068405
068405
    MOUNTZ
068405 数据手册
Torque Analyzers TorqueLab LTT Series Torque, Angle & Force Analyzer with ARCII Technology KEY FEATURES Accuracy Accuracy 0.5% of reading from 20% to 100% of full scale. 1% of reading from 10% to 20% of full scale. Recommended for all hand screwdrivers, wrenches, or power tools. Features a built-in transducer and can connect to an external torque sensor. Provides EZ-Plug & Play with Mountz torque sensors. Features ARCII technology, an instant auto-recognition system of the sensors connected to the LTT. Selection of six operation modes: Track, Peak, First Peak, Audit, Spindle Audit, and Torque + Angle Seven units of torque measurements: ozf.in, lbf.in, lbf.ft, cN.m, N.m, kgf.m, kgf.cm Two units of force measurement: lbf and kN Features built-in Tool Tests operation. Three PC Windows based software programs: Mountz Torque Meter Interface Program for sensor calibrations, meter calibration and tool tests. Torque Meter Bootloader for updating the LTT operating systems. Excel Add-In for Real-Time data collection into an Excel spreadsheet. It provides statistics calculations. Flash memory allows upgrades to be done by the user in the field & internet through the USB port. Five low-pass filters: 3000, 2000, 1500, 500, and 200Hz Six-digit display and easy to read menu structure. Real Time Clock for time stamping of readings. USB interface to download readings to PC. Model Item # American Torque Ranges S.I. LTT10i LTT25i LTT50i LTT100i LTT250i LTT50F LTT100F LTT250F 068400 068401 068402 068403 068404 068405 068406 068407 1 - 10 lbf.in 2.5 - 25 lbf.in 5 - 50 lbf.in 10 - 100 lbf.in 25 - 250 lbf.in 5 - 50 lbf.ft 10 - 100 lbf.ft 25 - 250 lbf.ft 11.3 - 113 cN.m 28.25 - 282.5 cN.m 56.5 - 565 cN.m 113 - 1130 cN.m 282.5 - 2825 cN.m 6.8 - 67.8 N.m 13.56 - 135.6 N.m 33.9 - 339 N.m High Capacity Li-ion Batteries for long life (30 hours with standard torque sensors and 16 hours with brushless rotary sensors). Metric Drive Size Wt. 1.2 - 11.5 kgf.cm 2.9 - 28.8 kgf.cm 5.8 - 57.6 kgf.cm 11.5 - 115 kgf.cm 28.8 - 288 kgf.cm 0.7 - 6.9 kgf.m 1.4 - 13.8 kgf.m 3.5 - 34.5 kgf.m 1/4" F/Sq 1/4" F/Sq 1/4" F/Sq 1/4" F/Sq 1/4" F/Sq 3/8" F/Sq 1/2" F/Sq 1/2" F/Sq 8 lbs. 8 lbs. 8 lbs. 8 lbs. 8 lbs. 8 lbs. 8 lbs. 8 lbs. Can connect to most mv/v sensors and can store calibration data for up to 50 non-smart torque sensors. The 5VDC capability allows unit to be used with a brushless rotary torque sensor for testing pulse tools and high RPM tools. Torque and Angle data is displayed simultaneously when used with torque and angle sensors, up to 8000 RPM for angle measurement. Stores a total of 5000 data points. Real time graph of torque vs. time using associated PC Windows software. Features Go / No Go LEDs that illuminate when high or low setting is achieved. ACCESSORIES INCLUDED ACCESSORIES OPTIONAL CABLE CHART Item # Description Universal Charger (100-240VAC) 770301 USB Cable Run Down Adapter Mountz Software Progams Battery Pack 770319 See Pg. 01.16 072506 Multiplexer 072998 RTSX-A Bar Code Reader 072997 All BLRTSX models Mounting Bracket 072608 BMX (for LTT model 10i-50F) MTX Mounting Bracket 072606 SDX (for all LTT models) RTSX LTT 01.1 Item # Torque Sensor Description 800.456.1828 Item # 072000 072001 072002 072003 072004 072005 PLUG & PLAY CERTIFIED Supplied with Free ISO 17025 Certification of Calibration. NOTE! Since a tester cannot always duplicate actual joint characteristics, the torque reading displayed on the LTT may vary from the actual torque that a tool will apply to a joint. When critical assemblies are involved, the torque output of the power tool being used should be verified on the actual assembly using a calibrated measuring torque tool.
068405 价格&库存
很抱歉,暂时无法提供与“068405”相匹配的价格&库存,您可以联系我们找货
