09078.0401-00
09078.0401-00
    MARQUARDT(马夸特)
    MARQUARDT - 09078.0401-00 - Slide Switch, DPDT, On-On, Through Hole, 9078, 100 mA
09078.0401-00 数据手册
Slide switches 9078.0401 Product number Business unit Product family Actuation type Output Switching function Material fixed contact Contact system Number of poles connections Rating IEC Actuators and additional actuators Housing description Connection surface Contact material Miscellaneous Type of fastening 9078.0401 Switches, Sensors & Controls Slide switches direct catalogue miniature switch Changeover switch covering switching (DPDT) CuZn gold-plated Electrical life 50000 2 - pole PCB terminal, sealed with epoxy resin 0.1 A 30 V slide: thermosplastic, black, side actuation cover: thermoplastic, red base plate: thermoplastic glass fibre reinforced, gray bearing connection silver plated external connection silver plated CuSn gold-plated pcb assembly Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09078.0401-00 价格&库存
很抱歉,暂时无法提供与“09078.0401-00”相匹配的价格&库存,您可以联系我们找货
