076815
076815
    MOUNTZ
    MOUNTZ - 076815 - TORQUE TOOL, WRENCH, 6"
076815 数据手册
PRODUCT BROCHURE TBX PRESET PRECISION BREAK-OVER WRENCH “HAND ME THE MOUNTZ!” Mountz TBX Preset Break-Over Wrench SAFEGUARDING AGAINST FASTENING FAILURES • Torque limiting wrench improves control of the tightening process • Reduces the risk of both over and under-tightening • Break-over mechanism provides a visual indicator of achieving torque setting • Interchangeable end fitting design—selectable head types and sizes • Calibration life 4x ISO standards • Unmatched quality you can count on QUALITY IS AT THE HEART OF EVERYTHING WE DO Relied on by leaders in communications, aviation, automotive, medical and electronic-all industries in which process control is critical. 2 Reliable break-over technology in the palm of your hand QUALITY TORQUE WRENCH DELIVERS CONFIDENCE AT EVERY TURN Engineered and assembled in Silicon Valley, the Mountz TBX line of precision preset break-over wrenches ensures consistent process and quality control. The wrench's repeatability, traceability, and precision safeguards against fastening failures. When under- or over-torquing puts your products at risk, Mountz break-over wrenches help support your quality control process by empowering an operator to prevent assembly errors. Designed to tighten various types of fasteners accurately, the break-over wrench informs the operator when the proper torque is reached by deflecting at the pivot point near the tool's end. The unique break-over mechanism gives an operator ample time to react once the target torque is achieved and stop applying additional force to the fastener. Our break-over technology increases the consistency of torque delivered and joint reliability. Execute fastening tasks with precision and repeatability Mountz TBX tools stay in calibration 4X longer than the most stringent industry standard (ISO 6789). The torque limiting wrench is engineered with a breakover mechanism that enables manufacturers to achieve and maintain process reliability. You can give Mountz TBX wrenches to any operator and have the confidence that he/she will deliver the correct torque, time after time. 3 Preset break-over torque wrench improves productivity Modern, effective preset torque wrenches improve productivity by consistently applying the correct torque value to each fastener. Preset break-over wrenches are ideal for fastening applications where operators repeatedly assemble parts at the same torque setting. A preset wrench is similar to setting an alarm clock to signal the achievement of a selected time. The wrench is pre-set to the application’s required torque value. The tool breaks over, providing a visual indicator once torque is achieved. A preset wrench doesn’t have an external torque adjustment scale. These tools have an internal torque adjustment mechanism for setting the torque value and preset using a hex key and a torque analyzer. The locking mechanism prevents accidental torque setting changes. Once the tool is set, the wrench's end cap is sealed with a calibration sticker and ready to be used. However, if the preset torque value needs to be changed for a new fastening application, the flexible tool can easily be adjusted to a new preset torque value. TBX-12 4 TBX-25 PRODUCT OVERVIEW FEATURE Cycles Before Calibration Break-Over Technology WHAT IS IT? ADVANTAGE END USER BENEFIT • ISO 6789-1:2017 calls for • Exceeds standards • Mountz 4x ISO standards: • Longer time on the maximum of 5,000 torque applications • Limits the amount of torque applied • Break-over mechanism deflects at a pivot point near the tool’s end fitting Locking Mechanism • Internal mechanism prevents accidental torque setting changes 20,000 cycles before re-calibration • Prevent fastening errors • Tool’s built-in hinge provides a visual indicator of achieving the torque setting • Avoids torque setting drift • Prevents incidental adjustments • Accurate and repeatable torque setting Preset Tool • Internal torque adjustment • Tool is set to a designated • Non-graduated setting • Correct torque value is • Anodized aluminum end cap • Durable and doesn’t strip out mechanism torque tool Metal End Cap for all models torque value consistently applied like plastic production line • Reduces calibration budget and down time • Precision and repeatability • Mitigate under- or overtorquing events • Boost project ROI • Ensures fastening precision and accuracy • Reliable process control • Longer period before re-calibration • Enhance process reliability • Improve production quality • Increase productivity • Reduce scrap rates • Improve operator's efficiency • Reduce discomfort, fatigue, and risk of injury Ergonomics • Ergonomic handle • Cushion, non-slip grip • Improve operator's efficiency • Reduce discomfort, fatigue, and risk of injury Interchangeable Heads • The end fitting of the wrench allows different head types and sizes to be exchanged and attached • Compatible for various applications from open end spanner, box end, flare end, hex key, or a ratchet head with a single wrench. • Configure the head type and size per fastening application • Flexibility to replace and change • Custom design heads available upon request • Enables the tool to fit in restricted space applications 5 MOUNTZ TBX PRESET BREAK-OVER WRENCHES MODEL ITEM NO. TORQUE RANGES AMERICAN S.I. DRIVE SIZE LENGTH WEIGHT BREAK TBX-12 076815 21.2–106.2 lbf.in 2.4–12 N.m Type A 6" 0.8 lbs 20° or 90° TBX-12 ESD 076818 21.2–106.2 lbf.in 2.4–12 N.m Type A 6" 0.8 lbs 20° or 90° TBX-25 076816 44.3–221.3 lbf.in 5–25 N.m Type B 10.4" 1.6 lbs 20° TBX-25 ESD 076819 44.3–221.3 lbf.in 5–25 N.m Type B 10.4" 1.6 lbs 20° Designed and manufactured to meet or exceed the accuracy and repeatability requirements of ISO 6789: 2017 (+/- 4% of setting). Tamper-proof internal adjustment. No external adjustment scale—must be preset using a torque analyzer. 6 Interchangeable heads for TBX-12 model type A end fitting OPEN END HEADS AMERICAN BOX END HEADS METRIC AMERICAN METRIC SIZE ITEM NO. SIZE ITEM NO. SIZE ITEM NO. SIZE ITEM NO. 3/16" 068605 6 mm 068615 7/32" 068625 7 mm 068631 1/4" 068606 7 mm 068616 1/4" 068626 8 mm 068632 5/16" 068607 8 mm 068617 5/16" 068627 9 mm 068633 3/8" 068608 9 mm 068618 3/8" 068628 10 mm 068634 7/16" 068609 10 mm 068619 7/16" 068629 11 mm 068635 1/2" 068610 11 mm 068620 1/2" 068630 12 mm 068636 9/16" 068611 12 mm 068621 – – 13 mm 068637 5/8" 068612 13 mm 068622 11/16" 068613 14 mm 068623 3/4" 068614 15 mm 068624 HEX KEY HEADS AMERICAN METRIC FIXED SQUARE DRIVE HEADS RATCHET HEAD AMERICAN AMERICAN SIZE ITEM NO. SIZE ITEM NO. SIZE ITEM NO. SIZE ITEM NO. 1/16" 068639 1.5 mm 068648 1/4" Sq. Dr. 068655 1/4" Sq. Dr. 068599 5/64" 068640 2 mm 068649 3/8" Sq. Dr. 068656 3/32" 068641 2.5 mm 068651 7/64" 068642 3 mm 068652 1/8" 068643 4 mm 068653 9/64" 068644 5 mm 068654 5/32" 068645 – – 3/16" 068646 – – 1/4" 068647 – – BOX RATCHET HEAD AMERICAN SIZE ITEM NO. 1/4" Box End 068598 BLANK END HEAD SIZE ITEM NO. Blank End 068603 7 Interchangeable heads for TBX-25 model type B end fitting OPEN END HEADS AMERICAN METRIC AMERICAN METRIC SIZE ITEM NO. SIZE ITEM NO. SIZE ITEM NO. SIZE ITEM NO. 1/4" 068657 7 mm 068673 1/4" 068684 9 mm 068694 5/16" 068658 8 mm 068674 5/16" 068685 13 mm 068695 3/8" 068659 9 mm 068675 3/8" 068686 17 mm 068696 7/16" 068660 10 mm 068676 7/16" 068687 18 mm 068697 1/2" 068661 11 mm 068677 1/2" 068688 – – 9/16" 068662 12 mm 068678 9/16" 068689 – – 5/8" 068663 13 mm 068679 5/8" 068690 – – 11/16" 068664 14 mm 068680 3/4" 068691 – – 3/4" 068665 17 mm 068681 7/8" 068692 – – 13/16" 068666 19 mm 068682 15/16" 068693 – – 7/8" 068667 22 mm 068683 15/16" 068668 – – 1" 068669 – – 1 1/16" 068670 – – 1 1/8" 068671 – – 1 1/4" 068672 – – RATCHET HEAD AMERICAN 8 BOX END HEADS SIZE ITEM NO. 3/8" Sq. Dr. 068698 1/2" Sq. Dr. 068699 BLANK END HEAD SIZE ITEM NO. Blank End 068604 At Mountz, we take great pride in knowing that our advanced torque tools will end up in the right hands. 9 ABOUT MOUNTZ Mountz, The Torque Tool Specialists®, has been a leader in the torque tool industry for more than 55 years. Engineered in the Silicon Valley and serving the globe, Mountz focuses on delivering high-quality torque products, services, and solutions to ensure customers can always proceed with confidence. We are committed to forging a safer world through precision and accuracy, and by innovating every day. mountztorque.com SILICON VALLEY HEADQUARTERS INTERNATIONAL AND SERVICE CENTER For inquiries outside of the USA, Canada, and Mexico, please contact: international@mountztorque.com Phone: +44 1428 741756 1080 N. 11th St., San Jose, CA 95112 408-292-2214 / M–F 6am–5pm PST ALABAMA DISTRIBUTION AND SERVICE CENTER 19051 Underwood Road, Foley, AL 36535 Copyright © 2021 Mountz Inc. All Rights Reserved. V1/092821
076815 价格&库存
很抱歉,暂时无法提供与“076815”相匹配的价格&库存,您可以联系我们找货
