09073.1101-00
09073.1101-00
    MARQUARDT(马夸特)
    MARQUARDT - 09073.1101-00 - Toggle Switch, On-Off-On, SPDT, Non Illuminated, Through Hole
09073.1101-00 数据手册
Toggle switches 9073.1101 Product number Business unit Product family Actuation type Output Switching function Material fixed contact Contact system Number of poles connections Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Miscellaneous Type of fastening 9073.1101 Switches, Sensors & Controls Toggle switches direct catalogue miniature switch Changeover switch with OFF position in the center (SPDT - Center OFF) CuZn gold-plated Electrical life 50000 1 - pole PCB terminal, injected in base, sealed with epoxy resin ≤ 0.4V A 28 V < 50 mOhm > 500 MOhm small contact distance -25 °C ... +70 °C lever: CurZn nickel-plated housing: PA glass fiber-reinforced, gray, for round device cut-out base plate: PA glass fiber-reinforced, gray bearing connection gold plated external connection gold plated CuSn gold-plated slide contact momentary function both sides pcb assembly Technical changes reserved. Dimensions are not binding. Detailed specifications available on request. > 500 V
09073.1101-00 价格&库存
很抱歉,暂时无法提供与“09073.1101-00”相匹配的价格&库存,您可以联系我们找货
    • 15+38.17987
    • 35+36.64070
    库存:100
