09070.1101-00
09070.1101-00
    MARQUARDT(马夸特)
    MARQUARDT - 09070.1101-00 - TOGGLE SWITCH, SPDT, 0.4VA, 28VAC, THT
09070.1101-00 数据手册
Toggle switches 9070.1101 Product number 9070.1101 Business unit Switches, Sensors & Controls Product family Actuation type Packing unit Output Switching function Material fixed contact Contact system Number of poles connections Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Toggle switches direct Housing description Connection surface Contact material Contact type Miscellaneous 100 catalogue miniature switch Changeover switch (SPDT) CuZn gold-plated Electrical life 1 - pole PCB terminal, injected in base, sealed with epoxy resin ≤ 0.4V A 28 V < 50 mOhm > 500 MOhm small contact distance > 500 V -25 °C ... +70 °C lever: CurZn nickel-plated housing: PA glass fiber-reinforced, gray, for round device cutout base plate: PA glass fiber-reinforced, gray bearing connection gold plated external connection gold plated CuSn gold-plated slide contact Technical changes reserved. Dimensions are not binding. Detailed specifications available on request. 50000
09070.1101-00 价格&库存
很抱歉,暂时无法提供与“09070.1101-00”相匹配的价格&库存,您可以联系我们找货
