SERIES 1800 - SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES
UP TO 12 (4) A 250 V~ AND 8 (8) A 250 V~
PRODUCT ADVANTAGES
Switching principle with long life
endurance due to a low friction contact
system (ball), proven a 100 million
times
Attractive rocker switches with silk matt
surfaces and abrasionproof markings
High ratings up to 12 (4) A 250 V ~
resp. 8 (8) A 250 V~ and inrush current
peaks up to 70 A
Suitable for ambient temperatures up
to T 100/55
High accuracy of fit between rocker
and housing
Excellent actuation characteristic
Simple snap-on assembly for
appliance panel thickness of 0.75 ...
3.00 mm
Tight fit in appliance cut-out due to tolerance compensation ribs on the
switch housing
Staked terminals for reliable plugging of
connectors
SWITCHING FUNCTIONS
Single throw (ST) switches
ST- switches with indicator lamp
Double throw (DT) switches
Double throw switches with
centre-OFF
Switches with momentary function
Pilot lights
TERMINAL VERSIONS
Quick-connect terminal 4.8 mm
Solder terminal
Straight PCB terminal
Angled PCB-terminal
VERSIONS ON REQUEST
With flammability according to UL 94 V-0
With gold-plated contacts for low voltages
With cutting contacts for applications in
a dusty environment
With additional supports for PCB
assembly
With special rocker for snapping on
customized actuators
ACCESSORIES
2.6
Protection caps against dust and
splash water (see page 2.48)
STANDARD VERSIONS
single pole
double pole
X = panel thickness
Y
X = panel thickness
X
Y
0.75...1.25 19.2 0.1
1.25...2
19.4 0.1
2 ...3
19.8 0.1
Z
12.9 +0.1
12.9 +0.1
12.9 +0.1
Electrical rating (depending on version)
Inrush current ST-switches
Mechanical life endurance ST / DT
DT with centre-OFF 5E4
Contact resistance (new state)
Insulation resistance (new state)
Z
Y
Z
APPLIANCE CUT-OUT
X
Y
1.25...2
19.4 0.1
2 ...3
19.8 0.1
Z
21.9 +0.1
21.9 +0.1
21.9 +0.1
8 (8) A 250 V~ 5E4
12 (4) A 250 V~
15 A 125 - 250 V AC
3/4 HP 125 V AC
1 1/2 HP 250 V AC
70 A capacitive 104 operations
1E5
< 100 m# (12 V, 1 A DC)
> 100 M# (500 V DC between the
open contacts)
High voltage resistance
< 3 mm
750 V eff. (between the open
(new state)
" 3 mm
1250 V eff. contacts)
3750 V eff. (reinforced insulation)
Resistance to tracking
PTI 250
Contact gap
ST / DT
" 3 mm
DT with centre-OFF < 3 mm (µ)
Insulation spacing
" 8 mm
Protection type
IP 40
Ambient temperature
Terminal side
-20 °C ... +100 °C (no condensation)
Actuating side
-20 °C ... + 55 °C (no condensation)
Storage temperature
-40 °C ... + 80 °C
Actuating force
3-8 N (depending on the switching function)
Flammability
UL 94 V-2
Heat and fire resistant
850 °C (category D)
Material housing and rocker
PA
rocker illuminated
PC
Contacts
Ag
Terminals
silver-plated
Temperature rise at the terminals
max. 30 K (UL 1054)
(according to electrical life endurance)
max. 55 K (EN 61058-1)
Solderability of terminals
max. 350 °C, 3 sec. (no pressure when
soldering by hand!)
Push-on force of connectors
! 80 N
Approval marks
or v d n s t k j . w r a
Suitable for appliances of protection class II
2.7
SINGLE POLE ST-SWITCHES
with indicator lamp
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
5/50 A 250 V~
T 100/55
6 A (1/2 HP) 250 V AC
1800.1102*
1800.0102
1800.1108*
1800.0108
1800.1104*
ST-switches for 125 V AC on request
quick-connect terminal 4.8
solder terminal
1805.7110*
1805.6102
1805.7109*
1805.6108
DOUBLE POLE ST-SWITCHES
with indicator lamp
21
17.5
13.2
4,8 x 0,8
3 x 15
7
10.2
22
18.6
SINGLE POLE COMBINATION
13.2
2
5.3
7
18.6
24
5.3
24
21
19.5
ST-switches with indicator lamp for
12 (4) A 250 V~ resp. 8 (8) A 250 V~,
for 125 V AC and for 125 V - 250 V AC
on request
1805.7104*
2
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
5/50 A 250 V~
T 100/55
10.2
22
solder terminal
Appliance cut-out
10 (4) A 250 V~
6 (4) A 250 V~ 5 E 4
T 100/55
Y
Z
X = panel thickness
Additional switching functions on request
ST-switch / ST-switch
Z
21.9 +0.1
21.9 +0.1
21.9 +0.1
ST-switch / Pilot light
1806.1402
7
10.2
18.6
2.8
* Version on stock
22
4.8-0.8
18
2
x
11.7
5.3
1806.1102*
X
Y
1.25...2
19.4 0.1
2 ...3
19.8 0.1
12 (4) A 250 V~
8 (8) A 250 V~ 5E4
5/70 A 250 V~
T 100/55
15 A (3/4 HP) 125 V AC
15 A (1 1/2 HP) 250 V AC
1801.1121*
1801.0121*
1801.1908*
1801.0136*
1801.1101
1801.6101
1801.1102*
1801.6102*
1801.5102
1801.1119*
1801.6112
1801.1139*
1801.0179
1801.1903
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
5/50 A 250 V~
T 100/55
6 A (1/4 HP) 125 V AC
16.75
4.7
7.3
0.75
10.45
17.5
23.5
with installed dust protection cap
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
5/50 A 250 V~
T 100/55
1801.1146*
1801.6115*
1801.2106
7
13
18.6
17.9
23.9
1801.1403*
1802.1123*
1802.0130*
12 (4) A 250 V~
8 (8) A 250 V~ 5E4
5/70 A 250 V~
T 100/55
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
5/50 A 250 V~
T 100/55
1802.1108*
1802.6103*
1802.2104
1802.5103*
* Version on stock
1802.1101
1802.0101
1802.1102*
2.9
SINGLE POLE DT-SWITCHES
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
T 100/55
DT-switches with r- and a-approval
marks for 10 A on request
1803.1102*
1803.6102*
1803.2102
1803.5102
1804.1102*
1804.6102*
1804.2102
DOUBLE POLE DT-SWITCHES
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
T 100/55
with centre-OFF
6 (2) A 250 V~ µ
T 100/55
6 A (1/8 HP) 125-250 V AC
Momentary function on one side on
request
without momentary
1808.1102*
1808.0102*
1808.2102*
without momentary
1808.1103*
1808.0111*
momentary on both sides
1808.1302*
1808.0302*
1808.2302*
solder terminal
with centre-OFF
6 (2) A 250 V~ µ
T 100/55
Momentary function from one side on
request
2.10
without momentary
1809.1102*
* Version on stock
1809.1302*
SINGLE POLE WITH MOMENTARY FUNCTION
4 (2) A 250 V~
T 100/55
6 A (1/10 HP) 125 V AC
4 A (1/10 HP) 250 V AC
normally closed
1801.1302*
normally open
1801.1202*
1801.0202*
DT momentary
1803.1202*
1803.0202*
solder terminal
DOUBLE POLE WITH MOMENTARY FUNCTION
4 (2) A 250 V~
T 100/55
normally open
1802.1221*
for direct connection to the mains
10 (4) A 250 V~
6 (4) A 250 V~ 5E4
5/50 A 250 V~
T 100/55
quick-connect 4.8
and bush terminals
1802.3102*
Higher electrical rating on request
PILOT LIGHTS
Pilot lights with neon lamps and
resistor for 230 V~
v
Pilot lights for 125 V AC on request
1807.1102*
* Version on stock
1807.1108
2.11
很抱歉,暂时无法提供与“01802.1123-02”相匹配的价格&库存,您可以联系我们找货
