CT1-F5Y5V2A103MSPW
CT1-F5Y5V2A103MSPW
    FH(风华)
    CAP_D5X3.5MM_TM
    直插陶瓷电容/独石电容 CAP_D5X3.5MM_TM 10nF ±20% 50V Y5V
CT1-F5Y5V2A103MSPW 数据手册
CERAMIC DISC CAPACITOR Product Part Number Expression M 2 CT81 1 1 5 3 Y5V 4 5 5 B 6 102 7 M 8 T 9 E 10 Product Type Product Type Type code CC81 High voltage temperature compensation capacitor CT1 Low voltage high dielectric constant disk ceramic capacitor CT81 High voltage high dielectric constant disk ceramic capacitor CS1 Semiconductor disk ceramic capacitor CT7 Alternating current disk ceramic capacitor 2 Voltage Code F Code Rated Voltage 50V L N M 500V 1KV 2KV Q P 3KV 4KV S 6KV U W X Y 250 VAC 400VAC Z 8KV 10KV 15KV The Code Chip Diameter Range 3 Code 5 6 10 12 Diameter(mm) 4.5-5.4 5.5-6.4 9.5-10.4 11.5-12.4 4 ( EIA ) Temperature Characteristics ( temperature coefficient and EIA code): TemperatureCharacteristics USE code Temperature range EIA code Capacitance with temperature change rate NP0 C0H N750 U2J SL S2L Y5P Y5P Y5R Y5R Y5U Y5U +22/-56% Y5V Y5V +22/-82% 0 60PPM/ 750 120PPM/ +140~-1000PPM/ -25~-+85 10% 15% 207 5 Lead style Code lead Style 1 (16-28mm) Straight lead (16~28m) 3 short lead( cut the feet) 4 Tape straight lead 5 Tape small inside kink 6 Tape large inside kink Special Straight lead 7 6 9 Outside kink 0 vertical kink lead Lead Spacing B Code D 7.5 0.5 5.0 0.5 7 E K 10.0 0.5 12.5 0.5 Standard capacitance 100 10PF 560 56PF 821 820PF 102 1000PF ----- ----- pF 3 0 Note: The unit of standard capacitance if consisting of 3 digits, the first and second digits stand for effective value of the Standard capacitance;third digit indicates the number of zeros. 8 Capacitance Tolerance Code Tolerance 9 K 10% Z 20% +80%~-20% Packing style Code Packing style 10 M S T bulk Taping Coating style code Coating style E P Epoxy resin 208 Phenol resin CERAMIC DISC CAPACITOR Product Structure and Overall Dimensions Lead shape 209 Packing style Bulk Taping products Taping products ( P 0 =12.7mm F=5.0mm,F=7.5mm) Taping products(P 0 =15.0mm,F=7.5mm) Taping products(P 0 =15.0mm,F=10.0mm) 210 CERAMIC DISC CAPACITOR Packing style products paking Packing style Lead spacing F=5.0 Bulk F=7.5 Bulk Taping(P0=12.7mm D
CT1-F5Y5V2A103MSPW
物料型号:文档中提到了多种型号,例如CC81、CT1、CT81、CS1、CT7等,这些型号代表了不同类型的圆片瓷介电容器。
器件简介:圆片瓷介电容器是一种电子元件,用于储存电荷并具有不同的电压和容量规格。
引脚分配:文档中提到了不同的引脚样式代码,如直脚、短脚、编带直脚型、编带小内型、编带大内弯型等,这些代码描述了电容器的物理引脚形状和布局。
参数特性:包括温度特性、容量偏差、额定电压等。例如,Y5V、NP0等代表不同的温度特性,容量偏差有±5%、±10%、±20%等。
功能详解:文档中描述了不同型号电容器的电路应用,如CC81适用于要求损耗值小、容量稳定性高的电路,CT1、CT81适用于对损耗值和容量稳定性要求不高的电路。
应用信息:电容器可以用于多种电路中,包括振回路、高频旁路、温度补偿、控制电路的时间常数元件、耦合元件等。
封装信息:文档提供了电容器的封装尺寸,包括本体直径、本体厚度等,以及不同的包装风格,如散装、编带等。
CT1-F5Y5V2A103MSPW 价格&库存
很抱歉,暂时无法提供与“CT1-F5Y5V2A103MSPW”相匹配的价格&库存,您可以联系我们找货
