076571
076571
    MOUNTZ
    MOUNTZ - 076571 - Torque, Wrench, Length 17.5", 25N-m to 125N-m
076571 数据手册
PRODUCT BROCHURE FGC PRESET PRECISION CAM-OVER WRENCH “HAND ME THE MOUNTZ!” Mountz FGC Precision Preset Cam-Over Wrench SAFEGUARDING AGAINST FASTENING FAILURES • Poka-yoke torque wrench prevents over-torque. • Accuracy and precision delivered for all tightening applications • Calibration life 2x ISO standards • Unmatched quality you can count on • Two-year unlimited warranty • Lifetime warranty against manufacturer defects QUALITY IS AT THE HEART OF EVERYTHING WE DO Relied on by leaders in aviation, automotive, medical and electronic-all industries in which process control is critical. 2 Quality cam-over technology in the palm of your hand PRECISION TORQUE WRENCH DELIVERS CONFIDENCE AT EVERY TURN Engineered and assembled in Silicon Valley, the Mountz FGC line of precision preset cam-over wrenches are the most advanced torque wrenches for high-level process and quality control. The wrench’s repeatability, traceability, and precision safeguards against fastening failures. When under- or over-torquing puts your products at risk, Mountz cam-over wrenches deliver the accuracy you need. Mountz cam-over wrenches use an internal cam-over mechanism to reduce the risk of operator error by disengaging once torque is reached. Our cam-over technology increases consistency of torque delivered and joint reliability. Precision and accuracy delivered every time Mountz FGC tools stay in calibration 2X longer than the most stringent industry standard (ISO 6789). Engineered with a cam-over mechanism, the poka-yoke wrench prevents over torque. Implementing this errorproofing wrench removes the operator influence out of the torque equation and delivers an accurate and repeatable fastening result than a standard click type wrench. You can give Mountz FGC wrenches to any operator and have the confidence that he/ she will deliver the correct torque, time after time. 3 Preset cam-over torque wrench improves productivity Modern, effective preset torque wrenches improve productivity by guaranteeing that the correct torque value is consistently applied to each fastener. Preset cam-over wrenches are ideal for fastening applications where operators repeatedly assemble parts at the same torque setting. A preset wrench is similar to setting an alarm clock to signal the achievement of a selected time. The wrench is pre-set to the application’s required torque value. The tool signals once torque is achieved. A preset wrench doesn’t have an external torque adjustment scale. These tools have an internal torque adjustment mechanism for setting the torque value and preset using a hex key and a torque analyzer. The locking mechanism prevents accidental torque setting changes. Once the tool is set the wrench’s end cap is sealed with a calibration sticker and ready to be used. However, if the preset torque value needs to be changed for new fastening application the flexible tool can easily be adjusted to a new preset torque value. 4 The stamp for quality tools Mountz FGC wrenches comply with ISO6789 and are constructed from high quality materials, engineered for superior reliability and safety and backed by an industry leading warranty. Look for the Mountz hexagon logo – it’s a stamp for quality tools, service and knowledge in the field of torque control. It’s why we have an industry-leading warranty. • Mountz FGC tools are the only cam-over wrenches on the market to offer a twoyear unlimited warranty. If it breaks in any way, we’ll fix it or replace it for free. • Lifetime guarantee against manufacturing defects. • Warranty includes a free calibration within the first year. PRODUCT OVERVIEW FEATURE Cycles Before Calibration Cam-Over Technology WHAT IS IT? ADVANTAGE END USER BENEFIT • ISO 6789-1:2017 calls for • Exceeds standards • Mountz 2x ISO standards: • Longer time on the maximum of 5,000 torque applications • Eliminate over-torque • Limits the amount of force applied Locking Mechanism • Internal mechanism prevents accidental torque setting changes 10,000 cycles before recalibration • Ensures correct torque is applied • Eliminates fastener breakage issues • Avoids torque setting drift • Prevents incidental adjustments • Accurate and repeatable torque setting Preset Tool • Internal torque adjustment • Tool is set to a designated • Non-graduated setting • Correct torque value is • Independent torque output • Operator’s hand position on mechanism torque tool Non-length Dependent vs. hand position torque value consistently applied the tool does not affect on torque output production line • Reduces calibration budget and down time • Precision and accuracy • Error-proofing assembly process fastening failures • Ensures fastening precision and accuracy • Reliable process control • Longer period before re-calibration • Enhance process reliability • Improve production quality • Increase productivity • Reduce scrap rates • Allows for precision tightening • Higher repeatability • Less training for correct operation Metal End Cap • Anodized aluminum end cap • Durable and doesn’t strip out Ergonomics • Ergonomic handle • Cushion, non-slip grip for all models like plastic • Fewer parts need replacement • Easier to service • Improve operator’s efficiency • Reduce discomfort, fatigue, and risk of injury Durability Safety & Quality Standards • Coated corrosion-resistant stainless steel head • Anodized aluminum handle • Non-strip ratchet head • ISO 6789-1:2017 & ASME B107.300-2010 standards • Long tool service life • Reduces need to replace tools/ parts • Lower required tool inventory • Meets & exceeds the requirements • Compliance with materials, for design and calibration for both standards for hand torque tools & instruments markings, accuracy, drives, capacity, load, testing and safety standards 5 MOUNTZ FGC PRESET PRECISION CAM-OVER WRENCHES MODEL ITEM NO. FGC-5 TORQUE RANGES DRIVE SIZE LENGTH WEIGHT 1 – 5 N.m 1/4" Sq. Dr. 7.8" 0.6 lbs. 17.7 – 88.5 lbf.in 2 – 10 N.m 1/4" Sq. Dr. 7.8" 0.7 lbs. 076567 17.7 – 88.5 lbf.in 2 – 10 N.m 3/8" Sq. Dr. 7.8" 0.7 lbs. FGC-30D 076568 4.4 – 22.1 lbf.ft 6 – 30 N.m 1/4" Sq. Dr. 12.8" 1.7 lbs. FGC-30A 076569 4.4 – 22.1 lbf.ft 6 – 30 N.m 3/8" Sq. Dr. 12.8" 1.7 lbs. FGC-75 076570 11.1 – 55.3 lbf.ft 15 – 75 N.m 3/8" Sq. Dr. 17.5" 3.1 lbs. FGC-125 076571 18.5 – 92.2 lbf.ft 25 – 125 N.m 1/2" Sq. Dr. 17.5" 3.1 lbs. AMERICAN S.I. 076565 8.9 – 44.2 lbf.in FGC-10D 076566 FGC-10A FGC-5 and FGC-10 models Designed and manufactured to meet or exceed the accuracy and repeatability requirements of ISO 6789: 2017 (+/- 6% of setting). FGC-30, FGC-75 and FGC-125 models Designed and manufactured to meet or exceed the accuracy and repeatability requirements of ISO 6789: 2017 (+/- 4% of setting). Tamper-proof internal adjustment. No external adjustment scale—must be preset using a torque analyzer. At Mountz, we take great pride in knowing that our advanced torque tools will end up in the right hands. 6 7 ABOUT MOUNTZ Mountz, The Torque Tool Specialists®, has been a leader in the torque tool industry for more than 50 years. Engineered in the Silicon Valley and serving the globe, Mountz focuses on delivering high-quality torque products, services, and solutions to ensure customers can always proceed with confidence. We are committed to forging a safer world through precision and accuracy, and by innovating every day. SILICON VALLEY HEADQUARTERS INTERNATIONAL AND SERVICE CENTER For enquiries outside of the USA, Canada, and Mexico, please contact: international@mountztorque.com Phone: +44 800 014 8753 1080 N. 11th St., San Jose, CA 95112 408-292-2214 / M–F 6am–5pm PST mountztorque.com ALABAMA DISTRIBUTION AND SERVICE CENTER 19051 Underwood Road, Foley, AL 36535 Copyright © 2020 Mountz , Inc. All Rights Reserved. V2/080220
076571 价格&库存
很抱歉,暂时无法提供与“076571”相匹配的价格&库存,您可以联系我们找货
