SERIES 1050 - ENCLOSED SNAP ACTION SWITCHES
UP TO 10 (1,5) A 250 V~
PRODUCT ADVANTAGES
Small snap action switches in size
DIN 41635 design B
Maximum functional reliability by tension spring contact system
Precise switching accuracy with long
life endurance
Special shape of the PCB terminals for
better automatic soldering
The versions with mushroom-head
actuators can be approached from all
sides
The standard program includes a
number of different ratings and
terminal versions
The optional actuators made of
chrome-nickel-steel are available in different shapes and lengths. These can
easily be retrofitted.
SWITCHING FUNCTIONS
Change-over
Normally open
Normally closed
TERMINAL VERSIONS
Quick-connect terminal 2.8 x 0.5 mm
Solder terminal
PCB terminal
Angled PCB terminal
VERSIONS ON REQUEST
3.10
With longer over-travel
Approved to T 125
With increased or reduced movement
differential
With gold-plated contacts
With electrical rating
2 (2) A 250 V~ 25E3
Actuating force ! 2,2 N
6 (2) A 250 V~ 25E3
Electrical rating (depending on version)
10 (1,5) A 250 V~ 10E3
10,1 A 125 - 250 V AC 1/4 HP
Version
DIN 41635 B
Actuating force max.
! 2,2 N
Mechanical life endurance
10E6 without optional actuator (1,5N-Version)
1E6 with optional actuator
Electrical life endurance
electrical rating-dependent
Contact resistance (new state)
< 100 m#
Insulation resistance (new state)
> 100 M# (500 V DC between the
open contacts)
High voltage resistance (new state)
750 V eff. (between the open
contacts)
1250 V
(basic insulation)
Bounce time
< 5 ms
Protection type
IP 40
Resistance to tracking
PTI 175
Contact gap
< 3 mm (µ)
Ambient temperature
-40 °C ... +100 °C no condensation
Storage temperature
-40 °C ... +100 °C
Flammability
UL 94 V-2
Heat and fire-resistance
850 °C (category D)
Material
actuator
PA
housing
PBTP
optional actuator
chrome-nickel steel
optional actuator roller
PA
Contacts
AgNi/AgNi resp. gold-plated
Material
quick-connect terminals CuZn resp. silver-plated
solder terminals
NC and NO tinned / COM silver-plated
PCB terminals
tinned and sealed to the switch
Solderability of terminals
max. 350 °C, 2-3 sec. (no pressure on
the terminals when soldering by hand!)
Approval marks
ra
Suitable for appliances of protection class II. Required air and creepage distances
within the appliances have to be observed.
The test conditions comply with EN 61058-1 resp. UL 1054.
mov. differential max. 0.2 mm
pre-travel
max. 1.2 mm
over-travel
min. 0.6 mm
STANDARD VERSION
Actuating force ! 1,5 N
[Actuating force ! 2,2 N]
free position
operating pos.
total travel
position allowed
5 A 250 V~ 50E3
5 A 125-250 V AC 1/10 HP
change-over
1050.1102*
1050.0102*
1050.2102*
1050.3102
1050.4102
10,1 A 125-250 V AC 1/4 HP
change-over
[1050.0103*]
2 (0,5) A 250 V~ 25E3
2 A 125-250 V AC
contacts gold-plated
1050.1151*
1050.2151*
* Version on stock
normally open
1050.1122
1050.0122*
1050.2122*
normally closed
1050.1142
3.11
pre-travel
max. 1.2 mm
over-travel
min. 0.5 mm
MUSHROOM HEAD ACTUATOR
free position
operating pos.
total travel position
allowed
5 A 250 V~ 50E3
Change-over
1050.1202*
1050.0202*
1050.2202*
2 A 125-250 V AC
Contacts gold- plated
1050.4251
The mushroom head actuator allows actuation
from all sides in addition to vertical actuation
from above.
An angle of < 45° is necessary on the actuating
element for such applications (angle for versions
with longer over-travel on request). To keep the
friction as low as possible, we recommend that
you use materials with a low friction coefficient.
The surface of the actuating element should be
polished.
The mechanical life depends on the material
and surface properties as well as on the design
of the slide.
VERSION WITH OPTIONAL ACTUATOR
total travel pos. allowed
operating position
7.5
12.3
9.5
5.7
free position
Actuating force ! 0,5 N
[Actuating force ! 0,6 N]
6.4
mov. differential max. 1.0 mm
pre-travel
max. 5.4 mm
over-travel
min. 2.2 mm
7.4
1
5 A 250 V~ 50E3
Change-over
1050.5202*
1050.7202*
2 A 125-250 V AC
Contacts gold-plated
1050.6251
1050.5251*
4
!15
11.1 ±1.5
3.4
2
operating position
5.8
12.3
free position
2.7
6.4
3.4
1
5 A 250 V~ 50E3
4
! 20
16.4
13
±1.5
9.5
R2
.5
pre-travel
max. 5.1 mm
over-travel
min. 1.9 mm
2
Change-over
[1050.5502*]
12.3
5.8
9.5
operating position
6.4
free position
5.2
2.9
3.3
1
5 A 250 V~ 50E3
Change-over
[1050.6702*]
[1050.5702*]
[1050.7702*]
3.12
* Version on stock
4
2
13
±1.5
Ø5
pre-travel
max. 5.3 mm
over-travel
min. 1.7 mm
OPTIONAL METAL LEVERS
These optional metal levers are available
as accessory parts for retrofitting.
191 071 011*
191 071 021*
191 071 041*
191 071 101*
191 078 013*
191 078 023*
18.9
(12.3)
operating positionl
free position
18.6
(12.3)
operating position
4.8
free position
190 072 013*
!16.5
9.4
12.5
R2
(6.15)
! 16
8
11.5
(6.15)
free position
190 075 013*
operating position
5
R2
(6.15)
These optional plastic levers are available
as accessory parts for retrofitting..
3.8
!20
6.4
16.6
20.6
(12.3)
13.6
OPTIONAL PLASTIC LEVERS
191 071 051*
190 074 013*
DIMENSIONED DRAWINGS
quick-connect
solder terminal
bent PCB
terminal
9.5
9.5
Ø1.6
5
5
Ø1.6
2.75
Ø1.3
7.5
7.5
2.75
terminal holes
fixing holes
angled PCB-terminal to socket side
(left)
* Version on stock
terminal holes
fixing holes
Ø1.3
7.5
7.5
angled PCB-terminal to cover side
(right)
3.13
很抱歉,暂时无法提供与“01050.1202-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+57.22490
- 5+49.40586
- 10+47.55492
- 20+46.11926
- 50+44.42256
