1805.7109-03
1805.7109-03
    MARQUARDT(马夸特)
1805.7109-03 数据手册
Marquardt Mechatronik GmbH Schloss-Str. 16 78604 Rietheim-Weilheim Germany Product image / Drawings Phone: +49 (0) 7424 / 99-0 Fax: +49 (0) 7424 / 99-2399 Net: www.marquardt.de E-mail: marquardt@marquardt.de Technical data Product number 1805.7109 Actuator color / printing Similar to original product X = wall thickness X Y Z 0.75 ... 1.25 19.2 -0.1 21.9 +0.1 1.25 ... 2 19.4 -0.1 21.9 +0.1 2 ... 3 19.8 -0.1 21.9 +0.1 Product family Actuation type Weight Switch on continuous current (capacitive) Inrush current (capacitive) ROHS conform Switching function Material fixed contact Number of poles connections Mechanical life endurance Rocker switches direct 6.482 g 5A 50 A yes ON / OFF switch (DPST) Cu silver-plated 2 - pole Quick-connect terminal, 4.8 x 0.8 5E4 10 (4) A250 VAC 1E4 Rating IEC 6 (4) A250 VAC 5E4 Rating North America 6 A250 VAC 1/2 HP Contact resistance (new condition) < 100 (1 A12 V DC) mOhm Insulation resistance (new > 100 (500 V DC) MOhm condition) Voltage strength at 250 V function insulation / basic insulation reinforced insulation small contact distance Proof tracking Insulation spacing 1 500 V 3 000 V 500 V 250 PTI acc. to EN 61058 for reinforced or double insulation Protection type Connection Actuator Ambient temperature Ambient temperature Storage temperature Flammability Glow wire test temperature -20 °C ... +100 °C -20 °C ... +55 °C -40 °C ... +80 °C UL 94 V-2 850 °C rocker: PC, transparent green, identification white housing: PA, black Actuators and additional actuators Housing description IP 40 IP 40 Connection surface bearing connection external connection Contact material Contact distance Ag ≥ 3 mm function illumination: glow lamp, 230 V, green R 87 lifting contact ≤ 80 N CSA/ UL / ENEC 05 Lighting Rating Code UL Contact type Plug force of the terminals Approval marks Suitable for appliances of protection class Miscellaneous Type of fastening Degree of pollution Stock version silver plated silver plated II installation depth 19.5 Snap fastening 3 converted by Web2PDFConvert.com
1805.7109-03 价格&库存
很抱歉,暂时无法提供与“1805.7109-03”相匹配的价格&库存,您可以联系我们找货
