145866
145866
    MOUNTZ
    MOUNTZ - 145866 - BRUSHLESS DRIVER, LEVER START, 1/4" - Drive Type:Lever Start; Driver Size:1/4"; Dr...
145866 数据手册
E-DR IV NF-Series Brushless Electric Torque Screwdrivers KEY FEATURES Torque Covers Various models that range from 2.6 - 39 lbf.in High performance brushless motor design provides durability and reduces the standard maintenance costs for electric drivers. Protects from incidental or operator tampering of torque setting Allows for color coding of specific torque values in production areas. Designed for high production environments. Minimal heat buildup even when tool is operated continuously. Over Heat Protection (OHP) and Over Current Protection (OCP) protect driver from damage or malfunction. Features a LED display that signals the tool status for the operator to view. Can be connected with the Scout Screw Counter. External torque adjustment scale. Black Item # 145955 Requires a Transformer (power supply). All models are ESD designed and prevent the occurrence of electrostatic discharge, which improves production yields, manufacturing costs, product quality, product reliability, reputation and profitability. Mr. Metric is the leading metric fastner specialist in North America. Well regarded as experts in metric. Mr. Metric is known for hard to find metric items at competitive prices. Visit www.mrmetric.com R E-DRIV NF-SERIES 01.7 Follow Mountz Keep informed about our torque tool products, events and industry news. Select your favorite social media site to catch the latest news from Mountz. Torque Ranges lbf.in cN.m RPM Adjustable* Grip Dia. Drive Size Wt. oz. STANDARD MODELS Model Adjustable RPM setting on the tool. NF150-A ESD Lever Start 145846 2.6 - 13 29.4 - 147 800 - 1700 1 1/3" 10 1/4" 1/4 F/Hex 18.4 1 NF150P-A ESD Push-to-Start 145849 2.6 - 13 29.4 - 147 800 - 1700 1 /3" 10 1/4" 1/4 F/Hex 18.4 NF220-A ESD Lever Start 145847 5.2 - 19 58.9 - 215.8 600 - 1200 1/4 F/Hex 18.4 1 1/3" 10 1/4" NF220P-A ESD Push-to-Start 145850 5.2 - 19 58.9 - 215.8 600 - 1200 1/4 F/Hex 18.4 1 1/3" 10 1/4" NF450-A ESD Lever Start 145848 6.1 - 39 68.7 - 441 300 - 600 1/4 F/Hex 18.4 1 1/3" 10 1/4" NF450P-A ESD Push-to-Start 145851 6.1 - 39 68.7 - 441 300 - 600 1/4 F/Hex 18.4 1 1/3" 10 1/4" *Requires Program Lock Key (Item# 145774) to adjust RPM & Soft Start Settings. Program Lock Key must be plugged into the STC40 Transformer (see page 01.19 for details) A selectable Soft Start mode from 0.2 - 0.6 seconds STANDARD PLUS MODELS The “Plus” models feature a selectable Double Hit Mode for soft joint applications and seletable Soft Start mode (from 0.2 - 0.6 seconds). These options are controlled on the side of the driver. Driver Type Item # Model Driver Type Item # Torque Ranges lbf.in cN.m RPM Grip Dia. Length Drive Size Wt. oz. NF150-A ESD Plus NF150P-A ESD Plus NF220-A ESD Plus NF220P-A ESD Plus NF450-A ESD Plus NF450P-A ESD Plus Lever Start Push-to-Start Lever Start Push-to-Start Lever Start Push-to-Start 145852 145855 145853 145856 145854 145857 2.6 - 13 2.6 - 13 5.2 - 19 5.2 - 19 6.1 - 39 6.1 - 39 1700 1700 1200 1200 600 600 1 1/3" 1 1/3" 1 1/3" 1 1/3" 1 1/3" 1 1/3" 10 1/4" 10 1/4" 10 1/4" 10 1/4" 10 1/4" 10 1/4" 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 18.4 18.4 18.4 18.4 18.4 18.4 SOFT STOP MODELS Precision “Soft Stop” clutch prevents shock to sensitive assemblies like disk drives, plastics, electronics, etc. Adjustable RPM setting on the tool. A selectable Soft Start mode from 0.2 - 0.6 seconds Length 29.4 - 147 29.4 - 147 58.9 - 215.8 58.9 - 215.8 68.7 - 441 68.7 - 441 Model Driver Type Item # Torque Ranges lbf.in cN.m RPM Adjustable* Grip Dia. Length Drive Size Wt. oz. NFS150-A ESD NFS220-A ESD Lever Start Lever Start 145865 145866 2.6 - 13 5.2 - 19 800 - 1700 600 - 1200 1 1/3" 1 1/3" 10 1/4" 10 1/4" 1/4 F/Hex 1/4 F/Hex 18.4 18.4 29.4 - 147 58.9 - 215.8 *Requires Program Lock Key (Item# 145774) to adjust RPM & Soft Start Settings. Program Lock Key must be plugged into the STC40 Transformer (see page 01.19 for details) ANGLE CONTROL & AUTO REVERSE MODELS Time Angle Control & Auto Reverse model. Set the start and stop point by angle control within a range of 0.25 15 turns. Also set the “Stop Holding Time” within a range of 0.1 to 6 seconds. Adjustable RPM setting on the tool. STC40 TRANSFORMER Model: STC40 Item #145754 Max. Output: 10A Output VDC: 30 / 40 Input VAC: 110 / 230V Size (WxDxH): 4 3/8" x 7 1/2" x 2 3/8" Weight (lbs.): 1.8 Model Driver Type Item # Torque Ranges lbf.in cN.m RPM Adjustable* Grip Dia. Length Drive Size Wt. oz. NFT150-A ESD NFT220-A ESD NFT450-A ESD Lever Start Lever Start Lever Start 145858 145859 145860 2.6 - 13 5.2 - 19 6.1 - 39 800 - 1700 600 - 1200 300 - 600 1 1/3" 1 1/3" 1 1/3" 10 1/4" 10 1/4" 10 1/4" 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 18.4 18.4 18.4 PROGRAM LOCK KEY 29.4 - 147 58.9 - 215.8 68.7 - 441 VACUUM ADAPTER KIT Adjust RPM & Soft Start Settings for select models. Program Lock Key must be plugged into the STC40 Transformer. (see page 01.19 for details) Mounts easily to NF-Series Drivers. Accepts different size screws and various length fasteners. Allows quick change set-up at a low cost. Item #145774 Mounts with threaded torque nut. The driver remains externally adjustable while allowing semi-automatic pickup of non-ferrous fasteners. PISTOL GRIP ATTACHMENT For NF-Series Item #145789 Plug driver into vacuum supply or choose the Vacuum Ejector. Mouthpiece and bit purchased separately. Item #145864 R E-DRIV NF-SERIES 01.8
145866 价格&库存
很抱歉,暂时无法提供与“145866”相匹配的价格&库存,您可以联系我们找货
