氧化膜电阻
FHMOR-*W***J
一. 品名 TYPE NAME
依据其种类,分别标明型号、额定功率、标称阻值、精度、和形态。
According to the types of power rated, resistor value, tolerance and shapes.
FHMOR
1/4W
10Ω
±5%
Type
Wattage
Nominal resistance
tolerance
型号
额定功率
标称阻值
误差
S(small):为体积小型化
二. 金属氧化膜电阻器结构图
METAL OXIDE FILM CONSTRUCTION
镀锡铜线 SOLDER PLATED COPPER LEAD WIRE
帽盖 END CAP
氧化金属皮膜 METAL OXIDE FILM
不燃性绝缘涂料 NONFLAMMABLE COATING
表示色环 COLOR CODING
螺旋切沟线 SPIRAL TRIMMING LINE
REMARK: 底漆颜色 COATING COLOR : 灰色(GREY)
三.特点 FEATURES
1. 具有大负荷下的优良耐久性.
GOOD DURABILITY UNDER HEAVY LOAD.
2. 不燃性绝缘涂装.
FLAME RETARDANT COATING WITH NON-FLAMABLE PAINT.
3.
标准误差:±5%(1%、±2%客户要求)
STANDARD TOLERANCES:±5%(1% ,±2%IS AVAILABLE ON REQUEST)
2. 环保无铅产品
RoHS COMPLIANT / LEAD-FREE AVAILABLE.
四.主要技术指标 MAIN SPECIFICATION
功率
POWER
最大工作电压
WORKING
最大负荷电压
MAX OVERLOAD
额定功率
RatedPowerat70℃
电阻范围
RESISTANCE
VALUE RANGE
MO 1/4W / I/4WS
200V
350V
0.25W
1Ω-22KΩ
MO 1/2W / 1/2WS
250V
400V
0.5W
1 Ω-75KΩ
MO 1W / 1WS
350V
600V
1W
MO 2W / 2WS
MO 3W / 3WS
MO 5W/ 5WS
350V
500V
750V
800V
800V
1000V
2W
3W
5W
1 Ω-100KΩ
1 Ω-120KΩ
1 Ω_ 150KΩ
1Ω _180KΩ
1.额定功率 POWER RATING
额定功率是指在环境温度 70℃最大输出功率,当环境温度超过 70℃时功率变化如下图:
Power rating is defined as maximum power rating continuously applied under ambient
temperature at 70℃.when the ambient temperature exceeds 70℃。
2. 额定电压 RATED VOLTAGE
额定电压为交流或直流电压(频率为 50Hz 或 60Hz)额定电压计算方式为:
Rated voltage is defined as the DC or AC (effective Value at commercial frequency
example 50 C/S,60 C/S),Voltage when rated power is applied and can be calculated
By the following:
V = √ P×R
V = RATED VOLTAGE V 标示电压
P = RATED POWER (WATTS) P 表示功率
R = NOMINAL RESISTANCE VALUE (OHM)
R 表示阻值
When the calculated rated voltage exceeds the Maximum usable voltage flue shown
in CHART, the Maximum usable voltage is defined as the voltage According to the
power-decreasing curve shown in CHART.
3.产品性能 PERFORMANCE
项目
ITEM
性能及验收标准
测试方法
PERFORMANCE AND QUALIITY
ACCEPTANCE
TEST METHOD
106
R – RO
PPM/℃ =
温度系数
Resistance to
temperature
coefficient
短时负荷
Short time overload
耐电压
Voltage endurance
RO
±350PPM/℃
T-
T0
R = Measured resistance(Ω)at T
T ℃ 电阻实测值(Ω)
Ro = Measured resistance (Ω)at To
To ℃ 电阻实测值(Ω)
T = Measured test temperature(℃)
测试温度的实测值
To = Measured base temperature( ℃)
基准温度的实测值
2.5 倍额定电压(交流或直流),5 秒。
±(2% + 0.1ohm)
Shall be no mechanical breakage AC or DC voltage 2.5times the rated
无破损(外观正常)
Voltage for 5 seconds .
No breakdown or flashover
无击穿或飞弧
将电阻放于“V”形槽内,加 1.42 倍
额定电压,保持一分钟.
Lay the resistor on the 90° angle
metal “V” peak is 1.42 times as much
as insulate voltage .
施加 3.5KG 30S 的拉力
端子强度
Terminal strength
耐焊性
Heat resistively
against soldering
内外部无损伤
Pull test apply 3.5KG force to the
Shall be no mechanical breakage lead in the direction of lead axis for
30±5 seconds.
将电阻引出端浸入 350℃ ± 10℃的
锡中,深度离电阻体 3±0.05mm,时
间 3.5±0.5 秒。放置一小时再测试。
± (1% + 0.05ohm)
Dip the lead in to a solder bath
无破损(外观正常)
having a temperature of 350 ℃ ±
10℃ up to 3±0.05mm from the body
of the resistor and hold it for 3.5 ±
0.5seconds leave the resistor ,at
room temperature 1 hours after ,then
Measure.
项目
ITEM
寿命试验
Load life test
上锡效果
Solder ability
湿度负荷试验
Humidity load test
性能及验收标准
ACCEPTANCE
测试方法
TEST METHOD
在 70℃的环境中施加额定电压,1 小
时通,0.5 小时断 1000 小时。
±(5%+ 0.1ohm)
Shall be no mechanical breakage In
the
constant
temperature
无破损(外观正常)
chamber 70 ℃ ,apply rated voltage
for 1 hour and shut voltage for 0.5
hour and repeat this cycle for 1000
hours,
吃锡面积≥95%
Solder area≥95%
浸入 260℃±5℃的锡槽中,
时间 5± 0.5 秒。
having a temperature of 260℃±5℃.
Time:5± 0.5seconds。
温度在 40℃± 2℃,相对湿度 90 95%室内,用额定电压 1.5 小时开和
关闭电压 0.5 小时 ,重复这个 周 期
± (5% + 0.1ohm)
Shall be no mechanical breakage 1000 小时,离开 1 小时后在室温下测
试。
无破损(外观正常)
In temperature chamber 40℃±2℃,
relative humidity 90 – 95%,Apply
rated voltage 1.5hour and shut
voltage 0.5 hour repeat this cycle for
1000 hours, leave in room
temperature for 1 hour after test,
不燃性
Flammability
不燃烧现象
No evidence of flaming
本体用试验火焰烧 15 秒,离开 15 秒,
5 次.
The test flame shall be applied and
removed
for
15
secretary
respectively,and repeated cycle for
5times.
五. 标示 Marking
Color
1 st Band
2 nd Band
3 th Band
Tolerance
Black
黑
Brown
棕
1
1
101
±1﹪
(F)
Red
红
2
2
102
±2﹪
(G)
3
Orange
橙
3
3
10
Yellow
黄
4
4
104
Green
绿
5
5
105
±0.5﹪ (D)
±0.25﹪(C)
Blue
蓝
6
6
106
Violet
紫
7
7
107
±0.1﹪ (B)
Grey
灰
8
8
108
±0.05﹪(A)
9
9
White
白
Gold
金
10-1
±5﹪
(J)
银
10-2
±10﹪
(K)
Silver
9
10
六. B 型尺寸 Dimension(B)
Unit: mm/mm
POWER
L
D
H
1/4W / 1/2WS / 1WS
1/2W / 1WS
1W
2WS
2W / 3WS
6.0±0.5
9.0±1.0
11.0±1.0
11.0±1.0
15.0±1.0
17.0±1.0
24.0±1.0
2.3±0.3
3.5±0.5
4.5±0.5
4.5±0.5
5.0±0.5
6.0±0.5
8.0±1.0
27.0±2.0
26.0±2.0
30.0±2.0
30.0±2.0
32.0±2.0
31.5±2.0
28.0±2.0
3W /5WS
5W
d ±0.02m PULLING(Kg)
0.45±0.02
0.50±0.02
0.60±0.02
0.65±0.05
0.65±0.05
0.70±0.05
0.70±0.05
2.5Kg-30S
2.5Kg-30S
3.0Kg-30S
3.0Kg-30S
5.0Kg-30S
5.0Kg-30S
5.0Kg-30S
七. 编带尺寸 Taping Dimension(TB)
E
D1
D2
P
I
Z
S
TB
W
Unit: mm/mm
Type
TB
P±0.5
W±0.5
(D1-D2)
MAX
T 26
26±1.5
5
6
0.8
T 52
52±1.5
5
6
0.8
T 52
52±1.5
5
6
T52
52±1.5
5
T 63
63±1.5
T63
S
MAX
(I)
MAX
1.2
0.8
3.2
0.8
3.2
0.8
0.8
3.2
6
0.8
0.8
3.2
5
6
0.8
0.8
3.2
63±1.5
5
6
0.8
0.8
3.2
T 73
73±1.5
5
6
0.8
0.8
3.2
3W / 5WS
T 73
73±1.5
10
6
0.8
0.8
3.2
5W
T 73
73±1.5
10
6
0.8
0.8
3.2
POWER
1/4W / 1/2WS
1/2W / 1WS
1W / 2WS
2W / 3WS
E MAX Z MAX
八.
包装 PACKING
1. 标签规格 LABEL SPECIFICATION
TYPE、WATTS
型号、功率
RESISTOR VALUE AND TOLERANCE 阻值、误差
QUANTITY
数量
LOT NO.
生产批号
1).
2).
3).
4).
2. 包装数量 Packing quantity
Unit: BOX / Kpcs
TYPE
1/4W
1/2W
1W
2W
3W
5W
T26
5
NA
NA
NA
NA
NA
T52
5
2.5
1
1
NA
NA
T63
NA
NA
1
1
0.5
0.25
T73
NA
NA
1
1
0.5
0.25
B
10
5
4
3
2
1
F
10
5
4
3
2
1
M
10
5
4
3
2
1
MB
NA
NA
4
3
2
1
MK
NA
NA
4
3
2
1
QTY
很抱歉,暂时无法提供与“FHMOR-1W1R0J”相匹配的价格&库存,您可以联系我们找货
