0100.2901-00
0100.2901-00
    MARQUARDT(马夸特)
0100.2901-00 数据手册
SERIES 0100 - SINGLE-POLE TOGGLE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 2 A 250 V AC ON REQUEST Robust and powerful toggle switch with 50 000 mechanical switching cycles Other terminal variants SLIDE SWITCHES Central fastening with nut M12 Mechanical life endurance 5E4 Material metal / PA (product-dependent) CnZn nickel-plated / Duroplast (base) / chromated galvanized steel (bracket plate) silver plated actuator housing SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES Stock version Miscellaneous Contact material Contact distance in mm Terminal type 2 A 250 V 1E3 Housing color single-pole Actuator color / printing TACT AND KEY SWITCHES terminals FOOT SWITCHES ROTARY SWITCHES Metal or plastic lever 0100.1201 > 3 CuZn silver plated actuating torque 45.0 +14.0 Nmm 0100.2901 > 3 CuZn silver plated actuating torque 45.0 +14.0 Nmm metal lever SENSORS ON/OFF switch (SPST) 125 | SERIES 0100 - SINGLE-POLE TOGGLE SWITCHES ROCKER SWITCHES TO 2 A 250 V AC 12.5 ø4.5 3 1.7 23.5 ø2.1 12.5 30 Solder terminal Basic type 0100 Identification plate of aluminum for plugging on with black inscription “ON” and “OFF” TOGGLE SWITCHES PUSHBUTTON SWITCHES 15.5 10 M12x0.75 28 ON 16.5 Identificatin plate 240.001.011 Identification plate of CuZn nickelplated for plugging on and with twist protection and stamped inscription “ON” and “OFF” Identification plate 240.002.011 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES 26 ROTARY SWITCHES SLIDE SWITCHES OFF | 126 Further information under WWW.MARQUARDT-SWITCHES.COM
0100.2901-00 价格&库存
很抱歉,暂时无法提供与“0100.2901-00”相匹配的价格&库存,您可以联系我们找货
