0805B221K501NT
0805B221K501NT
    FH(风华)
    贴片电容(MLCC) 0805 220pF ±10% 500V X7R
0805B221K501NT 数据手册
编号:GH-ZD4132E 版本号:2 承 认 书 APPROVAL SHEET 客户名称 CUSTOMER : 多层片状陶瓷电容器 Multilayer Chip Ceramic Capacitors 产品名称 PART NAME: 规格 SPECIFICATION: 0201~2225TYPE 版本 VERSION: 日期 DATE OF ISSUE: 制 造 客 户 MANUFACTURER CUSTOMER 拟制 审核 批准 检验 审核 批准 DESIGN CHECK APPROVAL INSPECTOR CHECK APPROVAL 附件 7 版本号:FH-2022-001 一、概述 ●电容器及介质种类: ※高频类: 此类介质材料的电容器为Ⅰ类电容器,包括通用型高频 COG、COH 电容器和温度补偿型高频 HG、 LG、PH、RH、SH、TH、UJ、SL 电容器。其中 COG、COH 电容器电性能最稳定,几乎不随温度、电压和时 间的变化而变化,适用于低损耗,稳定性要求高的高频电路,HG、LG、PH、RH、SH、TH、UJ、SL 电容器 容量随温度变化而相应变化,适用于低损耗、温度补偿型电路中。 ※ X7R、X5R、X7S、X6S:此类介质材料的电容器为Ⅱ类电容器,具有较高的介电常数,容量比Ⅰ类电容器 高,具有较稳定的温度特性,适用于容量范围广,稳定性要求不高的电路中,如隔直、耦合、旁路、鉴频等电 路中。 ※Y5V:此类介质材料的电容器为Ⅱ类电容器,是所有电容器中介电常数最大的电容器,但其容量稳定性较差, 对温度、电压等条件较敏感,适用于要求大容量,温度变化不大的电路中。 ※Z5U:此类介质材料的电容器为Ⅱ类电容器,其温度特性介于 X7R 和 Y5V 之间,容量稳定性较差,对温度、 电压等条件较敏感,适用于要求大容量,使用温度范围接近于室温的旁路,耦合等,低直流偏压的电路中。 ●执行标准:GH/T 21041-2007 GH/T 21042-2007 SUMMARY ●Types of Dielectric Material and Capacitor ※HIGH FREQUENCY TYPE: The capacitor of this kind dielectric material is considered as ClassⅠcapacitor, including high frequency COG、COH capacitor and temperature compensating capacitor such as HG, LG, PH, RH,SH, TH, UJ, SL. The electrical properties of COG、COH capacitor are the most stable one and change invariablly with temperature, voltage and time. They are suited for applications where low-losses and high-stability are required, HG,LG,PH,RH,SH,TH,UJ,SL capacitor’s capacitance changes with temperature.They are suited for applications where low-losses and temperature compensating circuits. ※X7R、X5R、X7S、X6S:X7R、X5R、X7S、X6S material is a kind of material has high dielectric constant. The capacitor made of this kind material is considered as Class Ⅱ capacitor whose capacitance is higher than that of class Ⅰ . These capacitors are classified as having a semi-stable temperature characteristic and used over a wide temperature range, such in these kinds of circuits, DC-blocking, decoupling, bypassing, frequency discriminating etc. ※Y5V:The capacitor made of this kind of material is the highest dielectric constant of all ceramic capacitors. They are used over a moderate temperature range in application where high capacitance is required because of its unstable temperature coefficient, but where moderate losses and capacitance changes can be tolerated. Its capacitance and dissipation factors are sensible to measuring conditions, such as temperature and voltage, etc. ※Z5U:The capacitor made of this kind of material is considered as ClassⅡ capacitor, whose temperature characteristic is between that of X7R and Y5V. The capacitance of this kind of capacitor is unstable and sensible to temperature and voltage. Ideally suited for bypassing and decoupling application circuits operating with low DC bias in the environment approaches to room temperature. ●Executive Standard: GH/T 21041-2007 第 1 页 GH/T 21042-2007 共 32 页 DIMENSIONS AND STRUCTURE 二、尺寸及结构 ※ 尺寸 DIMENSIONS L L W W T WB WB ●≤50V 通用产品 型号 Type 尺寸 英制表示 公制表示 介质种类 British Metric Dielectric Dimensions (mm) 特别说明 Special Instructions L W T WB 0.4±0.02 0.2±0.02 0.2±0.02 0.1±0.03 All 0.6±0.03 0.3±0.03 0.3±0.03 0.15±0.05 C<220nF All Dielectric 0.6±0.05 0.3±0.05 0.3±0.05 0.15±0.05 C≥220nF 1.00±0.05 0.50±0.05 0.50±0.05 0.25±0.05 C<0.33uF expression expression 1005 0402 0201 0603 所有介质 All Dielectric 所有介质 Y5V/Z5U 0402 1005 除 Y5V/Z5U 外 1.00±0.15 0.50±0.10 0.50±0.10 1.00±0.05 0.50±0.05 0.50±0.05 1.00±0.15 0.50±0.15 0.50±0.15 1.00±0.20 0.50±0.20 0.50±0.20 0603 1608 0.25±0.05 0.25±0.05 0.25±0.05 0.25±0.05 2012 C<1uF 1uF≤C<10uF C≥10uF 1.60±0.10 0.80±0.10 0.80±0.10 0.35±0.20 C≤1uF All Dielectric 1.60±0.20 0.80±0.20 0.80±0.20 0.35±0.20 C>1uF 所有材料 2.00±0.20 1.25±0.20 0.70±0.10 0.50±0.20 0805 0.33uF≤C≤1uF Y5V/Z5U C≤0.22uF 2.00±0.20 1.25±0.20 0.80±0.10 0.50±0.20 0.22uF<C≤2.2uF 2.00±0.20 1.25±0.20 1.25±0.20 0.50±0.20 2.2uF<C≤10uF 第 2 页 共 32 页 ●≤50V 通用产品 型号 Type 尺寸 2012 WB 除 Y5V/Z5U 2.00±0.20 1.25±0.20 0.80±0.20 外 2.00±0.20 1.25±0.20 1.25±0.20 0.50±0.20 C≤2.2μF 0.50±0.20 C≥0.47μF 3.20±0.30 1.60±0.30 0.80±0.20 0.60±0.30 C≤10μF 3.20±0.30 1.60±0.30 1.60±0.30 0.60±0.30 C>10μF 3.20±0.30 1.60±0.30 0.80±0.20 0.60±0.30 C≤330nF Y5V/Z5U 1206 3216 (mm) 特别说明 Special Instructions 介质种类 Dielectric 英制表示 公制表示 British Metric expression expression 0805 Dimensions L W T 除 Y5V/Z5U 3.20±0.30 1.60±0.30 1.00±0.20 外 3.20±0.30 1.60±0.30 1.25±0.20 3.20±0.30 1.60±0.30 1.60±0.30 1210 3225 所有介质 3.20±0.30 2.50±0.30 All Dielectric ≤2.80 0.60±0.30 330nF<C<470nF 0.60±0.30 470nF≤C<2.2μF 0.60±0.30 C≥2.2μF 0.60±0.30 All 所有介质 All ≤2.20 0.60±0.30 All Dielectric 4.50±0.40 2.00±0.20 所有介质 All 1812 4532 4.50±0.40 3.20±0.30 ≤3.50 0.60±0.30 All Dielectric 所有介质 All 2220 5750 ≤3.50 0.60±0.30 All Dielectric 5.70±0.40 5.00±0.40 所有介质 All 2225 5763 5.70±0.50 6.30±0.50 ≤6.20 0.60±0.30 All Dielectric 备注:1、产品具体厚度“T”查阅本承认书中“容量范围及其电压”。 2、可根据客户的特殊要求设计符合客户需求的产品。 Note:1、The specific thickness of the product can read "capacity range and voltage "in this approval sheet. 2、We can design according to customer special requirements 1808 4520 第 3 页 共 32 页 ●>50V 中高压产品 型号 Type 尺寸 英制表示 公制表示 Metric British expression expression 0402 0603 Dimensions (mm) L W T WB 1005 1.00±0.05 0.50±0.05 0.50±0.05 0.25±0.05 1608 1.60±0.10 0.80±0.10 0.80±0.10 0.35±0.20 ≤0.55 0805 2012 2.00±0.20 0.80±0.20 1.25±0.20 1.00±0.20 0.50±0.20 1.25±0.20 0.80±0.20 1206 3216 3.20±0.30 1.00±0.20 1.60±0.30 1.25±0.20 0.60±0.30 1.60±0.30 1210 3225 3.20±0.30 2.50±0.30 ≤2.80 0.60±0.30 1808 4520 4.50±0.40 2.00±0.20 ≤2.20 0.60±0.30 1812 4532 4.50±0.40 3.20±0.30 ≤3.50 0.60±0.30 2220 5750 5.70±0.40 5.00±0.40 ≤3.50 0.60±0.30 2225 5763 5.70±0.50 6.30±0.50 ≤6.20 0.60±0.30 备注:1、产品具体厚度“T”查阅本承认书中“容量范围及其电压”。 2、可根据客户的特殊要求设计符合客户需求的产品。 Note:1、The specific thickness of the product can read "capacity range and voltage "in this approval sheet. 2、We can design according to customer special requirements ※ 结构 STRUCTURE W 序号 NO L ① T ② ③ ① ② ③ ④ ⑤ ④ ⑤ 第 4 页 名称 Name 陶瓷介质 Ceramic dielectric 内电极 Inner electrode 外电极 Substrate electrode 镍层 Nickel Layer 锡层 Tin Layer 共 32 页 HOW TO ORDER 三、型号规格表示方法 0805 CG 101 J 500 N T ② ③ ④ ⑤ ⑥ ⑦ ① ※说明 NOTES: ①尺寸 DIMENSIONS 尺寸规格 1005 0201 0402 SizeCode 长×宽 0.01 0.02 0.04 (L×W) × × × inch 0.005 0.01 0.02 长×宽 (L×W) mm 0603 0805 1206 1210 1808 1812 2220 2225 0.06 0.08 0.12 0.12 0.18 0.18 0.22 0.22 × × × × × × × × 0.03 0.05 0.06 0.10 0.08 0.12 0.20 0.25 0.40 0.60 1.00 1.60 2.00 3.20 3.20 4.50 4.50 5.70 5.70 × × × × × × × × × × × 0.20 0.30 0.50 0.80 1.25 1.60 2.50 2.00 3.20 5.00 6.30 ② 介质种类 DIELECTRIC STYLE 介质种类 (DielectricCode) CG CH 介质材料 CO CO (Dielectric) G H HG LG PH RH SH TH UJ SL HG LG PH RH SH TH UJ SL X B BS DS E F X5 X7 X7 X6 Z5 Y5 R R S S U V ③ 标称容量 NOMINAL CAPACITANCE 单位(unit):pF 表示方式 实际值 (Express Method) (Actual Value) 0R5 0.5 1R0 1.0 102 10×102 224 22×104 … … 注:头两位数字为有效数字,第三位数字为 0 的个数;R 为小数点。 Note: the first two digits are significant; third digit denotes number of zeros; R=decimal point. ④ 容量误差 CAPACITANCE TOLERANCE 代码 (Code) A B C D F G J 误差 ± ± ± ± ± ± ± 0.05pF 0.10pF 0.25pF 0.5pF 1.0% 2.0% 5.0% (Tolerance) K ±10% M ±20% S Z +50% -20% +80% -20% 备注:A、B、C、D 级误差适用于容量≤10pF 的产品。 Note:These capacitance tolerance A,B, C, D are just applicable the capacitance that equals to or less than 10pF。 第 5 页 共 32 页 ⑤ 额定电压 RATED VOLTAGE 表示方式 实际值 (Express Method) (Actual Value) 6R3 6.3 500 50×100 201 20×101 102 10×102 … … 单位(unit):V 注:头两位数字为有效数字,第三位数字为 0 的个数; R 为小数点。 Note: the first two digits are significant; third digit denotes number of zeros; R=decimal point. ⑥ 端头材料 TERMINAL MATERIAL STYLES 端头类别 (Termination Styles) 表示方式 (Express Method) 纯银端头 (Silver Solderable Termination) S 纯铜端头 (Copper Solderable Termination) C 三层电镀端头 (Nickel Barrier Termination) N ⑦ 包装方式 PACKAGE STYLES B T 散包装(Bulk Bag) 编带包装(Taping Package) 四、温度系数/特性 Temperature Coefficient /Characteristics 介质种类 Dielectric 参考温度点 Reference Temperature Point 标称温度系数 Temperature Coefficient 工作温度范围 Operation Temperature Range COG 20C 030 ppm/℃ -55℃~125℃ COH 20C 060 ppm/℃ -55℃~125℃ HG 20C -3330 ppm/℃ -25℃~85℃ LG 20C -7530 ppm/℃ -25℃~85℃ PH 20C -150 60 ppm/℃ -25℃~85℃ RH 20C -220 60 ppm/℃ -25℃~85℃ SH 20C -330 60 ppm/℃ -25℃~85℃ TH 20C -470 60 ppm/℃ -25℃~85℃ UJ 20C -750 120 ppm/℃ -25℃~85℃ SL 20C X7R 20C -1000~+140 ppm/℃ 15% -25℃~85℃ -55℃~125℃ X5R 20C 15% -55℃~85℃ X7S 20C 22% -55℃~125℃ X6S 20C 22% -55℃~105℃ Z5U 20C -56%~+22% 10℃~85℃ Y5V 20C -80%~+30% -25℃~85℃ 备注:Ⅰ类电容器标称温度系数和允许偏差是采用温度在 20C 和 85C 之间的电容量变化来确定的,而Ⅱ类 电容器标称温度系数是按照工作范围之间的电容量相对 20C 的电容量变化来确定的。 Note : Nominal temperature coefficient and allowed tolerance of class Ⅰ are decided by the changing of the capacitance between 20  C and 85  C. Nominal temperature coefficient of class Ⅱ are decided by the temperature of 20C. 第 6 页 共 32 页 五、容量范围及其电压 Capacitance Range and Operating Voltage 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. 容量范围 Capacitance 尺寸规格 额定电压 Size Code Rated Voltage COG(NPO)(PF) Y5V (Z5U)(PF) 6.3V —— —— 10V 0.1~220【0.2】 —— 16V 0.1~100【0.2】 —— 25V 0.1~100【0.2】 —— 50V —— —— 6.3V —— 10,000~100,000【0.3】 10V —— —— 16V —— 10,000【0.3】 25V 0.1~1,000【0.3】 —— 50V 0.1~220【0.3】 —— 6.3V 3,300~4,700【0.5】 1,000~1,000,000【0.5】 10V 1,200~2,700【0.5】 1,000~1,000,000【0.5】 16V 1,200~2,700【0.5】 1,000~220,000【0.5】 25V 0.1~1,200【0.5】 1,000~220,000【0.5】 50V 0.1~1,000【0.5】 1,000~100,000【0.5】 6.3V —— 2,700,000~10,000,000【0.8】 10V 12,000~22,000【0.8】 2,700,000~10,000,000【0.8】 16V 8,200~10,000【0.8】 1,000~2,200,000【0.8】 25V 0.1~6,800【0.8】 1,000~2,200,000【0.8】 50V 0.1~6,800【0.8】 1,000~1,000,000【0.8】 1005 0201 0402 0603 第 7 页 共 32 页 容量范围 Capacitance 尺寸规格 额定电压 Size Code Rated Voltage COG(NPO)(PF) Y5V (Z5U)(PF) 6.3V —— 2,700,000~22,000,000【0.8】 10V 10,000~100,000【1.25】 2,700,000~22,000,000【0.8】 16V 10,000~33,000【1.25】 2,700,000~10,000,000【0.8】 25V 10,000~27,000【1.25】 2,700,000~4,700,000【0.8】 0805 0.1~8,200【0.8】 50V 1206 10,000~22,000【1.25】 6.3V —— 22,000,000~47,000,000【1.6】 10V —— 22,000,000【1.6】 16V —— 22,000,000【1.6】 25V —— 4,700,000~10,000,000【0.8】 0.3~8,200【0.8】 50V 1210 1808 1812 第 1,000~2,200,000【0.8】 10,000~100,000【1.6】 1,000~4,700,000【0.8】 6.3V —— 10,000,000~100,000,000【2】 10V —— 10,000,000~47,000,000【2】 16V —— 10,000,000~22,000,000【2】 25V —— 6,800,000~10,000,000【1.25】 50V 10~100,000【1.25】 4,700~4,700,000【1.25】 50V 10~100,000【1.6】 —— 6.3V —— 10,000~100,000,000【1.6】 10V —— 10,000~100,000,000【1.6】 16V —— 10,000~22,000,000【1.6】 25V —— 10,000~10,000,000【1.6】 50V 10~100,000【1.25】 10,000~10,000,000【1.6】 8 页 共 32 页 尺寸规格 容量范围 Capacitance 额定电压 Size Code Rated Voltage 1005 0201 0402 X7R (nF) X7S(μF) X5R(μF) X6S(μF) 4V/6.3V —— —— 0.015~0.1【0.2】 —— 10V/16V 0.1~1【0.2】 —— 0.015~0.01【0.2】 —— 4V —— 0.01~1【0.3】 6.3V 0.015~2.2 【0.3】 0.015~2.2【0.3】 —— 0.01~0.22【0.3】 0.015~2.2 【0.3】 0.015~2.2【0.3】 10V 0.1~22【0.3】 0.01~0.22【0.3】 0.015~2.2 【0.3】 0.015~0.1【0.3】 16V 0.1~22【0.3】 —— 0.015~0.22【0.3】 0.015~0.1【0.3】 25V 0.1~10【0.3】 —— 0.015~0.1【0.3】 0.015~0.1【0.3】 50V 0.1~1【0.3】 —— 0.0047~0.01【0.3】 —— 4V —— —— 0.1~22 【0.5】 0.1~22 【0.5】 6.3V 0.1~470【0.5】 0.1~0.47【0.5】 0.1~22 【0.5】 0.1~22 【0.5】 10V 0.1~470【0.5】 0.1~0.47【0.5】 0.1~10 【0.5】 0.1~10 16V 0.1~220【0.5】 0.047~0.22【0.5】 0.1~4.7 【0.5】 0.1~4.7 【0.5】 25V 0.1~220【0.5】 50V 0.1~100【0.5】 0.0047~0.1【0.5】 4V 0603 0.1~1 【0.5】 0.047~1【0.5】 —— 【0.8】 0.1~47 【0.8】 6.3V 0.15~4,700【0.8】 0.47~2.2【0.8】 0.47~47 【0.8】 0.1~47 【0.8】 10V 0.15~2,200【0.8】 0.47~2.2【0.8】 0.47~22【0.8】 0.1~10 【0.8】 16V 0.15~2,200【0.8】 0.47~1【0.8】 0.47~10【0.8】 0.1~10 【0.8】 25V 0.15~1,000【0.8】 0.47~1【0.8】 0.47~10【0.8】 0.1uF~4.7 【0.8】 50V 0.15~1,000【0.8】 —— 0.47~2.2【0.8】 4V —— —— 1~47【1.25】 6.3V 0.15~470【0.8】 560~10,000【1.25】 1~10【1.25】 1~47【1.25】 10V 0.15~470【0.8】 560~10,000【1.25】 1~10【1.25】 16V 0.15~470【0.8】 1~4.7【1.25】 560~10,000【1.25】 第 9 页 —— 0.1~2.2 【0.5】 0.47~47 0805 —— 0.022~0.1【0.5】 【0.5】 1~47 —— 0.1~0.47【0.8】 0.56~47【1.25】 0.1~0.47【0.8】 0.56~22【1.25】 0.1~0.47 【0.8】 【1.25】 0.56~47 【1.25】 0.1~0.47【0.8】 0.56~10【1.25】 1~22【1.25】 共 32 页 尺寸规格 额定电压 Size Code Rated 容量范围 Capacitance X7R (nF) Voltage 0.15~470【0.8】 25V 560~4,700【1.25】 0805 X7S (μF) X5R(μF) 1~4.7【1.25】 1~22【1.25】 —— 1~4.7【1.25】 0.15~470【0.8】 50V 560~2,200【1.25】 4V —— 2.2~100【1.6】 X6S(μF) 0.1~1.5 【0.8】 2.2~100 【1.6】 0.2~330【0.8】 470~1,500【1.25】 2.2~22 【1.6】 6.3V 2.2~100 【1.6】 2,200~22,000【1.6】 0.2~330【0.8】 470~1,500【1.25】 2.2~22 【1.6】 10V 2.2~47 【1.6】 0.1~0.47【0.8】 0.56~10【1.25】 —— 2.2~100 【1.6】 0.1~1.5 【0.8】 2.2~100 【1.6】 0.1~1.5 2.2~47 【0.8】 【1.6】 0.1~1.5 【0.8】 2.2~47 【1.6】 0.1~1.5 【0.8】 2.2~10 【1.6】 2,200~22,000【1.6】 1206 0.2~330【0.8】 16V 470~1,500【1.25】 2,200~22,000【1.6】 0.2~330【0.8】 25V 470~1,500【1.25】 2,200~22,000【1.6】 0.2~330【0.8】 50V 470~1,500【1.25】 2,200~10,000【1.6】 第 10 页 1~1.5 【0.8】 2.2~10 【1.6】 1~1.5 【0.8】 2.2~10 【1.6】 1~1.5 【0.8】 2.2~10 【1.6】 2.2~47 【1.6】 2.2~22 【1.6】 2.2~10 【1.6】 共 32 —— 页 尺寸规格 额定电压 Size Code Rated 容量范围 Capacitance X7R (nF) Voltage X7S (μF) 4V —— 6.3V 10V 25V 50V 560~47,000【1.6】 12~100【2.5】 12~330【2.5】 12~330【2.5】 0.1~0.47【1.25】 0.56~10【1.6】 12~100【2.5】 0.1~0.47【1.25】 4.7~10【1.6】 0.56~10【1.6】 12~100【2.5】 12~100【2.5】 0.1~0.47【1.25】 0.22~470【1.25】 2,2~10【1.6】 4.7~10【1.6】 560~22,000【1.6】 15~22【2.5】 12~100【2.5】 0.22~470【1.25】 2,2~10【1.6】 4.7~10【1.6】 0.1~0.47【1.25】 560~22,000【1.6】 15~22【2.5】 12~47【2.5】 0.56~22【1.6】 4.7~10【1.6】 —— 0.22~470【1.25】 560~10,000【1.6】 1808 0.56~10【1.6】 12~330【2.5】 4.7~10【1.6】 —— 0.1~0.47【1.25】 4.7~10【1.6】 4.7 ~ 10 【 1.6 】 560~47,000【1.6】 16V X6S(μF) 0.22~470【1.25】 0.22~470【1.25】 1210 —— X5R(μF) 1~10【1.6】 0.56~10【1.6】 12~47【2.5】 6.3V 0.22~4,700【1.6】 —— 4.7~100【1.6】 —— 10V 0.22~4,700【1.6】 —— 4.7~47【1.6】 —— 16V 0.22~4,700【1.6】 —— 4.7~22【1.6】 —— 25V 0.22~4,700【1.6】 —— 4.7~10【1.6】 —— 50V 0.22~4,700【1.6】 —— —— —— 第 11 页 共 32 页 容量范围 Capacitance 尺寸规格 额定电压 Size Code Rated Voltage X7R (PF) X7S (μF) X5R(μF) X6S(μF) 6.3V —— —— 10~100【2.5】 —— 10V —— —— 10~47【2.5】 —— 16V 0.47~1,000【1.6】 —— 4.7~22【2.5】 —— —— 4.7~10【2.5】 —— —— —— —— 1812 1,200~6,800【2.5】 25V 0.47~1,000【1.6】 1,200~4,700【2.5】 50V 0.47~1,000【1.6】 1,200~4,700【2.5】 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. 第 12 页 共 32 页 HIGH VOLTAGE MLCC 六、中高压电容器 中高压多层片状陶瓷电容器是在多层片状陶瓷电容器的工艺技术、设备基础上,通过采用特殊工艺制 作的一种具有良好高压可靠性的产品,该产品适合于表面贴装,适合于多种直流高压线路,可以有效的改 善电子线路的性能。 ●应用范围 ※模拟或数字调制解调器 。 ※局域网/广域网接口界面。 ※日光灯启动辉器照明电路。 ※倍压电器。 ※直流变送器。 ※背光源驱动电路。 Middle & high voltage MLCC is a kind of special design 、 special technology MLCC that bases on the technology of general MLCC. This kind of MLCC has stable high voltage reliability and suitable to SMT. Middle & high MLCC is widely applicable for many direct high voltage circuits in which it can improve the performance of the circuit. ●APPLICATIONS ※Analog & Digital Modems ※LAN/WAN Interface ※Lighting Ballast Circuits ※Voltage Multipliers ※DC-DC Converters ※Back-lighting Inverters ●容量范围及其电压 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. . 尺寸规 格 Size Code 容量范围 Capacitance 工作电压 Rated Voltage 0402 0603 NPO(pF) X7R(nF) Y5V(nF) 100V 0.1~100【0.5】 0.15~4.7【0.5】 —— 100V 0.1~1,000【0.8】 0.150~100【0.8】 200V 0.1~470【0.8】 0.15~10【0.8】 2.2~100【0.8】 —— 250V 0.1~470【0.8】 0.15~10【0.8】 100V 0.1~3,300【0.8】 200V~250V 0805 500V~630V 1000V 第 13 页 0.1~1,000【0.8】 0.150~56 0.1~330【0.8】 470~560【1.25】 0.1~100【1.25】 【0.8】 68~220 【1.25】 0.15~18 【0.8】 1,200~1,500【1.25】 20~22 10~100【0.8】 10~47【0.8】 【1.25】 0.150~5.6 6.8~10 —— 【0.8】 —— 【1.25】 —— —— 共 32 页 单位/unit: pF 容量范围及其电压 尺寸规格 Size Code 工作电压 Rated Voltage 容量范围 Capacitance NPO(pF) X7R(nF) Y5V(nF) 0.150~56【0.8】 100V 0.1~3,300【0.8】 68~330【1.25】 15~470【0.8】 470~1,000【1.6】 200V~250V 1206 0.1~1,800【0.8】 2,000~2,700【1.25】 0.1~10【0.8】 500V~630V 11~470【1】 560~1,500【1.25】 1000V 0.150~20【0.8】 22~150【1.25】 10~220【0.8】 180~220【1.6】 0.150~2.7【0.8】 —— 3.3~33【1.25】 0.1~220【1】 0.150~1【0.8】 271~1,000【1.25】 1.1~12【1.25】 —— 0.1~39【1】 2000V 47~68【1.25】 0.150~2.7【1.25】 —— 82~270【1.6】 1210 100V 1.0~6,800【1.25】 0.15~220【1.25】 330~2,200【1.6】 15~1,000【1.25】 200V~250V 1.0~3,300【1.25】 0.150~150【1.25】 180~220【1.25】 15~470【1.25】 500V~630V 1.0~1,200【1.25】 1,500~2,200【1.6】 0.150~56【1.25】 68~100【1.6】 —— 1000V 1.0~680【1.25】 820~1,200【1.6】 0.150~3.9【1.25】 4.7~22【1.6】 —— 2000V 1.0~270【1.25】 300~470【1.6】 0.150~2.7【1.25】 3.3~10【1.6】 —— 第 14 页 共 32 页 单位/unit: pF 容量范围及其电压 尺寸规格 Size Code 容量范围 Capacitance 工作电压 Rated Voltage NPO(pF) X7R(nF) Y5V(nF) 100V 2.0~4,700【1.6】 0.220~2,200【1.6】 150~1,000【1.25】 200V~250V 2.0~3,900【1.6】 0.22~220【1.6】 10~390【1.25】 500V~630V 2.0~2,700【1.6】 0.220~68【1.6】 —— 1000V 2.0~1,000【1.6】 0.15~22【1.6】 —— 2000V 2.0~470【1.6】 0.15~10【1.6】 —— 3000V 2.0~330【1.6】 0.15~4.7【1.6】 —— 4000V 2.0~33【1.6】 0.15~2.2【1.6】 —— 5000V 2.0~33【1.6】 —— —— 100V 3.0~10,000【1.25】 0.27~560【1.6】 680~1,000【2】 150~2,200【1.6】 200V~250V 3.0~6,800【1.25】 0.27~220【1.6】 330~560【2】 100~470【1.6】 500V~630V 3.0~1,000【1.25】 1,200~4,700【1.6】 0.27~100【1.6】 120~220【2】 —— 1000V 3.0~1,200【1.6】 0.27~47【1.6】 56【2】 —— 2000V 3.0~1,000【1.6】 0.27~12【1.6】 —— 3000V 3.0~560【1.6】 0.27~4.7【1.6】 —— 4000V 3.0~220【1.6】 0.27~3.3【1.6】 —— 5000V 3.0~68【1.6】 —— —— 100V 3.0~22,000【1.6】 12~2,200【1.6】 150~2,200【1.6】 200V-250 3.0~8,200【1.6】 12~100【1.6】 120~1,200【2.5】 100~470【1.6】 500V-630 3.0~5,600【1.6】 1~470【1.6】 —— 1000V 3.0~1,800【1.6】 1~100【1.6】 —— 2000V 3.0~1,000【1.6】 1~22【1.6】 —— 3000V 3.0~680【1.6】 1~10【1.6】 —— 4000V 3.0~470【1.6】 1~6.8【1.6】 —— 5000V 3.0~82【1.6】 —— —— 1808 1812 1825 第 15 页 共 32 页 尺寸规格 工作电压 Rated Voltage Size Code 容量范围 Capacitance 100V 200V~250V 500V~630V NPO(pF) 5.0~27,000【1.6】 5.0~12,000【1.6】 5.0~6,800【1.6】 1000V 5.0~3,900【1.6】 2000V 5.0~1,000【1.6】 3000V 4000V 5000V 5.0~680【1.6】 5.0~560【1.6】 5.0~120【1.6】 100V 5.0~27,000【1.6】 200V~250V 5.0~12,000【1.6】 500V~630V 1000V 2000V 3000V 4000V 5000V 5.0~6,800【1.6】 5.0~3,900【1.6】 5.0~1,000【1.6】 5.0~680【1.6】 5.0~560【1.6】 5.0~120【1.6】 2220 2225 X7R(nF) 22~2,200【1.6】 22~1,200【1.6】 1.5~470【1.6】 1.5~33【1.6】 39~150【2】 1.5~6.8【1.6】 22~47【2】 1.5~12【2】 1.5~8.2【2】 —— 2.2~1,500【1.6】 2,200【2】 2.2~680【1.6】 1,000~2,200【2】 2.2~470【1.6】 2.2~100【1.6】 2.2~47【1.6】 2.2~15【1.6】 2.2~6.8【1.6】 —— Y5V(nF) 150~1,500【1.6】 100~1,000【1.6】 —— —— —— —— —— —— 250~3,300【1.6】 220~2,200【1.6】 —— —— —— —— —— —— 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. 第 16 页 共 32 页 中高压电容器介质耐电强度的测试方法: Measurement method of dielectric withstanding voltage for high voltage MLCC 额定电压范围 Rated voltage range 耐电性能的测试方法 Measuring Method 施加额定电压的 200%, 5 秒, 最大电流不超过 50mA Force 200%Rated voltage for 5 second. Max..current should not exceed 50 mA. 施加额定电压的 150%, 5 秒, 最大电流不超过 50mA Force 150%Rated voltage for 5 second. Max..current should not exceed 50 mA. 施加额定电压的 120%, 5 秒, 最大电流不超过 50mA Force 120%Rated voltage for 5 seconds. Max..current should not exceed 50 mA. 施加额定电压的 120%, 5 秒, 最大电流不超过 10mA Force 120%Rated voltage for 5 seconds. Max..current should not exceed 10 mA. 100V≤Vr<500V 500V≤Vr≤1000V 1000V<Vr≤2000V 2000V<Vr≤5000V 七、可靠性测试 Reliability Test 项目 Item 技术规格 Technical Specification Ⅰ类 ClassⅠ 应符合指定的误差级别 Should be within specified tolerance. the 容量 Capacitance Ⅱ类 Class Ⅱ 应符合指定的误差级别 Should be within the specified tolerance. DF 损耗角正切 (DF, tanδ) Ⅰ类 Dissipation ClassⅠ Factor 第 Cr<5 pF 1MHz±10% 5pF≤Cr<50 pF 1MHz±10% ≤0.15% 50pF≤Cr≤1000 pF 1MHz±10% ≤0.15% >1000 pF 1KHz±10% ≤0.56% 1.5[(150/Cr)+7]×10 17 页 测 试 方 法 Test Method and Remarks 测试频率 测试电压 标称容量 Measuring Measuring Capacitance Frequency Voltage ≤1000pF 1MHz±10% 1.0±0.2Vrms >1000 pF 1KHz±10% 测试温度: 25℃±3℃ Test Temperature: 25℃±3℃ C≤10µF:测试频率: 1KHz±10% 测试电压: 1.0±0.2Vrms Test Frequency: 1KHz±10% Test Voltage: 1.0±0.2Vrms C>10µF X7R、X5R、X7S、X6S、Y5V: 测试频率: 120±24 Hz 测试电压:0.5±0.1Vrms Test Frequency: 120±24 Hz Test Voltage: 0.5±0.1Vrms Z5U:测试频率:1±0.1KHz 测试电压:0.5±0.05Vrms Test Frequency: 1±0.1KHz Test Voltage: 0.5±0.05Vrms 测试频率 测试电压 标称容量 Measuring Measuring Capacitance Frequency Voltage -4 共 32 1.0±0.2Vrms 页 项目 Item 技术规格 Technical Specification 电压 50V 25V 损耗角正 切(DF, tanδ) Dissipation Factor Ⅱ类 Class Ⅱ 16V 10V ≦6.3 V Ⅰ类 ClassⅠ 绝缘电阻 (IR) Insulation Resistance Ⅱ类Class Ⅱ DF 0201 0402 0603 0805 1206 以上 ≦2.5% ≤3.3nF ≤10nF ≤100nF ≤330nF ≤680nF ≦3.5% ≤10nF —— —— —— ≤1μF ≦5% —— —— —— ≤680nF —— ≦10% —— ≤1μF ≤2.2μF ≤4.7μF ≤10μF ≦2.5% ≤3.3nF ≤10nF ≤150nF ≤330nF ≤680nF ≦3.5% ≤10nF ≤100nF ≤330nF —— ≤2.2μF ≦5% —— —— —— ≤1μF —— ≦7.5% —— —— —— ≤2.2μF ≤4.7μF ≦10% ≤100nF ≤2.2μF ≤10μF ≤22μF ≤22μF ≦2.5% ≤3.3nF ≤10nF ≤150nF ≤330nF ≤680nF ≦3.5% ≤15nF ≤100nF ≤330nF —— ≤2.2μF ≦5% —— ≤220nF ≤680nF ≤2.2μF —— ≦7.5% —— —— —— ≤4.7μF ≤4.7μF ≦10% ≤100nF ≤4.7μF ≤10μF ≤22μF ≤47μF ≦2.5% ≤3.3nF ≤10nF ≤150nF ≤330nF ≤680nF ≦3.5% ≤15nF ≤100nF ≤330nF —— ≤2.2μF ≦5% —— —— ≤680nF ≤2.2μF —— ≦7.5% —— ≤1μF ≤2.2μF ≤4.7μF ≤10μF ≦10% ≤2.2μF ≤10μF ≤22μF ≤47μF ≤100μF ≦2.5% ≤3.3nF —— ≤150nF —— ≤680nF ≦3.5% ≤15nF ≤100nF ≤330nF —— ≤2.2μF ≦5% —— ≤220nF ≤680nF —— ≦7.5% —— ≤1μF —— —— 10μF~22 μF ≦10% ≤4.7μF ≤22μF ≤47μF ≤47μF ≤100μF C≤10 nF, Ri≥50000MΩ C>10 nF, Ri•CR≥500S X7R/ X5R/ X7S/ X6S C≤25 nF, Ri≥10000MΩ C>25 nF, Ri•CR>100S Y5V Z5U C≤25 nF, Ri≥4000MΩ C>25 nF, Ri•CR>100S 第 18 测 试 方 法 Test Method and Remarks 页 及 C≤10µF 测试频率: 1KHz±10% 测试电压: 1.0±0.2Vrms Test Frequency: 1KHz ± 10% Test Voltage: 1.0 ± 0.2Vrms C>10µF X7R、X5R、 X7S、X6S、Y5V 测试频率: 120±24 Hz 测试电压:0.5±0.1Vrms Test Frequency: 120±24Hz Test Voltage: 0.5 ± 0.1Vrms Z5U:测试频率:1 ±0.1KHz 测试电压:0.5±0.05Vrms Test Frequency: 1 ± 0.1KHz Test Voltage: 0.5 ± 0.05Vrms ≤10μF 测试电压:额定电压(最高 500V) 测试时间: 60±5 秒 测试湿度:≤75% 测试温度: 25℃±3℃ 测试充放电电流:≤50mA Measuring Voltage: Rated Voltage(Max 500V) Duration: 60±5s Test Humidity: ≤75% Test Temperature: 25℃±3℃ Test Current: ≤50mA 共 32 页 项目 Item 技术规格 Technical Specification 介质耐电强度 (DWV) Dielectric Withstanding 不应有介质被击穿或损伤 No breakdown or damage. Voltage 可焊性 Solderability Test Method and Remarks 测量电压: Ⅰ类:300%额定电压 Ⅱ类:250%额定电压 时间: 1~5 秒 充/放电电流:不应超过 50mA (这部分说明不包括中高压 MLCC) Measuring Voltage: ClassⅠ:300% Rated voltage ClassⅡ:250% Rated voltage Duration: 1~5s Charge/ Discharge Current: 50mA max. (This method excludes high-voltage MLCC) 将电容在 80~120℃的温度下预热 10~30 秒. Preheating conditions:80 to 120℃; 10~30s. 上锡率应大于 95% 外观:无可见损伤. 有铅焊料: (Sn/Pb:63/37) At least 95% of the terminal electrode is 浸锡温度:235±5℃ covered by new solder. 浸锡时间:2±0.5s Visual Appearance: No visible damage. SolderTemperature:235±5℃ Duration:2±0.5s NPO至 SL NPOtoSL 无铅焊料: 浸锡温度:245±5℃ 浸锡时间:2±0.5s SolderTemperature:245±5℃ Duration:2±0.5s Y5V、 将电容在 100~200℃的温度下预热 10±2 分钟. Z5U 浸锡温度: 265±5℃ ≤ ± 0.5% 或 ± 浸锡时间: 10±1s 0.5PF,取较大值 -10~+2 然后取出溶剂清洗干净,在 10 倍以上的显微镜底 ΔC/C -5~+10% ≤±0.5%or ±0.5PF, 0% 下观察. whicheverislarger 放置时间:24±2 小时 放置条件:室温 同初始标准 Preheatingconditions:100to200℃;10±2min. DF Same to initial value. Solder Temperature: 265±5℃ Duration: 10±1s 同初始标准 IR Clean the capacitor with solvent and examine it with Same to initial value. a 10X(min.) microscope. 外观:无可见损伤 上锡率:≥95% Appearance:No visible damage.At least 95% of Recovery Time: 24±2h the terminal electrode is covered by new solder. Recovery condition: Room temperature 项目 Item 耐焊接热 Resistanceto SolderingHeat 测 试 方 法 X7R/X5R/ X7S/X6S 试验基板:Al2O3 或 PCB 施压速度:1mm/sec. 弯曲深度:1mm 单位:mm 应在弯曲状态下进行测量。 20 抗弯曲强度 Resistance 外观:无可见损伤. to Flexure Appearance: No visible damage. T=10S 1mm of Substrate 45±2 (Bending 45±2 Test Board: Al2O3 or PCB Strength) Speed: 1mm/sec. ΔC/C 第 ≤±10% 19 页 Warp: 1mm Unit: mm The measurement should be made with the board in the bending position. 共 32 页 项目 Item 端头结合强度 Termination Adhesion 技术规格 Technical Specification 外观无可见损伤 No visible damage. 测 试 方 法 Test Method and Remarks 施加的力:5N Applied Force: 5N 时间:10±1S Duration: 10±1S 预处理※(2 类) :上限类别温度,1 小时 恢复:24±1h 初始测量 循环次数:5 次,一个循环分以下 4 步: 阶段 温度(℃) 时间(分钟) 下限温度 第 1 步 (NPO/X7R/X7S/X6S/X5R:-5 30 5 Y5V:-25 Z5U:+10) 温度循环 Temperature Cycle ΔC/C: Ⅰ类:≤±1%或±1pF , 取两者中最大者 Ⅱ类: B,X,BS,DS: ≤±10% E,F: ≤±20% ClassⅠ: ≤±1% or ±1pF, whichever is larger. ClassⅡ: B,X,BS,DS: ≤±10% E,F: ≤±20% 第2步 常温 (+20) 上限温度(NPO/X7R/X7S: 第3步 +125 Y5V/Z5U/X5R:+85 2~3 30 X6S:+105) 第4步 常温 (+20) 2~3 试验后放置(恢复)时间:24±2h Preheating conditions: up-category temperature, 1h Recovery time: 24±1h Initial Measurement Cycling Times: 5 times, 1 cycle, 4 steps: Time Step Temperature(℃) (min.) 1 Lowcategory temp. 30 (NPO/X7R/X7S/X6S/X5R:-55 Y5V:-25 Z5U:+10) 2 3 Normal temp. (+20) Up- category temp. (NPO/X7R/X7S: +125 2~3 30 Y5V/Z5U/X5R:+85 X6S:+105) 耐湿负荷 Humidity load 4 Normal temp. (+20) 2~3 Recovery time after test: 24±2h Ⅰ类: ±7.5%或±0.75pF,取两者之中较大者 Δ 温度:40±2℃ Ⅱ类: B,X,BS,DS: ≤±12.5% E,F: ≤±30% C/C 湿度:90~95%RH ClassⅠ: ±7.5% or ±0.75pF, whichever is larger. 电压:额定电压 ClassⅡ: B,X,BS,DS: ≤±12.5% E,F: ≤±30% 时间:500 小时 ≤2 倍初始标准 DF Not more than twice of initial value. 放置条件:室温 ClassⅠ Ri≥5000MΩ或 Ri•CR ≥50S 取两 IR 放置时间:24 小时(Ⅰ类); 者之中较小者. Ri ≥ 5000M Ω 或 Ri • CR ≥ 50S 48 小时(Ⅱ类) whichever is smaller. B,X, Ri≥1000MΩ或 Ri•CR ≥10S 取两 Temperature: 40±2℃ BS,D 者之中较小者. Humidity: 90~95%RH S Ri ≥ 1000M Ω 或 Ri • CR ≥ 10S Cl Voltage: Rated Voltage whichever is smaller. ass E,F Ri≥400MΩ或 Ri•CR≥10S 取两者 Duration: 500h Ⅱ 之中较小者. Ri ≥ 400M Ω 或 Ri • CR ≥ 10S Recovery conditions: Room temperature whichever is smaller. Recovery Time: 24h (Class1) or 外观:无损伤 Appearance: No visible damage. 48h (Class2) 第 20 页 共 32 页 项目 Item 寿命试验 Life Test 技术规格 Technical Specification Ⅰ类:≤±2%或±1pF 取两者之中较大者 Ⅱ类:B,X,BS,DS: ≤±20% Δ E,F: ≤±30% C/C ClassⅠ:≤±2% or ±1pF, whichever is larger. ClassⅡ: B,X,BS,DS: ≤±20% E,F: ≤±30% ≤2 倍初始标准 DF Not more than twice of initial value. Ⅰ类:Ri≥4000MΩ或 Ri•CR ≥40S 取两者之中较小者. Class Ⅰ : Ri ≥ 4000M Ω 或 Ri • CR ≥ 40S whichever is smaller. IR Ⅱ类:Ri≥2000MΩ或 Ri•CR ≥50S 取两者之中较小者. Class Ⅱ : Ri ≥ 2000M Ω 或 Ri • CR ≥ 50S whichever is smaller. 外观:无损伤 Visual Appearance: No visible damage. 测 试 方 法 Test Method and Remarks 低压产品(<100V) 电压:2 倍额定工作电压,除了表 1 外 时间:1000 小时 温度:125℃(NPO、X7R、X7S) 85℃(X5R、Y5V) 105℃(X6S) 充电电流:不应超过 50mA 放置条件:室温 放置时间:24 小时(Ⅰ类) ,或 48 小时(Ⅱ类) , Low-Voltage(<100V) Applied Voltage: 2*Ur,except the table 1 Duration: 1000h Temperature:125℃(NPO、X7R、X7S) 85℃(X5R、 Y5V)105℃(X6S) Charge/ Discharge Current: 50mA max. Recovery Conditions: Room Temperature Recovery Time: 24h (Class 1), or 48h (Class2) 表 1(table 1) 容量 试验电压 容量 0201≥47nF 0402≥330nF 0805≥1uF 1.5Ur 1206≥10uF 0603≥470nF 中高压产品 寿命试验 Middle &high voltage Life Test Ⅰ类:≤±2%或±1pF 取两者之中较大者 Ⅱ类:B,X,BS,DS: ≤±20% Δ E,F: ≤±30% C/C ClassⅠ:≤±2% or ±1pF, whichever is larger. ClassⅡ: B,X,BS,DS: ≤±20% E,F: ≤±30% ≤2 倍初始标准 DF Not more than twice of initial value. Ⅰ类:Ri≥4000MΩ或 Ri•CR≥40S 取两者之中较小者. ClassⅠ: Ri≥4000MΩ或 Ri•CR ≥ 40S whichever is smaller. IR Ⅱ类:Ri≥2000MΩ或 Ri•CR≥50S 取两者之中较小者. ClassⅡ: Ri≥2000MΩ或 Ri•CR ≥ 50S whichever is smaller. 外观:无损伤 Visual Appearance: No visible damage. 试验电压 1.5Ur 1210≥10uF 中高压产品: 100V≤额定电压≤200V:1.5 倍工作电压 200V<额定电压≤500V:1.3 倍工作电压 500V<额定电压: 1.2 倍工作电压 时间:1000 小时 充电电流:不应超过 50mA 温度:125℃(NPO X7R、X7S);85℃(X5R、Y5V) 105℃(X6S) 放置条件:室温 放置时间:24 小时(Ⅰ类),或 48小时(Ⅱ类) , Applied Voltage: 100V≤Rated Voltage≤200V:1.5 Multiple 200V<Rated Voltage≤500V: 1.3 Multiple 500V<Rated Voltage: 1.2 Multiple Duration: 1000h Charge/ Discharge Current: 50mA max. Temperature:125℃(NPO X7R、X7S);85℃(X5R、 Y5V)105℃(X6S) Recovery Conditions: Room Temperature Recovery Time: 24h (Class 1), or 48h (Class2) ※ 注解:专门预处理 (仅对 2 类电容器) :将电容器放在上限类别温度或按详细规范中可能规定的更高温度下经 1h 后, 接着在试验的标准大气条件下恢复 24±1h。 Note:Pretreatment (only for class2 capacitor): Pretreatment (only for class2 capacitor) is a method to treat the capacitor before measurement. First, place the capacitor in the up-category temperature or other specified higher temperature environment for 1hour. Then recovery the capacitor at standard pressure conditions for 24±1hours。 第 21 页 共 32 页 八、包装 PACKAGE EMBOSSED PLSATIC TAPING ●塑料压纹带卷盘结构 Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket)芯片孔 Polystyrene reel 胶盘 ※仅适用于 1005 规格,压纹带尺寸如下: The emboss plastic applies only to 1005 type,the dimensions as follows: D0 P0 E W F B0 K0 P1 A0 Unit:mm W P0 P1 E F D0 A0 B0 K0 4±0.05 2±0.04 1±0.02 0.9±0.05 1.8±0.02 0.8±0.04 0.24±0.02 0.45±0.02 0.24±0.02 第 22 页 共 32 页 ●纸带卷盘结构 PAPER TAPING Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket) 芯片孔 Polystyrene reel 胶盘 Bottom tape 底胶 ※ 1005、0201、0402 纸带编带尺寸大小 Dimensions of paper taping for 1005、0201、0402 type 代号 Code 1005 0201 0402 W1 L1 D C B P1 P2 P0 d t 0.24± 0.45± 8.00 3.50 1.75 2.00 2.00 4.00 1.50 0.30 0.02 0.02 0.10 0.05 0.10 0.05 0.05 0.10 -0/+0.10 Below 0.37 0.67 8.00 3.50 1.75 2.00 2.00 4.00 1.50 0.80 0.10 0.10 0.10 0.05 0.10 0.05 0.05 0.10 -0/+0.10 Below 0.65 1.15 8.00 3.50 1.75 2.00 2.00 4.00 1.50 0.80 0.10 0.10 0.10 0.05 0.10 0.05 0.05 0.10 -0/+0.10 Below 第 23 页 共 32 页 ※适合‘0603,0805,1206’常规尺寸产品的纸带尺寸 Dimensions of paper taping for 0603,0805,1206 types. 送带孔 Feeding hole 芯片方穴 Chip pocket J E A D B T H Chip cap G F C Tape running direction 纸带运行方向 Unit:mm 代号Code 纸带规格 papersize A B C D* E F G* H J T 0603 1.10  0.10 1.90  0.10 8.00  0.10 3.50  0.05 1.75  0.10 4.00  0.10 2.00  0.10 4.00  0.10 1.50 -0/+0.10 1.10 Max 0805 1.45  0.15 2.30  0.15 8.0  0.15 3.50  0.05 1.75  0.10 4.00  0.10 2.00  0.10 4.00  0.10 1.50 -0/+0.10 1.10 Max 1206 1.80  0.20 3.40  0.20 8.00  0.20 3.50  0.05 1.75  0.10 4.00  0.10 2.00  0.10 4.00  0.10 1.50 -0/+0.10 1.10 Max 注意:*表示此处对尺寸的要求非常精确。 Note: The place with “*” means where needs exactly dimensions. EMBOSSED TAPING ●塑胶卷盘结构 Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket)芯片孔 Polystyrene reel 胶盘 第 24 页 共 32 页 ※ 塑胶带尺寸结构(适合‘0805~1812’型产品) Dimensions of embossed taping for 0805~1812 type 送带孔 Feeding hole 芯片方穴 Chip pocket J E A D B T H Chip cap G C Tape running direction F 塑胶带传送方向 代号 Code 规格 Tapesize 0805 1206 1210 1808 1812 A B C D* E F G* H J T 1.55 2.35 8.00 3.50 1.75 4.00 2.00 4.00 1.50 1.50  0.20  0.20  0.20  0.05  0.10  0.10  0.10  0.10 -0/+0.10 Max 1.95 3.60 8.00 3.50 1.75 4.00 2.00 4.00 1.50 1.85  0.20  0.20  0.20  0.05  0.10  0.10  0.10  0.1 -0/+0.10 Max 2.70 3.42 8.00 3.50 1.75 4.00 2.00 4.00 1.55 3.2  0.10  0.10  0.10  0.05  0.10  0.10  0.05  0.10 -0/+0.10 Max 2.20 4.95 12.00 5.50 1.75 4.00 2.00 4.00 1.50 3.0  0.10  0.10  0.10  0.05  0.10  0.10  0.05  0.10 -0/+0.10 Max 3.66 4.95 12.00 5.50 1.75 8.00 2.00 4.00 1.55 4.0  0.10  0.10  0.10  0.05  0.10  0.10  0.05  0.10 -0/+0.10 Max 备注:*表示此处对尺寸的要求非常精确。 Note:The place with “*” means where needs exactly dimensions. Structure of leader part and end part of the carrier paper ●传送带的前后结构 尾部(空带) 芯片传送 End (Vacant position) 带头(面胶面) Vacant position Leader part(cover) tape) 大于 150 mm 大于 150 mm over 150mm over 150mm 大于 150 mm /Over 150 mm 传送方向/ Moving Direction 第 Chip carrier 空带 25 页 共 32 页 ※ 卷盘尺寸 Reel Dimensions (unit: mm) ※ 尺寸代码(CODE) 卷盘型号 A B C D 7 REEL φ178±2.0 3.0 φ13±0.5 φ21±0.8 13′REEL φ330±2.0 3.0 φ13±0.5 φ21±0.8 ′ E φ50或更大 φ50 ormore φ50或更大 φ50ormore F G 10.0±1.5 12max 10.0±1.5 12max ● 关于卷带的说明 Taping specification ※面胶剥离强度 Top tape peeling strength (a)纸带 Paper Taping Cover tape peeling direction 面胶剥离方向 Cover tape 面胶 0~15° Carrier tape 传送带 (b) 塑料胶盘 Embossed Taping Cover tape peeling direction 面胶剥离方向 Cover tape 面胶 0~15° Carrier tape 传送带 标准:0.1N
0805B221K501NT
物料型号:文档中提到了多种电容器型号,包括但不限于0201、0402、0603、0805、1206、1210、1808、1812、2220、2225、3012和3035等。
器件简介:文档主要介绍了多层片式瓷介电容器(MLCC),包括高频类、Ⅱ类电容器(X7R、X5R、X7S、X6S、Y5V、Z5U)等,它们在不同电路中的应用和特性。
引脚分配:文档中未明确提到具体的引脚分配信息,但提到了电容器的尺寸和结构,包括陶瓷介质、内电极、外电极、镍层和锡层。
参数特性:文档详细列出了不同尺寸电容器的尺寸规格、温度系数/特性、容量范围及其电压等参数。例如,COG电容器在20°C时的标称温度系数为0±30 ppm/°C,工作温度范围为-55°C~125°C。
功能详解:文档解释了不同类型电容器的功能和应用场景,如高频类电容器适用于低损耗、稳定性要求高的高频电路,而Y5V电容器由于介电常数最大,适用于要求大容量、温度变化不大的电路中。
应用信息:电容器的应用信息包括在射频RF电路、微波电路、模拟或数字调制解调器、局域网/广域网接口界面、日光灯启动辉器照明电路等多种场景中的应用。
封装信息:文档提供了电容器的封装尺寸,如0201、0402、0603等,以及它们的英制和公制尺寸表示。
0805B221K501NT 价格&库存
很抱歉,暂时无法提供与“0805B221K501NT”相匹配的价格&库存,您可以联系我们找货
