CT4-0805B683K500F3
CT4-0805B683K500F3
    FH(风华)
    径向
    直插陶瓷电容/独石电容 径向 68nF ±10% 50V X7R
CT4-0805B683K500F3 数据手册
RADIAL LEADED MLCC RADIAL LEADED MLCC HOW TO ORDER CT4 0805 A B Y 104 M 500 P F3 C E G D F H B: A: UNIT INCHES ( Nominal Body Size(L Product Type I CC4 Class I Dielectric Radial Leaded & Mlcc II Class II Dielectric Radial Leaded & Mlcc CT4 0805 0.17 0.15 1206 0.20 1209/1210 Tolerance B 0.10pF 0.18 C 0.25pF 0.20 0.22 D 0.5pF 1812 0.34 0.26 F 1.0% G 2.0% 2225 0.41 0.37 J 5.0% K 10% M 20% N 30% D: C: Nominal Capacitance Temperature Characteristics CG COG (N) (NPO) Y(F) ) W) Type Code B E: 0 30ppm/ 15% X7R Y5V (-55~+125 ) (-55~+125 +30 % - 80 (-25~+85 ) ) S +50% -20% Z +80% -20% digit is number of zeros. P +100% For example: B.C.D C 10PF B.C.D for C 10PF NPO:B.C.D.F.G.J.K.M X7R:K.M.N.S.Z Y5V:M.N.S.Z.P First two digits are significant, and the third 104=100000pF 5R6=5.6pF F: H: G: mm Lead Space(Unit:mm) Packaging Style Rated Voltage P First two digits are significant, and the third Ammo F1 2.54 F2 4.57 F3 5.08 F4 3.50 Tape T digit is number of zeros. Reel For example: Bulk 500=50V -0% Blank 101=100V 161 SIZE CODE CAPACITANCE AND VOLTAGE mm Dimensions Unit mm Size Code 0805 1206 1210/ 1209 1812 2225 Shape F 0.5 H 1 a b C1 C2 C3 2.54/3.5 2.54 5.08 5.08 5.08 5 10 5/10 5 5/10 a b C1 2.54 3.50 5.08 b C1 3.50 5.08 b b 4.57 5.50 10 10 10 10 L max 4.2 5.5 5.5 8.5 10.5 W max 3.8 4.5 5.5 6.5 9.5 Available Capacitance Range T max 3.8 3.8 3.8 3.8 4.2 Voltage C0G (NP0) X7R Y5V 25 0R5~272 101~105 102~125 50 0R5~222 101~105 102~105 100 0R5~102 101~104 --- 25 0R5~562 101~225 102~125 50 0R5~472 101~105 102~105 100 0R5~332 101~154 --- 25 100~103 471~105 472~155 50 100~103 471~105 472~205 100 5R0~103 101~105 --- 25 100~153 471~335 103~335 50 100~103 471~225 103~225 100 5R0~103 101~105 --- 25 100~473 102~475 103~475 50 100~273 102~335 103~335 100 5R0~273 101~105 --- 0.1 * . Others are available, contact FH. d 162 RADIAL LEADED MLCC PACKAGING STYLE P Note:P1=3.85mm for F=5.08mm; P1=5.1mm for F=2.54mm Note: Code P P0 12.7 12.7 Dim F=5.08mm P1 3.85 P2 d 6.35 0.5 h 0 W 18.5 0.2 0.7 8 W1 W2 H 9 1.5 32.25 10 5.1 1.0 W0 1.3 0.1 1 1 1 H0 I D t 16 1.42 4.0 0.7 19.5 0.5 1.5 Max 1.0 0 Max 0.2 Max Tol AMMO PACKAGING TAPE& REEL PACKAGING 163 P 6
CT4-0805B683K500F3 价格&库存
很抱歉,暂时无法提供与“CT4-0805B683K500F3”相匹配的价格&库存,您可以联系我们找货
CT4-0805B683K500F3
    • 1+0.29452
    • 10+0.24225
    • 30+0.21611
    库存:3
