076722
076722
    MOUNTZ
    MOUNTZ - 076722 - Torque Tool, Adjustable, 0.25", 7", 0.4 N-m to 4.5 N-m
076722 数据手册
PRODUCT BROCHURE FGA ADJUSTABLE TORQUE SCREWDRIVER “HAND ME THE MOUNTZ!” Mountz FGA Precision Adjustable Torque Screwdriver SAFEGUARDING AGAINST FASTENING FAILURES • Poka-yoke torque screwdriver prevents over-torque • Accuracy and precision delivered for all fastening applications • Calibration life 4x ISO standards • Unmatched quality you can count on • Two-year unlimited warranty • Lifetime warranty against manufacturer defects • Digital torque scale provides an accurate and simplistic process to adjust the torque setting QUALITY IS AT THE HEART OF EVERYTHING WE DO Relied on by leaders in aviation, automotive, medical and electronic-all industries in which process control is critical. 2 Quality cam-over technology in the palm of your hand THE STATE-OF-THE-ART PRECISION TORQUE DRIVER Engineered and assembled in Silicon Valley, the Mountz FGA line of precision adjustable torque screwdrivers are the most advanced hand tools for high-level process and quality control. The screwdriver’s repeatability, traceability, and precision safeguards against fastening failures. When under- or over-torquing puts your products at risk, Mountz cam-over torque screwdrivers deliver the accuracy you need. Mountz cam-over drivers use an internal cam-over mechanism to reduce the risk of operator error by disengaging once reaching torque. Our cam-over technology increases the consistency of torque delivered and joint reliability. The screwdriver’s design features a digital torque scale that allows you to adjust the torque setting quickly. A flexible and simplistic adjustment process. Eliminates the hassle of you fumbling around to align and set a torque setting with a tool that is a micrometer based scale system. Precision and accuracy delivered every time Mountz FGA tools stay in calibration 4X longer than the most stringent industry standard (ISO 6789). Engineered with a cam-over mechanism, the poka-yoke adjustable screwdriver prevents over-torque. You can give Mountz FGA tools to any operator and have the confidence that he/she will deliver the correct torque, time after time. 3 Improve Productivity and Reduce Costs with Adjustable Torque Screwdriver An adjustable torque screwdriver can save manufacturers and maintenance workers time and money by allowing them to accurately tighten critical fasteners of different sizes—all with a single tool. Thanks to the externally adjustable torque setting on these tools, you can quickly switch torque values in the field or at the station, leading to improved productivity. A quality adjustable screwdriver has an easy adjustment process along with a locking mechanism that prevents incidental torque adjustment. Digital Scale vs Micrometer Scale System A micro-meter scale tool requires you to fumble around and align the setting visually on small print scale markings. The adjusting process is tedious. The nuisances of recalibrating these tools are a cumbersome and time-consuming process as it requires testing various springs to bring the tool back into calibration. A digital scale enhances your experience as the torque setting adjustment process is quick and simplistic. Easily convert between American, metric, and standard torque units. The screwdriver’s recalibration process is more straightforward with digitally reprogramming the tool. MICROMETER SCALE TOOL DIGITAL SCALE TOOL 4 PRODUCT OVERVIEW FEATURE Cycles Before Calibration Cam-Over Technology WHAT IS IT? ADVANTAGE END USER BENEFIT • ISO 6789-1:2017 calls for • Exceeds standards • Mountz 4x ISO standards: • Longer time on the maximum of 5,000 torque applications • Eliminate over-torque • Limits the amount of force applied 20,000 cycles before re-calibration • Ensures correct torque is applied • Eliminates fastener breakage issues production line • Reduces calibration budget and down time • Improves productivity • Error-proofing assembly process • Safeguards against fastening failures Locking Mechanism • Mechanism prevents accidental torque setting changes • Avoids torque setting drift • Prevents incidental adjustments • Accurate and repeatable torque setting Adjustable Tool • External torque adjustment mechanism • Quick torque setting adjustment • Converts between metric and standard units • Ensures fastening precision and accuracy • Reliable process control • Longer period before re-calibration • More efficient processes • Enhance process reliability • Improve field service quality • Accurately tighten critical fasteners of different sizes—all with a single tool Digital Display Scale • 3 digit display • Intuitive digital controls • Accurate and simplistic • Easy to view torque setting • Effortlessly fine-tune torque • Safe and secure • No band / spring and captive • Better quality and productivity adjusting process Bit Retention (Universal Bit Holder) Handle Flutes Safety & Quality Standards • ¼ inch female hex bit holder that grips any type of bit • Patented one touch bit release ball to fall out • Sleek 4-flute handle design • Ergonomic • ISO 6789-1:2017 & ASME • Meets & exceeds the B107.300-2010 standards requirements for design and calibration for both standards for hand torque tools & instruments settings and units on line • Bits don’t fall out or into tightening operation • Sleek and comfortable • Easy to clean • Compliance with materials, markings, accuracy, drives, capacity, load, testing and safety standards 5 MOUNTZ FGA ADJUSTABLE TORQUE SCREWDRIVERS MODEL ITEM NO. FGA-8 TORQUE RANGES DRIVE SIZE LENGTH WEIGHT 18 – 90 cN.m 1/4″ F/Hex 7″ 13 oz. 2 – 20 lbf.in 22 – 226 cN.m 1/4″ F/Hex 7″ 13.1 oz. 4 – 40 lbf.in 0.4 – 4.5 N.m 1/4″ F/Hex 7″ 13.3 oz. AMERICAN S.I. 076516 1.6 – 8 lbf.in FGA-20 076517 FGA-40 076518 Five units of torque measurements: (ozf.in, lbf.in, cN.m, N.m, kgf.cm). The preferred and certified ranges of these tools is in accordance with the requirements of ISO 6789 (+/- 6% of indicated setting). Note: Battery life is calculated based on an estimate of 20 power cycles per working day. More or less frequent use may result in a difference in performance. The Stamp for Quality Tools Mountz FGA screwdrivers comply with ISO6789 and are constructed from highquality materials, engineered for superior reliability and safety and backed by an industry-leading warranty. Look for the Mountz hexagon logo—it’s a stamp for quality tools, service and knowledge in the field of torque control. It’s why we have an industry-leading warranty. • Mountz FGA tools are the only adjustable cam-over screwdrivers on the market to offer a two-year unlimited warranty. If it breaks in any way, we’ll fix it or replace it for free. • Lifetime guarantee against manufacturing defects • Warranty includes a free calibration within the first year 6 At Mountz, we take great pride in knowing that our advanced torque tools will end up in the right hands. 7 ABOUT MOUNTZ Mountz, The Torque Tool Specialists®, has been a leader in the torque tool industry for more than 50 years. Engineered in the Silicon Valley and serving the globe, Mountz focuses on delivering high-quality torque products, services, and solutions to ensure customers can always proceed with confidence. We are committed to forging a safer world through precision and accuracy, and by innovating every day. mountztorque.com SILICON VALLEY HEADQUARTERS INTERNATIONAL AND SERVICE CENTER For enquiries outside of the USA, Canada, and Mexico, please contact: international@mountztorque.com Phone: +44 800 014 8753 1080 N. 11th St., San Jose, CA 95112 408-292-2214 / M–F 6am–5pm PST ALABAMA DISTRIBUTION AND SERVICE CENTER 19051 Underwood Road, Foley, AL 36535 Copyright © 2020 Mountz Inc. All Rights Reserved. V1/121120
076722 价格&库存
很抱歉,暂时无法提供与“076722”相匹配的价格&库存,您可以联系我们找货
