01006.1801-02
01006.1801-02
    MARQUARDT(马夸特)
    MARQUARDT - 01006.1801-02 - Microswitch, Miniature, Bent Spring Lever, SPDT, Quick Connect, 10 A
01006.1801-02 数据手册
SERIES 1004 / 1005 / 1006 - ENCLOSED SNAP ACTION SWITCHES UP TO 21 (8) A 250 V~ PRODUCT ADVANTAGES ◆ Universally applicable, proven snap action switch series with high functional reliability in size DIN 41635 design A ◆ Long mechanical life endurance ◆ Very high inrush currents ◆ Compulsory friction contact system, its shearing movement can free welded contacts ◆ Wide range of ratings from 6 (2,5) A 400 V~ to 21 (8) A 250 V~ ◆ Contact gaps < 3 mm and " 3 mm ◆ Actuating forces of 0,2 N to 4,2 N SWITCHING FUNCTIONS ◆ Change-over ◆ Normally open ◆ Normally closed TERMINAL VERSIONS ◆ Solder terminal and short solder terminal ◆ Quick-connect 6.3 x 0.8 mm ◆ Quick-connect 4.8 x 0.8 mm ◆ PCB terminal frontal ◆ Angled PCB terminal VERSIONS ON REQUEST ◆ Electrical rating change-over 21 (8) A 250 V~ 25E3 ◆ Electrical rating normally open and normally closed 20 A 250 V~ 50E3 ◆ Electrical rating normally open > 3 mm 10 (10) A 250 V~ 50E3 ◆ Electrical rating change-over 8 (8) A 250 V~ 50E3 ◆ For ambient temperatures T 125 ◆ Change-over with contact gap " 3 mm (series 1005) ◆ Normally open with lateral bearing connection (series 1005) ◆ Quick-connect 4.8 x 0.5 mm ◆ Quick-connect 2.8 x 0.8 mm ◆ UL-electrical rating up to 21 A 125 V AC 1 HP 21 A 250 V AC 2 HP 3.17 SERIES 1004 / 1005 / 1006 - ENCLOSED SNAP ACTION SWITCHES UP TO 21 (8) A 250 V~ Electrical rating (depending on version) 21 (8) A 250 V~ 25E3 16 (4) A 400 V~ 50E3 8 (8) A 250 V~ 50E3 21 A 125 V AC 1 HP 21 A 250 V AC 2 HP Version DIN 41635 A Actuating force series 1004 0,2 ... 1,8 N series 1005 1,0 ... 4,2 N series 1006 0,3 ... 4,2 N Mechanical life endurance< 3 mm 10E6 " 3 mm and lever versions 5E6 Electrical life endurance electrical rating-dependent Contact resistance (new state) < 100 m# Insulation resistance (new state) >100 M# (500 V DC between the open contacts) High voltage resistance (new state) < 3 mm 750 V (between the " 3 mm 1250 V open contacts) 3750 V (reinforced insulation) Bounce time < 10 ms Resistance to tracking PTI 250 Contact gap < 3 mm (µ) or " 3 mm Ambient temperature -40 °C ... +100 °C no condensation Storage temperature -40 °C ... +80 °C Flammability housing UL 94 V-0 actuator UL 94 V-0 / V-2 Heat and fire-resistance 850 °C (category D) Material housing / actuator duroplast or PA optional actuator chrome-nickel steel optional actuator roller PA Contacts Ag/Ag resp. gold-plated Terminals silver-plated Solderability of terminals duroplast-housing max. 350 °C, 5 sec. thermoplast-housing max. 350 °C, 2-3 sec. (no pressure on the terminals when soldering by hand) Approval marks ra Suitable for appliances of protection class II. Required air and creepage distances within the appliances have to be observed. The test conditions comply with EN 61058-1 resp. UL 1054 3.18 mov. differential max. 0.3 mm pre-travel max. 1.8 mm over-travel min. 0.8 mm SERIES 1005 with contact gap < 3 mm free position operating pos. total travel position allowed Actuating force 1,5 ... 2,5 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP change-over 1005.1001* 1005.0401* Actuating force 2,4 ... 3,8 N 20 (4) A 400 V~ 10E3 16 (4) A 400 V~ 50E3 10 (6) A 250 V~ 50E3 16 A 125-250 V AC 1/2 HP 1005.1004* 1005.0404* normally open 1005.1201* 1005.4001 normally closed 1005.1101 mov. differential max. 0.3 mm pre-travel max. 1.8 mm over-travel min. 0.8 mm SERIES 1004 with low actuating forces and contact gap < 3 mm free position operating pos. total travel position allowed Actuating force 0,2 ... 0,6 N 6 (2,5) A 250 V~ 50E3 4 A 125-250 V AC 1/6 HP change-over 1004.1002* 1004.0402 Actuating force 0,5 ... 1,1 N 10 (4) A 250 V~ 50E3 8 A 125-250 V AC 1/3 HP 1004.1001* Actuating force 0,8 ... 1,8 N 16 (4) A 250 V~ 25E3 1004.3503 mov. differential max. 1.2 mm pre-travel max. 1.9 mm over-travel min. 0.7 mm SERIES 1005 with contact gap " 3 mm free position operating pos. total travel position allowed Actuating force 2,4 ... 3,8 N 10 (6) A 250 V~ 50E3 10 A 125-250 V AC 1/2 HP normally open 1005.1204* 1005.0904 mov. differential max. 1.0 mm pre-travel max. 1.8 mm over-travel min. 0.8 mm free position operating pos. total travel position allowed Actuating force 2,6 ... 4,2 N 10 (6) A 250 V~ 50E3 10 A 125-250 V AC 1/2 HP normally closed 1005.1105* * Version on stock 3.19 SERIES 1004 / 1005 / 1006 - ENCLOSED SNAP ACTION SWITCHES UP TO 21 (8) A 250 V~ SERIES 1006 with straight metal lever contact gap < 3 mm free position operating pos. total travel pos. allowed actuating force 1,5 ... 2,5 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP mov. differential max. 0.3 mm pre-travel max. 1.8 mm over-travel min. 0.8 mm change-over 1006.1101 free position operating pos. total travel pos. allowed actuating force 0,8 ... 1,4 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP mov. differential max. 0.7 mm pre-travel max. 4.0 mm over-travel min. 1.6 mm change-over 1006.1401* 1006.0901 free position operating pos. total travel pos. allowed actuating force 0,30 ... 0,55 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP mov. differential max. 1.8 mm pre-travel max. 8.5 mm over-travel min. 3.2 mm change-over 1006.1301* free position operating pos. total travel pos. allowed actuating force 1,5 ... 2,5 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP mov. differential max. 0.3 mm pre-travel max. 1.8 mm over-travel min. 0.8 mm change-over 1006.1201* 1006.0701* versions with 16 A or contact gap " 3 mm on request. 34 ! 23,5 20.8 ±1,2 18 Ø5 free position operating pos. total travel pos. allowed actuating force 0,7 ... 1,25 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP change-over 1006.1511* 1006.1011* 3.20 * Version on stock mov. differential max. 0.9 mm pre-travel max. 3.9 mm over-travel min. 1.6 mm SERIES 1006 with metal spring actuator contact gap < 3 mm The spring actuator allows a recoil of 1.5 mm actuating force 1,50 ... 2,50 N 6 (2,5) A 400 V~ 50E3 10 (4) A 400 V~ 10E3 10 A 125-250 V AC 1/4 HP free position operating pos. total travel pos. allowed mov. differential max. 0,6 mm pre-travel max. 3,5 mm over-travel min. 1,0 mm + 1,5 mm with elastic hysteresis change-over 1006.1801* INSULATING PLATES made of hard paper HP 2061 for mounting on metal or between stackable switches for solder terminal thickness 0.5 mm thickness 0.8 mm 231 009 011* 231 009 021* for quick-connect thickness 0.5 mm thickness 0.8 mm 231 010 011* 231 010 021* DIMENSIONED DRAWINGS quick-connect angled PCB-terminal to socket side (left) * Version on stock solder terminal angled PCB-terminal to cover side (right) 3.21
01006.1801-02 价格&库存
很抱歉,暂时无法提供与“01006.1801-02”相匹配的价格&库存,您可以联系我们找货
  • 1+61.122621+7.93260
  • 10+54.8536310+7.11900
  • 20+53.4605320+6.93820
  • 100+50.76138100+6.58790
库存:115
