1117.0206-01
1117.0206-01
    MARQUARDT(马夸特)
1117.0206-01 数据手册
SERIES 1117 - SNAP-ACTION SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 16 ( 6 ) A 400 V AC PRODUCT FE ATURES ON REQUEST Double interrupting jump contact switching system Customized versions Contact distance > 3 mm Changeover basic type 1116 Material conformant with the filament wire test acc. to IEC 60 335-1:2001 chap. 30 and UL 94 V-0 Large overtravel ROTARY SWITCHES Actuator can be approached from all directions Normally open contact and normally closed contact versions Mechanical life endurance 10E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) | 194 Proof tracking 250 PTI Protection type IP 40 Ambient temperature -40 °C ... +85 °C Flammability UL 94 V-0 Glow wire test temperature 850 °C Material PA glass fiber-reinforced PA glass fiber-reinforced silver plated actuator housing terminals Contact material Ag Contact distance > Approval marks 3/ 1 3 mm /2 Suitable for appliances of protection class II under compliance with the installation conditions required on the equipment side Free position (FP) max. in mm Permissible total travel position (TP) in mm 6.3 > 3 3.5 + 0.5 12.4 + 0.5 2.6 15.2 8.5 22 ø6 30 13 6.3-0.8 10 Quick-connect terminal 6.3 x 0.8 PUSHBUTTON SWITCHES ROCKER SWITCHES Difference travel max. in mm 8.5 TOGGLE SWITCHES Operating position (OP) in mm 15.2 SLIDE SWITCHES Operating force in N 2.6 ROTARY SWITCHES Contact distance in mm 12.4 + 0.5 Stock version Terminal description 3.5 + 0.5 FOOT SWITCHES TP Terminal type 12 A 125 V AC 1/6 HP 3 TACT AND KEY SWITCHES 8.5 1117.0106 > SNAP-ACTION SWITCHES FP Normally open contact (SPNO) 6.3 MICRO-SIGNAL SWITCHES
1117.0206-01 价格&库存
很抱歉,暂时无法提供与“1117.0206-01”相匹配的价格&库存,您可以联系我们找货
