280039
280039
    MOUNTZ
    MOUNTZ - 280039 - Torque, Adjustable Click Wrench, 183N-m to 779.5N-m
280039 数据手册
Making a Safer World Through Accuracy and Precision Product Bulletin PB # 0057 (Rev2) Follow us on Twitter @mountztorque June 2015 www.mountztorque.com EPT Click Wrench (Adjustable) - Designed and manufactured to meet or exceed the accuracy and repeatability of ISO 6789:2003 (Tools < 10 N.m (+/- 6% of setting): EPT100i (Tools > 10 N.m are +/- 4% of setting): EPT250i - EPT750F - Durable and robust for industrial fastening applications. - Adjustable torque wrench with a square drive. Bi-directional ratchet head. - External dual scale (American & S.I.) Graduation collar on the torque handle. - Easy to read laser marked scale. - Crafted with strong steel shaft with high corrosion resistance. - Lightly knurled non-slip grip. - 48 tooth ratchet (for models EPT250i - EPT750F). 60 tooth ratchet (for EPT100i) - Positive lock with spring loaded pull-down ring. - Positive “click” can be heard and felt when torque is reached. New model: EPT100i Torque Ranges Graduation Length Weight Model Item # American S.I. American S.I. Square Drive in mm lbs kg EPT100i 280050 20 - 100 lbf.in 2.8 - 11.9 N.m 0.5 lbf.in 0.1 N.m 1/4” 7 1/2” 193 0.4 0.18 EPT250i-D 280033 50 - 250 lbf.in 6.2 - 28.8 N.m 1 lbf.in 0.1 N.m 1/4” 9 2/3” 245 0.9 0.4 EPT250i-A 280034 50 - 250 lbf.in 6.2 - 28.8 N.m 1 lbf.in 0.1 N.m 3/8” 9 2/3” 245 0.9 0.4 EPT75F 280035 15 - 75 lbf.ft 23.7 - 105.1 N.m 0.5 lbf.ft 0.5 N.m 3/8” 16 1/8” 410 2.6 1.2 EPT150F 280036 10 - 150 lbf.ft 20.3 - 210.1 N.m 1 lbf.ft 1 N.m 1/2” 20 1/2” 520 3.5 1.6 EPT250F 280037 30 - 250 lbf.ft 47.4 - 345.7 N.m 2 lbf.ft 2 N.m 1/2” 24” 610 3.5 1.6 EPT400F 280038 80 - 400 lbf.ft 142.3 - 559.2 N.m 2.5 lbf.ft 2.5 N.m 3/4” 39 7/8” 1012 10.9 4.9 EPT550F 280039 110 - 550 lbf.ft 183 - 779.5 N.m 2.5 lbf.ft 5 N.m 3/4” 44 1/4” 1125 12.6 5.7 EPT750F 280040 150 - 750 lbf.ft 237.2 - 1050.6 N.m 5 lbf.ft 5 N.m 1” 48 1/4” 1225 14.4 6.5 Note! - After being used, an adjustable click wrench should be turned back to minimum scale value. This helps to preserve the springs and ensures a longer product life cycle with high precision. Corporate Headquarters: 1080 North 11th Street, San Jose, CA 95112 Page 1
280039 价格&库存
很抱歉,暂时无法提供与“280039”相匹配的价格&库存,您可以联系我们找货
