规格承认书
Specification for approval
客户名称:
深圳市立创电子商务有限公司
(Customer Name)
铝电解电容
产品名称:
(Product Name)
Aluninum Electrolytic Capacitor
客户料号:
(Customer part number)
科尼盛料号:
01EC1777
(KNSCHA number)
01EC1777
型号规格:
KNSCHA SHG 25V10μF Φ5*11L
(Specifications)
客
户
(Customer)
Approval
制 造
(Manufacture)
Approval
拟 制
(Fiction)
审 核
(Chief)
核
准
检 验
(Approval)
(Inspect)
审 核
(Chief)
东莞市科尼盛电子有限公司
DONG GUAN KNSCHA ELECTRONICS CO.,LTD.
No. The 8th Floor, A3 Building, R&D Center (Phase I),
Songshan Lake Intelligent Valley, Liaobu Town, Dongguan City.
TEL:0769-83698067 81035570
FAX: 0769-83861559
Email:sales@knscha.com Website: http://www.knscha.com
核
准
(Approval)
SHG Series
Aluminum Electrolytic Capacitors
Item Name
01EC1777
Rating
SHG25V10μF
Case size
Φ5*11L
KNSCHA Lifetime
7000 hours
1. Operating Temp. Range
-55℃ ~ + 105℃
2. Electrical Characteristics
See Table 1.
【Table 1】
Rated
Voltage
VDC
Surge
Voltage
VDC
25
32
Nominal
Tolerance
Permissible
Dissipation
Leakage
Static
on
Ripple
Factor
Current
Impedance(Ω)
Capacitan Capacitance
Current
(tanδ)max 2min. 20℃
100KHZ 20℃
ce
(mArms)ma
20℃ 120Hz (μA)max
(μF)
20℃ 120Hz
x
10
-20~+20
3
0.14
3. Dimensions
80
1.5
Rubber Bung
Sleeve
Фd=0.05 Tinned copper-ply wire
φd
Safety Vent
φ6.3 or over
F±0.5
ФD+αmax
15min.
L+βmax.
Unit(mm)
φD+0.5Max
5
L+2Max
11
φD+0.5
4min.
F±0.5
2.0
d±0.05
0.5
4. Marking
Following items are printed with white color on coffee color sleeve
Example of Marking
25V
10μF
① Rated voltage & Nominal Capacitance
② Polarity (negative)
③ Trade Mark
④ series
⑤ Symbol of Capacitance Tolerance (M)
⑥ Max Operating Temp.
①
②
KNSCHA
SHG
③
④
(M )105℃
⑤⑥
5.MULTIPLIER FOR RIPPLE CURRENT
①. Frequency Coefficient
Freq.(Hz)
60(50) 120
Cap(μF)
0.75
0.80
0.1-47
0.80
0.85
68-680
1000-22000
0.85
0.87
②. Temperature Coefficient
Ambient
40
60
Temperature(℃)
Coefficient
2.40
2.10
1K
10K
100K
0.85
0.90
0.89
0.90
0.95
0.92
1.00
1.00
1.00
70
85
105
1.78
1.65
1.00
No,KNS-2105002(1/5)
6.
No.
Characteristics
Item
1 Leakage
Current
Performance
I=
3.0 μA
Test Method
(I=0.01CV)
I= Max Leakage Current
C=Ctatic Capacitor: V=Rated Voltage
Protection Resistor : 1000±10Ω
Applied Volt : Rated Voltage
Mesauring time : 2minutes
Measured Frequency : 120Hz±20%
2
Static
Capacitance
3 Dissiption
Factor
(tanδ)
8
~ 12
μF
Measured Voltage
≤ 0.5Vrms, 1.5 ~ 2.0VDC
0.14 and Under
Same as condition of Capacitors
4 High Temp.
Load
Characteristics
Leakage Current
Cap. Change
Dissipation Factor
Appearance
≦the value specified in Table 1
Test Temp. : 105±2℃
Applied voltage: Rated voltage
≦±20% of initial value
≦200% of value specified in Table 1 Test Time :10,000 hours
No remarkable abnormality
+72, -0 hours
5 High Temp.
no load
Characteristics
Leakage Current
Cap. Change
Dissipation Factor
Appearance
Test Temp. : 105±2℃
No voltage applied
≦200% of value specified in Table 1 Test Time :1000 hours
+24, -0 hurs
6 Terminal
Strength
Tensile Strength
Bending Strength
7 Impedance
Ratio
45N {4.5kg}
25N {2.5kg}
WV
Z-25℃/Z+20℃
Z-40℃/Z+20℃
Keeping time
Tensile 1~5sec
Bending 30±5sec
25
2
3
8 Temperature Stage
Item
Charac 2,3 Impedance Ratio
teristics
5 Cap, Change
Performance
Stage Test Temp(℃)
20±2
less than the value mentioned in 5-7,
1
-25±3;
≤±25% against value in stage 4
2
-25±3;
3
20±2
4
105±2
After the capacitor is held at tempereture of each stage
5
20±2
and reaches temperature stability, measure performance.
6
9 Surge
Voltage
Item
Leakage Current
Cap, Change
Dissipation Factor
Appearance
Perforemance
≤ the initial specified value
≤ ±15% against value before test
No remakable abnormality
Test Temp. 15~35℃
Test volt. Surge Volt.Specified in 2
Voltage apply. 1,000times of chage for 30±5sec, under frequency of 6±0.5sec,
and discharge for 5min30sec.
No,KNS-2105002(2/5)
6-2. Characteristics
No.
Item
Performance
10 Vibration
Resistance
Test Method
Stability required
Capacitance
≤±5% of the initial specified value
Cap. Change
Appearance
Frequency : 10~55Hz/1min. Width of vibration, 1.5mm Direction and duration X,
Y and Z directions, each for 2 hours (Total 9 hours)
11 Solderbility
3/4 area of surrounding directions of surface
should be covered with new solder.
Solder: Sn-Ag, Sn-Cu Type
Soldering Temp : 240±5℃
Dipping degree : 2~2.5mm
Flux : Ethanol solution (JIS K8101)
or Isopropylalchol (JIS K8839)
solution of Rosin (JIS K5902)
12 Resistance
to
Soldering
Leakage Current
Cap. Change
Dissipation Factor
Appearance
≦ Initial specified value
≦±10% of initial value
≦ Initial specified in value
Soldering Temp. 280±5℃
Soldering Time . 10±1sec.
13 Resistance
to
Humidity
Leakage Current
Cap. Change
Dissipation Factor
Appearance
≦±15% of initial value
≦ Initial spesified value
Test Temp. : 40±2℃
Humidity
90~95%
Test Time : 500 ± 8 hours
After the above condition,restored
to normal temp, and then measured.
14 Perssure valve
moment
characterstics
There must not be thing ignition, scattering
the resolution that that case works safely
Dcmethod: impress the reverse voltage
and of 1A, I cancel an electric current.
7 Packing method
Packaging shape, size, quantity
Component
size
5*11
Quanity
per
package
40000pcs.
H
L
W
8
Related Standards JIS C 5141
9
Marking on packing box
①
②
③
④
⑤
⑥
⑦
Item name
Series name
Rated Voltage
Nominal Static Capacitance
Case size
Lot No.
Quantity
No,KNS-2105002(3/5)
10
Leakage
current
Connecting the capacitor with a protective resistor (1kΩ±10Ω) in series for
2 minutes, and then, measure leakage current.
很抱歉,暂时无法提供与“01EC1777”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07312
- 500+0.06146
- 2000+0.05498
- 5000+0.05109
- 25000+0.04769
- 60000+0.04590
