789:;
AXIAL COLOR CODE CAPACITOR
Product Type
Nominal Body Size Code
AB
Code
Type
789:;
ACC
Ф1.9 3 .0
Ф2.2 3 .2
Axial Color Code Capacitors
D:
E:
C:
Nominal Capacitance
Z[
STUV
Tolerance
Temperature Characteristics
B
0.10pF
C
0.25pF
CD$/EFGH/E,JK$/
D
0.5pF
ELMNO/。
F
1.0%
G
2.0%
J
5.0%
K
10%
M
20%
First two digits are significant,
and the
03
third is number
of
zeros.
N
QR:
For example:
104=100000pF
S
30%
+50%—-20%
Z
+80%—-20%
30PPm/℃
(-55~+125℃ )
CH
60ppm/℃
(-25~+85℃ )
RH
-220
60PPm/℃
(-25~+85℃ )
UJ
-750
120ppm/℃
(-25~+85℃ )
SL
+140~-1000PPm/℃
Y(F)
B.C.D for C<10PF
(-25~+85℃ )
10%
(-25~+85℃ )
15%
(-55~+125℃ )
+30 %
- 80
(-25~+85℃ )
H:
G:
F:
B
P
+100%—-0%
B.C.D \ 2 C<10PF
5R6=5.6PF
CG
`a!
^_
Rated Voltage
Lead Configuration
Packaging Style
26
CD$FGH/E,JK$L
MNO/。
P
and the
third is number
zeros.
QR:
of
Ammo
52
6*+
2
Tape
&Reel
T
3
250=25V
101=100V
Tape width:
" # :52mm
Tape width:
b a a # :5.08mm
5.08mm pitch formed lead
Reel
For example:
500=50V
" # :26mm
c*+
Bulk
F
4
152
b a a # :7.5mm
7.5mm pitch formed lead
b a a # :10mm
10mm pitch formed lead
Voltage VS Capacitance
STUV
^_
Temp. Char.
Rated Voltage
Available Capacitance Range
03
25
25
0R5~272
0R5~102
50
50
0R5~222
0R5~102
100
0R5~102
CH
50
50
1R5~102
1R5~102
RH
50
50
1R0~180
1R0~180
CG
Z[
Capacitance Tolerance
03
C:
0.25pF
D:
0.5pF
J: 5%
K:
10%
M:
20%
10%
UJ
50
50
2R2~300
2R2~300
SL
50
50
1R0~680
1R0~680
25
25
101~224
101~104
K
50
50
101~104
101~104
M
20%
30%
B
F(Y)
100
101~333
N
25
25
103~125
103~224
M:
20%
50
50
103~105
103~224
N:
30%
100
103~104
Z:-20%~+80%
d01e345f>
Others can be manufactured by customers' requirement.
Nominal capacitance(pF)
9:%gAB
COLOR CODE MARKING CODE
mK9:
1st color zone
mt9:
2nd color zone
mu9:
3rd color zone
mK9:
1st color zone
mt9:
2nd color zone
mu9:
3rd color zone
mK/E
1st digit
mt/E
2nd digit
mu/E
3rd digit
k
Black
X 10 0(1)
i
Brown
1
1
X 10 1(10)
v
Red
2
2
X 10 2(100)
w
Orange
3
3
X 10 3(1000)
x
Yellow
4
4
X 10 4(10000)
5
5
X 10 5(100000)
6
6
7
7
8
8
9
9
X 10 - 1(0.1)
X 10 - 2(0.01)
j
Green
y
Blue
z
Purple
Gray
White
Gold
Silver
Q R : % & F150N ; 9 h F: i(1)+j(5)+k(0);
E.g. If nominal capacitance is 150, the color of brown+green+black should be marked.
mKn9hopqDnrs。
The width of the first line should be wider than others.
153
EXTERNAL DIMENSIONS
DIMENSIONS OF BULK PRODUCTS
( m m )
Dimensions (mm)
Type
φD
L
F(
φd
0.6)
H
03
3.0 Max
1.9 Max
5.08
7.5
10
0.42
0.05
20 Min
3.2 Max
2.2 Max
5.08
7.5
10
0.42
0.05
20 Min
TAPING DIMENSIONS
$(UNIT) :mm
L0
Z
L 1 -L 2
26 1.5
0.8Max
1.0Max
+2.0
-1.0
1.2Max
1.0Max
Tape Style
" # :26
Tape width:
" # :52
Tape width:
52
PACKAGING STYLE
AMMO PACKAGING
50P
CS/
Dimension (
Tape
5mm)
Type
D
B
A
B
C
D
52
76
72
263
26
55
72
263
Label
A
C
6*+
TAPE AND REEL
c*+
BULK PACKAGING
PACKAGING QUANTITY
6*+
c*+
Tape & Reel
Ammo
Bulk
5000Pcs
5000Pcs
1000Pcs
012345*+
Packaging according to customer' s requirement
155
Fe a t u r e
Miniature size,large capacitance,tape and reel packaging suitable for auto-placement
*!" # $ % ,& ' ( ) * + , - . 、 0 1 2 3
4 5 。
Epoxy resin coating creates excellent performance in humidity resistance,mechanical strength
and heat resistance
*78 9 : ; < = >
? @ A : B 。
Standard size,various lead configuration
MLCC
Reliability and Test Methods for General Leaded MLCC
CD
Item
NOPQ
Technical Specification
ⅠS
ClassⅠ
fgh
Test Method and Remarks
UVWXYZ[\
within the specified
tolerance.
;i
Capacitance
jk
Measuring
Frequency
≤1000pF
1MHZ 10%
Ll
Measuring
Voltage
1.0 0.2V
>1000PF
Capacitance
(C)
1KHZ
10%
mnⅡSLo,qUrstu
The capacitor should be pretreated before measured.
(only for classⅡ).
ⅡS
Class Ⅱ
UVWXYZ[\
within the specified tolerance.
1KHZ
D F≤0 . 1 5 %
C R≥5 0 p F
(150 / CR)+7]X10
D F≤1. 5[
B
10%
1.0
≤1000pF
-4
ⅡS
ClassⅡ
jk:1KHZ
≤7.5%(C R ≤0.1uF)
Y (F)
JKLM
Insulation
Resistance
≤10.0%
(1uF> C R > 0.1uF)
Ll:0.3
1KHZ
10%
10%
C≤10nF
IR≥10000MΩ
C>10nF
10%
0.2V
Measuring Voltage:0.3
0.2V
Ll:vXLl
R . C≥1 0 0 ΩF
ⅡS
ClassⅡ
10%
0.3
Measuring Voltage:Rated Voltage
C≤25nF
IR≥4000 MΩ
wx:60
5y
Duration:60 5s
C>25 nF
R . C≥1 0 0 ΩF
156
0.2V
L l
Measuring
Voltage
Ll:1.0 0.2V
Measuring Voltage:
Measuring Frequency:1kHz
≤15%(C R≥1uF)
ⅠS
ClassⅠ
1MHZ
jk:1KHZ 10%;
D F≤3 . 5 %
B
(DF)
0.2V
1.0
>1000pF
EFGHI
Dissipation
Factor
F(Y)
jk
Measuring
Frequency
;i
Capacitance
C R≥5 0 p F
ⅠS
ClassⅠ
Ll
MeasuringVoltage
jk
Measuring
Frequency
0.2V
很抱歉,暂时无法提供与“ACC-03B102K500P26”相匹配的价格&库存,您可以联系我们找货
