072999
072999
    MOUNTZ
072999 数据手册
TorqueMate Torque Analyzers PTT Series Torque, Angle & Force Analyzer with ARCII Technology KEY FEATURES System Accuracy System Accuracy 0.5% of reading from 20% to 100% of full scale. 1% of reading from 10% to 20% of full scale. Operates with Torque & Force sensors. Recommended for all hand screwdrivers, wrenches or power tools. Provides EZ-Plug & Play with Mountz torque sensors. Features ARCII technology, an instant auto-recognition system of the sensor connected to the PTT. Selection of six/seven operation modes: Track, Peak, First Peak, Audit, Bolt Audit*, Spindle Audit, Torque + Angle. *The Bolt Audit Mode is an additional feature that is only available with PTT Bold Audit Model (Item #072995). Seven units of torque measurements: ozf.in, lbf.in, lbf.ft, cN.m, N.m, kgf.m, kgf.cm Two units of force measurement: lbf and kN Features built-in Tool Tests operation. Three PC Windows based software programs: Mountz Torque Meter Interface Program for sensor calibrations, meter calibration, and tool tests. Torque Meter Bootloader for updating the PTT operating systems. Excel Add-In for Real-Time data collection into an Excel spreadsheet. It provides statistic calculations. Flash memory allows upgrades to be done by the user in the field & internet through the USB port. Five low-pass filters: 3000, 2000, 1500, 500, and 200Hz Six-digit display and easy to read menu structure. Real Time Clock for time stamping of readings. USB interface to download readings to PC. High Capacity Li-ion Batteries for long life (30 hours with standard torque sensors and 16 hours with brushless rotary sensors). Can connect to most mv/v sensors and can store calibration data for up to 50 non-smart torque sensors. The 5VDC capability allows unit to be used with a brushless rotary sensors for testing pulse tools and high RPM tools. Torque and Angle data is displayed simultaneously when used with torque and angle sensors, up to 8000 RPM for angle measurement. Stores a total of 5000 data points. Real time graph of torque vs. time using associated PC Windows software. Features Go / No Go LEDs that illuminate when high or low setting is achieved. PTT-2000 Item #072999 PTT-2000 Bolt Audit Model (for HSD Multipliers) - Item #072995 ACCESSORIES INCLUDED Description Item # Universal Charger (100-240VAC) USB Cable Mountz Software Progams Case Battery Pack 770300 770319 072509 072506 ACCESSORIES OPTIONAL CERTIFIED Supplied with Free ISO 17025 Certification of Calibration. PLUG & PLAY NOTE! Since a tester cannot always duplicate actual joint characteristics, the torque reading displayed on the PTT may vary from the actual torque that a tool will apply to a joint. When critical assemblies are involved, the torque output of the power tool being used should be verified on the actual assembly using a calibrated measuring torque tool. Description Item # Multiplexer Bar Code Reader 072998 072997 CABLE CHART Tool Tests & Graphing Torque Sensor Item # RTSX-A All BLRTSX Models BMX MTX SDX RTSX ETX 072000 072001 072002 072003 072004 072005 072006 The PTT allows you to set up and create tool tests and save the readings so you can export the data to a PC for documentation. It is the ideal solution for organizing and storing test data for ISO and SPC documentation. The ability to graph a dynamic rundown allows joint analysis. Great resource to evaluate, create or confirm a torque specification or tool being used in production. PTT 01.4
072999 价格&库存
很抱歉,暂时无法提供与“072999”相匹配的价格&库存,您可以联系我们找货
