01058.0351-01
01058.0351-01
    MARQUARDT(马夸特)
    MARQUARDT - 01058.0351-01 - MICROSWITCH, PLUNGER, SPDT, 4A, 12VDC
01058.0351-01 数据手册
SERIES 1056/1055/1058 - ENCLOSED SNAP ACTION SWITCHES PROTECTION TYPE IP 40 AND IP 67, UP TO 4 A 12 V / 2 A 24 V PRODUCT ADVANTAGES ◆ Series 1055 / 1058: compact design with dust and water proof switching system according to IP 67, versions 1058 are also protected with IP 67 from the terminal side ◆ Large over-travel, " 1.2 mm despite small size ◆ Small operating point tolerances ◆ The special actuator design enables an approach angle up to 40° ◆ Switching reliability by tension spring contact system ◆ For electrical ratings up to 4 A 12 V resp. 2 A 24 V ◆ The modular principle offers a wide selection of terminals, optional actuators and types of fastenings SWITCHING FUNCTION SERIES 1055/1056 ◆ Change-over SWITCHING FUNCTIONS SERIES 1058 ◆ Change-over ◆ Normally open ◆ Normally closed TERMINAL VERSIONS ◆ Solder terminal ◆ Straight PCB terminal ◆ Angled PCB terminal ◆ Bent PCB terminal, asymmetrical connections ◆ Quick-connect terminal ◆ Top side connection wires (only 1058) VERSIONS ON REQUEST 3.6 ◆ With electrical rating 0,5 (0,5) A 250 V~ 25E3 and ENECapproval mark ◆ For ambient temperature > 100 °C ◆ Different optional actuators ◆ Other connection wires and different lengths Electrical rating 4 A 12 V 2 A 24 V Actuating force series 1055/1058 ! 1,8 N series 1056 ! 1,3 N Mechanical life endurance " 1E6 Electrical life endurance 10 mA / 12 V " 1E6 2 A / 12 V " 200E3 Contact resistance (new state) < 50 m# Insulation resistance (new state) > 100 M# (500 V DC between the open contacts) Protection type series 1056 actuating side IP 40 terminal side IP 00 Protection type series 1055 actuating side IP 67 terminal side IP 00 Protection type series 1058 actuating side IP 67 terminal side IP 67 Contact gap < 3 mm (µ) Ambient temperature -40 °C ... +85 °C no condensation Storage temperature -40 °C ... +100 °C Flammability UL 94 V-2 Material socket / housing / actuator PA / PBTP / POM optional actuator (1055 and 1058) chrome-nickel steel Contacts AuAg plated Connection slits tinned Solderability of terminals max. 350 °C, 2-3 sec. (without pressure on the terminals when soldering by hand!) Approval mark on request APPROACH ANGLE UP TO 40° 40° The robust actuator guide allows actuation by slide or camshaft from all directions with an approach angle ! 40°. The mechanical life depends on the material and surface properties of the slide and the insatallation situation in the device. The diagram opposite is also applicable to the 1056 and 1058 series. 3.7 SERIES 1056/1055/1058 - ENCLOSED SNAP ACTION SWITCHES PROTECTION TYPE IP 40 AND IP 67, UP TO 4 A 12 V / 2 A 24 V total travel position allowed 4.65 SERIES 1056 operating position 6.15 ± 0.3 mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm 6.3 Ø2.5 free position max. 7.15 13 8 8 4.35 Ø3.23 solder terminal Ø1.8 0.5 5 1.5 5 1056.0351* Ø2.95 2.2 9 SERIES 1056 mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm total travel position allowed 4.65 operating position 6.15 ± 0.3 free position max. 7.15 13 Ø2.5 0.5 8 5.33 Ø3.23 angled and straight PCB terminal 6.3 3.3 5 5 9 1056.3351* 1056.2351 0.2x45° Ø3.1 Ø3.5 1.5 Ø2.95 Ø1.3 SERIES 1056 5 5 mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm total travel position allowed 9.0 13 6.3 operating position 10.5 ± 0.3 4.2 PCB terminal bent and coded 3.1 2.2 9 5.08 0.9 Ø2.5 free position max. 11.5 3.8 8 0.35 1.7 0.9 x 0.5 1.5 5.6 1056.3060* Ø1.3 3.8 5.6 3.8 13 operating position 9.4 ± 0.3 13 free position max. 10.4 mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm 6.3 6.3 Ø2.5 Ø2.5 8 8 8 8 Ø 3.23 Ø 3.23 solder terminal 4.354.35 total travel position allowed 7.9 SERIES 1055 Ø1.8 0.5 Ø1.8 5 5 0.5 5 5 1.5 1055.0351* Ø2.95 2.2 9 6.3 total travel position allowed 7.9 operating position 9.4 ± 0.3 13 Ø 2.5 6.3 Ø 3.23 Ø 3.23 free position max. 10.4 5.33 0.5 4.35 0.9 5 5 0.5 3.3 0.35 0.9 5 0.35 4.35 8 8 angled and straight PCB terminal Ø 2.5 5.33 13 SERIES 1055 3.3 5 2.2 Ø3.1 Ø3.5 3.1 Ø 2.95 1.3 9 1.5 1055.3354 1055.2351 5 9 5 3.8 * Version on stock 0.2x45° mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm SERIES 1055 4.2 4.2 13 13 6.3 6.3 total travel position allowed 12,25 operating position 13,75 ± 0.3 mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm Ø2.5 Ø2.5 88 0.35 0.35 PCB terminal bent and coded 5.6 5.6 0.9 x 0.5 0.9 x 0.5 3.8 3.8 free position max. 14,75 1.5 1.5 3.8 3.8 Ø1.3 1055.2061 5.6 3.8 SERIES 1058 total travel position allowed 7.9 operating position 9.4 ± 0.3 cable outlet 13 6.3 free position max. 10.4 Ø2.5 Ø3.23 300 (0.7) 5 9 13 4.5 1058.0351* 14.4 1.5 17.7 mov. differential max. 0.4 mm pre-travel max. 1.3 mm over-travel min. 1.2 mm Ø2.95 2.2 9 mov. differential max. 0.6 mm pre-travel max. 2.25 mm over-travel min. 0.95 mm OPTIONAL ACTUATOR FOR 1055 / 1058 total travel position allowed 8.3 operating position 9.7 ± 0.45 free position max. 11,5 6.3 4 actuating force max. 4,2 N mov. differential max. 0,5 mm pre-travel max. 2,35 mm over-travel min. 1,0 mm OPTIONAL ACTUATOR FOR 1055 / 1058 total travel position allowed 8.25 operating position 9.7 ± 0.45 free position max. 11,6 6.3 4 actuating force max. 4,2 N mov. differential max. 0.8 mm pre-travel max. 2.95 mm over-travel min. 1.45 mm OPTIONAL ACTUATOR FOR 1055 / 1058 simulated roller total travel position allowed 10.3 operating position 12.4 ± 0.65 free position max. 14.7 actuating force max. 2,6 N * Version on stock 6.3 4 3.9
01058.0351-01 价格&库存
很抱歉,暂时无法提供与“01058.0351-01”相匹配的价格&库存,您可以联系我们找货
