09052.0200-00
09052.0200-00
    MARQUARDT(马夸特)
    MARQUARDT - 09052.0200-00 - PUSH BUTTON SW, DPDT, 5A, 48VAC, SOLDER
09052.0200-00 数据手册
Pushbutton switches 9052.0200 Product number Business unit Product family Actuation type Packing unit Output Switching function Material fixed contact Contact system Number of poles connections Mechanical life endurance Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Operating force Miscellaneous Type of fastening 9052.0200 Switches, Sensors & Controls Pushbutton switches direct 100 catalogue miniature switch Changeover switch (DPDT momentary) Ag Electrical life 2 - pole Solder terminal, sealed 25000 100000 4 A 30 V DC 5 A 48 V AC < 20 mOhm > 1000 MOhm small contact distance -25 °C ... +70 °C > 1000 V actuator: CurZn nickel-plated threaded socket: CnZn nickel-plated, hexagonal nuts of nickelplated CuZn bracket plate: stainless steel base plate: DAP, olivegreen bearing connection silver plated external connection silver plated Ag lifting contact 10 N corresponding pushbuttons 9090.03.. see additional parts / stroke 1.8 mm central fastening M6 x 0.75 Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09052.0200-00 价格&库存
很抱歉,暂时无法提供与“09052.0200-00”相匹配的价格&库存,您可以联系我们找货
