191.071.021
191.071.021
    MARQUARDT(马夸特)
191.071.021 数据手册
FROM MARQUARDT WWW.MARQUARDT.DE APPROVAL MARKS  ENEC 05 (KEMA)  UL (USA)  ENEC 10 (VDE) C US UL (USA + Canada) VDE  CSA (Canada) US CSA (Canada + USA) C TERMINAL SYMBOLS Quick-connect terminal Cable Solder terminal Terminal strip Short solder terminal Push-in terminal PCB terminal Snap-in terminal PCB terminal angled to left Cut terminal PCB terminal angled to right Screw terminal Socket terminal ACTUATOR SYMBOLS Straight lever Lever simulated roller with adjusting screw Lever simulated roller Lever with adjusting screw and roller Lever with roller Lever with cams Differential lever Housing cams Spring lever Pushbutton Spring lever bent Rotary shaft Spring lever with molded spring cam Standard actuator Lever with adjusting screw Mushroom-shaped actuator ABBRE VIATIONS TECHNICAL DR AWINGS ad Adjustable OP AN Anode Operating position normally OP NC closed contact BL Block OP NO Operating position normally open contact FH Fixing hole, locating hole fixing pin OR On request FI Fields for function indicator RC Recommended cut-out FP Free position RL Reference level FX Fixing pin SH Snap-in hole ju Adjusted SL Symbol limit MC Marking cathode SP Solder pads MF Mounting frame ST Slide travel Operating position MP Measuring point SW Switching position OFF Off TH Terminal hole off-range Zero position tk Thick OG Operating range to Top ON On TP Total travel position SWITCHING FREQUENCY (ABBRE VIATIONS ) ^ e.g. 5E4 switching cycles = 50 000 switching cycles Switching reliability ........................................................................... 12 Bounce time..................................................................................... 12 Switching time / switching travel ....................................................... 12 Operating force-travel diagram .......................................................... 12 Contact force-travels diagram ........................................................... 12 Positions-forces-travels .................................................................... 12 Further information .......................................................... 13 Order numbers ................................................................................. 13 Customized solutions ........................................................................ 13 Stock versions / minimum order quantities ......................................... 13 Application and ambient conditions.................................................... 13 Modifications / catalog data .............................................................. 13 Application note / liability .................................................................. 13 Slide switches ................................................................ 135 Series 4021 - double and four-pole slide switches ........................... 137 Series 1205 - double-pole slide switches......................................... 141 Series 1206 - single-pole slide switches .......................................... 142 Series 0140 - double-pole slide switches......................................... 144 Series 1703 - powerful rotary switches............................................ 149 Foot switches................................................................. 151 Series 2410 - ergonomic foot switches ............................................ 153 PUSHBUTTON SWITCHES TOGGLE SWITCHES ROTARY SWITCHES Rotary switches ............................................................. 147 Power tool switches ....................................................... 157 Series 1276 - single-pole power tool switches ................................. 159 Series 1277 - double-pole power tool switches ................................ 160 Series 1281 - double-pole power tool switches ................................ 161 Series 1298 - single-pole power tool switches ................................. 162 Series 1299 - single-pole power tool switches ................................. 164 Tact and key switches .................................................... 165 Series 3006 - tact switches ............................................................ 167 Series 6425 - key switches ............................................................. 169 Series 6450 - key switches ............................................................. 175 Series 3000 - key switches ............................................................. 177 Snap-action switches ..................................................... 179 Switches and sensors tab overview................................... 15 Series 1055 - subsubminiature snap-action switches IP67 ............... 182 Series 1050 - subminiature snap-action switches ............................ 187 Series 1080 - miniature snap-action switches.................................. 193 Series 1005 - miniature snap-action switches.................................. 198 Series 1040 - rotary shaft snap-action switches............................... 205 Series 1010 - open snap-action switches ........................................ 207 Series 1018 - snap-action switches ................................................ 212 Series 1019 - single-pole snap-action switches ............................... 213 Series 1022 - snap-action switches IP 67........................................ 216 Series 1117 - snap-action switches ................................................ 218 Rocker switches............................................................... 17 Micro-signal switches ....................................................221 Series 1900 - smallest single-pole rocker switches ............................ 20 Series 1800 - single and double-pole rocker switches ........................ 23 Series 1890 - single-pole rocker switches illuminated wit LED ............ 39 Series 1881 - single-pole round rocker switches ................................ 41 Series 1855 - smallest double-pole rocker switches ........................... 43 Series 1858 - smallest double-pole rocker switches ........................... 46 Series 1941 - single-pole rocker switches IP 50................................. 49 Series 1550 - single and double-pole rocker switches ........................ 51 Series 1830 - single and double-pole rocker switches ........................ 58 Series 1930 - double-pole rocker switches IP 65 ............................... 72 Series 1656 - single-pole rocker switches ......................................... 77 Series 3201 - single-pole 3-step rocker switches ............................... 79 Series 3230 - single and double-pole rocker switches ........................ 80 Series 1257 - double-pole rocker switches ........................................ 85 Series 0344 - three-pole rocker switches .......................................... 86 Series 1065 - micro-signal switches................................................ 223 SWITCHES AND SENSORS SLIDE SWITCHES Series 0350 - three-pole toggle switches......................................... 125 Series 1810 - single and double-pole toggle switches ...................... 126 Series 1820 - single and double-pole toggle switches ...................... 129 Series 0100 - single-pole toggle switches........................................ 133 FOOT SWITCHES Special information about snap-action switches ................ 12 Toggle switches ............................................................. 123 Sensors .........................................................................227 Series 2061 - flow sensors ............................................................. 229 Series 2066 - analogue pressure sensors ........................................ 230 Series 2068 - humidity sensors....................................................... 231 INDE X POWER TOOL SWITCHES About the catalog ............................................................................... 7 Approvals .......................................................................................... 7 Approval marks .................................................................................. 7 RoHS (Restriction of the Use of Certain Hazardous Substances) ............. 7 Household Appliances Standard IEC/EN 60335 .................................... 8 Rating for alternating current voltage (AC) ............................................ 8 Rating for direct current voltage (DC) ................................................... 8 Life endurance ................................................................................... 8 Gold-plated contacts........................................................................... 8 Switching frequency ........................................................................... 8 Contact distance ................................................................................ 8 Proof tracking..................................................................................... 9 Inrush current .................................................................................... 9 Ambient temperature .......................................................................... 9 Storage conditions .............................................................................. 9 Soldering conditions ........................................................................... 9 IP type of protection .......................................................................... 10 EMC (electromagnetic compatibility) ...................................... 10 Appliance safety law ......................................................................... 10 CE mark .......................................................................................... 10 Terminal symbols ............................................................................. 10 Contact resistance ............................................................................ 10 Switching functions .......................................................................... 11 TACT AND KEY SWITCHES General technical information ............................................. 7 Series 1680 - single and double-pole pushbutton switches ................. 90 Series 1683 - single and double-pole pushbutton switches ................. 96 Series 1691 - smallest single-pole pushbutton switches ..................... 99 Series 1246 - double-pole pushbutton switches ............................... 100 Series 1247 - double-pole pushbutton switches ............................... 102 Series 5000 - round pushbutton switches ........................................ 105 Series 1846 - single-pole pushbutton switches ................................ 107 Series 1840 - single and double-pole pushbutton switches ............... 109 Series 1660 - single and double-pole pushbutton switches ............... 113 Series 1670 - single and double-pole pushbutton switches ............... 118 SNAP-ACTION SWITCHES TECHNICAL INFORMATION Pushbutton switches ........................................................ 87 MICRO-SIGNAL SWITCHES Marquardt ......................................................................... 2 Business unit switches, sensors & controls ......................... 3 Reference products ............................................................ 4 SWITCHES AND SENSORS Index of part numbers ...................................................232 SENSORS MARQUARDT ROCKER SWITCHES CONTENT 1| MARQUARDT SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES CHOOSE THE BR AND OF THE BR ANDS |2 SE T TING STANDARDS SOLID FOUNDATION Switches and systems come into play wherever man encounters technology. They form an important bridge between the user and the appliance.  An independent familiy business for more than 80 years  About 7 % of the turnover annually for R&D  The latest in development tools Functional safety, shape, operating logic and comfort as well as eayse of installation, life endurance, reliability and price create the environment in which the requirements for a switch or a system evolve. The very first switch made by Marquardt in 1925 set a new standard in its area of application. Between then and now lie hundreds of innovations and technological quantum leaps.  Extensive test departments  11 production and sales locations worldwide  Presence on the most important markets in Europe, America and Asia T WO SUPPORTING PILL ARS By the two business units Automotive and Switches, Sensors & Controls Marquardt sets the benchmark for the most different applications. BUSINESS UNIT SWITCHES, SENSORS & CONTROLS KE Y COMPE TENCIES Since the beginning the name Marquardt has stood for a brand which unites consistency with a pioneering spirit. A brand which is constantly exploring new territory in the switching world, taking new roads and opening up great potential benefits for its customers in marketable switching solutions.  Development and design of switches and systems for large series production  SMD and THT assembly, laser soldering and welding of plastics  Highly integrated automatic production and assembly systems ROTARY SWITCHES POWER TOOL SWITCHES  High-speed punching technology with integrated laser welding and cleaning TACT AND KEY SWITCHES  Injection molding, varnishing and laser processing of plastic parts, multi-component injection, spraying of metal parts FOOT SWITCHES GRE AT PRODUCTION DEPTH SNAP-ACTION SWITCHES The focus is on the individual adjustment of standard products on customer requirements as well as the new development of innovative switches, sensors and systems. Our spectrum ranges from cable assembly and the production of special subassemblies to the complete mechatronic system.  Design and production of customized switches and switching systems MICRO-SIGNAL SWITCHES No matter whether they are looking for sensors and switches for all kinds of household appliances, for cleaning and drive technology, for heating and air conditioning technology or for standard switches which are turned out in their millions on large automatic production lines, the electrical appliance industry finds a partner here who offers much to many.  High integration of different techniques such as electronics and mechanics SENSORS WIDE PRODUCT RANGE  Development and manufacture of product and system-specific electronics for switching systems SLIDE SWITCHES LONG E XPERIENCE TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES A WIDE BASE FOR INTELLIGENT SOLUTIONS 3| REFERENCE PRODUCTS 3D - imbalance sensor Pressure sensor Automatic control systems Rotary switch Turbidity sensor Power switch Door lock Subassembly with snap-action switch Lighting SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES SWITCHES, SENSORS, LOCKS, LIGHTINGS |4 REFERENCE PRODUCTS Electronic switch for AC electric power tools Electronic switch for AC electric power tools Electronic switch for AC electric power tools Electronic switch for DC electric power tools Electronic switch for DC electric power tools ON/OFF trigger switch with timedelayed contact and suppression capacitor ON/OFF switch for AC and DC electric power tools Brushring with DT switch SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES EC-electronics TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES SWITCHES, CONTROL SYSTEMS FOR ELECTRIC POWER TOOLS 5| REFERENCE PRODUCTS Electronic key Electronic ignition starter switch Electronic steering lock Keyless antennas and control devices Gear selection switch Central control unit Seat control panel Roof control panel Rotary light switch SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES DRIVER AUTHORIZ ATION SYSTEMS, ASSEMBLIES, CONTROL PANELS FOR AUTOMOBILES |6 3  The order numbers of other versions and further information are available on request.  Sample switches, approvals and installation drawings with tolerance data can be provided. The high quality, long-life switches from Marquardt are used in many different applications. We are constantly working on new developments and customized versions. Please ask. All the products in our entire delivery program have one common feature: The consistently high quality level which has made us the favorite supplier of leading manufacturers worldwide. We are certified in accordance with ISO TS 16949: 2002, the latest QM standard of the automotive industry. Quality is a premium for us. 2US ENEC VDE UL CSA cCSAus 1US cULus 1 2 C C – – – – – Europe Germany USA Canada Canada with confirmation of the national US requirements – USA with confirmation of the national Canadian requirements Approval marks specified in the series overview are product-dependent. That means that the products are assignable in the tables based on the rating specifications (black print − Europe / blue print − North America). ROHS ( RESTRICTION OF THE USE OF CERTAIN HAZARDOUS SUBSTANCES) From July 1, 2006 no more new electrical and electronic products may be offered in the EU which do not comply with the RoHS directive. The use of lead, mercury, hexavalent chromium, cadmium and the flame inhibitors containing bromide PBB and PBDE is prohibited for the protection of man and the environment. Compliance with the legal regulations is a matter of principle for Marquardt. As far as we know and based on the information available to us from our suppliers, the products presented in this catalog meet the requirements of the EU Directive 2002/95/EU (Edition 1.12.2007). PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES APPROVAL MARKS ROTARY SWITCHES All standard versions are listed with their order numbers. FOOT SWITCHES In addition to the standard program, a number of modified, customized variants and special products and modules are available on request. POWER TOOL SWITCHES Basic types are distinguished within a series to group products with identical properties, e.g. the design. TACT AND KEY SWITCHES Almost all Marquardt switches have been tested in accordance with EN 61058-1 or IEC 61058-1 and designed for the application conditions specified therein unless specified otherwise. They carry the uniform European approval mark ENEC. The approvals for the USA and Canada are granted in accordance with UL 1054, on request also already in accordance with UL 61058 3rd ed. or CSA 61058. Please see the catalog for the respective granted approvals. A list of the approved Marquardt products can be found on the Internet pages of the respective test bodies (e.g. VDE, KEMA, UL and CSA). We will provide the appropriate certificate on request. SNAP-ACTION SWITCHES This catalog provides you with an overview of the wide range of Marquardt standard switches. The portfolio includes rocker switches, pushbutton switches, toggle switches, slide switches, rotary switches, foot switches, power tool switches, keys, snap-action switches, micro-signal switches and sensors. MICRO-SIGNAL SWITCHES APPROVALS SENSORS ABOUT THE CATALOG ROCKER SWITCHES GENER AL TECHNICAL INFORMATION 7| SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES GENER AL TECHNICAL INFORMATION |8 HOUSEHOLD APPLIANCES STANDARD IEC/EN 60335 Various switches in the Marquardt product portfolio are conformant with the Household Appliance Standard IEC/EN 60335-1:2001/2002, chapter 30. These switches are identified by a „G“ in the specification or drawing and on the label of the smallest packing unit. Materials are used here which comply with the values for the glow-wire-flammability index (GWFI) and the (glow-wire-ignition-temperature (GWIT) demanded by the standard. The appropriate switches are labeled in the catalog in the product tables of the individual series. The appropriate certificate with the confirmation of conformity is available on request. R ATING FOR ALTERNATING CURRENT VOLTAGE (AC ) The electrical reference values, i.e. the maximum permissible electrical loads in continuous operation, are specified for the respective switch series. Most Marquardt switches are suitable for ohmic resistance load and motor load. In the specification of the reference power using the bracket notation, e.g. 16 (4) A 250 V AC, the value in front of the brackets indicates the switch-off current and the value in brackets the nominal motor current. In switches which are additionally approved by test bodies in the USA (UL) and Canada (CSA) the corresponding ratings according to North American standards are listed additionally in blue. The motor loads may also be shown as HP (Horse Power) values according to North American conventions. R ATING FOR DIRECT CURRENT VOLTAGE ( DC ) Since the range of DC loads is very wide and extensive and also depends very greatly on the application, no DC values are specified for the majority of the series in this catalog. Explicit tests are recommended for this. Tests which have already been carried out are available on request and the results can be used as references. As a rule of thumb it can be assumed at low currents that the specified alternating current values (AC) correspond to the direct current values when the life is reduced to about one third. In series with DC voltage specifications the specified current always refers to an ohmic load. If inductive or capacitive loads are available, the application must be checked by tests with the original load. LIFE ENDURANCE The mechanical life endurance is the number of possible switching cycles without electrical loading of the contacts whilst the electrical life endurance is determined with the permissible rated electrical power for the contacts. The lower the electrical load is, the closer the electrical life is to the mechanical life when using the switch in the appliance. GOLD-PL ATED CONTACTS For applications with a rating of < 300 mW or < 12 V we recommend switches with gold-plated contacts, also for applications with rare actuation or in a sulfurous atmosphere or other corrosive environments. SWITCHING FREQUENCY For switches which are expected to be actuated more than 2 000 times a year, the test bodies prescribe an electrical life endurance of > 50 000 switching cycles. The majority of our switches meets these requirements and is marked by the 5E4 symbol (50 000 switching cycles) as an additional specification in the rating data. Switches without specification of the switching cycles in the rating data are approved for a switching frequency of 10 000 cycles. These data refer to the load which is typical for and described in the IEC 61058-1 standard. For greatly differing, e.g. slower or faster actuations, we will be glad to advise you! CONTACT DISTANCE The majority of our appliance switches and some of our snap-action switches have a contact distance which enables full disconnection from the mains. The opening distances are even more than 3 mm in most cases. Switches which are not suitable for full disconnection are marked with the μ symbol. The switch standard IEC 61058-1 demands a contact distance of > 1.5 mm, the Household Appliances Standard EN60335 < 3 mm depending on the application for full mains disconnection. In switch variants with < 3 mm the test bodies usually acknowledge the mains plug or a disconnection device in the installation as a disconnection from the mains. Ask your test body if in doubt. The delivered products must be stored in the original Marquardt packaging in a temperature range between 5 and 45 °C and 30 to 75 % relative humidity. The storage time of 12 months may not be exceeded. Storage in different containers and different climates may impair the properties of the product. Products with solder terminals can be stored under the following conditions: For UL-approved switches, the ambient temperature is determined by the RTI (Relative Temperature Index) of the used materials. Generally, the permissible ambient temperature of polyamides is 65 °C. Switches for higher ambient temperatures are available on request. We recommend: Soldering devices electronically controlled soldering station with the typical power consumption of 50 - 80 VA Solder flux-filled solder wire, flux type 1.2.2 Solder temperature 350 °C ±10 °C (setting on the appliance) Soldering time 2 to 3 s Notes: No force may be applied to the switch terminals during soldering, otherwise the switch properties (operating position etc.) could be changed. Longer soldering times and multiple soldering can impair the mechanical properties of the solder point and adjacent areas. When using flux, make sure that no flux gets inside the switch via the terminals. In such cases, the switch may not be soldered “upside down”, i.e. with the terminals on top. In open switching systems the soldering fumes must be kept away from the switch by suitable means. ROTARY SWITCHES FOOT SWITCHES 1. Recommended handling instructions for leadfree hand soldering The basis for the solderability of the products in this catalog in the as-delivered state is DIN IEC 600682-20. POWER TOOL SWITCHES The designation of the permissible ambient temperature with e.g. T 85 means that the switch can be used for a maximum ambient temperature of 85 °C according to the test criteria of the European safety standards (EN 61058 or IEC 61058-1). The identification T85/55 indicates that the connection side of the switch is suitable for an ambient temperature of 85 °C, whilst the actuating part (e.g. rocker) is subject to the room temperature of 55 °C demanded by the standard. Using the switches outside the permissible temperature range and in a very humid or corrosive atmosphere can impair the functional capability. SOLDERING CONDITIONS TACT AND KEY SWITCHES AMBIENT TEMPERATURE We recommend you to examine the processing results in the case of different storage conditions or on exceeding a storage time of more than 6 months. SNAP-ACTION SWITCHES Values above the possible capacitive inrush currents are available for most of our appliance switches. They are labeled with the specification of the continuous current and the maximum inrush current as well as the voltage, e.g. 5/100 A 250 V AC.  Temperatures between 5 °C and 40 °C  Mean relative humidity below 50 % (relative humidity max. 85 %)  No condensation and sulfurous environments MICRO-SIGNAL SWITCHES Short capacitive peak currents occur when switching on mainly in devices with power supply units (e.g. computers, printers, fax machines, etc.). The duration of these currents is typically < 10 ms. The test conditions with a special test circuit are defined in EN 61058-1 or IEC 61058-1. SENSORS INRUSH CURRENT PUSHBUTTON SWITCHES The proof tracking (PTI/CTI value) indicates at what voltage the proof tracking test is passed. The tracking distance is the shortest distance along the surface of the insulating material between two conductive parts. The values specified in the catalogue correspond to the division according to EN 61058-1 or IEC 61058-1. TOGGLE SWITCHES STORAGE CONDITIONS SLIDE SWITCHES PROOF TRACKING ROCKER SWITCHES GENER AL TECHNICAL INFORMATION 9| TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES GENER AL TECHNICAL INFORMATION 2. Recommended handling instructions for leadfree wave soldering Soldering profiles are published in DIN IEC 61670 which must be adapted to the respective modules and the production conditions. Typical and maximum values: Pre-heating duration 80 s typical at 110 °C, max. 125 °C Wave soldering duration 2 - 7 s at 235 °C, Tmax. 245 °C Gradient pre-heating max. 2 °C/s Gradient cooling max. -4 °C/s soldering SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES Tmax | 10 CE MARK The CE mark is an identification according to EU law for certain products with regard to the product safety. It is not a seal of quality (quality mark). By attaching the CE mark, the manufacturer confirms that the product complies with valid European regulations. The CE mark does not mean that the product has been checked for compliance with regulations by an independent body. Following revisions of the EU regulations in 2007 some of our switches have no labeling obligation, some are subject to the low voltage directive and some are subject to the machine directive. The CE mark and the issuing of the declaration of conformity depend on the respective situation. A CE mark is not prescribed for the components but for the smallest packing unit. pre-heating cooling These notes are guidelines which must be adapted respectively to the concrete process. IP T YPE OF PROTECTION The IP types of protection according to DIN EN 61058-1 and IEC 60529 specified in our documents refer to the actuating side of the switch unless stated otherwise. The customer must provide the seal between the switch and customer appliance and test for leaks at this point. EMC (ELECTROMAGNETIC COMPATIBILITY) TERMINAL SYMBOLS Quick-connect terminal Solder terminal Short solder terminal PCB terminal PCB terminal angled to left PCB terminal angled to right Socket terminal Cable Terminal strip Push-in terminal Snap-in terminal Cut terminal Screw terminal CONTACT RESISTANCE Marquardt switches for use in appliances meet the requirements for interference emissions in accordance with EN 61058-1 when they are used according to our specifications. Requirements for interference suppression in the appliances can be found in the appliance or EMC specifications. APPLIANCE SAFE T Y L AW If you need to observe the valid German appliance safety law, we recommend you to use switches which have been tested and approved according to the specifications EN 61058-1 or VDE 0630. Switches without approval marks must be tested by the approval body in connection with your appliance. The contact resistance is the electrical resistance which can be measured at the switch terminals with closed contacts. The data refer to unwired contacts in the new condition with a typical measuring current of greater than 100 mA. For silver-based contact materials this value is below 100 mƺ (measuring current 1 A at 12 V DC), for gold-based contact materials below 50 mƺ. ROCKER SWITCHES GENER AL TECHNICAL INFORMATION ON/OFF switch with signal lamp (SPST-Illuminated, DPST-Illuminated) Normally open contact / pushbutton (SPNO, DPNO) Normally closed contact / pushbutton (SPNC, DPNC) Changeover switch (SPDT, DPDT) Changeover switch / pushbutton (SPDT, DPDT) momentary Changeover switch with OFF position in center (SPDT-Center OFF, DPDT-Center OFF) Lamp SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES ON/OFF switch (SPST, DPST) TOGGLE SWITCHES PUSHBUTTON SWITCHES SWITCHING FUNCTIONS 11 | FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES SPECIAL INFORMATION ABOUT SNAP-ACTION SWITCHES SWITCHING RELIABILIT Y POSITIONS-FORCES-TR AVELS Optimum switching reliability is achieved when the pretravel and overtravel are fully exploited so that these should be fully exploited in the concrete application. Another criterion is the contact force which depends in turn on the operating force. Switches with high contact forces should be chosen if possible. Free position Position of the actuator in which no external force is applied. Operating position Point on the actuator travel at which the snap mechanism is irreversibly set in operation. BOUNCE TIME Total travel position Position of the actuator at the end of the permissible travel. The bounce time is the time between the first closing of the contacts (switch-on signal) and the last time the contact resistance drops below a given threshold value. The values are typically below 5 ms at typical actuation speeds of approximately 10 mm/s. Release position Point on the actuator travel at which the snap mechanism returns to its initial position. Operating force Force necessary on the actuator to move this from the free position over the operating position. Release force Force to which the operating force must be reduced for the snap mechanism to return to the initial position. SWITCHING TIME / SWITCHING TRAVEL Switching time/travel is the time or distance which the switching system requires to get from the first opening of the previously closed contacts to the first flow of current through the contacts closed after the snap-action. The respective operating position or release position must be exceeded reliably. Please ask about applications with very slow actuating speeds or applications in which the actuation of the switch is controlled by its switching process. Difference force Difference between operating force and release force. Total travel force Force necessary to keep the actuator in the permissible total travel position. MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES release difference force force total travel force total travel position operating position pretravel difference travel release travel Overtravel Distance between operating position and total travel position. Return travel Distance between total travel position and release position. Release travel Distance between release position and free position. s overtravel return travel total travel CONTACT FORCE-TRAVEL DIAGRAM F pretravel overtravel Difference travel Distance between operating position and release position. Total travel max. free position Total of pretravel and overtravel or return and release travel. Normally closed 0 operating position Normally open F s release position difference travel release travel SENSORS Distance between free position and operating position. release position free position max. | 12 Pretravel F operating force TACT AND KEY SWITCHES POWER TOOL SWITCHES OPERATING FORCE-TRAVEL DIAGRAM total travel return travel The application conditions must be checked in advance for continuously actuated snap-action switches. STOCK VERSIONS / MINIMUM ORDER QUANTITIES Many of our standard switches are usually available immediately ex-stock in quantities of at least one packing unit (PU). These versions are marked accordingly as a stock version in the tables of the individual series. Please ask about delivery times for the unmarked versions. We reserve the right to make technical modifications and improvements to our products. Data in the catalog (e.g. dimensions, photos, diagrams) are not binding. Specifications, samples and installation drawings with tolerance data will gladly be provided on request. APPLICATION NOTE / LIABILIT Y Since all the data in this catalog refer exclusively to the products delivered by us, you must check whether our products are suitable for your intended application yourselves. We will be glad to help you with advice and information. Our liability is governed exclusively by our Terms of Delivery and Payment which we will gladly send you on request. WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES A list of all switches can be found on page 232. The stock versions are marked by a dot and the respective packing unit is also listed. SLIDE SWITCHES The series and products shown in this catalog are only an excerpt from the complete Marquardt product range. One of Marquardt’s strengths is the implementation of customer-specific requirements. This includes services such as cable assembly, extended or modified functions, other colors, labelings and designs as well as the integration into complete modules and systems. We offer you worldwide contacts for these services. PUSHBUTTON SWITCHES MODIFICATIONS / CATALOG DATA CUSTOMIZED SOLUTIONS TOGGLE SWITCHES Substances penetrating inside the switch such as greases, oils or moisture can impair the function. ROTARY SWITCHES The standard products in every series are shown in table form with their most important technical characteristics and their 8-digit order numbers. The accessories have a nine-digit order number. APPLICATION AND AMBIENT CONDITIONS FOOT SWITCHES ORDER NUMBERS ROCKER SWITCHES FURTHER INFORMATION 13 | Further information under WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES SWITCHES AND SENSORS TAB OVERVIE W SENSORS SENSORS 15 | Further information under WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTONS SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TONS SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES ROCKER SWITCHES SENSORS SENSORS 17 | ROCKER SWITCHES ROCKER SWITCHES SERIES 1900 Smallest single-pole rocker switches to 6 (2) A 250 V AC TOGGLE SWITCHES PUSHBUTTONS SWITCHES Appliance cut-out: 19.2 x 6.8 mm 23.2 x 6.8 mm 30.0 x 6.8 mm SERIES 1800 Single and double-pole rocker switches to 12 (4) A 250 V AC Appliance cut-out: SLIDE SWITCHES Single-pole rocker switches illuminated with LED to 6 A 24 V DC ROTARY SWITCHES Single-pole round rocker switches to 12 (4) A 250 V AC FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 18 Smallest double-pole rocker switches to 4 A (1) 250 V AC Smallest double-pole rocker switches to 12 (4) A 250 V AC Single-pole rocker switches IP 50 to 6 (2) A 250 V AC PAGE 49 - 50 19.2 x 12.9 mm SERIES 1550 Single and double-pole rocker switches to 16 (4) A 250 V AC Appliance cut-out: PAGE 46 - 48 19.2 x 12.9 mm SERIES 1941 Appliance cut-out: PAGE 43 - 45 19.2 x 12.9 mm SERIES 1858 Appliance cut-out: PAGE 41 - 42 Ø 20.3 mm SERIES 1855 Appliance cut-out: PAGE 39 - 40 19.2 x 12.9 mm SERIES 1881 Appliance cut-out: PAGE 23 - 38 19.2 x 12.9 mm 19.2 x 21.9 mm SERIES 1890 Appliance cut-out: PAGE 20 - 22 26.2 x 12.4 mm 27.2 x 12.2 mm 28.6 x 14.0 mm PAGE 51 - 57 Single-pole rocker switches to 10 A 250 V AC 28.0 x 13.0 mm SERIES 3201 Single-pole 3-step rocker switches to 0.5 A 12 V DC SERIES 3230 Single and double-pole rocker switches / lamps to 10 (5) A 24 V DC PAGE 79 PAGE 80 - 84 POWER TOOL SWITCHES Appliance cut-out: PAGE 77 - 78 SLIDE SWITCHES SERIES 1656 Appliance cut-out: TOGGLE SWITCHES 30.0 x 22.0 mm 38.4 x 19.8 mm SERIES 1257 Double-pole rocker switches to 8 (8) A 250 V AC SERIES 0344 Three-pole rocker switches to 16 (6) A 400 V AC ROTARY SWITCHES Appliance cut-out: FOOT SWITCHES Double-pole rocker switches IP 65 to 20 (4) A 250 V AC PAGE 72 - 76 PAGE 85 PAGE 86 TACT AND KEY SWITCHES SERIES 1930 PUSHBUTTONS SWITCHES 30.0 x 11.0 mm 30.0 x 22.0 mm SNAP-ACTION SWITCHES Appliance cut-out: MICRO-SIGNAL SWITCHES Single and double-pole rocker switches / lamps to 20 (4) A 250 V AC PAGE 58 - 71 SENSORS SERIES 1830 ROCKER SWITCHES ROCKER SWITCHES 19 | SERIES 1900 - SMALLEST SINGLE-POLE ROCKER SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (2) A 250 V PRODUCT FE ATURES ON REQUEST  Reliable leaf spring contact system with contact spacing > 3 mm  Other colors  Attractive, slim design  Cable assembly  Other printing variants  Three sizes ROTARY SWITCHES  Low space requirement due to small sizes  Variable connection technique (plug or solder) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Mechanical life endurance | 20 75E3 Operating force 2-5N Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II SERIES 1900 - SMALLEST SINGLE-POLE ROCKER SWITCHES 1901.1103 z z z 4.8 > 3 50 Ag z 1901.1106 z z z 4.8 > 3 50 Ag 1911.1102 z z z 4.8 > 3 50 Ag 1911.1104 z z z 4.8 > 3 50 Ag 1921.1101 z z z 4.8 > 3 50 Ag 1921.1102 z z z 4.8 > 3 50 Ag 4.8 > 3 50 Au PUSHBUTTON SWITCHES Contact material z Stock version Inrush current in A (capacitive) Ag Miscellaneous Contact distance in mm 50 Connection type 3 6 A 125 - 250 V AC 1/8 HP > 30 mA 12 V DC 5E4 4.8 4 (1) A 250 V AC 5E4 z 6 (2) A 250 V AC 1E4 z z single-pole Housing color 1901.1102 Actuator color / printing Connection description ROCKER SWITCHES TO 6 (2) A 250 V X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 Z 6.8 +0.1 6.8 +0.1 6.8 +0.1 SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES POWER TOOL SWITCHES Quick-connect terminal 4.8 Basic type 1901 single-pole TACT AND KEY SWITCHES 6.8 SNAP-ACTION SWITCHES 9 18.6 MICRO-SIGNAL SWITCHES 15.6 2 9.5 SENSORS 5.2 21 z 22.5 z 1901.1152 z TOGGLE SWITCHES ON/OFF switch (SPST) 21 | SERIES 1900 - SMALLEST SINGLE-POLE ROCKER SWITCHES 6.1 ROCKER SWITCHES TO 6 (2) A 250 V 25 9 22.5 4.8-0.8 Quick-connect terminal 4.8 Basic type 1911 single-pole X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 23.2 -0.1 23.4 -0.1 23.8 -0.1 Z 6.8 +0.1 6.8 +0.1 6.8 +0.1 31.5 7.6 ROTARY SWITCHES SLIDE SWITCHES 6.8 22.6 TOGGLE SWITCHES PUSHBUTTON SWITCHES 15.6 2 9.5 9 6.8 4.8-0.8 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 27.2 | 22 Quick-connect terminal 4.8 Basic type 1921 single-pole X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 30 -0.1 30.2 -0.1 30.6 -0.1 Z 6.8 +0.1 6.8 +0.1 6.8 +0.1 22.5 15.6 FOOT SWITCHES 2 9.5 SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ON REQUEST  100 million times proven switching principle  Other colors  High, flexible design variety  Other printing variants  Excellent actuating characteristic  Other lamp variants  Illuminated and non-illuminated variants  Snap-on, customized actuators SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C ... +85 °C (product-dependent) actuating side -20 °C ... +55 °C Flammability UL 94 V-2 UL 94 V-0 (product-dependent) Heat and fire resistance 850 °C (category D) Material PA / PC PA silver-plated / tinned / gold-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 POWER TOOL SWITCHES 50 A 70 A (contact pairing Ag / Ag, product-dependent) TACT AND KEY SWITCHES Inrush current (capacitive) SNAP-ACTION SWITCHES 10E4 5E4 (basic types 1808 and 1809) MICRO-SIGNAL SWITCHES Mechanical life endurance FOOT SWITCHES ROTARY SWITCHES  Cable assembly SENSORS Suitable for appliances of protection class II 23 | SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 1801.1101 1802.1425 1801.6130 1801.6123 1801.6122 1801.5524 1801.5122 1801.1908 1801.1520 1801.1148 Actuator color / printing z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z 6 (4) A 250 V AC 5E4 z z z z 10 (4) A 250 V AC 1E4 z 12 (4) A 250 V AC 1E4 z z Housing color 8 (8) A 250 V AC 5E4 SLIDE SWITCHES 1801.1121 1800.1108 230 1800.1104 230 1800.1102 230 1800.0108 230 1800.0102 230 Voltage lamp in V ON/OFF switch (SPST) single-pole z TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC 6 (2) A 250 V AC 1E4 4 (3) A 250 V AC 6E3 30 mA 12 V 5E4 15 A 125 V AC 3/4 HP z z 15 A 250 V AC 1 1/2 HP z z 30 mA 12 V DC 5E4 z z ROTARY SWITCHES 4 (2) A 250 V AC 1E4 z z z z z 6 A 250 V AC 1/2 HP z 10 A 125 V AC 1/3 HP z 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP sealing plate z 4.8 50 3 > 70 3 > z two-pole housing form sealing plate Stock version snap-on rocker Miscellaneous z EN 60335 cap. 30 conform “G” Ag 70 3 > Ag 70 > Ag 3 > z Ag 3 70 4.8 6.5 long 70 > Ag 3 > Ag 3 50 4.8 70 3 > Ag 4.8 70 3 > Ag 4.8 70 3 Ag z > 4.8 Ag z > 3 Ag z > 3 > Ag z 3 3 > Ag z > > Ag Contact material Ag Contact distance in mm 3 Inrush current in A (capacitive) 3 70 4.8 Connection description 4.8 4.8 Connection type | 24 z z z z SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 6 A 125 V AC 1/4 HP Ag FOOT SWITCHES 10 A 250 V AC 1/2 HP SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Actuator color / printing TOGGLE SWITCHES Housing color z z z z z z z z z z z z z z 12 (4) A 250 V AC 1E4 10 (4) A 250 V AC 1E4 ROCKER SWITCHES 1801.6158 1801.6115 1801.6109 1801.6102 1801.6101 1801.5429 1801.2702 1801.2402 1801.2106 1801.1912 1801.1601 1801.1403 1801.1146 1801.1119 PUSHBUTTON SWITCHES Voltage lamp in V 1801.1102 single-pole ON/OFF switch (SPST) TO 12 (4) A 250 V AC SLIDE SWITCHES z z z z z z z z z z z z z z z z z z z z z z z z z 6 (4) A 250 V AC 5E4 z 8 (8) A 250 V AC 5E4 6 (2) A 250 V AC 1E4 4 (3) A 250 V AC 6E3 z 30 mA 12 V 5E4 30 mA 12 V DC 5E4 15 A 250 V AC 1 1/2 HP 15 A 125 V AC 3/4 HP ROTARY SWITCHES 4 (2) A 250 V AC 1E4 FOOT SWITCHES 10 A 250 V AC 1/2 HP z z z z z z z z z z z z POWER TOOL SWITCHES 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP Stock version TACT AND KEY SWITCHES z > Au MICRO-SIGNAL SWITCHES SENSORS Miscellaneous z EN 60335 cap. 30 conform “G” 3 50 3 Ag z > 50 3 Ag z > 50 3 Ag z > 50 3 > Ag z 50 > Ag 3 50 > Ag installation depth 28.1 3 50 3 > Ag installation depth 13.2 Ag > 3 50 4.8 50 3 > z Ag 4.8 50 3 Ag connections 30° angled > 4.8 50 3 Ag with dust cap black z > 4.8 50 3 Ag z > 4.8 50 3 Ag > 50 3 z Contact material > Contact distance in mm Ag Inrush current in A (capacitive) z Connection description 4.8 Connection type SNAP-ACTION SWITCHES 6 A 125 V AC 1/4 HP z z 6 A 250 V AC 1/2 HP z z 10 A 125 V AC 1/3 HP 25 | SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Actuator color / printing Housing color 1803.6152 1803.6121 1803.5102 1803.2503 1803.2402 1803.2102 1803.1121 Switch (SPDT) 1801.2202 1801.1202 1801.6222 1801.1303 1801.1302 Normally open contact (SPNO) Voltage lamp in V 1801.6325 single-pole Normally closed contact (SPNC) z z z z z z 10 (4) A 250 V AC 1E4 z 12 (4) A 250 V AC 1E4 z TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC z z z z z z 6 A 250 V AC 1/2 HP z z z z z z z z 10 A 125 V AC 1/3 HP z z 15 A 125 V AC 3/4 HP 4 A 250 V AC 1/10 HP z z 6 A 125 V AC 1/10 HP z z 6 A 125 - 250 V AC 1/8 HP 4.8 4.8 Connection description 4.8 4.8 Connection type 3 Au z > 3 Ag z > 3 > Ag z 3 Ag installation depth 16.2 > 3 Ag installation depth 13.2 z > 3 Ag z > 3 Ag z > 3 Ag z > 3 Ag z > 3 > Ag z 3 > Ag 3 > Ag Contact material > Contact distance in mm 3 Inrush current in A (capacitive) Ag POWER TOOL SWITCHES TACT AND KEY SWITCHES z 15 A 250 V AC 1 1/2 HP 6 A 125 V AC 1/4 HP SNAP-ACTION SWITCHES z z 30 mA 12 V DC 5E4 10 A 250 V AC 1/2 HP EN 60335 cap. 30 conform “G” Miscellaneous Stock version | 26 z SENSORS MICRO-SIGNAL SWITCHES z z z z z z z 30 mA 12 V 5E4 z z ROTARY SWITCHES z 4 (3) A 250 V AC 6E3 4 (2) A 250 V AC 1E4 FOOT SWITCHES z 6 (2) A 250 V AC 1E4 z z SLIDE SWITCHES 6 (4) A 250 V AC 5E4 z 8 (8) A 250 V AC 5E4 Contact material EN 60335 cap. 30 conform “G” Miscellaneous Stock version Ag Ag PCB tinned momentary function both sides installation depth 29.6 z momentary function both sides z 4 A 250 V AC 1/10 HP Connection type 6 A 125 V AC 1/4 HP FOOT SWITCHES z z z z z z Inrush current in A (capacitive) ROTARY SWITCHES SLIDE SWITCHES z z z z z z z z z z z z z z z z z z z POWER TOOL SWITCHES 6 A 125 V AC 1/10 HP TACT AND KEY SWITCHES 4.8 6 A 250 V AC 1/2 HP SNAP-ACTION SWITCHES z 8 (8) A 250 V AC 5E4 installation depth 20.5 ignition voltage < 100 V installation depth 19.5 z Contact material Ag Contact distance in mm z 12 (4) A 250 V AC 1E4 z Ag installation depth 17.5 Stock version z Inrush current in A (capacitive) 50 6 A 250 V AC 1/2 HP 3 6 (4) A 250 V AC 5E4 > 10 (4) A 250 V AC 1E4 z Ag installation depth 17.5 Voltage lamp in V Ag Miscellaneous z double-pole ROCKER SWITCHES 1802.1101 1802.6123 1802.3311 1802.2504 1802.2112 1802.1136 1802.1123 1802.1121 1802.1120 1805.7118 1805.7112 1805.7110 1805.7109 1805.7104 1805.6108 1805.6102 ON/OFF switch (DPST) SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 12 (4) A 250 V AC 29 | SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Housing color 1804.6121 1804.2402 1804.2102 1804.1125 1804.1121 Switch (DPDT) 1802.1221 1802.1222 1802.6152 1802.6103 1802.5103 1802.3102 1802.2104 1802.1108 1802.1102 Actuator color / printing Normally open contact (DPNO) Voltage lamp in V ON/OFF switch (DPST) double-pole z z z z z z z z z z 10 (4) A 250 V AC 1E4 z 12 (4) A 250 V AC 1E4 z TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC 30 mA 12 V DC 5E4 z z 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 4.8 4.8 installation depth 13.2 EN 60335 cap. 30 conform “G” SENSORS Miscellaneous z 3 > Ag 3 > Ag z 3 > Ag z 3 > Ag 3 > Ag 3 > Ag > Ag 3 > Au 3 50 > Ag z 3 50 3 Ag z > 50 3 > Ag z > Ag z 3 50 4.8 M3 4.8 50 3 > Ag 3 Contact material z Contact distance in mm Ag Inrush current in A (capacitive) 50 Connection description 4.8 Connection type Stock version | 30 z z z z z z z 1 mm longer 4.8 z z z z z z z z z z z z z z z z 6 A 250 V AC 1/2 HP z z 10 A 125 V AC 1/3 HP 4.8 15 A 125 V AC 3/4 HP > FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES z 15 A 250 V AC 1 1/2 HP 6 A 125 V AC 1/4 HP SNAP-ACTION SWITCHES z z 30 mA 12 V 5E4 10 A 250 V AC 1/2 HP MICRO-SIGNAL SWITCHES z 4 (3) A 250 V AC 6E3 4 (2) A 250 V AC 1E4 ROTARY SWITCHES z z z z z z z 6 (2) A 250 V AC 1E4 z SLIDE SWITCHES 6 (4) A 250 V AC 5E4 z 8 (8) A 250 V AC 5E4 SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 30 mA 12 V DC 5E4 15 A 250 V AC 1 1/2 HP ROCKER SWITCHES FOOT SWITCHES 10 A 125 V AC 1/3 HP z z 15 A 125 V AC 3/4 HP 10 A 250 V AC 1/2 HP SLIDE SWITCHES z z z ROTARY SWITCHES z z z TOGGLE SWITCHES PUSHBUTTON SWITCHES 1804.2202 1804.1225 1804.1204 1 mm longer 4.8 Changeover switch (DPDT momentary) 1809.2102 1809.2101 1809.1302 1809.1202 1809.1102 z z z 4.8 30 mA 12 V 5E4 z 4 (2) A 250 V AC 1E4 z 4 (3) A 250 V AC 6E3 z 6 (2) A 250 V AC 1E4 z 6 (4) A 250 V AC 5E4 z 8 (8) A 250 V AC 5E4 z 10 (4) A 250 V AC 1E4 z 12 (4) A 250 V AC 1E4 z Housing color z Actuator color / printing z Voltage lamp in V Switch with OFF position in the center (DPDT - Center OFF) 1804.6124 double-pole Switch (DPDT) TO 12 (4) A 250 V AC 6 A 250 V AC 1/2 HP TACT AND KEY SWITCHES 4.8 Connection description 4.8 4.8 Connection type 3 > Ag 3 > Ag 3 > z SENSORS z Miscellaneous PCB tinned EN 60335 cap. 30 conform “G” Stock version Ag Contact distance in mm 3 Inrush current in A (capacitive) EN 60335 cap. 30 conform “G” Miscellaneous z z Stock version | 32 4.8 4.8 4.8 4.8 Connection description 4.8 Connection type SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 6 A 125 V AC 1/4 HP z z 6 A 250 V AC 1/2 HP z z 10 A 125 V AC 1/3 HP Ag FOOT SWITCHES 10 A 250 V AC 1/2 HP SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Actuator color / printing ROCKER SWITCHES TOGGLE SWITCHES Housing color PUSHBUTTON SWITCHES 1807.1111 18 1807.1115 28 1807.6103 230 1807.1126 230 4.8 1807.1116 230 4.8 1807.1108 230 4.8 z 1806.1508 1807.1102 230 4.8 z Voltage lamp in V 230 230 Lamp Lamp TO 12 (4) A 250 V AC 12 (4) A 250 V AC 1E4 10 (4) A 250 V AC 1E4 8 (8) A 250 V AC 5E4 SLIDE SWITCHES 6 (4) A 250 V AC 5E4 6 (2) A 250 V AC 1E4 4 (3) A 250 V AC 6E3 4 (2) A 250 V AC 1E4 ROTARY SWITCHES 30 mA 12 V 5E4 30 mA 12 V DC 5E4 15 A 250 V AC 1 1/2 HP 15 A 125 V AC 3/4 HP FOOT SWITCHES 10 A 250 V AC 1/2 HP 10 A 125 V AC 1/3 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 4.8 4.8 40 mA 40 mA Inrush current in A (capacitive) Contact distance in mm Contact material EN 60335 cap. 30 conform “G” SENSORS Miscellaneous MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES 4.8 size basic type 1805 Connection description 4.8 Connection type TACT AND KEY SWITCHES POWER TOOL SWITCHES 6 A 125 - 250 V AC 1/8 HP Stock version 33 | SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 15 5.3 21 Quick-connect terminal 4.8 basic types 1801 and 1803 13.2 14.7 11.7 9.8 16 2 17.8 FOOT SWITCHES 2 13.3 21 5.3 6 15 2.6x1.6 7 POWER TOOL SWITCHES 7 13 Solder terminal basic type 1808 Solder terminal basic types 1801 and 1803 13.2 3.5 6 15 0.8 7.5 13 18.6 2 TACT AND KEY SWITCHES Solder terminal basic type 1800 15 7.5 18.5 SNAP-ACTION SWITCHES 13 18.5 21 MICRO-SIGNAL SWITCHES 21.6 7 13 18.6 18.6 SENSORS 2 11.7 18 7 21 | 34 15 9.8 2 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 Quick-connect terminal 4.8 basic type 1808 5.3 Quick-connect terminal 4.8 basic type 1800 21 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 13 18.5 X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 20.5 19.5 2 12.5 21.6 Basic types 1800, 1801, 1803 and 1808 single-pole illuminated / non-illuminated 15 7 13 18.6 TOGGLE SWITCHES PUSHBUTTON SWITCHES 7 ROTARY SWITCHES SLIDE SWITCHES 21 15 6 5.3 21 2 ROCKER SWITCHES TO 12 (4) A 250 V AC PCB terminal basic type 1808 0.8 13 SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC 7 11.7 10.2 18.6 22 22 Solder terminal basic types 1802 and 1804 24 24 3.5 19.7 5 2 16 11.7 21 5.3 0.8 7.5 10.2 10.2 18.6 3.5 18.6 22 22 24 18 21 PCB terminal basic types 1802 and 1804 10.3 5.3 PCB terminal angled 8° 11.4 6.2 4.8-0.8 18.6 M3 18.6 22 Quick-connect terminal 4.8, socket terminal M3 1802.3102 POWER TOOL SWITCHES 7 TACT AND KEY SWITCHES 21 SNAP-ACTION SWITCHES 5.3 Solder terminal basic type 1805 11.7 18.6 FOOT SWITCHES 10.2 SLIDE SWITCHES 2 7 7 16 13.2 5.3 19.7 ROTARY SWITCHES 5.3 24 17.5 Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 TOGGLE SWITCHES Quick-connect terminal 4.8 basic types 1802 and 1804 21 2 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 Quick-connect terminal 4.8 basic type 1805 2 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 22 2 X = Wall thickness 18.6 22 MICRO-SIGNAL SWITCHES 18.6 Basic types 1802, 1804 and 1805 double-pole illuminated / non-illuminated 10.2 10.2 SENSORS 7 PUSHBUTTON SWITCHES 11.7 18 19.7 2 19.5 13.2 2 5.3 5.3 24 21 35 | SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 13.2 13.2 Basic type 1809 double-pole non-illuminated 3.5 0.8 10.2 22 18.6 22 Quick-connect terminal 4.8 PCB terminal X = Wall thickness 7 7 10.2 10.2 18.6 22 Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 7 10.2 18.6 Solder terminal 1806.6108 22 11.7 24 2 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 21 5.3 X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 18.6 22 Quick-connect terminal 4.8 1806.1602 Basic type 1806 Combination 24 11.7 2 13.2 21 Quick-connect terminal 4.8 1806.2054 and 1806.1102 18 24 6 21 5.3 Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 2 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 20.5 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 ROTARY SWITCHES SLIDE SWITCHES 20.5 2 18.6 24 7.5 10.2 TOGGLE SWITCHES PUSHBUTTON SWITCHES 0.8 7 FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 36 6 21 24 6 21 2 ROCKER SWITCHES TO 12 (4) A 250 V AC SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC 14 PUSHBUTTON SWITCHES 18 2 11.7 15 21 13 18.6 Quick-connect terminal 4.8 TOGGLE SWITCHES Basic type 1807 Lamp X = Wall thickness Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 SLIDE SWITCHES Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 21 14 FOOT SWITCHES 19.5 13.2 24 17.5 POWER TOOL SWITCHES 22 18.6 Quick-connect terminal 4.8 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 TACT AND KEY SWITCHES X = Wall thickness Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 25 Transparent PVC-protection cap for single-pole switches of basic types 1800, 1801, 1803 and 1808. Serves as dust and water protection of the actuation side. 19 SNAP-ACTION SWITCHES Basic type 1807 Lamp MICRO-SIGNAL SWITCHES 2 ROTARY SWITCHES X 0.75 ... 1.25 1.25 ... 2 2 ... 3 0.8 Protection cap 203.089.011 SENSORS 8 37 | SERIES 1800 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 12 (4) A 250 V AC 28 0.8 8 Protection cap 203.090.011 TOGGLE SWITCHES PUSHBUTTON SWITCHES 25 ROCKER SWITCHES Transparent PVC-protection cap for double-pole switches of basic types 1802, 1804, 1805 and 1809. Serves as dust and water protection of the actuation side. 15 18.6 13 11.2 21 Dummy piece 203.007.013 - black 203.007.023 - blue gray Dummy piece for size of basic type 1806 of PA with window and housing in black Dummy piece 203.086.013 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES Dummy piece for size of basic type 1807 of PA | 38 Further information under WWW.MARQUARDT.DE SERIES 1890 - SINGLE-POLE ROCKER SWITCHES ILLUMINATED WITH LED ON REQUEST  Illuminated with LED  Other colors  High mechanical life endurance  Printing  Other connection types ROTARY SWITCHES  Variant for mains application SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 A 24 V DC Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 (actuator: V-2, housing: V-0) Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Plug force of the terminals < 80 N Suitable for appliances of protection class II POWER TOOL SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) TACT AND KEY SWITCHES < 100 mOhm (1 A 12 V DC) SNAP-ACTION SWITCHES 3N Contact resistance (new condition) MICRO-SIGNAL SWITCHES Operating force FOOT SWITCHES 75E3 SENSORS Mechanical life endurance 39 | SERIES 1890 - SINGLE-POLE ROCKER SWITCHES ILLUMINATED WITH LED Contact material > 3 Ag Stock version Contact distance in mm 4.8 Miscellaneous Connection description Connection type 6 A 24 V DC Housing color Actuator color / printing PUSHBUTTON SWITCHES Voltage lamp in V ROCKER SWITCHES TO 6 A 24 V DC 1890.1104 z 5.3 24 21 15 0.8 Quick-connect terminal 4.8 Basic type 1890 X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 TACT AND KEY SWITCHES POWER TOOL SWITCHES 13 18.6 FOOT SWITCHES ROTARY SWITCHES 21.5 14.5 2 SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (SPST) SENSORS MICRO-SIGNAL SWITCHES | 40 25 SNAP-ACTION SWITCHES Transparent PVC-protection cap. Serves as dust and water protection of the actuation side. 19 0.8 8 Protection cap 203.089.011 SERIES 1881 - SINGLE-POLE ROUND ROCKER SWITCHES  Changeover switch  Painted variants Mechanical life endurance 10E4 Operating force 3N Inrush current (capacitive) 70 A Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 and IP 51 (product-dependent) Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-0 (product-dependent) UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N / 1US C Suitable for appliances of protection class II SLIDE SWITCHES  Gold-plated contacts for low voltages  Appliance cut-out with 20 mm ROTARY SWITCHES  Cable assembly  Low depth with 18.7 mm  Other connection variants (e.g. PCB) FOOT SWITCHES  Variants with IP 51 POWER TOOL SWITCHES  Other printing variants TACT AND KEY SWITCHES  Other colors  High mechanical rating with at least 100 000 switching cycles SNAP-ACTION SWITCHES  Attractive round rocker switch MICRO-SIGNAL SWITCHES ON REQUEST SENSORS PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC 41 | SERIES 1881 - SINGLE-POLE ROUND ROCKER SWITCHES IP 40 z 1881.1104 z z z z 4.8 > 3 Ag IP 40 z 1881.1105 z z z z 4.8 > 3 Ag IP 40 z 1881.1106 z z z z 4.8 > 3 Ag IP 40 z 1881.1108 z z z z 4.8 > 3 Ag IP 51 z z z z z 4.8 > 3 Ag IP 51 PUSHBUTTON SWITCHES Stock version Actuator Ag Miscellaneous Contact material EN 60335 cap. 30 conform “G” Contact distance in mm 3 Connection type > 15 A 125 V AC 3/4 HP 4.8 8 (8) A 250 V AC 5E4 z z 12 (4) A 250 V AC 1E4 z z single-pole Housing color 1881.1103 Actuator color / printing Connection description 15 A 250 V AC 1 1/2 HP ROCKER SWITCHES TO 12 (4) A 250 V AC SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (SPST) with swtiching system cover 1881.1209 7.8 18.7 11.6 FOOT SWITCHES 2 15.4 3.4 ROTARY SWITCHES Normally open contact (SPNO) 7 4.8 18.6 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 11.8 | 42 DIN 46 244-A4.8-0.8 ø19.8 Quick-connect terminal 4.8 Basic type 1881 X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Ø 20.3 20.8 21.1 opening connection 1b closed with swtiching system cover z SERIES 1855 - SMALLEST DOUBLE-POLE ROCKER SWITCHES ON REQUEST  Illuminated rocker switch  Other colors  Different lamp variants  Other printing variants  Powerful with 50 000 mechanical switching cycles  Other connection types  Caulked terminals for reliable plugging of the receptacles  Other lamp variants SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 4 (1) A 250 V AC ROTARY SWITCHES  Cable assembly Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II POWER TOOL SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) TACT AND KEY SWITCHES < 100 mOhm (1 A 12 V DC) SNAP-ACTION SWITCHES 50 A Contact resistance (new condition) MICRO-SIGNAL SWITCHES Inrush current (capacitive) FOOT SWITCHES 5E4 SENSORS Mechanical life endurance 43 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (DPST) | 44 PUSHBUTTON SWITCHES ROCKER SWITCHES 1855.0102 230 z z > 3 Ag z 1855.0108 230 z z > 3 Ag z 1855.1102 230 z z 4.8 > 3 Ag z 1855.1104 230 z z 4.8 > 3 Ag z 1855.1108 230 z z 4.8 > 3 Ag z 1855.1115 230 z z 4.8 > 3 Ag z 1855.1118 230 z z 4.8 > 3 Ag z 1855.1121 110 z 4.8 > 3 Ag 1855.1122 110 z 4.8 > 3 Ag 1855.1124 110 z 4.8 > 3 Ag Further information under WWW.MARQUARDT.DE Stock version EN 60335 cap. 30 conform “G” Connection description Connection type 4 A 125 V AC 1/10 HP 6 A 125 V AC 1/10 HP 4 (1) A 250 V AC 1E4 Housing color Actuator color / printing Voltage lamp in V Contact material ROTARY SWITCHES double-pole Contact distance in mm FOOT SWITCHES SERIES 1855 - SMALLEST DOUBLE-POLE ROCKER SWITCHES TO 4 (1) A 250 V AC z z SERIES 1855 - SMALLEST DOUBLE-POLE ROCKER SWITCHES 15 15 10.3 4.8 0.8 18.6 12.9 14 2.8 18.6 0.8 12.9 Solder terminal TOGGLE SWITCHES Quick-connect terminal 4.8 X = Wall thickness Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 SLIDE SWITCHES Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 25 Transparent PVC-protection cap. Serves as dust and water protection for the actuating side. 19 0.8 ROTARY SWITCHES X 0.75 ... 1.25 1.25 ... 2 2 ... 3 FOOT SWITCHES Basic type 1855 21.5 5.3 14 21.5 5.3 2 2 21 PUSHBUTTON SWITCHES 10.3 21 ROCKER SWITCHES TO 4 (1) A 250 V AC TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS Protection cap 203.089.011 POWER TOOL SWITCHES 8 45 | SERIES 1858 - SMALLEST DOUBLE-POLE ROCKER SWITCHES SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC | 46 PRODUCT FE ATURES ON REQUEST  Non-illuminated rocker switch  Other colors  Powerful with inrush currents (capacitive) up to 100 A  Other printing variants  Immediately self-extinguishing due to UL 94 V-0 material  Cable assembly  Single-pole assembled  Conformant acc. to EN 60065 par. 14.6 Mechanical life endurance 10E4 Operating force < Inrush current (capacitive) 100 A Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) 5N Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-0 UL 94 V-2 (in the versions in white) Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II SERIES 1858 - SMALLEST DOUBLE-POLE ROCKER SWITCHES EN 60335 cap. 30 conform “G” 3 Ag z z 1858.0104 z z z z > 3 Ag z z 1858.1102 z z z z 4.8 > 3 Ag z z 1858.1103 z z z z 4.8 > 3 Ag z z 1858.1104 z z z z 4.8 > 3 Ag z 1858.1105 z z z z 4.8 > 3 Ag 1858.2202 z z z z > 3 Ag z 1858.2204 z z z z > 3 Ag z 1858.4202 z z z z > 3 Ag z z 1858.4205 z z z z > 3 Ag z z 1858.5104 z z z z > 3 Ag z single-pole occupied 1858.7204 z z z z > 3 Ag z single-pole occupied 1858.9202 z z z z > 3 Ag z single-pole occupied PUSHBUTTON SWITCHES Contact material > Stock version Contact distance in mm z Miscellaneous 12 A 125 V AC 1/3 HP z Connection description 12 A 250 V AC 1/2 HP z Connection type 6 (4) A 250 V AC 5E4 z Housing color 1858.0103 double-pole Actuator color / printing 10 (4) A 250 V AC 1E4 ROCKER SWITCHES TO 12 (4) A 250 V AC SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (DPST) WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES z ROTARY SWITCHES connection spacing 10 47 | SERIES 1858 - SMALLEST DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC 15 21 10.2 8.7 10.2 8.7 18.6 12.9 18.6 12.9 15 Basic type 1858 double-pole TOGGLE SWITCHES 22 Quick-connect terminal 4.8 21 15 21 6 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 8 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 10.2 8.7 18.6 12.9 PCB terminal ROTARY SWITCHES 18 13 6 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 20 13 SLIDE SWITCHES 15 2 X = Wall thickness Solder terminal 2 PUSHBUTTON SWITCHES 22 13 13 6 6 2 2 21 10.2 3.5 18.6 12.9 PCB terminal angled to terminal side 1 21 POWER TOOL SWITCHES 18 8 FOOT SWITCHES 13 6 2 15 10.2 3.5 18.6 12.9 PCB terminal angled to terminal side 2 25 TACT AND KEY SWITCHES Transparent PVC-protection cap. Serves as dust and water protection of the actuation side. 19 0.8 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES 8 | 48 Protection cap 203.089.011 SERIES 1941 - SINGLE-POLE ROCKER SWITCHES IP 50 ON REQUEST  Single-pole rocker switch  Other colors  High dust protection with IP 50  Other printing variants  100 million times proven switching principle  Other connection variants  Appliance cut-out same as basic type 1801  PVC-protection cap SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (2) A 250 V AC 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 50 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA / PA glass fiber-reinforced actuator housing Plug force of the terminals < 80 N Suitable for appliances of protection class II FOOT SWITCHES Voltage strength at 250 V POWER TOOL SWITCHES < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) TACT AND KEY SWITCHES Contact resistance (new condition) SNAP-ACTION SWITCHES 1E5 MICRO-SIGNAL SWITCHES Mechanical life endurance SENSORS  With approval mark ROTARY SWITCHES  Higher rating (e.g. 8 A) and inrush current (70 A) 49 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES | 50 2 SLIDE SWITCHES 1941.1103 X 0.75 ... 1.25 1.25 ... 2 1941.1203 Basic type 1941 single-pole X = Wall thickness Y 19.2 -0.1 19.4 -0.1 Z 12.9 +0.1 12.9 +0.1 ROCKER SWITCHES Connection type 6 (2) A 250 V AC 5E4 Actuator color / printing PUSHBUTTON SWITCHES 4.8 > 3 Ag 50 4.8 > 3 Ag 21 7 18.6 15 12.9 Quick-connect terminal 4.8 Stock version Miscellaneous Inrush current in A (capacitive) z Contact material Normally open contact (SPNO) Contact distance in mm ON/OFF switch (SPST) Connection description z 5.2 TOGGLE SWITCHES single-pole 11.8 18.1 ROTARY SWITCHES SERIES 1941 - SINGLE-POLE ROCKER SWITCHES IP 50 TO 6 (2) A 250 V AC SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ON REQUEST  Inrush currents (capacitive) up to 100 A  Other colors  Two housing variants (with flange or lower lying)  Other rocker labelings  With mechanical forced opening  Other lamp variants  Illuminated window with lens effect  Conformity IEC 60065 chap. 14.6 SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 (4) A 250 V AC  Cable assembly < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 and UL 94 V-0 (product-dependent) Heat and fire resistance 850 °C (category D) Material PA PA actuator housing Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II POWER TOOL SWITCHES Contact resistance (new condition) 3 mm TACT AND KEY SWITCHES > SNAP-ACTION SWITCHES 100 A Contact distance MICRO-SIGNAL SWITCHES Inrush current (capacitive) FOOT SWITCHES 5E4 SENSORS Mechanical life endurance ROTARY SWITCHES  Special rockers 51 | SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Ag low lying flange Miscellaneous 12 V 10 A DC low lying flange Stock version EN 60335 cap. 30 conform “G” Contact material Ag Connection type 6.3 16 A 125 V AC 1 HP 12 16 A 250 V AC 2 HP 12 V 10 A DC 20 A 125 V AC 1 HP Ag 20 A 250 V AC 2 HP 6.3 20 mA 250 V AC 5E4 12 16 (4) A 250 V AC 1E4 Connection description 10 (4) A 250 V AC 5E4 16 (4) A 250 V AC 5E4 Ag Housing color 6.3 Voltage lamp in V PUSHBUTTON SWITCHES single-pole Actuator color / printing ROCKER SWITCHES TO 16 (4) A 250 V AC FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (SPST) 1550.3102 230 1550.3105 1550.3609 POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS z 1551.2602 z z z z 1551.3102 z z z z 6.3 Ag 1551.3103 z z z z 6.3 Ag 1551.3105 z z z z 6.3 Ag 1551.3106 z z z z 6.3 Ag 1551.4803 z z z z z 1551.2654 z z z Ag 2 PCB holders low lying flange Au low lying flange special, robust switching system Normally closed contact (SPNC) z z 6.3 Ag z z z z 6.3 Ag 1551.1203 z z z z 4.8 Ag 1551.3202 z z z z 6.3 Ag 1551.3702 z z z z 6.3 Ag 1581.1303 | 52 z z 1551.1303 z Normally open contact (SPNO) z z low lying flange SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES PUSHBUTTON SWITCHES Stock version Miscellaneous EN 60335 cap. 30 conform “G” Contact material Connection description Connection type 16 A 125 V AC 1 HP 16 A 250 V AC 2 HP 20 A 125 V AC 1 HP 20 A 250 V AC 2 HP 20 mA 250 V AC 5E4 10 (4) A 250 V AC 5E4 16 (4) A 250 V AC 1E4 16 (4) A 250 V AC 5E4 Housing color Actuator color / printing double-pole Voltage lamp in V TO 16 (4) A 250 V AC z z z 1555.3102 230 z z z z z 6.3 Ag 1555.3104 230 z z z 6.3 Ag z 1555.3108 230 z z z 6.3 Ag z 1555.3604 230 z z z 6.3 Ag low lying flange 1555.4608 230 z z z Ag low lying flange 1555.8104 230 z z z 6.3 Ag flange dimension 31.5 x 17 mm 1555.3125 115 z z z z z 6.3 Ag 1555.4628 115 1555.3120 110 1555.3109 110 1555.3111 12 Ag z 6.3 Ag 6.3 Ag 12 V 10 A DC 1552.0103 z z z z Ag 1552.0605 z z z z Ag low lying flange 1552.2601 z z z z Ag low lying flange 1552.2602 z z z z Ag low lying flange 1552.3102 z z z z 6.3 Ag 1552.3104 z z z z 6.3 Ag 1552.3111 z z z z 6.3 Ag 1552.3112 z z z z 6.3 Ag z 1552.3117 z z z z z z 6.3 Ag z 1552.3120 z z z z 6.3 Ag 1552.3602 z z z z 6.3 1552.4602 z z 1552.4604 POWER TOOL SWITCHES Ag low lying flange z z conformant with EN 60065 par. 14.6 z Ag low lying flange z z z Ag low lying flange z z z z z Ag low lying flange 1552.4606 z z z z Ag low lying flange 1552.4702 z z z z Ag 2 PCB holders low lying flange 1552.4802 z z z z Ag low lying flange TACT AND KEY SWITCHES 6.3 z SNAP-ACTION SWITCHES z z FOOT SWITCHES Ag z MICRO-SIGNAL SWITCHES z z z SENSORS z low lying flange SLIDE SWITCHES 230 ROTARY SWITCHES 1555.0604 TOGGLE SWITCHES ON/OFF switch (SPST) 53 | SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES TO 16 (4) A 250 V AC 15 6.5 30 10 17.8 28.3 23.4 X = Wall thickness X 0.8 ... 5.0 Y 27.2 + 0.1 Z 12.2 +0.2 31.5 17 10 17.8 28.3 FOOT SWITCHES 12 6 23.4 12 29.8 2 28.4 6.5 PUSHBUTTON SWITCHES Basic types 1550 and 1555 single and double-pole TOGGLE SWITCHES 6 12 Quick-connect terminal 6.3 ROTARY SWITCHES SLIDE SWITCHES 12 29.8 2 27 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 14 | 54 Quick-connect terminal 6.3 1555.8104 double-pole X = Wall thickness X 0.8 ... 5.0 Y 28.6 + 0.1 Z 14 +0.2 SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 12 21 Solder terminal 6 12 TOGGLE SWITCHES Quick-connect terminal 6.3 12.8 4.5 5 23.4 SLIDE SWITCHES Z 12.4 +0.1 12.4 +0.1 12.4 +0.1 15 6.5 30 10 FOOT SWITCHES 17.8 28.3 29.8 2 27 ROTARY SWITCHES Y 26.2 -0.1 26.4 -0.1 26.8 -0.1 2 23.2 12.8 12 6 X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 10 23.7 PUSHBUTTON SWITCHES Basic types 1550 and 1555 lower lying flange single and double-pole 24.8 4.5 5 2 12 23.4 13 29.5 10 24.8 13 29.5 23.7 ROCKER SWITCHES TO 16 (4) A 250 V AC 12 Z 12.2 +0.2 POWER TOOL SWITCHES TACT AND KEY SWITCHES Y 27.3 + 0.1 SNAP-ACTION SWITCHES X = Wall thickness MICRO-SIGNAL SWITCHES Quick-connect terminal 4.8 Basic type 1551 single-pole X 0.8 ... 5.0 12 SENSORS 23.4 55 | SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 6.5 30 15 30 10 27 Basic types 1551 and 1552 single and double-pole 10 17.8 6 23.4 12 29.8 26 12 Solder terminal X = Wall thickness Z 12.2 +0.2 21 12.8 4.5 5 17 12.8 4.5 5 1.3x0.8 1.3x0.8 12 6 23.4 12.3 PCB terminal angled 5 4.5 5 10 23.7 2 12.8 Z 12.4 +0.1 12.4 +0.1 12.4 +0.1 13 29.5 10 5 Y 26.2 -0.1 26.4 -0.1 26.8 -0.1 12 Solder terminal 13 2 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 6 23.4 Quick-connect terminal 6.3 29.5 X = Wall thickness 12 6 12 23.7 10 23.7 2 23.3 Basic types 1551 and 1552 lower lying flange single and double-pole 24.8 4.5 5 2 12 13 29.5 10 23.7 24.8 13 29.5 12.8 Y 27.2 + 0.1 17 X 0.8 ... 5.0 FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS 29.8 28.3 17.8 2 Quick-connect terminal 6.3 ROTARY SWITCHES SLIDE SWITCHES 12 23.4 TOGGLE SWITCHES PUSHBUTTON SWITCHES 12 23.4 | 56 15 2 27 6.5 ROCKER SWITCHES TO 16 (4) A 250 V AC 6 12 3.5 23.4 3.5 PCB terminal angled mirror-inverted 12.3 SERIES 1550 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 13 12 PCB terminal X = Wall thickness Y 27.2 + 0.1 Z 12.2 +0.2 WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES X 0.8 ... 5.0 PUSHBUTTON SWITCHES 6 23.4 TOGGLE SWITCHES 0.8 SLIDE SWITCHES 12.8 3.5 1.3 12 17 10 23.7 2 5 4.5 29.5 Basic type 1552 lower lying flange single and double-pole ROCKER SWITCHES TO 16 (4) A 250 V AC 57 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC PRODUCT FE ATURES ON REQUEST  100 million times proven switching principle  Other colors  Mechanical life endurance up to 1 million switching cycles  Other rocker printings  Wide variety  Snap-on customized actuators  Variants with IP 67 or dust protection insert  Cable assembly  Other lamp variants  Two housing variants  Excellent actuating characteristic  Illuminated and non-illuminated variants SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES  Approval for 400 V (product-dependent) | 58 Mechanical life endurance 10E4 5E4 (basic type 1839) 1E6 (product-dependent) Inrush current (capacitive) 120 A / 50 A (contact pair Ag / Cu) Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 / IP 67 (product-dependent) Ambient temperature connection side -20 °C ... +105 °C / ... +85 °C / ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 and UL 94 V-0 (product-dependent) Heat and fire resistance 850 °C (category D) Material PA / PC PA silver-plated / tinned actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES SLIDE SWITCHES z z z z 10 A 12 V DC 6 (4) A 250 V AC 5E4 TOGGLE SWITCHES z z z z z z z z z PUSHBUTTON SWITCHES 1831.3317 1831.3313 1831.3312 1831.0115 1831.0114 1831.0112 z z z 10 (4) A 250 V AC 1E4 ON/OFF switch (SPST) 1835.3902 230 z z z z 10 (8) A 250 V AC 5E4 z 16 (4) A 250 V AC 1E4 z z z z z 20 (4) A 250 V AC 1E4 z Housing color z Actuator color / printing Changeover switch (SPDT momentary) 1830.6103 230 1830.0102 230 1830.8112 230 1830.3119 230 1830.3118 230 1830.3111 1830.3112 230 Voltage lamp in V 230 single-pole ON/OFF switch (SPST) TO 20 (4) A 250 V AC z 6 (4) A 250 V AC 4 (2) A 250 V AC 1E4 z z z z z z z z z z z z z 16 A 250 V AC 1 HP z 30 mA 12 V DC ROTARY SWITCHES 6 (4) A 250 V AC 1E4 z z 16 A 125 V AC 1/3 HP z 16 A 250 V AC 1/2 HP FOOT SWITCHES 16 A 125 V AC 1 HP z z 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 3 MICRO-SIGNAL SWITCHES z z Stock version z SENSORS Miscellaneous > z low lying flange EN 60335 cap. 30 conform “G” Ag 6.3 3 Ag z > 6.3 3 > Ag z > Ag 3 > Ag 3 > Ag 3 6.3 3 Ag external lamp connection two-pole size > 3 > Ag low lying flange Ag > 3 4.8 6.3 3 > Ag 6.3 3 Ag z z > 6.3 3 Ag z > 6.3 3 Ag > 3 > z Contact material Ag Contact distance in mm z Connection description 6.3 Connection type TACT AND KEY SWITCHES 6 A 125 V AC 1/4 HP SNAP-ACTION SWITCHES 6 A 250 V AC 1/2 HP POWER TOOL SWITCHES 16 A 125 V AC 1/4 HP 59 | | 60 > Ag > 3 4.8 6.3 4.8 z z z z z z z z z z z z z z z 16 A 125 V AC 1 HP z z 16 A 125 V AC 1/4 HP 3 3 6.3 6.3 16 A 250 V AC 1/2 HP Ag > Au 3 3 30 mA 12 V DC z z z z z z 16 (4) A 250 V AC 1E4 z > Ag low lying flange z > Ag z z z 4 A 250 V AC 1/10 HP 4.8 6.3 6 A 125 V AC 1/10 HP 3 3 4 (2) A 250 V AC 1E4 > > 3 z z z z z z z z z z PUSHBUTTON SWITCHES ROCKER SWITCHES 1831.8102 1831.7102 1831.1107 1831.8112 1831.3933 1831.3815 1831.3607 1831.3606 ON/OFF switch (SPST) 1833.1102 1833.3312 Switch (SPDT) 1831.1253 1831.8202 1831.3402 1831.1202 Normally open contact (SPNO) Housing color Ag Ag low lying flange > 6 (4) A 250 V AC z z z z z 6 (4) A 250 V AC 1E4 z z z z z z z TOGGLE SWITCHES Actuator color / printing z Ag low lying flange 4.8 6 A 125 V AC 1/4 HP 3 6.3 6.3 6.3 6 A 250 V AC 1/2 HP > 3 3 3 6.3 6 (4) A 250 V AC 5E4 Ag > > > 3 z SLIDE SWITCHES 10 (4) A 250 V AC 1E4 z Ag low lying flange z Stock version Ag Contact distance in mm > Connection description Ag Ag z Miscellaneous housing with 2 separating gates 16 A 125 V AC 1/3 HP z ROTARY SWITCHES 16 A 250 V AC 1 HP 6.3 FOOT SWITCHES 10 (8) A 250 V AC 5E4 3 POWER TOOL SWITCHES 20 (4) A 250 V AC 1E4 > TACT AND KEY SWITCHES Voltage lamp in V IP 67 1E6 mechanical life endurance Ag EN 60335 cap. 30 conform “G” z SNAP-ACTION SWITCHES Contact material housing with 2 separating gates MICRO-SIGNAL SWITCHES single-pole z SENSORS SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 20 (4) A 250 V AC 10 A 12 V DC 6 A 125 - 250 V AC 1/8 HP Connection type Stock version Ag Ag momentary function one side low lying flange momentary function both sides low lying flange momentary function both sides z z 6.3 6.3 2.8 4.8 4 A 250 V AC 1/10 HP Connection type TACT AND KEY SWITCHES 3 3 3 3 3 4.8 4.8 4.8 6.3 16 A 125 V AC 1 HP 16 A 125 V AC 1/4 HP ROTARY SWITCHES z z z z z z z z z z z z FOOT SWITCHES z z SLIDE SWITCHES TOGGLE SWITCHES z z z z z z z z z z z z z z z POWER TOOL SWITCHES 6 A 125 V AC 1/10 HP SNAP-ACTION SWITCHES > > > > > 3 3 3 3 6.3 16 A 250 V AC 1 HP MICRO-SIGNAL SWITCHES Ag momentary function one side Ag Ag > Ag momentary function one side z > > Ag Ag > 3 6.3 6 A 125 - 250 V AC 1/8 HP z momentary function both sides Ag > 3 16 A 125 V AC 1/3 HP > 16 A 250 V AC 1/2 HP 1833.8102 1833.7102 1833.3307 PUSHBUTTON SWITCHES ROCKER SWITCHES 1838.3402 1838.8302 1838.7203 1838.4307 1838.1602 1838.1509 1838.1502 1838.1402 1838.3901 1838.3512 1838.3412 1838.0305 Switch with OFF position in the center (SPDT - Center OFF) z 10 A 12 V DC z Ag momentary function both sides z z 10 (8) A 250 V AC 5E4 3 6.3 z 16 (4) A 250 V AC 1E4 > 3 30 mA 12 V DC z 4 (2) A 250 V AC 1E4 z z 20 (4) A 250 V AC 1E4 IP 67 1E6 mechanical life endurance Ag momentary function both sides > 3 Housing color Ag Ag low lying flange > z Actuator color / printing z SENSORS Miscellaneous Ag 6 (4) A 250 V AC z 6 (4) A 250 V AC 1E4 z z Voltage lamp in V z EN 60335 cap. 30 conform “G” z Contact material low lying flange Contact distance in mm 6.3 Connection description 3 6 A 125 V AC 1/4 HP > 6 A 250 V AC 1/2 HP Ag 6 (4) A 250 V AC 5E4 z 10 (4) A 250 V AC 1E4 z single-pole Switch (SPDT) SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 20 (4) A 250 V AC 61 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES SLIDE SWITCHES 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 ROTARY SWITCHES 6 (4) A 250 V AC 1E4 6 (4) A 250 V AC 1833.6206 1833.3402 1833.1202 1838.3502 4 (2) A 250 V AC 1E4 z 10 (8) A 250 V AC 5E4 z z 16 (4) A 250 V AC 1E4 z 20 (4) A 250 V AC 1E4 z z Housing color z Actuator color / printing Changeover switch (SPDT momentary) Voltage lamp in V z single-pole Switch with OFF position in the center (SPDT - Center OFF) TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 30 mA 12 V DC 16 A 250 V AC 1 HP FOOT SWITCHES 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 4.8 3 > low lying flange EN 60335 cap. 30 conform “G” z z SENSORS Miscellaneous Stock version | 62 Ag 6.3 3 > Ag 4.8 3 > 3 Ag SNAP-ACTION SWITCHES Contact material > Connection description 6.3 Connection type Contact distance in mm MICRO-SIGNAL SWITCHES z z 6 A 125 - 250 V AC 1/8 HP z 6 A 125 V AC 1/4 HP Ag TACT AND KEY SWITCHES POWER TOOL SWITCHES 16 A 125 V AC 1/4 HP Miscellaneous MICRO-SIGNAL SWITCHES > > 6.3 4.8 z 6 A 125 V AC 1/4 HP 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP POWER TOOL SWITCHES z 4 A 250 V AC 1/10 HP Connection type ROTARY SWITCHES z SLIDE SWITCHES z z z z z z z z z z TOGGLE SWITCHES 16 (4) A 250 V AC 1E4 FOOT SWITCHES z z z z z z 16 A 125 V AC 1/4 HP z 16 A 250 V AC 1/2 HP z 16 A 125 V AC 1 HP z z z z z z z z Housing color TACT AND KEY SWITCHES 3 3 6.3 6.3 6.3 z z z z z 1835.3802 Switch (DPDT) 1835.7108 1835.1115 1835.9413 1835.3418 1835.3118 1835.3114 1835.3112 1835.3111 1835.3419 12 115 - 230 ROCKER SWITCHES 1832.3311 1832.1612 1835.3107 1835.3116 ON/OFF switch (DPST) 230 230 230 230 230 230 230 230 230 400 PUSHBUTTON SWITCHES Actuator color / printing SNAP-ACTION SWITCHES Ag Ag 3 3 3 3 16 A 125 V AC 1/3 HP z cover frame 33.2 long > Ag > > Ag Ag > Ag 4.8 30 mA 12 V DC z 4 (2) A 250 V AC 1E4 z 6 (4) A 250 V AC z 6 (4) A 250 V AC 1E4 z z z z 10 A 12 V DC z low lying flange 3 3 6.3 6.3 6.3 6.3 6.3 6 A 250 V AC 1/2 HP > > 3 3 3 3 3 6 (4) A 250 V AC 5E4 Ag Ag PCB holder 248.103.011 mounted low lying flange > > > > > z 10 (4) A 250 V AC 1E4 z Ag Ag z cover frame 33.2 long Ag z Stock version Ag EN 60335 cap. 30 conform “G” z SENSORS Contact material Ag Contact distance in mm z Connection description 6.3 16 A 250 V AC 1 HP 3 10 (8) A 250 V AC 5E4 > 20 (4) A 250 V AC 1E4 Ag Voltage lamp in V 10 (8) 400 V AC 5E4 cover frame 33.2 long double-pole ON/OFF switch (DPST) SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 20 (4) A 250 V AC 63 | | 64 Stock version low lying flange > > Ag Ag 3 3 6.3 6.3 6.3 z z z z z z z z z z 6 A 125 - 250 V AC 1/8 HP z z 4 A 250 V AC 1/10 HP 3 3 6 A 125 V AC 1/10 HP > > z 30 mA 12 V DC z z z 4 (2) A 250 V AC 1E4 z z z z z z z 6 (4) A 250 V AC z z 6 (4) A 250 V AC 1E4 z z z 10 A 12 V DC z z z z z z z z z z TOGGLE SWITCHES z z z z z z z z z z PUSHBUTTON SWITCHES ROCKER SWITCHES 1832.9101 1832.1102 1832.0113 1832.9103 1832.8112 1832.7103 1832.6112 1832.3602 1832.3508 1832.3313 1832.3312 ON/OFF switch (DPST) 1834.3311 Switch (DPDT) 1832.8204 1832.3407 Normally open contact (DPNO) Housing color Ag Ag 4.8 6 A 125 V AC 1/4 HP 3 6 A 250 V AC 1/2 HP > 3 16 A 125 V AC 1/4 HP > 6.3 4.8 6.3 6.3 z 6 (4) A 250 V AC 5E4 low lying flange Ag dust protection inlay 3 3 3 3 3 3 16 A 250 V AC 1/2 HP z 16 A 125 V AC 1 HP > > > > > > 6.3 10 (4) A 250 V AC 1E4 Ag Ag low lying flange Ag low lying flange Ag Ag low lying flange low lying flange Ag cover frame 33.2 long Ag 3 z SLIDE SWITCHES Actuator color / printing z Miscellaneous > z ROTARY SWITCHES 16 (4) A 250 V AC 1E4 z EN 60335 cap. 30 conform “G” z Contact material Ag Contact distance in mm z Connection description 6.3 16 A 125 V AC 1/3 HP 3 FOOT SWITCHES 16 A 250 V AC 1 HP > POWER TOOL SWITCHES 10 (8) A 250 V AC 5E4 Ag TACT AND KEY SWITCHES 20 (4) A 250 V AC 1E4 single-pole occupied SNAP-ACTION SWITCHES Voltage lamp in V z MICRO-SIGNAL SWITCHES double-pole z SENSORS SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 20 (4) A 250 V AC Connection type z SENSORS MICRO-SIGNAL SWITCHES 6.3 6.3 4.8 4.8 4.8 4.8 4.8 4.8 4.8 4.8 6.3 6.3 16 A 125 V AC 1/3 HP 16 A 125 V AC 1 HP ROTARY SWITCHES z z z z z 20 (4) A 250 V AC 1E4 TOGGLE SWITCHES Housing color 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP Connection type POWER TOOL SWITCHES z z z z z z z z z z z z z 10 A 12 V DC SLIDE SWITCHES z z z z z z z z z z FOOT SWITCHES 16 A 250 V AC 1 HP z z z z z 30 mA 12 V DC z PUSHBUTTON SWITCHES Actuator color / printing TACT AND KEY SWITCHES 3 3 3 3 3 3 3 3 3 3 3 3 3 4 (2) A 250 V AC 1E4 z z z z Voltage lamp in V SNAP-ACTION SWITCHES > > Ag Ag momentary function one side > > Ag momentary function one side > > > > > > > > Ag Ag Ag z dust protection inlay Ag Ag momentary function both sides dust protection inlay z Ag momentary function both sides z Ag Ag Ag momentary function both sides z > 6 A 125 - 250 V AC 1/8 HP z low lying flange cover frame 33.2 long Ag 4.8 6 (4) A 250 V AC z 6 A 125 V AC 1/4 HP 3 6 (4) A 250 V AC 1E4 z z 6 A 250 V AC 1/2 HP 4.8 z 6 (4) A 250 V AC 5E4 3 z 10 (4) A 250 V AC 1E4 z > Stock version Ag Miscellaneous > EN 60335 cap. 30 conform “G” Ag Contact material z Contact distance in mm 6.3 Connection description 3 16 A 125 V AC 1/4 HP > 16 A 250 V AC 1/2 HP Ag 16 (4) A 250 V AC 1E4 z double-pole ROCKER SWITCHES 1839.3503 1839.3502 1839.2203 1839.1602 1839.1518 1839.1509 1839.1502 1839.1410 1839.1407 1839.1402 1834.6103 1834.3603 1834.3309 1834.1103 1834.1102 1834.3312 Switch (DPDT) SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 20 (4) A 250 V AC 10 (8) A 250 V AC 5E4 65 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 10 A 12 V DC 6 (4) A 250 V AC 1834.3504 1834.3402 1839.3512 1839.3412 4 (2) A 250 V AC 1E4 z ROTARY SWITCHES 6 (4) A 250 V AC 1E4 z 6 (4) A 250 V AC 5E4 z SLIDE SWITCHES 10 (4) A 250 V AC 1E4 z 10 (8) A 250 V AC 5E4 z z 16 (4) A 250 V AC 1E4 z 20 (4) A 250 V AC 1E4 z z Housing color Changeover switch (DPDT momentary) Actuator color / printing z Voltage lamp in V z 1839.0105 1839.3352 1839.7304 1839.3602 Switch (DPDT) double-pole Switch with OFF position in the center (DPDT - Center OFF) TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 30 mA 12 V DC 16 A 250 V AC 1 HP 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP z z z z FOOT SWITCHES 16 A 125 V AC 1 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 3 > Ag 6.3 3 Ag z > 6.3 3 > Ag z 6.3 3 > Ag Ag dust protection inlay > 3 6.3 3 Au cover frame 33.2 long > 3 Ag momentary function one side dust protection inlay, low lying flange > Ag momentary function one side Stock version z single-pole occupied momentary function both sides EN 60335 cap. 30 conform “G” z SNAP-ACTION SWITCHES Miscellaneous Contact material SENSORS MICRO-SIGNAL SWITCHES 3 Connection description 6.3 Connection type Contact distance in mm | 66 z 6 A 125 - 250 V AC 1/8 HP z 6 A 125 V AC 1/4 HP > TACT AND KEY SWITCHES POWER TOOL SWITCHES 16 A 125 V AC 1/4 HP SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Actuator color / printing ROCKER SWITCHES TOGGLE SWITCHES Housing color PUSHBUTTON SWITCHES 1837.8108 230 1837.8102 230 1837.3102 230 1837.1118 1837.2504 230 Voltage lamp in V 230 Lamp Lamp TO 20 (4) A 250 V AC 20 (4) A 250 V AC 1E4 16 (4) A 250 V AC 1E4 10 (8) A 250 V AC 5E4 SLIDE SWITCHES 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 ROTARY SWITCHES 6 (4) A 250 V AC 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP FOOT SWITCHES 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 125 V AC 1/4 HP 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 size basic type 1835 size basic type 1835 z z 6.3 6.3 z Connection description 4.8 Connection type TACT AND KEY SWITCHES POWER TOOL SWITCHES 6 A 250 V AC 1/2 HP Contact material low lying flange EN 60335 cap. 30 conform “G” Stock version z SENSORS Miscellaneous MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES Contact distance in mm 67 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 23.5 11 9.5 27.2 27.2 31.5 Quick-connect terminal 4.8 basic type 1838 14 3 6.4 Quick-connect terminal 2.8 1838.4307 Y 30 -0.1 30.2 -0.1 30.6 -0.1 Z 11 +0.1 11 +0.1 11 +0.1 26.5 15.8 9.5 15 11 0.8 27.2 9.5 34.2 27.2 Quick-connect terminal 4.8 basic types 1830, 1831 and 1833 Quick-connect terminal 6.3 1831.3815 31.5 14 16.2 15 9.5 SNAP-ACTION SWITCHES 0.8 9.5 27.2 27.2 6.4 Quick-connect terminal 6.3 basic types 1831 and 1833 Solder terminal basic type 1838 14 16.2 31.5 27 2 MICRO-SIGNAL SWITCHES 16.2 2 2 11 0.8 0.8 11 9.5 27.2 Solder terminal basic types 1830 and 1831 14 11 27 31.5 14 16.2 31.5 Quick-connect terminal 6.3 basic type 1838 27 6.4 Quick-connect terminal 6.3 1838.3901 5.6 POWER TOOL SWITCHES TACT AND KEY SWITCHES 27.2 9.5 SENSORS 11 0.8 27.2 34.6 | 68 27 3 15.8 FOOT SWITCHES 9.5 26.55 3 5.6 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 27 2 16.2 X = Wall thickness ROTARY SWITCHES SLIDE SWITCHES 16.2 0.8 11 9.5 Basic types 1830, 1831, 1833 and 1838 single-pole illuminated / non-illuminated 14 2 16.2 2 0.8 5.6 31.5 14 23.5 5.6 31.5 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 16.2 SLIDE SWITCHES 0.8 10.2 22 27.2 3.5 5.6 25 2 2 16.2 31.5 ROTARY SWITCHES Solder terminal basic type 1832 25 29.5 31.5 5.6 Quick-connect terminal 6.3 basic type 1839 0.8 9.5 22 POWER TOOL SWITCHES Solder terminal basic type 1839 PCB terminal basic type 1839 33.2 11.4 11.4 11.2 3.5 2 22 2 11.2 11.4 4.4 10.2 22 27.2 27.2 33.2 10 10.6 9.5 10 10.2 3.6 0.8 0.8 9.5 Basic types 1830, 1831, 1833 and 1838 single-pole, lower lying flange illuminated / non-illuminated X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 30 -0.1 30.2 -0.1 30.6 -0.1 Z 11 +0.1 11 +0.1 11 +0.1 11 27.2 Quick-connect terminal 4.8 basic types 1830, 1831 and 1833 10 10 27.2 PCB terminal basic type 1838 TACT AND KEY SWITCHES 27.2 11 SNAP-ACTION SWITCHES 9.5 22 MICRO-SIGNAL SWITCHES 10.2 9.5 16.2 2 16.2 0.8 9.5 16.2 Z 22 +0.2 22 +0.2 22 +0.2 29.5 2 Y 30 -0.1 30.2 -0.1 30.6 -0.1 25 FOOT SWITCHES 31.5 25 29.5 31.5 Quick-connect terminal 6.3 / 4.8 basic types 1832, 1834 and 1835 6.4 5.6 Quick-connect terminal 4.8 basic type 1839 TOGGLE SWITCHES 27.2 X = Wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 10.2 22 PUSHBUTTON SWITCHES 29.5 0.8 9.5 22 27.2 Basic types 1832, 1834, 1835 and 1839 double-pole illuminated / non-illuminated 2 16.2 23.5 22.5 2 10.2 9.5 9.5 25 25 SENSORS 5.6 31.5 31.5 ROCKER SWITCHES 6.4 TO 20 (4) A 250 V AC 69 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 33.2 Basic types 1832, 1834, 1835 and 1839 double-pole, lower lying flange illuminated / non-illuminated 11.2 Quick-connect terminal 6.3 basic type 1832 33.2 10.6 3.6 33.2 22.2 22.2 9.5 9.5 27.2 11.2 1.3x0.8 9.5 27.2 10.2 4 22 22 PCB terminal angled basic types 1832 and 1835 4.4 Quick-connect terminal 6.3 basic type 1839 10 27.2 0.8x0.8 22.2 11.2 2 10.2 11.2 3.5 3.4 3.2 FOOT SWITCHES 2 7 3.6 22.2 7 33.2 33.2 ø1.3 +0.1 10.2 0.8x0.8 10 22 10.2 10 22 PCB terminal basic type 1839 31.5 2 29.5 11 27.2 Quick-connect terminal 4.8 single-pole size 2.5 31.5 25.1 X = Wall thickness Quick-connect terminal 6.3 double-pole size 14 33.2 11.4 +0.1 20 0.8 11 19 20 3.5 22 22 +0.1 22 +0.1 1.3 +0.1 7 11.2 Z 2 Y 30 -0.1 30.2 -0.1 30.6 -0.1 26 16.2 28.2 2 SNAP-ACTION SWITCHES 22 27.2 Basic type 1837 Lamp single and double-pole 10.2 9.5 19 MICRO-SIGNAL SWITCHES 25 26 16.2 14 2 TACT AND KEY SWITCHES 2.5 31.5 25.1 PCB terminal basic types 1832 and 1835 16.2 POWER TOOL SWITCHES 27.2 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 11 27.2 SENSORS 27.2 | 70 13.5 5 Z 22 +0.2 22 +0.2 22 +0.2 15.5 11.2 Y 30 -0.1 30.2 -0.1 30.6 -0.1 24.5 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 4.4 11.4 2 2 X = Wall thickness 10.2 22 27.2 Quick-connect terminal 4.8 basic types 1832 and 1834 24.5 4.4 24.5 11.2 4.4 11.4 11.4 2 2 22.2 9.5 10.2 22 ROTARY SWITCHES SLIDE SWITCHES 33.2 22.2 9.5 27.2 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC Quick-connect terminal 6.3 single-pole size PCB terminal, lower lying flange, 1837.2504 SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 10.6 37 Protection cap 203.731.011 SLIDE SWITCHES 36 Protection cap 203.201.011 Dummy cap 203.145.051 TACT AND KEY SWITCHES SNAP-ACTION SWITCHES 19.1 25.1 MICRO-SIGNAL SWITCHES 9.5 Dummy cap for double-pole size of basic types 1832, 1834, 1835, 1837 and 1839 of PA black SENSORS Dummy cap 203.146.051 POWER TOOL SWITCHES FOOT SWITCHES Dummy cap for single-pole size of basic types 1830, 1831, 1833, 1837 and 1838 of PA black ROTARY SWITCHES 0.6 10.6 28 Transparent PVC-protection cap for double-pole switches of basic types 1832, 1834, 1835 and 1839 with frame length 33.2 mm. Serves as dust and water protection of the actuation side. TOGGLE SWITCHES 19.2 PUSHBUTTON SWITCHES 5.4 11 27.1 Transparent PVC-protection cap for single-pole switches of basic types 1830, 1831, 1833 and 1838. Serves as dust and water protection of the actuation side. ROCKER SWITCHES TO 20 (4) A 250 V AC 71 | SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC PRODUCT FE ATURES ON REQUEST  Illuminated and non-illuminated variants with various switching functions  Other connection types  IP 65 with integrated gasket for high dust and water protection  Other printing variants  Other lamp variants  With V-0 material  Approval for 400 V  100 million times proven switching principle  Cable assembly  Modern rocker design Mechanical life endurance 5E4 Operating force 3-8N Inrush current (capacitive) 120 A 100 A (basic types 1934 and 1939) Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES  High, flexible variety POWER TOOL SWITCHES ROTARY SWITCHES  Inrush currents (capacitive) up to 120 A  Other colors | 72 Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 65 (recessed installation) Ambient temperature connection side -20 °C ... +105 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 and UL 94 V-0 (product-dependent) Heat and fire resistance 850 °C (category D) Material hard components of PC / soft components of TPE (bellows) PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N / 2US C Suitable for appliances of protection class II SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES > > > Ag Ag Ag 3 3 3 3 3 4.8 6.3 6.3 6.3 6.3 6.3 14 A 125 V AC 1/4 HP 12 A 250 V AC 1 HP 12 A 125 V AC 1/2 HP Connection type POWER TOOL SWITCHES 14 A 250 V AC 3/4 HP 14 A 250 V AC 1/2 HP FOOT SWITCHES z z z z 15 A 125 V AC 3/4 HP ROTARY SWITCHES SLIDE SWITCHES z z z z z z z z z z z z z z z z z z z z z z z z z z z z 16 A 125 V AC 1/3 HP TACT AND KEY SWITCHES > > Ag 3 6.3 6.3 6.3 6.3 6.3 6.3 250 250 250 250 250 250 400 400 1935.3129 1935.3119 1935.3118 1935.3114 1935.3113 1935.3112 1935.3137 1935.3135 1935.3218 PUSHBUTTON SWITCHES 24 125 125 125 - 250 ROCKER SWITCHES 1932.1112 1935.3133 1935.3131 1935.3128 1935.3134 ON/OFF switch (DPST) 250 Normally open contact (DPNO) TOGGLE SWITCHES z z z z z z z z z z Housing color Ag > Ag 3 3 3 3 3 3 z z Actuator color / printing z > Ag > > Ag z > > Ag Ag z bellows anthracite Ag Miscellaneous z Stock version > Connection description z z 6 (4) A 250 V AC 5E4 z z 16 A 125 V AC 3/4 HP 6.3 16 A 250 V AC 1 HP Ag > Contact material Ag 10 A 24 V DC z z 10 (8) A 250 V AC 5E4 z z 10 (8) A 400 V AC 5E4 6.3 20 (4) A 250 V AC 1E4 z 3 > Voltage lamp in V 3 Contact distance in mm Ag double-pole ON/OFF switch (DPST) SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 TO 20 (4) A 250 V AC 12 (4) A 250 V AC 1E4 14 A 250 V AC 1 HP 14 A 125 V AC 1/3 HP 73 | | 74 Stock version > > > Ag Ag Ag 3 3 6.3 6.3 14 A 125 V AC 1/4 HP z z z z z z z z z z z z z z z 14 A 125 V AC 1/3 HP z z 14 A 250 V AC 1/2 HP z 14 A 250 V AC 3/4 HP z z 14 A 250 V AC 1 HP z 16 A 125 V AC 1/3 HP z z 12 A 125 V AC 1/2 HP 6.3 6.3 6.3 12 A 250 V AC 1 HP 3 3 3 z z z z z z z 6 (4) A 250 V AC 5E4 z 10 A 24 V DC z z TOGGLE SWITCHES z z z z z z z z PUSHBUTTON SWITCHES ROCKER SWITCHES 1932.3418 1932.3412 1932.3118 1932.3114 1932.3113 1932.3112 1932.1114 1932.1113 ON/OFF switch (DPST) 1934.3114 1934.3113 1934.3112 Switch (DPDT) 1932.3413 Normally open contact (DPNO) 1932.3312 Normally closed contact (DPNC) Housing color > > Ag 6.3 6.3 6.3 6.3 6.3 15 A 125 V AC 3/4 HP 3 3 3 3 3 6.3 4.8 SLIDE SWITCHES Actuator color / printing Ag > Ag > Ag > > Ag single-pole occupied Miscellaneous Ag > Ag 3 Connection description > > Contact material Ag ROTARY SWITCHES 16 A 125 V AC 3/4 HP 4.8 FOOT SWITCHES 16 A 250 V AC 1 HP Ag 3 > POWER TOOL SWITCHES 10 (8) A 250 V AC 5E4 3 Contact distance in mm Ag TACT AND KEY SWITCHES 20 (4) A 250 V AC 1E4 single-pole occupied SNAP-ACTION SWITCHES Voltage lamp in V z MICRO-SIGNAL SWITCHES double-pole z SENSORS SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 TO 20 (4) A 250 V AC 12 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 Connection type SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 10 (8) A 250 V AC 5E4 16 A 250 V AC 1 HP 16 A 125 V AC 1/3 HP z 15 A 125 V AC 3/4 HP z z z z POWER TOOL SWITCHES 6.3 3 Ag SENSORS > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA Cu and CuZn bare (terminal outlet silver-plated) actuator housing connections Plug force of the terminals < Approval marks 4 80 N /1/2 Suitable for appliances of protection class II SLIDE SWITCHES  Other connection types ROTARY SWITCHES  Other printing variants  Switching system sealed from rocker to protect against overflowing water (VDE 700 part 15) FOOT SWITCHES  Other colors  Can be mounted from rear (alternatively with frame)  As a double switch POWER TOOL SWITCHES  Silk matt printable surface TACT AND KEY SWITCHES  Other actuator forms (e.g. oval) SNAP-ACTION SWITCHES  Powerful, illuminated rocker switch with plate spring switching system MICRO-SIGNAL SWITCHES ON REQUEST SENSORS PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 A 250 V AC 77 | SERIES 1656 - SINGLE-POLE ROCKER SWITCHES Contact material z 4.8 > 3 Ag 1656.1703 230 z z 4.8 > 3 Ag 1656.1722 110 z 4.8 > 3 Ag 1656.1723 90 z 4.8 > 3 Ag Connection type Voltage lamp in V PUSHBUTTON SWITCHES 27.15 POWER TOOL SWITCHES FOOT SWITCHES 12.8 21 13 10° 10.5 11.35 11.5 25.5 Quick-connect terminal 4.8 Basic type 1656 X = Wall thickness X 2 > Y 28 + 0.1 Z 13 + 0.1 SNAP-ACTION SWITCHES TACT AND KEY SWITCHES glow lamp with ignition voltage < 90 V 7 ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (SPST) 2 37 18 MICRO-SIGNAL SWITCHES SENSORS Additional parts | 78 10 Mounting frame of polyamide 217.313.011 - black 217.313.041 - anthracite metallic Stock version Contact distance in mm z Miscellaneous Connection description 230 10 A 125 V AC 1/3 HP 10 A 250 V AC 1E4 1/2 HP 1656.1702 single-pole Actuator color / printing 10 A 250 V AC 1E4 ROCKER SWITCHES TO 10 A 250 V AC SERIES 3201 - SINGLE-POLE 3-STEP ROCKER SWITCHES ON REQUEST  Step rocker switch with switching function 0 - I - II  Other rocker colors  Attractive rocker design  Printing  Can be mounted from rear  Other connection variants PUSHBUTTON SWITCHES PRODUCT FE ATURES ROCKER SWITCHES TO 0.5 A 12 V DC 2E4 Ambient temperature connection side -40 °C ... +100 °C Material PA PBTP silver-plated / bare 13.6 9.5 21.1 15.9 6.7 7.6 24 10.9 Basic type 3201 Quick-connect terminal 4.8 FOOT SWITCHES POWER TOOL SWITCHES switching function 0 - I - II TACT AND KEY SWITCHES Ag SNAP-ACTION SWITCHES z MICRO-SIGNAL SWITCHES Miscellaneous 3201.1121 SENSORS Contact material 4.8 Step switch Stock version Connection description Connection type 0.5 A 12 V 15E3 Housing color single-pole Actuator color / printing ROTARY SWITCHES actuator housing connections SLIDE SWITCHES Mechanical life endurance TOGGLE SWITCHES  Mechanical rating at least 20 000 switching cycles 79 | SERIES 3230 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 ( 5) A 24 V DC PRODUCT FE ATURES ON REQUEST  Attractive rocker switch (rocker separate)  Other colors  Million times proven, friction snap-action contact system  Other rocker symbols (lasered)  Powerful with 100 000 switching cycles electrically and mechanically for DC voltage applications  Other lamp variants  Indicator lamp identical TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS  With mounted rocker  Dust and water protected  High variety  With or without function lighting (LED)  Installation from the front directly or with assembly frame  Block plug connection Mechanical life endurance 10E4 Ambient temperature -40 °C ... +85 °C Material PA glass fiber-reinforced PA silver-plated Miscellaneous | 80  Other switching functions actuator housing connections illumination with mounted rocker: day design = light gray / night design = green SERIES 3230 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES 3.0 x 0.8 circuit symbol: 3.01 PUSHBUTTON SWITCHES Miscellaneous circuit symbol: 3.01 Stock version Connection description 3.0 x 0.8 Connection type 10 (5) A 12 V 10E4 10 (5) A 24 V 10E4 Housing color single-pole (rocker separate) Voltage lamp in V TO 10 ( 5) A 24 V DC z 3230.0102 z 3230.0101 TOGGLE SWITCHES Normally open contact snapping 1-step (SPST) z 3230.0202 z 3230.0201 3.0 x 0.8 circuit symbol: 3.03 3.0 x 0.8 with function indicator circuit symbol: 3.03 3.0 x 0.8 circuit symbol: 3.02 3.0 x 0.8 circuit symbol: 3.02 SLIDE SWITCHES Normally open contact snapping 1-step with function indicator (SPST) z WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES 3230.1902 TACT AND KEY SWITCHES circuit symbol: 3.09 Changeover switch snapping 1-step (DPDT) Stock version Miscellaneous 3.0 x 0.8 Connection type 10 (5) A 24 V 10E4 Housing color Voltage lamp in V double-pole (rocker separate) 10 (5) A 12 V 10E4 z 3230.0301 Connection description z 3230.0302 ROTARY SWITCHES Normally open contact momentary 1-step (SPNO) 81 | SERIES 3230 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Stock version Miscellaneous Connection description Connection type 10 (5) A 12 V 10E4 10 (5) A 24 V 10E4 Housing color Combination (rocker separate) Voltage lamp in V PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 ( 5) A 24 V DC TOGGLE SWITCHES Changeover switch snapping 2-step (SPDT) z 3230.0502 z 3230.0501 3.0 x 0.8 2 x single-pole changeover switch circuit symbol: 3.31 3.0 x 0.8 2 x single-pole changeover switch circuit symbol: 3.31 SLIDE SWITCHES Changeover switch snapping 2-step with function indicator (SPDT) z 3230.0602 z 3230.0601 3.0 x 0.8 2 x single-pole changeover switch circuit symbol: 3.33 3.0 x 0.8 2 x single-pole changeover switch circuit symbol: 3.33 3.0 x 0.8 2 x single-pole changeover switch circuit symbol: 3.32 3.0 x 0.8 2 x single-pole changeover switch circuit symbol: 3.32 z 3230.0701 Connection description Miscellaneous 24 24 3.0 x 0.8 LED red / green 3237.0106 24 24 3.0 x 0.8 LED green / green 3237.0108 24 24 3.0 x 0.8 LED yellow / green Connection type 3237.0104 10 (5) A 12 V 10E4 LED red / red 10 (5) A 24 V 10E4 3.0 x 0.8 Housing color 24 24 Voltage lamp in V POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 82 3237.0102 Lamp (cap separate) Lamp Stock version z 3230.0702 FOOT SWITCHES ROTARY SWITCHES Changeover switch momentary 2-step (SPDT) SERIES 3230 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES TO 10 ( 5) A 24 V DC 19.5 Quick-connect terminal 3.0 x 0.8 Snap-on rocker for basic type 3230 and cap for basic type 3237 (without switching function) painted black with or without stop for both or one-sided switching function. Laser inscription by customer or on request. 40.4 Rocker 190.389.011 - without stop (switching function both sides) 190.389.021 - with stop (switching function one side) 20 9 to 19.4 9 ø3 4.8 FI Cap 203.442.011 - with stop both sides (for lamp 3237) SL Installation frame for basic types 3230 and 3237 in black 26 FOOT SWITCHES 16.4 50 ROTARY SWITCHES Basic types 3230 and 3237 SLIDE SWITCHES 5 TOGGLE SWITCHES PUSHBUTTON SWITCHES 25.5 9.3 41.2 RC +0.2 +0.05 Installation frame 217.353.021 SENSORS MICRO-SIGNAL SWITCHES Dummy piece 203.069.013 SNAP-ACTION SWITCHES TACT AND KEY SWITCHES Dummy piece for the basic types 3230 and 3237 with mounted black cap POWER TOOL SWITCHES 22 +0.2 +0.05 44 Lasered rocker symbols 83 | SERIES 3230 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES TO 10 ( 5) A 24 V DC 3 3 1 10 7 10 Circuit symbol: 3.02 Circuit symbol: 3.01 TOGGLE SWITCHES PUSHBUTTON SWITCHES 7 Circuit symbols 1 OI OI 5 1 3 3 8 6 1 OI SLIDE SWITCHES OI FA 7 10 4 10 Circuit symbol: 3.09 ROTARY SWITCHES Circuit symbol: 3.03 7 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES 5 | 84 3 8 6 1 3 5 II O I 8 6 1 II O I 7 4 10 Circuit symbol: 3.31 5 3 8 6 1 FA 4 Circuit symbol: 3.33 4 Circuit symbol: 3.32 II 0 I 7 7 10 10 SERIES 1257 - DOUBLE-POLE ROCKER SWITCHES PRODUCT FE ATURES ON REQUEST  Double-pole OFF switch  Other colors  Powerful up to 14 A (UL) and 100 000 mechanical switching cycles  Other connection variants  Dust protected  Higher ratings up to 12 (12) A PUSHBUTTON SWITCHES 10E4 Actuator IP 40 actuator housing PA glass fiber-reinforced PA glass fiber-reinforced Interference suppressor C = 0.22 μF 275 V AC Approval marks 3 SLIDE SWITCHES Material  Without interference suppression capacitor TOGGLE SWITCHES Mechanical life endurance ROCKER SWITCHES TO 8 ( 8 ) A 250 V AC Ag 15.9 46 14.8 2.5 62.4 10.5 1 10 19 20.6 11.7 8 15 44.4 85.5 19.4 92.3 28 28 Basic type 1257 Quick-connect terminal motor side, socket terminal mains side MICRO-SIGNAL SWITCHES 1° POWER TOOL SWITCHES 3 > SNAP-ACTION SWITCHES 2 x 6.3 x 0.8 2 x M4 Torx SENSORS 1257.0101 TACT AND KEY SWITCHES z ON/OFF switch (DPST) Stock version 125 V AC 3/4 HP z Contact material 250 V AC 1 1/2 HP z Contact distance in mm 14 A 125 - 250 V AC z Connection description 16 A 125 - 250 V AC z Connection type 8 (8) A 250 V AC 5E4 Housing color double-pole Actuator color / printing FOOT SWITCHES ROTARY SWITCHES /1/2 85 | SERIES 0344 - THREE-POLE ROCKER SWITCHES PRODUCT FE ATURES ON REQUEST  Robust and powerful rocker switch  Other connection variants  Dust protected  Approval for 400 V Material PA Duroplast / chromated galvanized steel chromated actuator housing connections 3 Approval marks Contact material > 3 Ag 0344.0201 z z M4 > 3 Ag FOOT SWITCHES 14 13 13 45° 31.5±1 6 9 POWER TOOL SWITCHES TACT AND KEY SWITCHES ON/OFF switch (TPST) SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 86 Stock version Contact distance in mm M4 Miscellaneous Connection description z Connection type 25 A 400 V AC z Housing color 0344.0102 three-pole Actuator color / printing 16 (6) A 400 V AC 5E4 ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 ( 6 ) A 400 V AC 8.2 1 56 Basic type 0344 Screw connection M4 2 39 3 z FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES PUSHBUT TON SWITCHES SENSORS SENSORS 87 | ROCKER SWITCHES PUSHBUT TON SWITCHES SERIES 1680 Single and double-pole pushbutton switches PAGE 90 - 95 SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES to 16 (4) A / 12 (12) A 250 V AC SERIES 1683 Single and double-pole pushbutton switches PAGE 96 - 98 to 16 A 250 V AC Appliance cut-out: 19.2 x 12.9 mm SERIES 1691 Smallest single-pole pushbutton switches PAGE 99 ROTARY SWITCHES for low voltages SERIES 1246 to 8 (8) A 250 V AC SERIES 1247 Double-pole pushbutton switches PAGE 102 - 104 to 7 A 250 V AC MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Double-pole pushbutton switches PAGE 100 - 101 SERIES 5000 Round pushbutton switches for at least 200 000 mechanical switching cycles Appliance cut-out: Ø 16,0 mm SERIES 1846 Single-pole pushbutton switches SENSORS to 2 (1) A 250 V AC | 88 PAGE 105 - 106 Appliance cut-out: 19.2 x 12.9 mm PAGE 107 - 108 SERIES 1840 Single and double-pole pushbutton switches PAGE 109 - 112 ROCKER SWITCHES PUSHBUT TON SWITCHES Ø 12,0 mm Single and double-pole pushbutton switches / lamps PAGE 113 - 117 TOGGLE SWITCHES SERIES 1660 to 16 (4) A 250 V AC Appliance cut-out: 30.0 x 22.2 mm SERIES 1670 Single and double-pole pushbutton switches / lamps PAGE 118 - 122 SLIDE SWITCHES Appliance cut-out: PUSHBUTTON SWITCHES to 6 (4) A 250 V AC 30.0 x 22.2 mm WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Appliance cut-out: ROTARY SWITCHES to 16 (4) A 250 V AC 89 | SERIES 1680 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES PRODUCT FE ATURES ON REQUEST  Million times proven double lifting contact system with at least 100 000 mechanical switching cycles  Special plastics  High electrical rating up to 16 A  Customized actuators and housing contours  High mechanical load capacity up to 750 N (for foot actuation)  Cable assembly  Great variety Mechanical life endurance 10E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation IP 40 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 (actuator: V-0, socket: V-1, housing: V-2) UL 94 V-0 (product-dependent) 850 °C (category D) Material PBTP / PA / PA glass fiber-reinforced (product-dependent) PA / PA glass fiber-reinforced (product-dependent) silver-plated / galvanically nickel-plated in plug area / tinned (product-dependent) SNAP-ACTION SWITCHES Protection type Plug force of the terminals < Approval marks 3 SENSORS  Behind PCB mountable variants  With pole separating wall (basic type 1689) Heat and fire resistance | 90  Other connection variants  Variable housing and pushbutton form with holders MICRO-SIGNAL SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 (4) A / 12 (12) A 250 V AC actuator housing connections 80 N / 1 / 2 (product-dependent) Suitable for appliances of protection class II SERIES 1680 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES Operating position (OP) in mm Permissible total travel position (TP) in mm EN 60335 cap. 30 conform “G” Miscellaneous 3 Ag 7.0 + 2.5 26.5 23.8 22.2 z resting pin 1681.3104 z z 4.8 horizontal > 3 Ag 7.0 + 2.5 26.5 23.8 22.2 z 1681.4403 z z horizontal > 3 Ag 7.0 + 2.5 24 21.3 19.7 z 1681.4431 z z z 5.3 horizontal > 3 Ag 7.0 + 2.5 24 21.3 19.8 z z z 4.8 vertical > 3 Ag 7.0 + 2.5 26.5 23.8 22.2 z 4.8 vertical > 3 Ag 7.0 + 2.5 24 21.3 19.7 z 4.8 horizontal > 3 Ag 7.0 + 2.5 26.5 23.8 22.2 > 3 Ag 7.0 + 2.5 24 21.3 19.7 PUSHBUTTON SWITCHES Free position (FP) max. in mm > Stock version Operating force in N vertical Actuator description Contact material z Connection description z Connection type 1681.2102 single-pole 16 (4) A 250 V AC 1E4 12 (12) A 250 V AC 5E4 12 (12) A 250 V AC 1E4 12 (8) A 250 V AC 1E4 10 (8) A 250 V AC 5E4 16 A 125 - 250 V AC 12 A 125 - 250 V AC 1/2 HP 5 A 125 V AC L Contact distance in mm ROCKER SWITCHES TO 16 (4) A / 12 (12) A 250 V AC z z 1681.3101 z z z 1681.3701 z z z 4.8 horizontal 1681.4402 z z z horizontal > 3 Ag 7.0 + 2.5 24 21.3 19.7 rest pin 1681.4701 z z z horizontal > 3 Ag 7.0 + 2.5 24 21.3 19.7 resting pin > 3 Ag 7.0 + 2.5 24 21.3 19.7 horizontal > 3 Ag 6.5 +1.5 26.85 29.4 22.8 23.8 22.2 z 1681.5701 SLIDE SWITCHES flange on the end faces ROTARY SWITCHES z z 1681.1702 rest pin z FOOT SWITCHES 1681.1101 TOGGLE SWITCHES ON/OFF switch (SPST) 1681.1202 z z 4.8 vertical > 3 Ag 7.0 + 2.5 26.5 1681.1304 z z 4.8 vertical > 3 Ag 7.0 + 2.5 24 < 21.3 19.8 z 1681.1354 z z 4.8 vertical > 3 Au 7.0 + 2.5 24 < 21.3 19.7 z z 4.8 horizontal > 3 Ag 7.0 + 2.5 24 1681.3501 z z 21.3 19.7 TACT AND KEY SWITCHES Normally open contact (SPNO) SNAP-ACTION SWITCHES resting pin MICRO-SIGNAL SWITCHES z SENSORS z 1681.9408 POWER TOOL SWITCHES Normally closed contact (SPNC) 91 | SERIES 1680 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES 19.7 z 20.95 19.7 z z Stock version 21.3 Actuator description 24 Miscellaneous 9.0 + 3 EN 60335 cap. 30 conform “G” Ag Permissible total travel position (TP) in mm Operating force in N 3 Operating position (OP) in mm Contact material > Free position (FP) max. in mm Contact distance in mm 6.3 vertical Connection description Connection type PUSHBUTTON SWITCHES double-pole 16 (4) A 250 V AC 1E4 12 (12) A 250 V AC 5E4 12 (12) A 250 V AC 1E4 12 (8) A 250 V AC 1E4 10 (8) A 250 V AC 5E4 16 A 125 - 250 V AC 12 A 125 - 250 V AC 1/2 HP 5 A 125 V AC L ROCKER SWITCHES TO 16 (4) A / 12 (12) A 250 V AC ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES ON/OFF switch (DPST) 1682.7704 z 1689.1302 z 1689.3803 z z z z 4.8 vertical > 3 Ag 9.0 + 3 24 z z 4.8 horizontal > 3 Ag 9.0 + 3 24 20.95 19.7 1682.1101 z z z 4.8 vertical > 3 Ag 9.0 + 3 26.5 23.8 22.2 1682.1702 z z z 4.8 vertical > 3 Ag 9.0 + 3 24 21.3 19.7 > 3 Ag 7.0 + 2.5 24 21.3 19.7 FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS z < 1682.1802 z z z 4.8 vertical 1682.2701 z z z vertical > 3 Ag 9.0 + 3 24 21.3 19.7 1682.3101 z z z 4.8 horizontal > 3 Ag 9.0 + 3 26.5 23.8 22.2 z 180° angled > 3 Ag 9.0 + 3 24 21.3 19.8 z z z horizontal > 3 Ag 9.0 + 3 24 20.95 19.7 1682.1201 z z z 4.8 vertical > 3 Ag 9.0 + 3 26.5 23.8 22.2 1682.1902 z z z z 4.8 vertical > 3 Ag 9.0 + 3 28.8 26.1 24.5 1682.3201 z z z 4.8 horizontal > 3 Ag 9.0 + 3 26.5 23.8 22.2 1682.3702 z z z 4.8 horizontal > 3 Ag 7.0 + 2.5 26.5 23.8 22.2 z z 1682.6101 | 92 z special housing contour z z z Normally open contact (DPNO) 1689.4202 z < z rest pin with cap 205.021.011 z SERIES 1680 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES 4 6 8 8 10 4 26.5 14.5 1.6±0.1 4.3 10 13 11 PUSHBUTTON SWITCHES h 6 19 Quick-connect terminal 4.8 vertical (standard actuator) FOOT SWITCHES 10 13 Quick-connect terminal 4.8 vertical (shortened actuator) 13 11 11 SLIDE SWITCHES 4 14.5 h 24 14.5 4 26.5 19 6 19 Quick-connect terminal 4.8 vertical (actuator with holder for different caps) h Quick-connect terminal 4.8 horizontal (standard actuator) Basic type 1681 single-pole ROTARY SWITCHES 10 4.8-0.8 DIN 46244 A 11 13 11 TOGGLE SWITCHES 7.7 13 10 8 h 24 14.5 h 4 26.5 14.5 6 19 6 19 ROCKER SWITCHES TO 16 (4) A / 12 (12) A 250 V AC 3.7 WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES PCB terminal vertical (standard actuator) POWER TOOL SWITCHES 7.3 93 | SERIES 1680 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 16 (4) A / 12 (12) A 250 V AC 6 19 h 24 14.5 4 4 14.5 9.5 ROCKER SWITCHES 6 7.7 10 13 10 13 11 4.8-0.8 DIN 46244 A 19 Cut terminal (actuator with holder for different caps) Basic type 1681 single-pole TOGGLE SWITCHES Quick-connect terminal 4.8 horizontal (shortened actuator) 6 19 6 h 24 14.5 4.3 14.5 4 4 19 24 PUSHBUTTON SWITCHES 0.6 11 4.5 2 2.5 3.7 7.3 ROTARY SWITCHES PCB terminal horizontal (actuator with holder for different caps) 5.95 0.8 14.5 18.5 1 1 2.2 3.7 7.3 17.5±0.2 ø2.2 ø1.6±0.1 0.93 4.23 19 13 FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS 6.98 1.3 4.5 1.1 | 94 PCB terminal horizontal (shortened actuator) PCB terminal horizontal 1681.9408 normally closed contact SPNC (actuator with holder for different caps) 15.7 4.5 13 10 11 24±0.1 11 12.8 ø2.2 13 3.7 7.3 1.6±0.1 10 SLIDE SWITCHES 4.3 SERIES 1680 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 (4) A / 12 (12) A 250 V AC 6 6 6 19 10.2 11 11 h 26.5 23.8 22.2 SLIDE SWITCHES 8 6.5 8 14.5 SW OFF ON BL h 26.5 4 11.5 14.5 4 9.5 6 10.2 13 10 13 10 4.8-0.8 DIN 46244 A 19 Quick-connect terminal 4.8 vertical (shortened actuator) Quick-connect terminal 4.8 vertical (standard actuator) h 24 3.7 13 10 13 10.2 1.6±0.1 4.3 8 11 10.2 11 FOOT SWITCHES 14.5 14.5 4 4 14.3 6 19 ø10.5 PCB terminal vertical (actuator with holder for different caps) 5.95 6 TACT AND KEY SWITCHES h 8.9 11 13 5.95 4.5 2.6 1.5 2.5 PCB terminal 180° angled (shortened actuator) 4.5 5.7 1.1 4.4 1.6 13 10 7.3 3.7 ø10 19.8 h=24 2 3 2 19 19 10.8 4 0.8 ø1.6±0.1 3.7 1.1 11 3.7 11.2 13 10 0.8 14.5 9.5 2 14.5 25.3 4 h ø4 1 2.5 6 4.8 1.1 Quick-connect terminal 6.3 vertical (actuator with holder for different caps) SNAP-ACTION SWITCHES Quick-connect terminal 4.8 horizontal (shortened actuator without cut-out) 4.5 10.2 10 10 13 19 MICRO-SIGNAL SWITCHES 7.7 24 14.5 11 6.5 11.5 14.5 4 9.5 19 7.3 PCB terminal horizontal (shortened actuator without cout-out) SENSORS Quick-connect terminal 4.8 vertical (with mounted cap) POWER TOOL SWITCHES 7.3 19 Basic types 1682 and 1689 double-pole PUSHBUTTON SWITCHES Quick-connect terminal 4.8 horizontal (standard actuator) ROTARY SWITCHES Quick-connect terminal 4.8 horizontal (actuator with holder for different caps) TOGGLE SWITCHES 4.8-0.8 DIN 46244 A 11 11 13 10 7.7 10 13 6 7.7 19 Basic types 1682 and 1689 double-pole 26.5 14.5 14.5 4 4 9.5 19 95 | SERIES 1683 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES PRODUCT FE ATURES ON REQUEST  Million times proven, double lifting contact system  Other colors  High electrical rating up to 16 A  Printing  High rating with 100 000 mechanical switching cycles  Other lamp variants  Illuminated and non-illuminated variants  Other connection variants (e.g. 6.3 x 0.8 mm)  Snap-on customized actuators  Cable assembly FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 A 250 V AC  Variant with dust and water protection Mechanical life endurance 10E4 Operating force ca. 12 N ca. 8 N (basic type 1683) Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) | 96 Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 (actuator: V-0, socket: V-1, housing: V-2) Heat and fire resistance 850 °C (category D) Material PC PA / PA glass fiber-reinforced silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II SERIES 1683 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES Permissible total travel position (TP) in mm 20.85 19.7 1686.1304 230 z z z z 4.8 > 3 Ag 23.9 20.85 19.7 1683.1101 z z z z 4.8 > 3 Ag 23.9 20.85 19.7 1683.1701 z z z z 4.8 > 3 Ag 23.5 20.45 19.3 1683.1801 z z z z 4.8 > 3 Ag 23.5 20.45 19.3 z 4.8 horizontal > 3 Ag 23.5 20.45 19.3 ROCKER SWITCHES Operating position (OP) in mm 23.9 PUSHBUTTON SWITCHES Free position (FP) max. in mm Ag Stock version Contact material 3 Actuator description Contact distance mm > Miscellaneous Connection description 4.8 Connection type 12 A 125 - 250 V AC 1/2 HP z 12 (8) A 250 V AC 1E4 z z z 16 (4) A 250 V AC 1E4 230 Actuator color / printing 1686.1101 single-pole Voltage lamp in V 10 (8) A 250 V AC 5E4 TO 16 A 250 V AC z z z z 4.8 > 3 Ag 23.5 20.45 19.3 1683.3601 z z z z 4.8 horizontal > 3 Ag 23.5 20.45 19.3 snap-on actuator SLIDE SWITCHES 20.85 19.7 z 1684.1101 z z z z 4.8 > 3 Ag 23.9 20.85 19.7 z 1684.1104 z z z z 4.8 > 3 Ag 23.9 20.85 19.7 1684.1701 z z z z 4.8 > 3 Ag 23.5 20.45 19.3 1684.1801 z z z z 4.8 > 3 Ag 23.5 20.45 19.3 1684.2701 z z z z vertical > 3 Ag 23.5 20.45 19.3 20.85 19.7 Stock version 23.9 Actuator description Ag Connection type 3 12 (8) A 250 V AC 1E4 > 16 (4) A 250 V AC 1E4 4.8 Actuator color / printing z Voltage lamp in V z z z double-pole ON/OFF switch (DPST) 230 snap-on actuator MICRO-SIGNAL SWITCHES 1687.1104 snap-on actuator Normally open contact (DPNO) 1684.1201 z z z z 4.8 > 3 Ag 23.9 1684.1802 z z z z 4.8 > 3 Ag 23.5 < 20.45 19.3 POWER TOOL SWITCHES 1683.1802 FOOT SWITCHES z TACT AND KEY SWITCHES 19.7 SNAP-ACTION SWITCHES 20.85 Permissible total travel position (TP) in mm 23.9 Operating position (OP) in mm Ag Free position (FP) max. in mm 3 Contact material > Contact distance mm 4.8 Connection description z 12 A 125 - 250 V AC 1/2 HP z z z 10 (8) A 250 V AC 5E4 1683.1201 Miscellaneous Normally open contact (SPNO) ROTARY SWITCHES snap-on actuator z SENSORS z z z 1683.3101 z TOGGLE SWITCHES ON/OFF switch (SPST) 97 | SERIES 1683 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES 6.5 8 8 11 21 21 15 15 11 Quick-connect terminal 4.8 6.5 6.5 Quick-connect terminal 4.8 13 13 h 2 17 18 2 18 h X = Wall thickness 17 PUSHBUTTON SWITCHES TOGGLE SWITCHES Basic type 1683 single-pole non-illuminated 13 2 17 18 13 2 17 18 6.5 ROCKER SWITCHES TO 16 A 250 V AC 7.8 21 21 14 15 10 14 11 11 Quick-connect terminal 4.8 horizontal Quick-connect terminal 4.8 horizontal 2 13 2 17 11 8 18 8 FOOT SWITCHES 18 13 17 6.9 6.5 15 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 10 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 ROTARY SWITCHES SLIDE SWITCHES 7.8 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 11 Quick-connect terminal 4.8 1684.1101, 1684.1104, 1684.1201, basic types 1687 and 1686 6.5 Basic types 1684,1686 and 1687 single and double-pole illuminated / non-illuminated 13 h 6.5 17 18 0.8 4 0.7 2 1.1 8 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 10.2 11 1.6±0.1 21 15 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 17 18 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Quick-connect terminal 4.8 basic type 1684 3.7 7.3 PCB terminal vertical 1684.2701 Transparent PVC-protection cap for dust and water protection from the actuation side MICRO-SIGNAL SWITCHES 19.8 25.8 SENSORS | 98 Quick-connect terminal 4.8 basic type 1684 X = Wall thickness SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 15 21 Protection cap 203.701.011 8.6 SERIES 1691 - SMALLEST SINGLE-POLE PUSHBUTTON SWITCHES PRODUCT FE ATURES ON REQUEST  Small compact pushbutton switch for indirect actuation  For network applications  High rating with 100 000 mechanical cycles  Different operating force ROCKER SWITCHES FOR LOW VOLTAGES PUSHBUTTON SWITCHES  Customized actuators 10E4 6.0 +1.0 N connection side -25 °C ... +70 °C Material PA PA silver-plated ROTARY SWITCHES < 23.9 22.5 3 Ag with strip without interference suppression capacitor 2 x 4.8 x 0.8 2 x 2.8 x 0.8 2 x M3.5 > 3 Ag with strip without interference suppression capacitor without approval mark Connection type PUSHBUTTON SWITCHES Contact material z Stock version Contact distance in mm z Connection description 8 A 125 V DC z 14 A 125 V AC z 6 (6) A 250 V AC 5E4 1246.3101 double-pole 8 (8) A 250 V AC 5E4 8 A 250 V AC ROCKER SWITCHES TO 8 ( 8 ) A 250 V AC Changeover switch (DPDT momentary) Quick-connect terminal motor side, quick-connect terminal additional connection, screw connection mains side, 1246.3201 ø5 22.5 2 2 22.5 32 4.8-0.8 26 35.7 M3.5 6 11.1 M3.5 29 Quick-connect terminal motor side, quick-connect terminal additional connection, screw connection mains side, 1246.6201 FOOT SWITCHES 25 26 29 Quick-connect terminal motor side, screw connection mains side with interference suppression capacitor 1246.3101 SNAP-ACTION SWITCHES 15 6 11.1 10 2 MICRO-SIGNAL SWITCHES Basic type 1246 2.8-0.8 4.8-0.8 POWER TOOL SWITCHES 7.3 M3.5 SENSORS 22 26 4.8-0.8 2.8-0.8 1.5 2 2 21 23 15 11.1 6 15 2 10.6 21.4 ø5 10 TACT AND KEY SWITCHES ø5 10 21 z 1.5 1246.6201 ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES Normally open contact (DPNO) 101 | SERIES 1247 - DOUBLE-POLE PUSHBUT TON SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 7 A 250 V AC PRODUCT FE ATURES ON REQUEST  Powerful single and double-pole pushbutton switch up to 10 A 125 V AC  Other connection types  Optionally with fastening strip and interference suppression capacitor ROTARY SWITCHES  Support point terminal (single-pole normally open contact)  Dust-protected SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Mechanical life endurance | 102 Actuator Material 1E5 IP 40 actuator housing PA glass fiber-reinforced Desmopan / PA glass fiber-reinforced Interference suppressor C = 0.22 μF 275 V AC (product-dependent) Approval marks 3 /1/2 Suitable for appliances of protection class II SLIDE SWITCHES 1247.0301 z z z 4 x 2.8 x 0.8 2 x M3.5 > 3 Ag with strip z 4 x 2.8 x 0.8 2 x M3.5 > 3 Ag without strip 1247.2301 z z z 4 x 2.8 x 0.8 2 x M3.5 > 3 Ag with strip 1247.2501 z z z 2 x 2.8 x 0.8 2 x M3.5 Torx 2 x cut terminal > 3 Ag with strip and interference suppression capacitor TOGGLE SWITCHES without strip ROTARY SWITCHES Ag FOOT SWITCHES Miscellaneous 3 POWER TOOL SWITCHES Contact material > Stock version Contact distance in mm 4 x 2.8 x 0.8 2 x M3.5 TACT AND KEY SWITCHES z Connection description z SNAP-ACTION SWITCHES z Connection type z PUSHBUTTON SWITCHES Stock version ROCKER SWITCHES Connection description Connection type 5 A 250 V AC 10 A 125 V AC 7 (7) A 250 V AC 5E4 z MICRO-SIGNAL SWITCHES Miscellaneous 1247.2102 5 A 250 V AC Normally open contact (SPNO) 1247.0102 SENSORS Contact material Normally open contact (DPNO) Contact distance in mm double-pole 10 A 125 V AC single-pole 7 (7) A 250 V AC 5E4 SERIES 1247 - DOUBLE-POLE PUSHBUT TON SWITCHES TO 7 A 250 V AC 103 | SERIES 1247 - DOUBLE-POLE PUSHBUT TON SWITCHES 24 24 ø5 9.4 2.8-0.8 ø5 27 29.2 19.5 SLIDE SWITCHES 9.4 2.8-0.8 25 ROTARY SWITCHES M3.5 TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Quick-connect terminal motor side, screw connection mains side without strip 1247.2102 and 1247.0102 SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 104 27 29.2 25 M3.5 Quick-connect terminal motor side, screw connection mains side (Torx), cut terminal additional connection for capacitor, 1247.2501 24 19.5 29.2 19.5 25 M3.5 Basic type 1247 ø5 9.4 27 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 7 A 250 V AC Further information under WWW.MARQUARDT.DE Quick-connect terminal motor side, screw connection mains side with strip 1247.0301 and 1247.2301 SERIES 5000 - ROUND PUSHBUT TON SWITCHES  Attractive, round pushbutton switch  Other colors  Efficient contact system at least 200 000 mechanical switching cycles  Actuator printing  Variants with sealing cap for IP 54 dust and water protection  Cable assembly  Snap fastening for greater wall thickness  Appliance cut-out with diameter 16 mm, alternatively with fixing pin IP 40 IP 54 (in variants with sealing cap) Ambient temperature connection side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA glass fiber-reinforced PA glass fiber-reinforced silver-plated actuator housing connections Type of fastening snap fastening material thickness 1.4 - 1.7 Plug force of the terminals < Approval marks 3 64 N /1/2 Suitable for appliances of protection class II POWER TOOL SWITCHES Protection type TACT AND KEY SWITCHES acc. to EN 61058 for reinforced or double insulation SNAP-ACTION SWITCHES 250 PTI Insulation spacing MICRO-SIGNAL SWITCHES Proof tracking FOOT SWITCHES 20E4 SENSORS Mechanical life endurance SLIDE SWITCHES ON REQUEST ROTARY SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES FOR AT LEAST 200 000 MECHANICAL SWITCHING CYCLES 105 | SERIES 5000 - ROUND PUSHBUT TON SWITCHES Connection description Contact distance in mm Contact material Pretravel max. in mm Total travel / stroke in mm z 2.8 > 3 Ag 2.0 + 0.4 4.0 z 5000.0103 z z z 2.8 > 3 Ag 2.0 + 0.4 4.0 z 5000.0104 z z z 2.8 > 3 Ag 2.0 + 0.4 4.0 z 5000.0212 z z z 2.8 > 3 Ag 2.0 + 0.4 4.0 5000.0501 z z z 2.8 > 3 Ag 2.0 + 0.4 4.0 Stock version PUSHBUTTON SWITCHES Miscellaneous 2 A 250 V AC 1/10 HP z Connection type 4 A 125 V AC 1/10 HP z single-pole Housing color 5000.0101 Actuator color / printing 4 (2) A 250 V AC 5E4 ROCKER SWITCHES FOR AT LEAST 200 000 MECHANICAL SWITCHING CYCLES ø20 ø11 Quick-connect terminal 2.8 (with fixing pin and IP 54 sealing cap), 5000.0501 21.5 10 Ø 16.0 +0.05 4 8 7.2 X 1.4 ... 1.7 ø16+0.05 6.2 ø17 11±0.05 ø20 ø21 Quick-connect terminal 2.8 5000.0101, 5000.0103 and 5000.0104 11±0.05 R 4 2.4+0.1 ø16+0.05 10 7.2 7.2 8 21.5 17.8±0.1 ø21 X = Wall thickness 6.2 1.3-0.15 2.4±0.1 ø16+0.05 R 12.2 6.2 10 FOOT SWITCHES POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS ø17 4 Basic type 5000 | 106 with IP 54 sealing cap ø20 21.5 ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES Normally open contact (SPNO) 17.8±0.1 ø21 Quick-connect terminal 2.8 (with fixing pin) 5000.0212 SERIES 1846 - SINGLE-POLE PUSHBUT TON SWITCHES ON REQUEST  Small, compact pushbutton switch  Other colors  Long life endurance with 500 000 mechanical switching cycles  With printing  Special design for dust and water protection  Cable assembly Mechanical life endurance 50E4 Operating force ca. 1 N < 4.0 N (1846.0204) Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) FOOT SWITCHES ROTARY SWITCHES  Other connection variants SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 2 (1) A 250 V AC acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Surface terminal outlet silver-plated Plug force of the terminals < Approval marks 3 80 N Suitable for appliances of protection class II TACT AND KEY SWITCHES 250 PTI Insulation spacing SNAP-ACTION SWITCHES Proof tracking MICRO-SIGNAL SWITCHES 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance SENSORS Voltage strength at 250 V POWER TOOL SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) 107 | SERIES 1846 - SINGLE-POLE PUSHBUT TON SWITCHES z 1846.2201 z 3 Ag z z z 4.8 > 3 Ag z 4.8 > 3 Ag z 4.8 > 3 Ag z z Contact distance in mm Normally open contact (SPNO) z z Connection description z Connection type 1843.1201 z 6 A 125 - 250 V AC 1/8 HP z 6 A 125 V AC 1/4 HP 1841.1201 6 A 250 V AC 1/2 HP SLIDE SWITCHES 1841.1301 6 (2) A 250 V AC 5E4 ROTARY SWITCHES 1843.1101 6 (4) A 250 V AC 5E4 Housing color FOOT SWITCHES single-pole Actuator color / printing TACT AND KEY SWITCHES SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 6 (4) A 250 V AC z z Normally closed contact (SPNC) z z SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (4) A 250 V AC PUSHBUTTON SWITCHES 15.6 23 8.4 M12x0.75 ø8 7 7 23.9 16.6 23.9 M12x0.75 SLIDE SWITCHES 23 12.7 19.9 ø8 TOGGLE SWITCHES Quick-connect terminal 4.8 10.2 25.6 7 Basic type 1842 double-pole 4.8-0.8 Quick-connect terminal 4.8 Identification plate of aluminum for plugging on with black inscription “ON” and “OFF” 28 FOOT SWITCHES ON ROTARY SWITCHES Basic types 1841 and 1843 single-pole OFF Identification plate of CuZn nickelplated for plugging on as well as with twist protection and stamped inscription “ON” and “OFF” 26 ON TACT AND KEY SWITCHES Identification plate 240.001.011 POWER TOOL SWITCHES 16.5 Neopren® - cap for pushbutton (M12 x 0.75) basic type 1840 as dust and water protection. Pushbutton plate on top of cap is CuZn nickelplated. 20 14 ø 22 MICRO-SIGNAL SWITCHES Identification plate 240.002.011 SNAP-ACTION SWITCHES OFF Protection cap 343.002.023 SENSORS SW 19 111 | SERIES 1840 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 6 (4) A 250 V AC ø 20 Pushbutton 205.008.011 Pushbutton of PA black, rectangular 20 x 25 mm for assembly by customer on 1841.6101 and 1842.6101 25 SLIDE SWITCHES 11.5 TOGGLE SWITCHES PUSHBUTTON SWITCHES 11.5 ROCKER SWITCHES Pushbutton of PA black, with diameter 20 mm for assembly by customer on 1841.6101 and 1842.6101 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES 20 Pushbutton 203.106.011 | 112 Further information under WWW.MARQUARDT.DE SERIES 1660 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES ON REQUEST  Illuminated and non-illuminated pushbutton switch  Other colors  Proven jump contact switching system (double interrupting)  Other printing variants  Opening and closing speed independent of the actuating speed  Other lamp variants 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA / PC (product-dependent) PA / PA glass fiber-reinforced (product-dependent) Cu / silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II FOOT SWITCHES Voltage strength at 250 V POWER TOOL SWITCHES < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) TACT AND KEY SWITCHES Contact resistance (new condition) SNAP-ACTION SWITCHES 5E4 MICRO-SIGNAL SWITCHES Mechanical life endurance ROTARY SWITCHES  Cable assembly SENSORS  Product-dependent with external lamp connection  Other connection types SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 (4) A 250 V AC 113 | SENSORS | 114 TACT AND KEY SWITCHES POWER TOOL SWITCHES 1660.0201 230 z 6.3 > 3 Ag z 1660.0202 230 z 6.3 > 3 Ag z 1660.0203 230 z 6.3 > 3 Ag 1660.3202 230 z 6.3 / 2 x 4.8 > 3 Ag 1660.0222 110 6.3 > 3 Ag 1661.0201 6.3 > 3 Ag 1661.0220 6.3 > 3 Ag z z z z z TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES z 6.3 / 2 x 4.8 > 3 Ag external lamp connection 1665.3102 230 z 6.3 / 2 x 4.8 > 3 Ag external lamp connection 1662.0201 z 6.3 > 3 Ag 1662.0203 z 6.3 > 3 Ag 1662.0101 z 6.3 > 3 Ag 1662.0102 z 6.3 > 3 Ag 4.8 3 Ag z 1670.5202 230 z 6.3 > 3 Ag z 1670.5204 230 z 6.3 > 3 Ag 1670.5304 230 z 6.3 / 2 x 4.8 > 3 Ag 1670.5203 115 230 z 6.3 > 3 Ag 1671.5201 z 6.3 > 3 Ag 1671.5203 z 6.3 > 3 Ag 1671.5101 z 6.3 > 3 Ag 1671.5104 z 6.3 > 3 Ag ROTARY SWITCHES > 3 Ag 4.8 PUSHBUTTON SWITCHES Stock version ROCKER SWITCHES Connection description Connection type 12 (4) A 250 V AC 1E4 16 (4) A 250 V AC 1E4 Housing color Actuator description Contact material z Contact distance in mm Switch (SPDT) 6.3 / 2 x 4.8 SNAP-ACTION SWITCHES 230 Connection type 1673.5501 12 (4) A 250 V AC 1E4 1672.5101 16 (4) A 250 V AC 1E4 Normally open contact (SPNO) z MICRO-SIGNAL SWITCHES 1670.5201 Housing color 230 SENSORS Contact material Normally open contact (SPNO) Contact distance in mm ON/OFF switch (SPST) Connection description double-pole Actuator description 1675.5315 Voltage lamp in V single-pole Voltage lamp in V SERIES 1670 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 16 (4) A 250 V AC cover gray 119 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES Lamp | 120 ROCKER SWITCHES Lamp 1677.5306 230 6.3 1677.5307 115 230 6.3 1677.5308 115 230 6.3 Further information under WWW.MARQUARDT.DE Stock version Miscellaneous Contact material Contact distance in mm Connection description Connection type 12 (4) A 250 V AC 1E4 16 (4) A 250 V AC 1E4 Housing color Actuator description Voltage lamp in V PUSHBUTTON SWITCHES SERIES 1670 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES TO 16 (4) A 250 V AC SERIES 1670 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES 13.65 29.5 21.8 Quick-connect terminal 6.3 / 2 x 4.8 external lamp connection basic type 1675 4.5 22.5 16 SLIDE SWITCHES 33 Z 22.2 +0.15 8.2 18.6 Quick-connect terminal 6.3 basic type 1672 4.5 FOOT SWITCHES 29.5 16.4 21.8 Quick-connect terminal 6.3 basic types 1670 and 1671 POWER TOOL SWITCHES 2.6 22.5 35.85 33 4.5 18.6 21.8 TACT AND KEY SWITCHES Z 22.2 +0.15 13.7 29.5 SNAP-ACTION SWITCHES Y 30.0 +0.15 18.6 Quick-connect terminal 6.3 / 2 x 4.8 chromated external lamp connection 1670.5304 25 16 MICRO-SIGNAL SWITCHES X 0.8 ... 5.0 33 22 SENSORS X = Wall thickness 25 16 22.5 33 2.6 33 22 ROTARY SWITCHES 21.8 29.5 Basic types 1670 and 1671 double-pole illuminated / non-illuminated PUSHBUTTON SWITCHES 18.6 TOGGLE SWITCHES 4.5 16.4 25 22 2.6 35.95 33 22.5 2.6 2.6 16 Quick-connect terminal 4.8 1673.5501 X = Wall thickness Y 30.0 +0.15 25 22 21.8 33 X 0.8 ... 5.0 33 4.8 29.5 Basic types 1672, 1673 and 1675 single-pole illuminated / non-illuminated 25 16 22.5 33 33.7 4.5 33 22 ROCKER SWITCHES TO 16 (4) A 250 V AC 121 | SERIES 1670 - SINGLE AND DOUBLE-POLE PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 (4) A 250 V AC 0.9 2.6 22.5 33 PUSHBUTTON SWITCHES TOGGLE SWITCHES 16 18.6 12.8 29.5 21.8 Quick-connect terminal 6.3 Basic type 1677 Lamp X = Wall thickness X 0.8 ... 5.0 Y 30 +0.15 Z 22.2 +0.15 Dummy piece for size of basic type 1677 of PA with housing in black and cover in blue FOOT SWITCHES 22.5 2.6 ROTARY SWITCHES SLIDE SWITCHES 25 33 22 29.5 33 Dummy piece 203.020.013 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES 25 21.8 | 122 Further information under WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES TOGGLE SWITCHES SENSORS SENSORS 123 | PUSHBUTTON SWITCHES ROCKER SWITCHES TOGGLE SWITCHES SERIES 0350 Three-pole toggle switches to 10 (4) A 400 V AC SERIES 1810 SLIDE SWITCHES TOGGLE SWITCHES Single and double-pole toggle switches Appliance cut-out: Ø 12 mm or 19.2 x 12.9 mm 19.2 x 21.9 mm SERIES 1820 Single and double-pole toggle switches ROTARY SWITCHES Ø 12 mm or 19.2 x 12.9 mm 19.2 x 21.9 mm to 2 A 250 V AC Appliance cut-out: Ø 12 mm SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Single-pole toggle switches MICRO-SIGNAL SWITCHES PAGE 129 - 132 to 6 (4) A 250 V AC SERIES 0100 SENSORS PAGE 126 - 128 to 10 (4) A 250 V AC Appliance cut-out: | 124 PAGE 125 Further information under WWW.MARQUARDT.DE PAGE 133 - 134 SERIES 0350 - THREE-POLE TOGGLE SWITCHES PRODUCT FE ATURES ON REQUEST  Robust and efficient toggle switch with 100 000 mechanical switching cycles  Other connection types ROCKER SWITCHES TO 10 (4) A 400 V AC PUSHBUTTON SWITCHES  With dust seal 10E4 Material Duroplast Duroplast / PA glass fiber-reinforced chromated actuator housing connections SLIDE SWITCHES Mechanical life endurance TOGGLE SWITCHES  Approval for 400 V 3 Approval marks M3.5 > 3 Ag lever with red dot 3 auxiliary terminals 48.5 30.5 36 8 30 4.5 22 M4 30 Basic type 0350 M3.5 Socket terminal M3.5 28 FOOT SWITCHES z POWER TOOL SWITCHES 0350.2101 TACT AND KEY SWITCHES z SNAP-ACTION SWITCHES Stock version lever with red dot MICRO-SIGNAL SWITCHES Miscellaneous Ag ON/OFF switch (TPST) SENSORS Contact material 3 Connection description > Connection type M3.5 10 (4) A 400 V AC 5E4 z Housing color 0350.0101 three-pole Actuator color / printing Contact distance in mm ROTARY SWITCHES Suitable for appliances of protection class II 125 | SERIES 1810 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES PRODUCT FE ATURES ON REQUEST  Attractive toggle switches  Other colors  100 million times proven switching principle  Other printing variants  Long life endurance with 100 000 mechanical switching cycles  Other switching functions  Excellent actuating characteristic  Cable assembly  Other connection variants SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 (4) A 250 V AC | 126 Mechanical life endurance 5E4 (changeover switch with OFF position in center) 10E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II Ag 1818.1202 z z 4.8 < 3 Ag momentary function one side z 1818.1302 z z 4.8 < 3 Ag momentary function both sides z 1818.2302 z z 3 Ag > 3 Ag 1819.1102 z z 4.8 < 3 Ag 1819.1302 z z 4.8 < 3 Ag momentary function both sides Connection type 4 A 250 V AC 1/10 HP 6 A 125 V AC 1/10 HP 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 4 (2) A 250 V AC 1E4 6 (2) A 250 V AC 1E4 6 (4) A 250 V AC 5E4 10 (4) A 250 V AC 1E4 Housing color Ag 4.8 > 3 Ag z z z z z TOGGLE SWITCHES PUSHBUTTON SWITCHES Stock version ROCKER SWITCHES 3 SLIDE SWITCHES > z ROTARY SWITCHES 4.8 Miscellaneous Ag POWER TOOL SWITCHES Switch with OFF position in the center (SPDT - Center OFF) 3 TACT AND KEY SWITCHES Switch (SPDT) > SNAP-ACTION SWITCHES Stock version z z Contact material z z 4 A 250 V AC 1/10 HP z z Contact distance in mm z z 6 A 125 V AC 1/10 HP z Connection description z z 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/4 HP z z 6 A 250 V AC 1/2 HP 4 (2) A 250 V AC 1E4 1811.1202 FOOT SWITCHES 4.8 < 3 6 (2) A 250 V AC 1E4 Normally open contact (SPNO) 4.8 MICRO-SIGNAL SWITCHES 1814.2102 z z SENSORS 1812.1102 z z Contact material z 6 (4) A 250 V AC 5E4 1813.1102 10 (4) A 250 V AC 1E4 1811.1102 Contact distance in mm z Housing color ON/OFF switch (SPST) Connection description 1818.1102 Miscellaneous double-pole Actuator color / printing single-pole Actuator color / printing SERIES 1810 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES TO 10 (4) A 250 V AC Switch with OFF position in the center (DPDT - Center OFF) 127 | SERIES 1810 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES ROCKER SWITCHES TO 10 (4) A 250 V AC 21 21 15 3.6 9.8 3.6 9 2 2 15 7 13 18.5 13 Quick-connect terminal 4.8 basic types 1813 and 1811 without third connection 15 21 3.6 9.8 2 9 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 13.2 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 3.5 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 2 SLIDE SWITCHES 14 X = Wall thickness 7 18.6 Quick-connect terminal 4.8 basic type 1818 Basic types 1811, 1813 and 1818 single-pole 11.7 18 2 13.2 20.5 19.5 2 7 TOGGLE SWITCHES PUSHBUTTON SWITCHES 14 14 9 0.8 7.5 0.8 7.5 13 18.5 ROTARY SWITCHES PCB terminal basic type 1818 21 24 21 3.6 2 15 2 24 18.6 22 Quick-connect terminal 4.8 basic type 1812 3.6 2 X = Wall thickness 24 15 Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 11.7 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 3.5 14 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 0.8 7.5 10.2 18.6 PCB terminal basic type 1814 22 22 Quick-connect terminal 4.8 basic type 1819 21 2 POWER TOOL SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS 10.2 10.2 18.6 Basic types 1812, 1814 and 1819 double-pole 20.5 7 7 | 128 18 2 11.7 2 FOOT SWITCHES 14 14 13.2 15 SERIES 1820 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES ON REQUEST  100 million times proven switching principle  Other colors  Long life endurance with 50 000 mechanical switching cycles  Other switching functions  Excellent actuating characteristic  Cable assembly  Other connection variants SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (4) A 250 V AC 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA glass fiber-reinforced / PA silver-plated actuator housing connections Plug force of the terminals < Approval marks 3 80 N /1/2 Suitable for appliances of protection class II POWER TOOL SWITCHES Voltage strength at 250 V TACT AND KEY SWITCHES < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) SNAP-ACTION SWITCHES Contact resistance (new condition) MICRO-SIGNAL SWITCHES 5E4 SENSORS Mechanical life endurance FOOT SWITCHES ROTARY SWITCHES  Fastening with nut M12 129 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES | 130 POWER TOOL SWITCHES double-pole FOOT SWITCHES ROTARY SWITCHES z z z 1822.1101 1824.1101 Switch (SPDT) Switch with OFF position in the center (SPDT - Center OFF) 3 Ag z > 3 Ag z z 1829.1101 z 4.8 3 Ag z z Stock version z Contact material 1821.6101 Contact distance in mm z Connection description 6 A 125 V AC 1/4 HP z Actuator color / printing 6 A 250 V AC 1/2 HP ROCKER SWITCHES z Connection type 1823.6101 6 A 125 V AC 1/4 HP z 6 A 250 V AC 1/2 HP 1823.1101 6 (2) A 250 V AC 1E4 PUSHBUTTON SWITCHES 1821.1101 Contact distance in mm 4.8 6 (4) A 250 V AC 5E4 TOGGLE SWITCHES ON/OFF switch (SPST) Connection description z Housing color SLIDE SWITCHES single-pole Actuator color / printing 1828.1101 Miscellaneous TACT AND KEY SWITCHES SERIES 1820 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES TO 6 (4) A 250 V AC z SERIES 1820 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES M12x0.75 M12x0.75 ø4 7 7 7 16.6 23.9 Quick-connect terminal 4.8 basic type 1828 Quick-connect terminal 4.8 basic types 1821 and 1823 TOGGLE SWITCHES Basic types 1821, 1823 and 1828 single-pole 16.6 23.9 PUSHBUTTON SWITCHES 23 24 21.5 8.9 8.9 22.9 22.9 ø4 ROCKER SWITCHES TO 6 (4) A 250 V AC M12x0.75 16.6 23.9 Solder terminal 1821.6101 and 1823.6101 M12x0.75 M12x0.75 FOOT SWITCHES 8.9 21.5 7 10.2 23.9 25.6 Quick-connect terminal 4.8 basic type 1829 23.9 4.8x0.8 10.2 25.6 Quick-connect terminal 4.8 basic types 1822 and 1824 Identification plate of aluminum for plugging on with black inscription “ON” and “OFF” 28 ON OFF 16.5 Identification plate 240.001.011 Identification plate of CuZn nickelplated for plugging on as well as with twist protection and stamped inscription “ON” and “OFF” 26 ON POWER TOOL SWITCHES Basic types 1822, 1824 and 1829 double-pole 7 TACT AND KEY SWITCHES 24 23 8.9 22.9 22.9 ø4 SNAP-ACTION SWITCHES ø4 MICRO-SIGNAL SWITCHES 7 ROTARY SWITCHES 19.6 SLIDE SWITCHES 8.9 22.9 ø4 Identification plate 240.002.011 SENSORS OFF 131 | SERIES 1820 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES Neopren® - cap for screwing on (M12 x 0.75) to levers of the series 1820 for dust and water protection of the actuator side 24.5 6.5 7 Protection cap 343.001.013 - green 343.001.023 - black 343.001.033 - red 9.5 24.5 ø8.5 ø17 15 ø 6.4 Lever receptacle 203.105.011 - black 203.105.021 - white 203.105.031 - red 203.105.041 - green ø 5.2 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES 1.15 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (4) A 250 V AC | 132 Further information under WWW.MARQUARDT.DE Lever receptacle in various colors for the plastic levers of the 1820 series for customer assembly. Serves as a design element and for distinguishing and marking. SERIES 0100 - SINGLE-POLE TOGGLE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 2 A 250 V AC ON REQUEST  Robust and powerful toggle switch with 50 000 mechanical switching cycles  Other connection variants SLIDE SWITCHES PRODUCT FE ATURES  Central fastening with nut M12 Mechanical life endurance 5E4 Material metal / PA (product-dependent) Duroplast (base) / chromated galvanized steel (bracket plate) silver-plated SNAP-ACTION SWITCHES Stock version 0100.1201 0100.2901 z z > CuZn silver-plated actuating torque 45.0 +14.0 Nmm z 3 CuZn silver-plated actuating torque 45.0 +14.0 Nmm metal lever > z MICRO-SIGNAL SWITCHES Miscellaneous 3 ON/OFF switch (SPST) SENSORS Contact material Contact distance in mm Contact material 2 A 250 V 1E4 Housing color single-pole Actuator description TACT AND KEY SWITCHES POWER TOOL SWITCHES actuator housing connections FOOT SWITCHES ROTARY SWITCHES  Metal or plastic lever 133 | SERIES 0100 - SINGLE-POLE TOGGLE SWITCHES 12.5 ø4.5 3 1.7 15.5 10 M12x0.75 12.5 23.5 ø2.1 30 Solder terminal Basic type 0100 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 2 A 250 V AC Identification plate of aluminum for plugging on with black inscription “ON” and “OFF” OFF 16.5 Identification plate 240.001.011 Identification plate of CuZn nickelplated for plugging on and with twist protection and stamped inscription “ON” and “OFF” ON 26 OFF Identification plate 240.002.011 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES 28 ON | 134 Further information under WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES SLIDE SWITCHES SENSORS SENSORS 135 | PUSHBUTTON SWITCHES ROCKER SWITCHES SLIDE SWITCHES SERIES 4021 Double and four-pole slide switches to 10 A 125 V or 5 A 250 V AC (as voltage selector switch) SERIES 1205 TOGGLE SWITCHES Double-pole slide switches PAGE 141 to 10 (6) A 250 V AC SERIES 1206 Single-pole slide switches PAGE 142 - 143 to 8 (8) A 250 V AC ROTARY SWITCHES SLIDE SWITCHES PAGE 137 - 140 SERIES 0140 to 2 A 250 V AC SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Double-pole slide switches | 136 Further information under WWW.MARQUARDT.DE PAGE 144 - 145 SERIES 4021 - DOUBLE AND FOUR-POLE SLIDE SWITCHES ON REQUEST  Different designs  Other colors  Various connection types  Other labels  Suitable as voltage selector switch (for currentless switching)  Single to four-pole variants  Other connection variants (e.g. PCB side) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 250 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Heat and fire resistance 850 °C (category D) Material PA PA / hard paper (baseplate) / PA glass fiber-reinforced (baseplate) silver-plated / chromated actuator housing connections Plug force of the terminals < Approval marks 4 60 N /1/2 POWER TOOL SWITCHES < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) TACT AND KEY SWITCHES Contact resistance (new condition) SNAP-ACTION SWITCHES 1E4 MICRO-SIGNAL SWITCHES Mechanical life endurance SENSORS  Simple assembly with screws FOOT SWITCHES ROTARY SWITCHES  Sunken slide for protection against accidental actuation SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 A 125 V OR 5 A 250 V AC (AS VOLTAGE SELECTOR SWITCH ) 137 | SERIES 4021 - DOUBLE AND FOUR-POLE SLIDE SWITCHES z z z 4021.4420 z z z z z z z PUSHBUTTON SWITCHES Stock version z Miscellaneous 4021.0512 Contact material z Contact distance in mm z Connection description z Connection type 5 A 250 V DC z 2 A 42 V AC 1E4 10 A 125 V DC 2 (0.5) A 250 V AC 1E4 5 A 250 V AC 1E4 4021.0203 double-pole Housing color 10 A 125 V AC 1E4 Actuator color / printing ROCKER SWITCHES TO 10 A 125 V OR 5 A 250 V AC (AS VOLTAGE SELECTOR SWITCH ) SLIDE SWITCHES TOGGLE SWITCHES Switch (DPDT) ROTARY SWITCHES 3 CuSn 5 A or 10 A only as voltage selector switch silver-plated slide with actuating slot z > 3 CuSn 5 A or 10 A only as voltage selector switch silver-plated slide with actuating slot z z > 3 CuSn 5 A or 10 A only as voltage selector switch silver-plated z z z > 3 CuSn 5 A or 10 A only as voltage selector switch silver-plated slide with actuating slot z z z > 3 CuSn 5 A or 10 A only as voltage selector switch silver-plated slide with actuating slot z 2.8 230V 4021.4620 230V 4021.4723 4021.0101 4021.0801 z CuSn >3 silver-plated z z CuSn >3 silver-plated z 2.8 4021.2202 z 5 long > 3 Cu 4021.2203 z 5 long > 3 Cu Switch with OFF position in the center (DPDT - Center OFF) 4021.1202 z 5 long > 3 CuSn silver-plated 4021.1203 z 5 long > 3 CuSn silver-plated SENSORS MICRO-SIGNAL SWITCHES | 138 Stock version Miscellaneous Contact material Contact distance in mm Connection description Connection type 5 A 250 V DC 10 A 125 V DC 2 A 42 V AC 1E4 2 (0.5) A 250 V AC 1E4 5 A 250 V AC 1E4 10 A 125 V AC 1E4 Housing color four-pole Actuator color / printing SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES > Switch (FPDT) 4024.0201 z 4024.0501 z 4024.4601 z 2.8 > 3 CuSn silver-plated slide with actuating slot > 3 CuSn silver-plated slide with actuating slot > 3 CuSn silver-plated slide with actuating slot z SERIES 4021 - DOUBLE AND FOUR-POLE SLIDE SWITCHES 34 16.5 18.5 0.8 8 17.6 TOGGLE SWITCHES Quick-connect terminal 2.8 4021.0512 and 4021.0801 41 41 16.5 2 8 26.2 R5 4 8 16 14 2 11.5 11.5 16.5 34 1.5 34 26.2 1.3 x 0.8 7 1 8 4 0.8 8 17.6 Solder terminal 4021.0203 and 4021.0101 PCB terminal Slide with actuating slot 4021.4420 and 4021.4620 11.5 17 11.5 34 2 41 7 26.2 11.5 1.3 x 0.8 Solder terminal 4024.0201 TACT AND KEY SWITCHES Quick-connect terminal 2.8 4024.0501 4 7 MICRO-SIGNAL SWITCHES PCB terminal 4024.4601 SNAP-ACTION SWITCHES 21 SENSORS Basic type 4024 four-pole POWER TOOL SWITCHES 30 3.3 2.8 x 0.8 SLIDE SWITCHES Wire-wrap 5 long 4021.2202, 4021.2203, 4021.1202 and 4021.1203 ROTARY SWITCHES Basic type 4021 double-pole FOOT SWITCHES 1.4 2.8 1.5-0.8 2.4 26.2 4 8 16.5 2 11.5 11.5 8 4 26.2 11.5 11.5 16.5 PUSHBUTTON SWITCHES 41 ROCKER SWITCHES TO 10 A 125 V OR 5 A 250 V AC (AS VOLTAGE SELECTOR SWITCH ) 139 | SERIES 4021 - DOUBLE AND FOUR-POLE SLIDE SWITCHES 4021.0203 Inscription SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 A 125 V OR 5 A 250 V AC (AS VOLTAGE SELECTOR SWITCH ) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES 4021.4724 | 140 Further information under WWW.MARQUARDT.DE 4021.4620 SERIES 1205 - DOUBLE-POLE SLIDE SWITCHES PRODUCT FE ATURES ON REQUEST  Double-pole changeover switch  Other colors ROCKER SWITCHES TO 10 ( 6 ) A 250 V AC  Powerful up to 15 A 5E4 Material PA PA / PA glass fiber-reinforced silver-plated actuator housing connections SLIDE SWITCHES Mechanical life endurance TOGGLE SWITCHES PUSHBUTTON SWITCHES  Dust protected with felt gasket 3 Approval marks z z Ag 26.5 26.5 18.5 14 5 4.5 17.6 7.5 24.4 20 Screw connection M3.5 1205.0101 23.5 M3.5 20 Screw connection M3.5 1205.0304 without collar SNAP-ACTION SWITCHES M3.5 14 MICRO-SIGNAL SWITCHES Basic type 1205 14.6 3 29.5 18.5 5 1.5 23.5 z FOOT SWITCHES M3.5 SENSORS 1205.0101 24.4 1205.0304 POWER TOOL SWITCHES Ag Switch (DPDT) TACT AND KEY SWITCHES Contact material M3.5 Stock version Connection description Connection type 10 (6) A 250 V AC 1E4 15 A 125 AC Housing color double-pole Actuator color / printing ROTARY SWITCHES Suitable for appliances of protection class II 141 | SERIES 1206 - SINGLE-POLE SLIDE SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 8 ( 8 ) A 250 V AC PRODUCT FE ATURES ON REQUEST  Powerful up to 25 A at 12 - 36 V DC  Other colors  Single-pole slide switch optionally with fastening strip  Other connection types  For snapping on customized slides  For direct and indirect actuation ROTARY SWITCHES  Dust protected  Castable SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Mechanical life endurance | 142 Actuator Material Approval marks 1E5 IP 40 actuator housing connections PA glass fiber-reinforced PA glass fiber-reinforced silver-plated 3 /1/2 Suitable for appliances of protection class II SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES 17.5 18.3 Solder terminal 1206.0201 Further information under WWW.MARQUARDT.DE 1.3 17.5 ø1.6+0.1 1 Miscellaneous 3 Ag with slide for direct actuation 1206.2503 z z z z > 3 Ag with slide for direct actuation ø2+0.2 12.4±0.2 25.3 23.3 5±0.1 TOGGLE SWITCHES Contact material > 20±0.2 SLIDE SWITCHES Contact distance in mm z 3.7±0.1 15 A 125 V AC z 11±0.2 5 ST 1.6+0.1 25 A 12 - 36 V DC z ROTARY SWITCHES 4.8 3.5 8 A 250 V AC z MICRO-SIGNAL SWITCHES 23.3 25.3 12.5 3.7 13 15.6 6.8 5 ST 19.4 2 1 12.5 5.9 1206.0201 SENSORS Basic type 1206 15.6 19.4 ON/OFF switch (SPST) 8 (8) A 250 V AC 5E4 single-pole PUSHBUTTON SWITCHES Stock version Connection type Housing color ROCKER SWITCHES Actuator color / printing SERIES 1206 - SINGLE-POLE SLIDE SWITCHES TO 8 ( 8 ) A 250 V AC ø1.8+0.1 PCB terminal 1206.2503 143 | SERIES 0140 - DOUBLE-POLE SLIDE SWITCHES PRODUCT FE ATURES ON REQUEST  Long life endurance with 50 000 mechanical switching cycles  Other connection variants  Screw and solder terminals  Slide with riffle Mechanical life endurance 5E4 Material Duroplast Duroplast (base) / PA (cover plate) silver-plated actuator housing connections SENSORS | 144 Miscellaneous M3 CuBe M3 without screws ON/OFF switch (DPST) 0141.1202 z Switch (DPDT) 0140.0601 z 0140.1604 z 0140.2501 z 4 x solder connection CuBe M3 silver-plated M3 CuBe CuBe M3 without screws M3 without screws Stock version Contact material Connection type 2 A 250 V 5E4 Housing color Actuator color / printing double-pole Connection description MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 2 A 250 V AC SERIES 0140 - DOUBLE-POLE SLIDE SWITCHES 32 18.5 16.4 27.9 16.4 17 8.95 8.95 7 ø2.35 16.4 3.9 3.9 25.5 39 Solder terminal 9.5 39 16.4 Screw connection chromated M3 without screw 3.5 TOGGLE SWITCHES Basic types 0140 and 0141 ø2.35 25.5 19.5 (36.15) WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Solder terminal x 4, screw connection M3 without screw ROTARY SWITCHES 16.4 3.9 SLIDE SWITCHES M3 3.9 18.05 27.9 25.5 PUSHBUTTON SWITCHES M3 19.05 5.5 19.05 1 ø6 1 17 3.5 18.5 3.5 32 27.9 ROCKER SWITCHES TO 2 A 250 V AC 145 | Further information under WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES ROTARY SWITCHES SENSORS SENSORS 147 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES ROTARY SWITCHES | 148 SERIES 1703 Powerful rotary switches to 20 (4) A 400 V AC Further information under WWW.MARQUARDT.DE PAGE 149 - 150 SERIES 1703 - POWERFUL ROTARY SWITCHES  Gold contacts Mechanical life endurance 3E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Voltage strength at 250 V 1 500 V function insulation / basic insulation 3 000 V reinforced insulation 500 V small contact distance Proof tracking 400 PTI Insulation spacing acc. to EN 61058 for reinforced or double insulation Protection type IP 40 Ambient temperature connection side -20 °C ... +100 °C Flammability UL 94 (housing: V-0, spindle: V-2) Heat and fire resistance 850 °C (category D) Material PA PA glass fiber-reinforced silver-plated or bare actuator housing connections Plug force of the terminals < Approval marks 4 80 N Suitable for appliances of protection class II SLIDE SWITCHES  Customized actuators  Approval for 400 V ROTARY SWITCHES  Cable assembly  With mechanical forced opening FOOT SWITCHES  Other connection variants  Fastening with thread M3 or bayonet connection  Other switching functions and sequences POWER TOOL SWITCHES  60° switching angle (1 - 4 switching steps) TACT AND KEY SWITCHES  Single to four-pole variant SNAP-ACTION SWITCHES  Creep and air distances greater than 8 mm, therefore suitable for mains and touchable low voltage MICRO-SIGNAL SWITCHES ON REQUEST SENSORS PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 400 V AC 149 | MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES | 150 9 ROTARY SWITCHES 26 6 Basic type 1703 ROCKER SWITCHES Miscellaneous 6.3 > 3 Ag 1 switching step (60 °) 40 6 60° 16 23 6 Further information under WWW.MARQUARDT.DE 14 33 6.3x0.8 Quick-connect terminal 6.3 Stock version Contact material Connection type 20 (4) A 400 V AC 1E4 Housing color Actuator color / printing PUSHBUTTON SWITCHES Contact distance in mm ON/OFF switch (DPST) Connection description z 10 10 TOGGLE SWITCHES 1703.3201 2.3 SLIDE SWITCHES double-pole 4.6 SENSORS SERIES 1703 - POWERFUL ROTARY SWITCHES TO 20 (4) A 400 V AC FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES FOOT SWITCHES SENSORS SENSORS 151 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES FOOT SWITCHES | 152 SERIES 2410 Ergonomic foot switches to 6 (2.5) A 250 V AC Further information under WWW.MARQUARDT.DE PAGE 153 - 155 SERIES 2410 - ERGONOMIC FOOT SWITCHES  Long life endurance up to 300 000 mechanical switching cycles  Other colors  Robust design  Special switching functions  Cable can be retrofitted by customer  Other connection variants  Customized cable assembly  Ergonomical dimensions with different switch actuating forces  With wall hanger treadplate of PA PA Approval marks actuator housing 4 POWER TOOL SWITCHES Material TACT AND KEY SWITCHES acc. to EN 61058 for reinforced or double insulation SNAP-ACTION SWITCHES 250 PTI Insulation spacing MICRO-SIGNAL SWITCHES Proof tracking FOOT SWITCHES 30E4 SENSORS Mechanical life endurance SLIDE SWITCHES ON REQUEST ROTARY SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 (2.5) A 250 V AC 153 | SERIES 2410 - ERGONOMIC FOOT SWITCHES Connection description Contact distance in mm Contact material Operating force in N Miscellaneous Stock version Connection type 6 (2.5) A 250 V AC 5E4 Housing color PUSHBUTTON SWITCHES single-pole Actuator color / printing ROCKER SWITCHES TO 6 (2.5) A 250 V AC 2 terminals 3 Ag small actuator small locking actuator 1298.2201 z 2 x M3 4 x terminal connection > 3 Ag 1298.5201 z 2 x M3 4 x terminal connection 4 x 2.8 x 0.8 > 3 Ag lock R-L switch 1298.5401 z 2 x M3 4 x terminal connection 4 x 2.8 x 0.8 > 3 Ag lock width design R-L switch 1298.7101 z 2 x M3 4 x terminal connection 4 x 2.8 x 0.8 > 3 Ag 296.5° lock R-L switch adjusting wheel 1298.7312 z 2 x M3 4 x terminal connection 4 x 2.8 x 0.8 > 3 Ag 296.5° small locking pushbutton small pushbutton R-L switch, adjusting wheel Stock version Miscellaneous Connection type PUSHBUTTON SWITCHES > Setting wheel angle Contact material 2 x M3 4 x terminal connection Connection description z 8 (8) A 250 V AC 5E4 1298.0101 single-pole Actuator color / printing Contact distance in mm ROCKER SWITCHES TO 8 ( 8 ) A 250 V AC 32.8 SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES 32.8 Socket terminal mains side, screwless push-in terminal motor side 1298.0101 32.8 28.4 32.8 8 11 Socket terminal M3 mains side, screwless push-in terminal motor side 1298.0301 28.8 Ø13.7 36.5 4 13.5 15.9 Ø11.5 2.3 2.3 11.85 11 Ø5.9 M3 12.7 4 19.6 15.9 M3 16 28.8 19.9 11 Socket terminal M3 mains side, screwless push-in terminal motor side 1298.2201 TACT AND KEY SWITCHES Socket terminal M3 mains side, screwless push-in terminal motor side, quick-connect terminal, 1298.7101 18.3 2.3 13.3 ø11.5 2.3 Ø11.5 SNAP-ACTION SWITCHES 4 13.3 15.9 M3 11 20.2 24 20.7 55 8 28.8 34.3 4 M3 MICRO-SIGNAL SWITCHES 20.1 28.8 Ø12.1 18.3 20.6 3 POWER TOOL SWITCHES 11 8 11 20° 15.9 33.5 11 8 34.25 8 Basic type 1298 lock adjusting wheel SENSORS 31 296.5° TOGGLE SWITCHES Normally open contact (SPNO) 163 | SERIES 1299 - SINGLE-POLE POWER TOOL SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 6 ( 6 ) A 250 V AC PRODUCT FE ATURES ON REQUEST  Single-pole normally open contact with integrated potential-free linear potentiometer  Other colors  Powerful with up to 6 A at 100 000 mechanical switching cycles  Other connection variants  As changeover switch  With lock  Right / left rotation  Without lock  Higher rating Mechanical life endurance 1E5 Contact distance > 3 mm Material SLIDE SWITCHES  Other actuator forms PA / PA glass fiber-reinforced PA glass fiber-reinforced chromated actuator housing connections 3 Approval marks /1/2 Miscellaneous 1299.0101 z 2 x M3 4 x terminal connection z R = 220 kOhm 33.5 8 32.8 9 28.8 34.3 11 4 20.7 ø11.5 Basic type 1299 2.3 11 13.3 15.9 M3 Socket terminal M3, terminal connection Stock version Contact material Connection description Connection type 13 A 125 V AC 6 (6) A 250 V AC 5E4 Ag Normally open contact (SPNO) SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 164 Actuator color / printing single-pole TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES Suitable for appliances of protection class II FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES TACT AND KE Y SWITCHES SENSORS SENSORS 165 | PUSHBUTTON SWITCHES ROCKER SWITCHES TACT AND KE Y SWITCHES SERIES 3006 Tact switches to 50 mA 28 V SERIES 6425 TOGGLE SWITCHES Key switches PAGE 169 - 174 to 100 mA 28 V SERIES 6450 Key switches PAGE 175 - 176 to 100 mA 28 V ROTARY SWITCHES SLIDE SWITCHES PAGE 167 - 168 SERIES 3000 to 30 mA 28 V SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Key switches | 166 Further information under WWW.MARQUARDT.DE PAGE 177 SERIES 3006 - TACT SWITCHES ON REQUEST  Low height even with integrated LED  Other LED colors  SMD connection technique  Different brightness groups  Pleasant actuating characteristic thanks to clearly tangible pressure point SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 50 mA 28 V  Extremely large actuator surface < 100 mOhm Protection type IP 50 Ambient temperature -40 °C ... +95 °C (1 h to +120 °C) Material gold-plated connections Bounce time < 5 ms Packing unit 1 800 pieces in blister belt on a roller Miscellaneous rating max. 1 W voltage range 20 mV - 28 V current range 10 μA - 50 mA POWER TOOL SWITCHES Contact resistance (new condition) TACT AND KEY SWITCHES 50E4 SNAP-ACTION SWITCHES Mechanical life endurance MICRO-SIGNAL SWITCHES  Reflow lead-free solderable SENSORS  Two operating force variants FOOT SWITCHES ROTARY SWITCHES  Six standard colors 167 | SERIES 3006 - TACT SWITCHES Permissible total travel position (TP) in mm Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2101 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2102 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2104 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2105 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2106 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2107 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 3006.2151 z Au 4 +1 -0.5 3.2 + 0.2 4.15 2.9 low current consumption reduced brightness 3006.2300 z Au 6 +1.5 -0.75 3.2 + 0.2 4.15 2.9 without LED 3006.2301 z Au 6 +1.5 -0.75 3.2 + 0.2 4.15 2.9 3006.2306 z Au 6 +1.5 -0.75 3.2 + 0.2 4.15 2.9 Stock version Color lamp Contact material 50 mA 28 V Miscellaneous Free position (FP) max. in mm z Operating force in N 3006.2100 PUSHBUTTON SWITCHES Operating position (OP) in mm ROCKER SWITCHES TO 50 mA 28 V SENSORS | 168 without LED LED white LED white 9.85 5.08 MC 9.85 2 SP 1 3.95 Ø 6.8 SMD connection technique 2 K 2 3.05±0.1 3.05±0.1 Basic type 3006 9.6±0.1 MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES Normally open contact with 1 pressure point 1 1 A 7.1±0.1 LED w/o LED Circuit diagram with / without LED Solder pad design SERIES 6425 - KE Y SWITCHES ON REQUEST  Single-pole normally open contact with and without LEDs  Customized key caps  Pleasant actuating characteristic and low actuation noise  Bicolor LED  Other LED colors SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 100 mA 28 V  Standard with gold-plated contacts  Wide range of key caps for different design requirements < 3 mm Ambient temperature -20 °C ... +70 °C Contact material Au Material actuator housing connections Connection type POM PBTP tinned PCB terminal Mechanical life endurance 1E6 at 10 mA 12 V Miscellaneous The key base of the standard key can be snapped into a 1.2 mm thick frame with a cut-out of 13.55 x 13.55 mm. A current limiting to max. 20 mA must be provided for the integrated LED! POWER TOOL SWITCHES Contact distance TACT AND KEY SWITCHES < 5 ms SNAP-ACTION SWITCHES Bounce time MICRO-SIGNAL SWITCHES Insulation resistance (new condition) > 100 MOhm FOOT SWITCHES < 250 mOhm SENSORS Contact resistance (new condition) ROTARY SWITCHES  Low bounce time 169 | SERIES 6425 - KE Y SWITCHES Operating force in N Total travel / stroke in mm Miscellaneous Stock version z > 16 0.7 1.6 customer LED assembly possible z 6425.1101 z > 16 0.7 1.6 narrow base for parallel guide z 6425.3111 z 19 0.7 1.6 z 6425.3121 z 19 0.7 1.6 z 6425.3131 z 19 0.7 1.6 z 6425.4111 z 16 0.7 1.6 z 6425.4121 z 16 0.7 1.6 z 6425.4131 z 16 0.7 1.6 z 6425.6111 z > 15 0.7 1.6 LED higher for button 827 ... 011 z 6425.6121 z > 15 0.7 1.6 LED higher for button 827 ... 011 z 6425.6131 z > 15 0.7 1.6 LED higher for button 827 ... 011 z 100 mA 28 V Color lamp 6425.0101 PUSHBUTTON SWITCHES Pitch in mm ROCKER SWITCHES TO 100 mA 28 V SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES Normally open contact (SPNO) | 170 Further information under WWW.MARQUARDT.DE SERIES 6425 - KE Y SWITCHES 6.8 ROCKER SWITCHES 4.3 7.1 8 PUSHBUTTON SWITCHES TOGGLE SWITCHES 4.3 without LED window: 825.000.011 - anthracite 825.000.021 - dark gray 825.000.071 - red 825.000.091 - green 6.2 13 18.3 6.2 13 18.3 ø3.3 18.3 18.3 Square key caps pitch 19 mm with LED window: 828.000.011 - anthracite 828.000.021 - dark gray 828.000.071 - red 828.000.091 - green Key caps with ergonomic actuation surface 840.000.011 - anthracite 840.000.021 - dark gray SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES SENSORS 6.8 7.1 10.7 13.2 ø17 POWER TOOL SWITCHES Square key caps pitch 16 mm TACT AND KEY SWITCHES 11.5 15.5 5.1 11.5 15.5 with LED window: 829.000.011 - anthracite 829.000.021 - dark gray 829.000.071 - red 829.000.091 - green SNAP-ACTION SWITCHES 3.6 5.1 15.5 7.1 13.5 14.8 For multiple key caps with parallel guide 6.8 13.2 10.7 7.1 15.5 10.9 without LED window: 826.000.011 - anthracite 826.000.021 - dark gray 826.000.071 - red 826.000.091 - green ø3.3 13.2 4 0.8 13.5 14.8 With LED for design key caps 10.7 14.4 MICRO-SIGNAL SWITCHES 3.6 1.5 7.1 11 10.7 14.4 4 3.6 1.5 3.6 0.8 13.5 13.5 14.8 13.5 With LED 4.3 14.4 10.7 3.6 1.5 0.8 13.5 14.8 Without LED or customer LED assembly 14.4 14.4 7.1 13.5 3.6 3.6 0.8 Basic type 6425 14.4 7.1 10.7 3.6 1.5 14.4 10.7 14.4 4.3 TO 100 mA 28 V Round key caps 171 | SERIES 6425 - KE Y SWITCHES TO 100 mA 28 V ROCKER SWITCHES Key cap with oval actuation surface pitch 16 mm 5.1 827.020.011 - anthracite 827.020.021 - dark gray 827.020.031 - gray 5 1.4 15.5 5.1 6 7.1 7 10.7 PUSHBUTTON SWITCHES 11.3 ø4 0.6 11 15.5 TOGGLE SWITCHES Design key caps Key cap with round actuation surface pitch > 15 mm 827.100.011 - anthracite 827.100.021 - dark gray 827.100.031 - gray 8 14.4 4 6.8 2.5 7.1 10.7 With these two-part key caps with snap-on transparent caps individual inspection and color requirements, especially for small series, can be implemented at low cost by customer insertion. These key caps are suitable for key switches with and without LED and pitch 16 mm. 15.5 Key caps with transparent cap 11.5 13.1 6.8 31.5 27.5 with one LED window: 842.500.011 - anthracite 13.1 5.1 10.7 7 2.5 15.5 5.1 without LED window: 842.000.011 - anthracite 842.000.021 -dark gray 842.000.031 - gray with two LED windows: 842.800.011 - anthracite Double key caps 16 mm pitch without LED window: 844.000.011 - anthracite 844.000.021 - dark gray 844.000.031 - gray 37.3 32 13 6.2 18.3 15.7 6.8 10.7 Double key caps 19 mm pitch 7.1 2.5 POWER TOOL SWITCHES 6 835.900.013 key cap anthracite, cap transparent, enclosed loose TACT AND KEY SWITCHES SNAP-ACTION SWITCHES 11.7 Design key caps MICRO-SIGNAL SWITCHES SENSORS | 172 7.1 7.4 10.7 14.4 FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES 4 with one LED window: 844.500.011 - anthracite SERIES 6425 - KE Y SWITCHES 56.3 32 51 190.053.013 Recommended appliance cut-out and perforation pattern component side 14.4 5.08 5.08 5.08 13.55 OR 0.1 2.2 21.6 FH ø1.3 TH ø1.3 SH ø3 Parallel guide The parallel guide guarantees an optimum function even in case of off-center actuation and can be equipped additionally with one or two LEDs. 190.053.023 Recommended appliance cut-out and perforation pattern component side OR 0.1 5.08 1.6 5.08 5.08 13.55 16.5 31.4 2.2 26.7 5.08 6 10 PUSHBUTTON SWITCHES 17 14.5 13,55 SH ø3 The parallel guide can be equipped additionally with a LED. WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES Parallel guide FH ø1.3 TH ø1.3 Parallel guide for: triple key caps, pitch 16 mm double key caps, pitch 19 mm triple key caps, pitch 19 mm FOOT SWITCHES 5.08 16.5 26.2 Parallel guide for: double key caps, pitch 16 mm POWER TOOL SWITCHES 6 10 1.6 14.4 11.9 11.9 13.55 TOGGLE SWITCHES 6.8 7.1 845.000.011 - anthracite pitch 19 mm SLIDE SWITCHES 843.000.011 - anthracite pitch 16 mm Triple key caps ROTARY SWITCHES 6.8 10.7 7.1 10.7 2.5 2.5 47.5 ROCKER SWITCHES TO 100 mA 28 V 173 | SERIES 6425 - KE Y SWITCHES SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 100 mA 28 V | 174 Square key caps with white characters 051 052 053 054 055 056 057 058 059 060 061 062 063 064 065 066 067 068 069 070 071 072 073 074 075 076 017 018 019 020 021 022 023 024 011 016 015 170 010 001 002 003 004 005 006 007 008 009 Please complete the reference numbers by the three figures below the respective character. Basic reference numbers for pitch 16 mm: 826 ... 011 - anthracite 826 ... 021 - dark grey Basic reference numbers for pitch 19 mm: 825 ... 011 - anthracite 825 ... 021 - dark grey Other key cap colors and characters on request. SERIES 6450 - KE Y SWITCHES  Single-pole normally open contact with key cap  Other key cap colors  Narrow design with proven switching principle of series 6425  Labeled key cap  Pleasant actuating characteristic and low actuation noise  Low bounce time  Long life endurance  Standard with gold-plated contacts < 3 mm Bounce time < 5 ms Ambient temperature -20 °C ... +80 °C Material PA PBTP tinned actuator housing connections Connection type PCB terminal Mechanical life endurance 1E6 at 10 mA 12 V POWER TOOL SWITCHES Contact distance TACT AND KEY SWITCHES Au SNAP-ACTION SWITCHES Contact material MICRO-SIGNAL SWITCHES Insulation resistance (new condition) > 100 MOhm FOOT SWITCHES < 250 mOhm SENSORS Contact resistance (new condition) SLIDE SWITCHES ON REQUEST ROTARY SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 100 mA 28 V 175 | SERIES 6450 - KE Y SWITCHES Operating force in N Total travel / stroke in mm Miscellaneous Stock version 6450.0001 z 0.7 1.6 gray z 6450.0003 z 0.7 1.6 dark gray z 6450.0005 z 0.7 1.6 anthracite similar to RAL 9011 z 6450.0006 z 0.7 1.6 red similar to RAL 3013 z 6450.0007 z 0.7 1.6 yellow similar to RAL 1012 z 6450.0008 z 0.7 1.6 green similar to RAL 6001 z 6450.0009 z 0.7 1.6 blue similar to RAL 5019 z PUSHBUTTON SWITCHES Actuator color / printing 100 mA 28 V ROCKER SWITCHES TO 100 mA 28 V 5.08 5.08 13.5 10.85 5.2 7.5 14.8 ø1.3 5.08 MF: 11 x 13.55 mm 1.2 mm tk Basic type 6450 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES ø1-1.5 9.5 3.6 13.2 6.8 15.5 11.5 FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES Normally open contact (SPNO) | 176 Further information under WWW.MARQUARDT.DE 5.08 Narrow key switch with integrated key cap The key base can be snapped into a 1.2 mm thick frame with a cut-out of 11 x 13.55 mm. SERIES 3000 - KE Y SWITCHES ON REQUEST  With one or two normally open contacts switching in sequence  Available with centrally placed LED (only version with a pressure point)  By separating the mechanical and electrical components, a high contact reliability and excellent actuating characteristic are achieved  Different actuator caps PUSHBUTTON SWITCHES PRODUCT FE ATURES ROCKER SWITCHES TO 30 mA 28 V  Connections sealed 1E5 2E4 (basic type 3003 - two pressure points) Ambient temperature -40 °C ... +85 °C Material PC / POM PA glass fiber-reinforced tinned actuator housing connections Au Contact distance < 3 mm 5-7 9.8 +0.3 -0.2 9.2 operating force 2: 11 - 14 N operating position 2: 8.9 +0.3 -0.2 TACT AND KEY SWITCHES z Normally open contact with 1 pressure point 3.2 1.1 4.4 12.4 1.3 4.5 1.1 Normally open contact with one pressure point 3000.0452 Double normally open contact with two pressure points 3003.0451 MICRO-SIGNAL SWITCHES Basic types 3000 and 3003 2.54 SENSORS 2.54 1.5 1.5 tk 2.5 9.4 2.5 3 3 12.4 2.8 9.4 10.6 2.8 1.5 1.3 9.8 +0.3 -0.2 4.4 4.5 5-7 10.6 z 3.2 3000.0452 SNAP-ACTION SWITCHES 3003.0451 FOOT SWITCHES 10.9 Double normally open contact with 2 pressure points POWER TOOL SWITCHES 8.6 Stock version Permissible total travel position (TP) in mm 10.9 Miscellaneous Free position (FP) max. in mm Operating position (OP) in mm Operating force in N Connection type 30 mA 28 V ROTARY SWITCHES Contact material SLIDE SWITCHES Mechanical life endurance TOGGLE SWITCHES  For direct or indirect actuation 177 | Further information under WWW.MARQUARDT.DE FOOT SWITCHES POWER TOOL SWITCHES TACT AND KE Y SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES PUSHBUTTON SWITCHES TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES FOOT SWITCHES ROTARY SWITCHES POWER TOOL SWITCHES SLIDE SWITCHES TACT AND KEY SWITCHES TOGGLE SWITCHES SNAP-ACTION SWITCHES PUSHBUT TON SWITCHES MICRO-SIGNAL SWITCHES ROCKER SWITCHES ROCKER SWITCHES SNAP-ACTION SWITCHES SENSORS SENSORS 179 | ROCKER SWITCHES SNAP-ACTION SWITCHES SERIES 1055 Subsubminiature snap-action switches IP 67 PAGE 182 - 186 SERIES 1050 Subminiature snap-action switches PAGE 187 - 192 to 10 (1.5) A 250 V AC SERIES 1080 Miniature snap-action switches PAGE 193 - 197 to 21 (8) A 250 V AC ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES to 4 A 12 V or 2 A 24 V SERIES 1005 MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES Miniature snap-action switches to 21 (8) A 250 V AC SERIES 1040 Rotary shaft snap-action switches SENSORS PAGE 205 - 206 to 4 (1) A 250 V AC SERIES 1010 Open snap-action switches PAGE 207 - 211 to 10 (3) A 250 V AC SERIES 1018 Snap-action switches to 2 A 12 V DC | 180 PAGE 198 - 204 PAGE 212 SERIES 1019 Single-pole snap-action switches PAGE 213 - 215 ROCKER SWITCHES SNAP-ACTION SWITCHES SERIES 1022 Snap-action switches IP 67 PAGE 216 - 217 SERIES 1117 Snap-action switches WWW.MARQUARDT.DE SENSORS Further information under MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES to 16 (6) A 400 V AC PAGE 218 - 219 SLIDE SWITCHES TOGGLE SWITCHES to 4 A 12 V DC PUSHBUTTON SWITCHES to 6 (2) A 250 V AC 181 | SERIES 1055 - SUBSUBMINIATURE SNAP-ACTION SWITCHES IP 67 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES POWER TOOL SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 4 A 12 V OR 2 A 24 V DC | 182 PRODUCT FE ATURES ON REQUEST  Compact design with dust and water protected switching system acc. to IP 67 (basic types 1055 / 1058)  Rating 0.5 (0.5) A 250 V AC 25E3 and ENEC approval mark  Large overtravel of > 1.2 mm for small size  Customized cable assembly  The specially designed pushbutton guide enables a start-up angle of 40°  Basic type 1058 as double switch or with cable outlet in other directions  For higher ambient temperatures  The modular principle offers a wide selection of connections, auxiliary actuators and fastening types Mechanical life endurance 1E6 at 10 mA 12 V Contact resistance (new condition) < 50 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Protection type IP 00 connection side basic types 1055 and 1056 IP 40 actuator side basic type 1056 IP 67 actuator side basic type 1055, connection and actuator side basic type 1058 Ambient temperature -40 °C ... +85 °C Flammability UL 94 HB Material actuator additional actuator housing connections POM stainless steel spring steel PBTP tinned basic type 1058: wires FLRY 0.5 mm², tinned wire ends Contact material Ag gold-plated Approval marks 4 Shock resistance 50 g Miscellaneous connection side cast electrical life endurance at 12 V 2 A: 200E3 (ohmic load) on request SERIES 1055 - SUBSUBMINIATURE SNAP-ACTION SWITCHES IP 67 ROCKER SWITCHES 10.4 7.9 pin right 1.5 long PUSHBUTTON SWITCHES Permissible total travel position (TP) in mm 0.4 Stock version Free position (FP) max. in mm 9.4 + 0.3 Miscellaneous Difference travel max. in mm 1.8 Lever drawing Operating position (OP) in mm < Actuator description Operating force in N 400 long crimped Connection description Connection type 0.5 (0.5) A 250 V AC 25E3 2 A 24 V DC (ohmic load) 4 A 12 V DC (ohmic load) TO 4 A 12 V OR 2 A 24 V DC 1058.0395 z z TOGGLE SWITCHES Normally closed contact (SPNC) 1058.0373 z z 150 long < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin right 1.5 long 1058.0593 z z 300 long < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin both sides 5 long 1058.5172 z z 254 long < 2.6 12.4 + 0.65 0.8 14.7 10.3 L21 SLIDE SWITCHES Normally open contact (SPNO) pin left 5 long z z < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin right 1.5 long 1055.0551 z z < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin right 5 long 1055.0552 z z < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin left 5 long 1055.2061 z z < 1.8 13.75 + 0.3 0.4 14.75 12.25 1055.2351 z z < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin right 1.5 long 1055.3653 z z < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin right 2.5 long 1055.3654 z z < 1.8 9.4 + 0.3 0.4 10.4 7.9 pin left 2.5 long 1055.5155 z z < 2.6 12.4 + 0.65 0.8 14.7 10.3 L21 pin both sides 2.5 long 1055.5253 z z < 4.2 9.7 + 0.45 0.5 11.6 8.25 L31 pin both sides 2.5 long 1055.5350 z z < 4.2 14.05 + 0.45 0.5 15.85 12.65 L02 without pin 1055.7255 z z < 4.2 14.05 + 0.45 0.5 15.95 12.6 L31 without pin 1055.8155 z z < 12.4 + 0.65 0.8 14.7 10.3 L21 pin right 2.5 long 1056.0351 z z
191.071.021 价格&库存
很抱歉,暂时无法提供与“191.071.021”相匹配的价格&库存,您可以联系我们找货
  • 100+8.75378100+1.13142
  • 500+4.16428500+0.53823
  • 1000+3.925441000+0.50736
  • 2500+3.378712500+0.43670
库存:4100
