ACE05K222JT
ACE05K222JT
    FH(风华)
    阻值:2.2kΩ;精度:±5%;功率:125mW;
ACE05K222JT 数据手册
AEC-Q200 Compliant with AEC-Q200 standard Miniature and light weight Suit for reflow and wave flow solder Stable electrical capability,high reliability Low assembly cost,suit for automatic SMT equipment Superior mechanical and frequency characteristics With good sulfuration-resistant performance RoHS Compliant with RoHS directive Halogen f ree requirement AC D 03 Product Code Rated Power Code Type Code K T.C.R Code 1003 F T Resistance Value Code Resistance Tolerance Code Packaging Style Code (E-24 Code C D Thick Film Chip Fixed Resistor Automotive Grade Rated Power 1/16W 1/10W Code Type 02 03 0402 0603 E 1/8W 05 0805 F 1/4W 06 1206 R 1/3W Type Code 0402 0603 0805 1206 1210 2010 2512 K 100 3/4W 10 2010 J 1W 12 2512 Three digits (E-24 series):The first two digits are significant figures and the third one denotes number of zeros. (E-96 ) Code Code Packaging Tolerance D 0.5% F 1% Style T L 250 1210 1210 H ) Chip No Marking Jumper 1 Four digits(E-96 series):The first three digits are Significant figures and the four one denotes number of zeros. R Decimal point should be expressed by "R". Example: 103 =10K (E-24) 1003=100K (E-96) 1R0 =1.0 (E-24) 000=0 G 2% J 5% K 10% F Tape & Reel 10m C Chip G Jumper J 20m 50m Case THICK FILM CHIP FIXED RESISTOR AUTOMOTIVE GRADE Ceramic Substrate Bottom Electrode Top Electrode Resistor Layer Primary Overcoat Secondary Overcoat Edge Electrode Barrier Layer External Electrode Dimensions (mm) Type L 0402 1.00 0.10 0.50 0.10 0603 1.60 0.15 0.80 0.15 0805 2.00 0.20 1.25 1206 3.20 0.20 1210 3.20 2010 2512 100 a t W b 0.10 0.25 0.15 0.25 0.10 0.45 0.10 0.30 0.20 0.30 0.20 0.15 0.55 0.10 0.30 0.20 0.40 0.20 1.60 0.15 0.55 0.10 0.35 0.20 0.50 0.20 0.20 2.50 0.20 0.55 0.10 0.35 0.20 0.50 0.20 5.00 0.20 2.50 0.20 0.55 0.10 0.40 0.20 0.60 0.20 6.40 0.20 3.20 0.20 0.55 0.10 0.40 0.20 0.60 0.20 0.35 -55 70 : 75 Percent Rated Load Operating Temperature Range: -55 ~155 50 25 0 -75 -50 -25 0 25 75 50 100 125 155 Ambient temperature( ) 70 ( ) Note For resistors operated in ambient over 70 ,rated load (rated power or rated current) shall be derated in accordance with the above figure. 70 70 Rated Power at 70 (W) Limiting Element Voltage Max. Overload Voltage (V) 0402 1/16 0603 (V) Rated Current for Chip Jumper at 70 (A) Max. Overload Current for Chip Jumper (A) 50 100 1 2 1/10 50 100 1 3 0805 1/8 150 300 2 5 1206 1/ 4 200 400 2 5 1210 1/ 3 200 400 2 5 2010 3/ 4 200 400 2 5 2512 1 200 400 2 5 Type 1 Note 2 Voltage of DC or AC RMS value. E= E= or Limiting element voltage whichever is lower. E Rated voltage(V) P Rated power(W) R Normal resistance( ) 2 T.C.R (ppm/ ) Type Resistance Tolerance Resistance Range 0.5% 0402 0603 0805 1206 1210 2010 2512 1 / R 10 10 R 1M 1M R 10M 100 / 1% 2% 5% 10% 250 250 250 250 100 100 100 100 250 250 250 250 Specifications Item Test Methods Resistor High Temperature Exposure (Storage) Temperature Cycling Jumper No mechanical damage No mechanical AEC-Q200 Test 3/MIL-STD-202 Method 108 damage 1000 @ T=125 , R 100 m (J ) 0.05 ) 1000 h @ T=125 , Unpowered R 40 m (G ) 0.05 ) R 20 m (F ) 0.5% 1% R (1.0%R 2% 5% 10% R (2.0%R No mechanical damage No mechanical damage 0.5% 1% R 100 m (J ) R (0.5%R 0.05 ) R 40 m (G ) 2% 5% 10% R 20 m (F ) R (1.0%R 0.05 ) AEC-Q200 Test 4/JESD22 Method JA-104 -55 (30 ) ( 1 ) 125 (30 ) 1000 -55 (30min) normal temperature( 1min) 125 (30min),1000 cycles; ; AEC-Q200 Test 7/ MIL-STD-202 Method 103 Biased Humidity No mechanical damage R (3.0%R 0.05 ) No mechanical 85 85% 10% ( ) damage 1000 R 100 m (J ) 85 /85%RH. 1000 hours, Apply 10% of operating power R 40 m (G ) R 20 m (F ) (current) or limiting element voltage whichever is lower. AEC-Q200 Test 8/ MIL-STD-202 Method 108 No mechanical damage No mechanical 125 2 1000 ( ) ( ) damage 0.5% 1% 1.5 / 0.5 Operational Life R 100 m (J ) R (1.0%R 0.05 ) 125 2 1000h rated voltage (current) or limiting element R 40 m (G ) 2% 5% 10% voltage whichever is lower for 1.5h ON/0.5h OFF. R (3.0%R 0.05 ) R 20 m (F ) AEC-Q200 Test 12/ MIL-STD-202 Method 215 3min 10 3 Resistance to Solvents Clearly marked No mechanical damage Immersed in three solvents after 3min immersion, brush wipe 10 times, a total of 3 times, washing with washing and cleaning agent, room temperature on the surface of the ventilation drying. AEC-Q200 Test 13/ MIL-STD-202 Method 213 Mechanical Shock 100 g s 6ms No mechanical damage 3 18 No mechanical damage R 50 m (J ) Positive half wave, peak acceleration: 100g s , pulse R (1.0%R 0.05 ) R 20 m (G ) duration: 6ms, three axis six to each 3 times, a total R 10 m (F ) of 18 times. AEC-Q200 Test 14/ MIL-STD-202 Method 204 Vibration Resistance to Soldering Heat No mechanical 5g s 10Hz~2000Hz, 20min X damage Z 12 36 No mechanical damage R 50 m (J ) Frequency: 10Hz ~ 2000Hz, acceleration: 5 g s , a loop R (1.0%R 0.05 ) R 20 m (G ) 20min, X, Y, Z three directions, each direction 12 cycles, R 10 m (F ) 36 cycles. No mechanical damage 0.5% 1% R (0.5%R 0.05 ) 2% 5% 10% R (1.0%R 0.05 ) No mechanical AEC-Q200 Test 15/ MIL-STD-202 Method 210 damage 270 5 10s 1s R 50 m (J ) 5 for 10s 1s. R 20 m (G ) Lead-free solder bath at 270 R 10 m (F ) 3 Y THICK FILM CHIP FIXED RESISTOR AUTOMOTIVE GRADE Continue Specifications Item Thermal Shock ESD Electrostatic Discharge (ESD) Solderability T.C.R Flammability Resistor Test Methods Jumper No mechanical damage No mechanical damage 0.5% 1% R (0.5%R 0.05 ) R 50 m (J ) 2% 5% 10% R 20 m (G ) R (1.0%R 0.05 ) R 10 m (F ) No mechanical damage R (3.0%R 0.05 ) AEC-Q200 Test 16/MIL-STD-202 Method 107 -55 (15 ) ( 20 ) 155 (15 ) 300 1206 -55 (15min) normal temperature( 20s) 155 (15min) 300 cycles. No mechanical AEC-Q200 Test 17/AEC-Q200-002 damage R 50 m (J ) Human body model, 1pos + 1neg dischargs. R 20 m (G ) 0402/0603 1KV 0805 2KV 1206 3KV R 10 m (F ) No mechanical damage 95% 95% Cover Min AEC-Q200 Test 18/IEC 60115-1 4.17 245 5 3s 0.3s. Lead-free solder bath at 245 5 for 3s 0.3s. AEC-Q200 Test 19/IEC 60115-1 4.8 +20 /-55 /+20 /+125 /+20 Within specified T.C.R No ignition of the tissue paper or scorching or the pinewood board. AEC-Q200 Test 20/UL-94 V-0 V-1 V-0 or V-1 are acceptable. Electrical test not required. AEC-Q200 Test 21/AEC-Q200-005 Substrate Bending Test Terminal Strength Flame Retardance No mechanical damage No mechanical (Bending distance) 0.5% 1% damage 0402 0603 0805 5mm 1206 R (0.5%R 0.05 ) R 50 m (J ) 2010 2512:2mm 2% 5% 10% R 20 m (G ) (Duration) 60s 5s R (1.0%R 0.05 ) R 10 m (F ) 1210:4mm; No mechanical damage No mechanical AEC-Q200 Test 22/AEC-Q200-006 damage 0.5% 1% : 17.7N 60 1 R (0.5%R 0.05 ) R 50 m (J ) Appling force 17.7N for 60s 1s . 2% 5% 10% R 20 m (G ) R (1.0%R 0.05 ) R 10 m (F ) AEC-Q200 Test 24/AEC-Q200-001 9Vdc 32Vdc 500A 1 No flame 1.0Vdc Subjected to voltage from 9.0 to 32.0 VDC(current clamped up to 500A), and each voltage level shall be increased in 1.0 VDC for one hour minimum. IEC 60115-1 4.6 100V Insulation Resistance 1000M 15V 1 Min Apply DC 100V 15V between substrate and terminations for 1min, then check insulation resistance. IEC 60115-1 4.7 Voltage Proof 100V/s 60s 5s. No breakdown or flashover Apply max. overload voltage of AC RMS at a rate of approximately 100V/s between substrate and terminations for 60s 5s. IEC 60115-1 4.13 2.5 / ( ) 5 2.5 times rated voltage or max. overload voltage(current) whichever is lower for 5s. Short Time Overload No mechanical damage 0.5% 1% R (1.0%R 0.05 ) 2% 5% 10% R (2.0%R 0.05 ) No mechanical damage R 50 m (J ) R 20 m (G ) R 10 m (F ) Operation at Low Temperature No mechanical damage 0.5% 1% R (1.0%R 0.05 ) 2% 5% 10% R (2.0%R 0.05 ) No mechanical -55 5 1 ( ) ( damage )45 15 R 50 m (J ) -55 5 , 1h without load rated voltage(current) or limiting R 20 m (G ) element voltage whichever is lower for 45min, 15min without R 10 m (F ) load. IEC 60115-1 4.36 4 Continue Specifications Item Sulfuration Resistant Resistor Test Methods Jumper 105 3 500 No mechanical No mechanical damage Cutting oil: sulphur power, constant temperature: damage R (5.0%R 0.05 ) R 100 m (J ) 105 3 ,for 500hrs. R 40 m (G ) R 20 m (F ) 1 9 Packaging see the appendix 1-9 Page . 5 PACKAGING AND PRECAUTION OF CHIP RESISTOR Chip fixed resistor C A B unit: mm unit: mm Thick Film Resistor and Thin Film Resistor Type 01005 0201 0402 0603 0805 1206 1210 2010 2512 A 0.17 0.23 0.45 0.80 1.05 1.90 2.00 3.50 4.80 B 0.60 0.84 1.45 2.50 3.25 4.50 4.60 6.50 7.80 Metal Foil Resistor Type C 0.22 0.38 0.60 0.95 1.40 1.75 2.70 2.70 3.40 0603 0805 1206 2010 2512 R003~R004 R005~R030 R003~R004 R005~R047 R003~R004 R005~R068 R003~R009 R010~R100 R002~R004 R005~R200 A 0.4 0.6 0.5 0.8 0.8 1.8 1.6 2.7 1.0 3.8 B C 2.8 1.0 3.2 1.4 4.4 1.8 6.3 2.9 8.0 3.4 Thick film chip network resistor A B Q1 Q2 Q3 Q2 Q3 Q2 Q1 RCMY08 / RCMT08 / RCML08 unit: mm A B Q1 Q2 Q3 RCMY08 0.30 0.90 0.20 0.20 0.20 RCMT08 0.38 1.60 0.40 0.20 0.30 RCML08 0.80 2.70 0.60 0.40 0.40 Type 1 Paper Taping 01005 0201 0402 RCMY08 RCMT08 For 01005 0201 0402 RCMY08 RCMT08 unit: mm Type A B W F E 01005 0.45 0.02 0.25 0.02 8.00 0.02 3.50 0.05 1.75 0.05 0201 0.70 0.10 0.40 0.10 8.00 0.20 3.50 0.05 1.75 0.10 0402 1.20 0.10 0.70 0.10 8.00 0.20 3.50 0.05 1.75 0.10 RCMY08 1.57 0.05 0.77 0.05 8.00 0.20 3.50 0.05 1.75 0.10 RCMT08 2.20 0.10 1.20 0.10 8.00 0.20 3.50 0.05 1.75 0.10 unit: mm Type P P0 P1 D0 T1 T 01005 2.00 0.05 4.00 0.10 2.00 0.05 1.55 0.02 0.17 0.02 0.31 0.02 0201 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 0.28 0.04 0.42 0.05 0402 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 / 0.42 0.05 RCMY08 2.00 0.05 4.00 0.10 2.00 0.05 1.50 0.10 / 0.60 0.10 RCMT08 2.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 / 0.60 0.10 0603 0805 1206 1210 RCML08: For 0603 0805 1206 1210 RCML08: 2 PACKAGING AND PRECAUTION OF CHIP RESISTOR unit: mm Type B A W F E 0603 1.85 0.10 1.10 0.10 8.00 0.20 3.50 0.05 1.75 0.10 0805 2.35 0.10 1.65 0.10 8.00 0.20 3.50 0.05 1.75 0.10 1206 3.50 0.20 1.90 0.20 8.00 0.20 3.50 0.05 1.75 0.10 1210 3.50 0.20 2.80 0.20 8.00 0.20 3.50 0.05 1.75 0.10 RCML08 3.50 0.20 1.90 0.20 8.00 0.20 3.50 0.05 1.75 0.10 unit: mm T Type P0 P D0 P1 Thick Film Resistor and Thin Film Resistor Metal Foil Resistor 0603 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.60 0.10 0.75 0.10 0805 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 0.95 0.10 1206 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 0.95 0.10 1210 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 RCML08 4.00 0.10 4.00 0.10 2.00 0.05 1.50 0.10 0.75 0.10 Embossed Taping 2010 2512 For 2010 2512 unit: mm W B0 A0 Type t E F 2010 5.50 0.15 2.82 0.15 12.00 0.10 5.50 0.10 1.75 0.10 0.25 0.05 2512 6.78 0.15 3.45 0.15 12.00 0.10 5.50 0.10 1.75 0.10 0.25 0.05 unit: mm K0 Type P P0 D0 P1 D1 Thick Film Resistor and Thin Film Resistor Metal Foil Resistor 2010 4.00 0.10 4.00 0.10 2.00 0.05 1.50+0.10/-0 1.50 0.10 0.84 0.10 0.84 0.10 2512 4.00 0.10 4.00 0.10 2.00 0.05 1.50+0.10/-0 1.50 0.10 0.81 0.10 1.00 0.10 3 Reel unit: mm M W 01005 0201 0402 0603 0805 1206 1210 RCMY08 RCMT08 RCML08 178 2.0 9.5 1.0 2010 2512 178 2.0 13.0 0.5 Type A B C D 12.5 1.5 2.0 0.5 13.0 0.5 21.0 0.5 58.0 2.0 15.5 1.5 2.0 0.5 13.0 0.5 21.0 0.5 57.0 2.0 T Packaging Quantity Tape & reel Packaging style W M Type Quantity(pcs) 178 178 01005 2.0 E-24 ( 0201 0402 RCMY08 RCMT08 20000 10000 9.5 unit 0.001 1.0 1.1 2.0 1.2 1.3 g Quantity 0.01 0.1 2010 2512 5000 4000 12.5 1 10 100 2.2 1.6 0.52.7 2.0 A 0603 0805 1206 RCMY08 RCMT08 RCML08 01005 0201 0402 50000 10000 2.0 1.5 1210 2010 2512 4000 0.5 1 ) 1.5 13.0 1.8 T 0603 0805 1206 1210 RCML08 1.0 E-24 series( 10 n Case 2.4 1k 10k 100k 1M 3.3 15.53.6 1.5 3.9 3.0 4.3 4 10M 100M 4.7 5.1 5.6 6.2 1000M ) 6.8 2.0 7.5 0.5 8.2 9.1 1 PACKAGING AND PRECAUTION OF CHIP RESISTOR E-96 ( 10 n E-96 series ( unit 0.001 0.01 ) 0.1 1 10 100 1k 10k 100k 1M 10M 100M 1000M ) 1.00 1.33 1.78 2.37 3.16 4.22 5.62 7.50 1.02 1.37 1.82 2.43 3.24 4.32 5.76 7.68 1.05 1.40 1.87 2.49 3.32 4.42 5.90 7.87 1.07 1.43 1.91 2.55 3.40 4.53 6.04 8.06 1.10 1.47 1.96 2.61 3.48 4.64 6.19 8.25 1.13 1.50 2.00 2.67 3.57 4.75 6.34 8.45 1.15 1.54 2.05 2.74 3.65 4.87 6.49 8.66 1.18 1.58 2.10 2.80 3.74 4.99 6.65 8.87 1.21 1.62 2.15 2.87 3.83 5.11 6.81 9.09 9.31 1.24 1.65 2.21 2.94 3.92 5.23 6.98 1.27 1.69 2.26 3.01 4.02 5.36 7.15 9.53 1.30 1.74 2.32 3.09 4.12 5.49 7.32 9.76 E 96 0603 E-96 series(0603) multiplied Cross-reference List and Resistance Cross-reference List multiplied code Code 10 0 10 1 10 2 10 A B C D E-96 E-96 resistance 3 10 4 10 5 10 6 10 7 10 -1 10 -2 10 -3 E F G H X Y Z Code E-96 E-96 resistance Code E-96 E-96 resistance Code E-96 E-96 resistance 01 100 25 178 49 316 73 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 562 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 5 Description for Resistance Value Code and Marking of Thick Film Chip Resistor Resistance Value Code All the resistance value code of thick film chip resistor is corresponding with the marking . Marking E-24 (0603 5%) 10 E-24 series: Express resistance value on the glass side with three digits, the first tow digits should be significant and the third one denote number of zeros. 10K For example: 33 E-24 (0603 1%& 0.5%) E-24 series(0603 1%& 0.5%): One short bar under marking letter. For example: E-96 E24 1%& 0.5% 0805 1206 1210 2010 2512 4R02 4R03 E-96 series & E-24 series:For the dimension type of 0805 1206 1210 2010 2512 4R02 4R03 express the resistance value with four digits, the first three digits are significant figures and the fourth de notes the number of zeros. For example: 133 100K E-96 0603 E-96 For the dimension type of 0603, express the resistance value with three code, the first two digit code denote the resistance of E-96 series, and the third code of letter denote the multiplier (see the table three and four ). For example: R 2M The decimal point should be expressed by R For example: 0 . 1 5.6 The jumper should be expressed by For example: 01005 0201 0402 on the glass side. 0 0 For the dimension type of 01005 0201 0402 there is no mark For example: IEC IEC E24 For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most close to the required resistance of non-IEC serial for replacement. To get agreement by both party if there special requirement for the marking. 6 PACKAGING AND PRECAUTION OF CHIP RESISTOR Description for Resistance Value Code and Marking of Thin Film Chip Resistor Resistance Value Code 0201 0402 0603 0805 1206 1210 2010 2512 All resistance value code of thin film chip resistor,including 0201 0402 0603 0805 1206 1210 2010 2512 size used four digits. Example TD03G4701BT 4701=4.7K 1R50=1.5 To use four digits code represent resistance value , Example 4701=4.7K 1R50=1.5 Marking E24 E96 E96 . When resistance value belongs to E24 as well as E96 series, we suggest preferentially use E96 series. Example 10K=1002, 103 0805 1206 1210 2010 2512 Marking for 0805 1206 1210 2010 2512 Size Resistor 0805 1206 1210 2010 2512 For 0805 1206 1210 2010 2512 size resistor , express the resistance value with four digits code; Example 100K 0603 Marking for 0603 Size Resistor 0603-E96 For resistance value belongs to E96 series, express the resistance value with three digits code. Example 2M 0603-E24 For resistance value belongs to E24 series, express the resistance value with three digits code. Example 10K The decimal point should be expressed by "R" . Example 5.6 0201 0402 For the dimension type of 0201 0402 there is no mark on the glass side. Example 7 Description for Resistance Value Code and Marking of Current Sensing Thick Film Chip Resistor Resistance Value Code 0402 0603 0805 1206 1210 2010 2512 All resistance value code of current sensing thick film chip resistor, including 0402 0603 0805 1206 1210 2010 2512 size used four digits. Example RBF03MR010FT R010=10m 30M1=30.1m To use four digits code represent resistance value , Example R010=10m 30M1=30.1m Marking E -24 E-96 For 0805 (0805 1206 1210 2512 2010 5% 1% 0.5%) 2512 w hen resistance value belongs to E24 and E96 series, we suggest preferentially use four digits. Resistance Value Mark Code R00X 1m R0XX 10m RXXX 100m Sample R 9m R005=5m R 99m R033=33m R 999m R100=100m XMXX 1m R 10m (Contains two significant digits after the decimal point.) 5M10=5.1m XXMX 10m R 100m (Contains one significant digit after the decimal point.) 30M1=30.1m E -24 E-96 (0603 5% 1% 0.5%) For 0603,when resistance value belongs to E24 and E96 series, we suggest preferentially use three digits. Mark Code Resistance Value Range V0X 1m VXX 10m RXX 100m XMX Sample R 9m V05=5m R 99m V33=33m R 999m R33=100m 1m R 10m (Contains one significant digit after the decimal point.) 5M1=5.1m 0402 For 0402, there is no mark on the glass side. IEC IEC E24 For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most close to the required resistance of non-IEC serial for replacement. To get agreement by both party if there special requirement for the marking. 8 PACKAGING AND PRECAUTION OF CHIP RESISTOR 1 2 3 4 5 6 7 1 Use in various types of liquid, including water, oils, chemicals, and organic solvents. 2 Use outdoors where the products are exposed to direct sunlight, or in dusty places. 3 Use in places where the products are exposed to sea winds or corrosive gases, including Cl2, H2S, Nh3, SO2, and No2 etc. 4 Use in places where the products are exposed to static electricity or electromagnetic waves. 5 Use in proximity to heat-producing components, plastic cords, or other flammable items. 6 Use involving sealing or coating the products with resin or other coating materials. 7 Use involving unclean solder or use of water or water-soluble cleaning agents for cleaning after soldering. 1 2 3 4 : 5 30 30% 70% 1 Avoid applying power exceeding normal rated power, exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 2 Be careful when pick up the products with tweezers. There may be a care that the overcoat and / or the body can be chipped. 3 Soldering tip shall not touch the product when install product manually. 4 Storage conditions: T 5 30 , RH 30% 70%. Recommended wave solder profile Recommended reflow profile Recommended solder alloy 96.5Sn/3.0Ag/0.5Cu 9
ACE05K222JT 价格&库存
很抱歉,暂时无法提供与“ACE05K222JT”相匹配的价格&库存,您可以联系我们找货
