1801.1146
1801.1146
    MARQUARDT(马夸特)
1801.1146 数据手册
SERIES 1800 - SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES UP TO 12 (4) A 250 V~ AND 8 (8) A 250 V~ PRODUCT ADVANTAGES ◆ Switching principle with long life endurance due to a low friction contact system (ball), proven a 100 million times ◆ Attractive rocker switches with silk matt surfaces and abrasionproof markings ◆ High ratings up to 12 (4) A 250 V ~ resp. 8 (8) A 250 V~ and inrush current peaks up to 70 A ◆ Suitable for ambient temperatures up to T 100/55 ◆ High accuracy of fit between rocker and housing ◆ Excellent actuation characteristic ◆ Simple snap-on assembly for appliance panel thickness of 0.75 ... 3.00 mm ◆ Tight fit in appliance cut-out due to tolerance compensation ribs on the switch housing ◆ Staked terminals for reliable plugging of connectors SWITCHING FUNCTIONS ◆ Single throw (ST) switches ◆ ST- switches with indicator lamp ◆ Double throw (DT) switches ◆ Double throw switches with centre-OFF ◆ Switches with momentary function ◆ Pilot lights TERMINAL VERSIONS ◆ Quick-connect terminal 4.8 mm ◆ Solder terminal ◆ Straight PCB terminal ◆ Angled PCB-terminal VERSIONS ON REQUEST ◆ With flammability according to UL 94 V-0 ◆ With gold-plated contacts for low voltages ◆ With cutting contacts for applications in a dusty environment ◆ With additional supports for PCB assembly ◆ With special rocker for snapping on customized actuators ACCESSORIES ◆ 2.6 Protection caps against dust and splash water (see page 2.48) STANDARD VERSIONS single pole double pole X = panel thickness Y X = panel thickness X Y 0.75...1.25 19.2 –0.1 1.25...2 19.4 –0.1 2 ...3 19.8 –0.1 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 Electrical rating (depending on version) Inrush current ST-switches Mechanical life endurance ST / DT DT with centre-OFF 5E4 Contact resistance (new state) Insulation resistance (new state) Z Y Z APPLIANCE CUT-OUT X Y 0.75...1.25 19.2 –0.1 1.25...2 19.4 –0.1 2 ...3 19.8 –0.1 Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 8 (8) A 250 V~ 5E4 12 (4) A 250 V~ 15 A 125 - 250 V AC 3/4 HP 125 V AC 1 1/2 HP 250 V AC 70 A capacitive 104 operations 1E5 < 100 m# (12 V, 1 A DC) > 100 M# (500 V DC between the open contacts) High voltage resistance < 3 mm 750 V eff. (between the open (new state) " 3 mm 1250 V eff. contacts) 3750 V eff. (reinforced insulation) Resistance to tracking PTI 250 Contact gap ST / DT " 3 mm DT with centre-OFF < 3 mm (µ) Insulation spacing " 8 mm Protection type IP 40 Ambient temperature Terminal side -20 °C ... +100 °C (no condensation) Actuating side -20 °C ... + 55 °C (no condensation) Storage temperature -40 °C ... + 80 °C Actuating force 3-8 N (depending on the switching function) Flammability UL 94 V-2 Heat and fire resistant 850 °C (category D) Material housing and rocker PA rocker illuminated PC Contacts Ag Terminals silver-plated Temperature rise at the terminals max. 30 K (UL 1054) (according to electrical life endurance) max. 55 K (EN 61058-1) Solderability of terminals max. 350 °C, 3 sec. (no pressure when soldering by hand!) Push-on force of connectors ! 80 N Approval marks or v d n s t k j . w r a Suitable for appliances of protection class II 2.7 SERIES 1800 - SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES UP TO 12 (4) A 250 V~ AND 8 (8) A 250 V~ SINGLE POLE ST-SWITCHES with indicator lamp 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 5/50 A 250 V~ T 100/55 6 A (1/2 HP) 250 V AC 1800.1102* 1800.0102 1800.1108* 1800.0108 1800.1104* ST-switches for 125 V AC on request quick-connect terminal 4.8 solder terminal 1805.7110* 1805.6102 1805.7109* 1805.6108 DOUBLE POLE ST-SWITCHES with indicator lamp 21 17.5 13.2 4,8 x 0,8 3 x 15 7 10.2 22 18.6 quick-connect terminal 4.8 SINGLE POLE COMBINATION 13.2 2 5.3 7 18.6 24 5.3 24 21 19.5 ST-switches with indicator lamp for 12 (4) A 250 V~ resp. 8 (8) A 250 V~, for 125 V AC and for 125 V - 250 V AC on request 1805.7104* 2 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 5/50 A 250 V~ T 100/55 6 A (1/2 HP) 250 V AC 10.2 22 solder terminal Appliance cut-out 10 (4) A 250 V~ 6 (4) A 250 V~ 5 E 4 T 100/55 Y Z X = panel thickness Additional switching functions on request ST-switch / ST-switch Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 ST-switch / Pilot light 1806.1402 7 10.2 18.6 quick-connect terminal 4.8 2.8 * Version on stock 22 quick-connect terminal 4.8 4.8-0.8 18 2 x 11.7 5.3 1806.1102* X Y 0.75...1.25 19.2 –0.1 1.25...2 19.4 –0.1 2 ...3 19.8 –0.1 SINGLE POLE ST-SWITCHES 12 (4) A 250 V~ 8 (8) A 250 V~ 5E4 5/70 A 250 V~ T 100/55 15 A (3/4 HP) 125 V AC 15 A (1 1/2 HP) 250 V AC 1801.1121* 1801.0121* 1801.1908* 1801.0136* quick-connect terminal 4.8 1801.1101 1801.6101 1801.1102* 1801.6102* 1801.5102 1801.1119* 1801.6112 1801.1139* 1801.0179 1801.1903 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 5/50 A 250 V~ T 100/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC 16.75 4.7 7.3 0.75 10.45 17.5 23.5 SINGLE POLE ST-SWITCHES with installed dust protection cap 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 5/50 A 250 V~ T 100/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC 1801.1146* 1801.6115* 1801.2106 7 13 18.6 17.9 23.9 1801.1403* quick-connect terminal 4.8 1802.1123* 1802.0130* quick-connect terminal 4.8 DOUBLE POLE ST-SWITCHES 12 (4) A 250 V~ 8 (8) A 250 V~ 5E4 5/70 A 250 V~ T 100/55 15 A (3/4 HP) 125 V AC 15 A (1 1/2 HP) 250 V AC 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 5/50 A 250 V~ T 100/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC 1802.1108* 1802.6103* 1802.2104 1802.5103* * Version on stock 1802.1101 1802.0101 1802.1102* 2.9 SERIES 1800 - SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES UP TO 12 (4) A 250 V~ AND 8 (8) A 250 V~ SINGLE POLE DT-SWITCHES 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 T 100/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC DT-switches with r- and a-approval marks for 10 A on request 1803.1102* 1803.6102* 1803.2102 1803.5102 quick-connect terminal 4.8 1804.1102* 1804.6102* 1804.2102 quick-connect terminal 4.8 DOUBLE POLE DT-SWITCHES 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 T 100/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC DT-switches with r- and a-approval marks for 10 A on request SINGLE POLE DT-SWITCHES with centre-OFF 6 (2) A 250 V~ µ T 100/55 6 A (1/8 HP) 125-250 V AC Momentary function on one side on request without momentary 1808.1102* 1808.0102* 1808.2102* without momentary 1808.1103* 1808.0111* quick-connect terminal 4.8 momentary on both sides 1808.1302* 1808.0302* 1808.2302* solder terminal DOUBLE POLE DT-SWITCHES with centre-OFF 6 (2) A 250 V~ µ T 100/55 6 A (1/8 HP) 125-250 V AC Momentary function from one side on request 2.10 without momentary 1809.1102* * Version on stock momentary on both sides 1809.1302* quick-connect terminal 4.8 SINGLE POLE WITH MOMENTARY FUNCTION 4 (2) A 250 V~ T 100/55 6 A (1/10 HP) 125 V AC 4 A (1/10 HP) 250 V AC normally closed 1801.1302* normally open 1801.1202* 1801.0202* quick-connect terminal 4.8 DT momentary 1803.1202* 1803.0202* solder terminal DOUBLE POLE WITH MOMENTARY FUNCTION 4 (2) A 250 V~ T 100/55 6 A (1/10 HP) 125 V AC 4 A (1/10 HP) 250 V AC normally open 1802.1221* quick-connect terminal 4.8 DOUBLE POLE ST-SWITCHES for direct connection to the mains 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 5/50 A 250 V~ T 100/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC quick-connect 4.8 and bush terminals 1802.3102* Higher electrical rating on request PILOT LIGHTS Pilot lights with neon lamps and resistor for 230 V~ v Pilot lights for 125 V AC on request 1807.1102* * Version on stock 1807.1108 quick-connect terminal 4.8 2.11
1801.1146 价格&库存
很抱歉,暂时无法提供与“1801.1146”相匹配的价格&库存,您可以联系我们找货
