)
max. 350 °C, 3 sec. (no pressure on the
terminals when soldering by hand!)
! 80 N
ra
The test conditions comply with EN 61058-1 and UL 1054
FORCED CONTACT OPENING
The series 1550 is designed in order to
force mechanicallly welded contacts
(melting under heat) which may occur at
extremely high switching loads to open.
stop point in the
rocker dome
contact bridge
actuator
2.25
ST-SWITCHES
with indicator lamp
16 (4) A 250 V~
10 (4) A 250 V~ 5E4
5/100 A 250 V~
16 A (2 HP) 250 V AC
Switches for 125 V AC and
single pole versions on request
double pole
1555.3104*
double pole
1555.3102*
quick-connect terminal 6.3
double pole
1555.3108*
double pole
1555.3604
ST-SWITCHES
12.8
13
6
12.3
5
12
23.4
17
23.7
double pole
1552.4606*
4.5
double pole
1552.3602*
1552.2602
1552.4602*
5
double pole
1552.3102*
17
single pole
1551.3102*
2
16 (4) A 250 V~
10 (4) A 250 V~ 5E4
5/100 A 250 V~
16 A 125 - 250 V AC
1 HP 125 V AC
2 HP 250 V AC
quick-connect terminal 6,3
angled PC-terminal
SWITCHES WITH MOMENTARY FUNCTION
16 (4) A 250 V~
10 (4) A 250 V~ 5E4
5/100 A 250 V~
16 A 125 - 250 V AC
1 HP 125 V AC
2 HP 250 V AC
2.26
single pole NO
1551.3202*
* Version on stock
3.5
很抱歉,暂时无法提供与“1555.3108”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+62.10593
- 25+60.77637
- 100+58.91978
- 250+57.51836
