09077.0200-00
09077.0200-00
    MARQUARDT(马夸特)
    MARQUARDT - 09077.0200-00 - PUSH BUTTON SW, DPDT, 0.4VA, 28VAC, THT
09077.0200-00 数据手册
Pushbutton switches 9077.0200 Product number Business unit Product family Actuation type Output Switching function Material fixed contact Contact system Number of poles connections Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Operating force Total travel / stroke Miscellaneous Type of fastening 9077.0200 Switches, Sensors & Controls Pushbutton switches direct catalogue miniature switch Changeover switch (DPDT momentary) CuZn gold-plated Electrical life 50000 2 - pole PCB terminal, sealed with epoxy resin ≤ 0.4V A 28 V < 50 mOhm > 500 MOhm small contact distance > 500 V -25 °C ... +70 °C actuator: PC, natural cover: PA, black base plate: PA glass fiber-reinforced, gray bearing connection gold plated external connection gold plated CuSn gold-plated lifting contact 3.5 N 1.1 mm corresponding pushbuttons 9090.17.. see additional parts pcb assembly Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09077.0200-00 价格&库存
很抱歉,暂时无法提供与“09077.0200-00”相匹配的价格&库存,您可以联系我们找货
