076586
076586
    MOUNTZ
    MOUNTZ - 076586 - Torque Tool, Screwdriver, 0.25", 5.2", 9 cN-m to 90 cN-m
076586 数据手册
PRODUCT BROCHURE FG PRESET PRECISION TORQUE SCREWDRIVER “HAND ME THE MOUNTZ!” Mountz FG Precision Preset Torque Screwdriver SAFEGUARDING AGAINST FASTENING FAILURES • Poka-yoke torque screwdriver prevents over-torque • Accuracy and precision delivered for all fastening applications Unmatched quality you can count on • Calibration life 4x ISO standards • Two year unlimited warranty • Lifetime warranty against manufacturer defects QUALITY IS AT THE HEART OF EVERYTHING WE DO Relied on by leaders in aviation, automotive, medical and electronic-all industries in which process control is critical. 2 Quality cam-over technology in the palm of your hand THE STATE-OF-THE-ART PRECISION TORQUE DRIVER Engineered and assembled in Silicon Valley, the Mountz FG line of precision preset torque screwdrivers are the most advanced hand tools for high-level process and quality control. When under- or over-torquing puts your products at risk, Mountz cam-over torque screwdrivers deliver the accuracy you need. Mountz cam-over drivers use an internal cam-over mechanism to reduce the risk of operator error by disengaging once torque is reached. Our cam-over technology increases consistency of torque delivered and joint reliability. Precision and accuracy delivered every time BREAKTHROUGH ACCURACY AND REPEATABILITY INCREASES OPERATOR CONFIDENCE AND OVERALL QUALITY OF ASSEMBLY Mountz FG tools stay in calibration 4X longer than the most stringent industry standard (ISO 6789). Engineered with a cam-over mechanism, the poka-yoke screwdriver prevents over torque. You can give Mountz FG tools to any operator and have the confidence that they will deliver the correct torque, time after time. Our unique bearing system eliminates axial (end) and side loads by the operator, increasing consistency of torque delivered and joint reliability. 3 Preset cam-over torque screwdriver improves productivity Modern, effective preset torque screwdrivers improve productivity by guaranteeing that the correct torque value is consistently applied to each fastener. Preset torque screwdrivers are ideal for fastening applications where operators repeatedly assemble parts at the same torque setting. A preset screwdriver is similar to setting an alarm clock to signal the achievement of a selected time. The screwdriver is pre-set to the application’s required torque value. The tool signals once torque is achieved. A preset screwdriver doesn’t have an external torque adjustment scale. These tools have an internal torque adjustment mechanism for setting the torque value and preset using a hex key and a torque analyzer. The locking mechanism prevents accidental torque setting changes. Once the tool is set the screwdriver’s end cap is sealed with a calibration sticker and ready to be used. However, if the preset torque value needs to be changed for new fastening application the flexible tool can easily be adjusted to a new preset torque value. 4 The last precision torque screwdriver you’ll ever need to buy! We’ve tested them over millions of cycles in our controlled lab environment and we still can’t break them! It’s why we have an industry-leading warranty. • Mountz FG tools are the only cam-over drivers on the market to offer a two year unlimited warranty. If it breaks in any way, we’ll fix it or replace it for free. • Lifetime guarantee against manufacturing defects. • Warranty includes a free calibration within the first year. PRODUCT OVERVIEW FEATURE Cycles Before Calibration Consistency Cam-Over Technology WHAT IS IT? ADVANTAGE END USER BENEFIT • ISO 6789-1:2017 calls for • Exceeds standards • Mountz 4x ISO standards: • Longer time on the maximum of 5,000 torque applications • Lifecycle testing of well over 3 million combined torque applications • Eliminate over-torque • Limits the amount of force applied 20,000 cycles before re-calibration production line • Reduces calibration budget and down time • Confidence every tool meets • Reduces need to replace • Eliminates fastener breakage • Lower required tool inventory • Precision and accuracy • Error proofing assembly requirements issues • Ensures correct torque is applied tools/parts process • Safeguards against fastening failures Handle Flutes Needle Thrust Bearing • Sleek 4-flute handle design • Ergonomic • Rotary bearing to allow • Reduces axial load torque rotation between parts dependency • Reduces friction influence on • Sleek and comfortable • Easy to clean • Higher accuracy • Durability tool output • Longer life on internal components Metal End Cap Bit Retention (Universal Bit Holder) • Eliminates possibility of • Durable and doesn’t strip out • ¼ inch female hex bit holder • Safe and secure • No band / spring and captive damage to end cap that grips any type of bit • Patented One Touch bit release Locking Mechanism Preset Tool • Double locking mechanism to prevent accidental torque setting change like plastic ball to fall out • Avoids torque setting drift • Internal torque adjustment • Tool is set to a designated • Non-graduated setting • Correct torque value is mechanism torque tool torque value consistently applied • Fewer parts need replacement • Easier to service • Better quality and productivity on line • Bits don’t fall out or into assembly operation • Longer period before re-calibration • Higher accuracy over time • Enhance process reliability • Improve production quality • Increase productivity • Reduce scrap rates 5 MOUNTZ FG PRESET PRECISION HAND SCREWDRIVER LINEUP TORQUE RANGES AMERICAN S.I. LABEL COLOR 076546 0.8 – 8 lbf.in 9 – 90 cN.m Blue 1/4″ F/Hex 5.2″ 7.3 oz. FG-8i 076551 0.8 – 8 lbf.in 9 – 90 cN.m Red 1/4″ F/Hex 5.2″ 7.3 oz. FG-8i 076556 0.8 – 8 lbf.in 9 – 90 cN.m Green 1/4″ F/Hex 5.2″ 7.3 oz. FG-8i 076561 0.8 – 8 lbf.in 9 – 90 cN.m Gold 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i 076547 2 – 20 lbf.in 22 – 226 cN.m Blue 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i 076552 2 – 20 lbf.in 22 – 226 cN.m Red 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i 076557 2 – 20 lbf.in 22 – 226 cN.m Green 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i 076562 2 – 20 lbf.in 22 – 226 cN.m Gold 1/4″ F/Hex 5.2″ 7.3 oz. FG-40i* 076548 4 – 40 lbf.in 0.4 – 4.5 N.m Blue 1/4″ F/Hex 6.3″ 11.5 oz. FG-40i* 076553 4 – 40 lbf.in 0.4 – 4.5 N.m Red 1/4″ F/Hex 6.3″ 11.5 oz. FG-40i* 076558 4 – 40 lbf.in 0.4 – 4.5 N.m Green 1/4″ F/Hex 6.3″ 11.5 oz. FG-40i* 076563 4 – 40 lbf.in 0.4 – 4.5 N.m Gold 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i* 076549 25 – 125 lbf.in 2.8 – 14.1 N.m Blue 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i* 076554 25 – 125 lbf.in 2.8 – 14.1 N.m Red 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i* 076559 25 – 125 lbf.in 2.8 – 14.1 N.m Green 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i* 076564 25 – 125 lbf.in 2.8 – 14.1 N.m Gold 1/4″ F/Hex 6.3″ 11.5 oz. MODEL ITEM NO. FG-8i Designed and manufactured to meet or exceed the accuracy and repeatability requirements of ISO 6789: 2017 (+/- 6% of setting). DRIVE SIZE LENGTH WEIGHT *A removable, sliding T-bar is supplied with FG-40i and FG-125i models. Color coding labels allows for torque setting identification in manufacturing area. Tamper-proof internal adjustment. No external adjustment scale—must be preset using a torque analyzer. 6 MOUNTZ FG-OWC PRESET PRECISION HAND SCREWDRIVER LINEUP TORQUE RANGES AMERICAN S.I. LABEL COLOR 076586 0.8 – 8 lbf.in 9 – 90 cN.m Blue 1/4″ F/Hex 5.2″ 7.3 oz. FG-8i OWC 076591 0.8 – 8 lbf.in 9 – 90 cN.m Red 1/4″ F/Hex 5.2″ 7.3 oz. FG-8i OWC 076596 0.8 – 8 lbf.in 9 – 90 cN.m Green 1/4″ F/Hex 5.2″ 7.3 oz. FG-8i OWC 076601 0.8 – 8 lbf.in 9 – 90 cN.m Gold 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i OWC 076587 2 – 20 lbf.in 22 – 226 cN.m Blue 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i OWC 076592 2 – 20 lbf.in 22 – 226 cN.m Red 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i OWC 076597 2 – 20 lbf.in 22 – 226 cN.m Green 1/4″ F/Hex 5.2″ 7.3 oz. FG-20i OWC 076602 2 – 20 lbf.in 22 – 226 cN.m Gold 1/4″ F/Hex 5.2″ 7.3 oz. FG-40i OWC** 076588 4 – 40 lbf.in 0.4 – 4.5 N.m Blue 1/4″ F/Hex 6.3″ 11.5 oz. FG-40i OWC** 076593 4 – 40 lbf.in 0.4 – 4.5 N.m Red 1/4″ F/Hex 6.3″ 11.5 oz. FG-40i OWC** 076598 4 – 40 lbf.in 0.4 – 4.5 N.m Green 1/4″ F/Hex 6.3″ 11.5 oz. FG-40i OWC** 076603 4 – 40 lbf.in 0.4 – 4.5 N.m Gold 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i OWC** 076589 25 – 125 lbf.in 2.8 – 14.1 N.m Blue 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i OWC** 076594 25 – 125 lbf.in 2.8 – 14.1 N.m Red 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i OWC** 076599 25 – 125 lbf.in 2.8 – 14.1 N.m Green 1/4″ F/Hex 6.3″ 11.5 oz. FG-125i OWC** 076604 25 – 125 lbf.in 2.8 – 14.1 N.m Gold 1/4″ F/Hex 6.3″ 11.5 oz. MODEL ITEM NO. FG-8i OWC FG-OWC (ONE WAY-CLUTCH) A one-way torque clutch system is designed to apply torque in one direction and remains positive (no torque control) in the opposite direction. This allows the tool to be used for easy screw removal. Ideal for maintenance and refurbishing applications and where undoing or loosening screws is required. Screwdriver is torque limiting and calibrated in the CW direction only Designed and manufactured to meet or exceed the accuracy and repeatability requirements of ISO 6789: 2017 (+/- 6% of setting). DRIVE SIZE LENGTH WEIGHT **A removable, sliding T-bar is supplied with FG-40i OWC and FG-125i OWC models. Tamper-proof internal adjustment. No external adjustment scale—must be preset using a torque analyzer. Color coding labels allows for torque setting identification in manufacturing area. 7 At Mountz, we take great pride in knowing that our advanced torque tools will end up in the right hands. 8 ABOUT MOUNTZ Mountz, The Torque Tool Specialists®, has been a leader in the torque tool industry for more than 50 years. Engineered in the Silicon Valley and serving the globe, Mountz focuses on delivering high-quality torque products, services, and solutions to ensure customers can always proceed with confidence. We are committed to forging a safer world through precision and accuracy, and by innovating every day. mountztorque.com SILICON VALLEY HEADQUARTERS INTERNATIONAL AND SERVICE CENTER For enquiries outside of the USA, Canada, and Mexico, please contact: international@mountztorque.com Phone: +44 800 014 8753 1080 N. 11th St., San Jose, CA 95112 408-292-2214 / M–F 6am–5pm PST ALABAMA DISTRIBUTION AND SERVICE CENTER 19051 Underwood Road, Foley, AL 36535 Copyright © 2020 Mountz Inc. All Rights Reserved. V3/120220
076586 价格&库存
很抱歉,暂时无法提供与“076586”相匹配的价格&库存,您可以联系我们找货
