1841.1201-01
1841.1201-01
    MARQUARDT(马夸特)
1841.1201-01 数据手册
SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES ON REQUEST 100 million times proven switching principle with longer life endurance with 100 000 mechanical switching cycles Higher power with 6 (6) A 250 V AC Other terminal types Cable assembly Fastening by round nut M12 Excellent actuating characteristic ROTARY SWITCHES Variant for snapping on customized pushbuttons SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (4) A 250 V AC Mechanical life endurance 10E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) terminal side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Glow wire test temperature 850 °C Material PA PA glass fiber-reinforced / PA silver plated actuator housing terminals Plug force of the terminals < Approval marks 3/ 1 80 N Suitable for appliances of protection class II /2 TACT AND KEY SWITCHES IP 40 Ambient temperature SNAP-ACTION SWITCHES Protection type MICRO-SIGNAL SWITCHES 250 PTI SENSORS Proof tracking FOOT SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) 103 | SENSORS MICRO-SIGNAL SWITCHES | 104 FOOT SWITCHES 1842.1101 4.8 > 3 Ag 1842.6101 4.8 > 3 Ag TOGGLE SWITCHES 1841.1201 Changeover switch (SPDT) 1843.1101 Changeover switch (SPDT momentary) 1843.1201 PUSHBUTTON SWITCHES ROCKER SWITCHES > 3 Ag 1841.6101 4.8 > 3 Ag 4.8 > 3 Ag 4.8 > 3 Ag 4.8 > 3 Ag 4.8 > 3 Ag snap-on actuator caps see page 105 Stock version Miscellaneous Terminal type 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 (2) A 250 V AC 5E4 6 (4) A 250 V AC 5E4 Housing color Actuator color / printing Contact material Normally open contact (SPNO) Contact distance in mm 1841.1301 Terminal description Normally closed contact (SPNC) 4.8 Stock version SLIDE SWITCHES ON / OFF switch (SPST) 1841.1101 Miscellaneous Terminal type 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 (2) A 250 V AC 5E4 6 (4) A 250 V AC 5E4 Housing color ROTARY SWITCHES single-pole Actuator color / printing Contact material ON / OFF switch (DPST) Contact distance in mm TACT AND KEY SWITCHES double-pole Terminal description SNAP-ACTION SWITCHES SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 6 (4) A 250 V AC snap-on actuator caps see page 105 SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (4) A 250 V AC 15.6 7 7 23.9 PUSHBUTTON SWITCHES 23 8.4 M12x0.75 ø8 16.6 23.9 M12x0.75 Basic type 1842 double-pole 4.8-0.8 Quick-connect terminal 4.8 x 0.8 Identification plate of aluminum for plugging on with black inscription “ON” and “OFF” 28 ON ROTARY SWITCHES 10.2 25.6 7 SLIDE SWITCHES 23 12.7 19.9 ø8 TOGGLE SWITCHES Quick-connect terminal 4.8 x 0.8 Basic types 1841 and 1843 single-pole 16.5 Identification plate 240.001.011 Identification plate 240.002.011 Neopren® - cap for pushbutton (M12 x 0.75) basic type 1840 as dust and water protection. Pushbutton plate on top of cap is CuZn nickel plated. 20 14 ø 22 MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES 26 Identification plate of CuZn nickelplated for plugging on as well as with twist protection and stamped inscription “ON” and “OFF” TACT AND KEY SWITCHES FOOT SWITCHES OFF Protection cap 343.002.023 SENSORS SW 19 105 | SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 6 (4) A 250 V AC ø 20 Pushbutton 205.008.011 Pushbutton of PA black, rectangular 20 x 25 mm for assembly by customer on 1841.6101 and 1842.6101 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES 25 11.5 TOGGLE SWITCHES PUSHBUTTON SWITCHES 11.5 ROCKER SWITCHES Pushbutton of PA black, with diameter 20 mm for assembly by customer on 1841.6101 and 1842.6101 | 106 20 Pushbutton 203.106.011
1841.1201-01 价格&库存
很抱歉,暂时无法提供与“1841.1201-01”相匹配的价格&库存,您可以联系我们找货
