SERIES 1117 - SNAP-ACTION SWITCHES
SLIDE SWITCHES
TOGGLE SWITCHES
PUSHBUTTON SWITCHES
ROCKER SWITCHES
TO 16 ( 6 ) A 400 V AC
PRODUCT FE ATURES
ON REQUEST
Double interrupting jump contact switching system
Customized versions
Contact distance > 3 mm
Changeover basic type 1116
Material conformant with the filament wire test
acc. to IEC 60 335-1:2001 chap. 30 and UL 94 V-0
Large overtravel
ROTARY SWITCHES
Actuator can be approached from all directions
Normally open contact and normally closed
contact versions
Mechanical life endurance
10E4
Contact resistance (new condition)
< 100 mOhm (1 A 12 V DC)
SENSORS
MICRO-SIGNAL SWITCHES
TACT AND KEY SWITCHES
FOOT SWITCHES
Insulation resistance (new condition) > 100 MOhm (500 V DC)
| 194
Proof tracking
250 PTI
Protection type
IP 40
Ambient temperature
-40 °C ... +85 °C
Flammability
UL 94 V-0
Glow wire test temperature
850 °C
Material
PA glass fiber-reinforced
silver plated
actuator
housing
terminals
Contact material
Ag
Contact distance
Approval marks
3/ 1
3 mm
/2
Suitable for appliances of protection class II under compliance with the installation conditions
required on the equipment side
Free position (FP) max. in mm
Permissible total travel
position (TP) in mm
6.3
3
3.5 + 0.5
12.4 + 0.5
2.6
15.2
8.5
22
ø6
30
13
6.3-0.8
10
Quick-connect terminal
6.3 x 0.8
PUSHBUTTON SWITCHES
ROCKER SWITCHES
Difference travel max. in mm
8.5
TOGGLE SWITCHES
Operating position (OP) in mm
15.2
SLIDE SWITCHES
Operating force in N
2.6
ROTARY SWITCHES
Contact distance in mm
12.4 + 0.5
Stock version
Terminal description
3.5 + 0.5
FOOT SWITCHES
TP
Terminal type
12 A 125 V AC 1/6 HP
3
8.5
1117.0106
FP
Normally open contact (SPNO)
6.3
很抱歉,暂时无法提供与“1117.0106-01”相匹配的价格&库存,您可以联系我们找货
