773069
773069
    MOUNTZ
773069 数据手册
DC Control System MD & AD Series CERTIFIED CERTIFIED & DOCUMENTED fastening results. Supplied with FREE certification. LEANER Operate a LEANER production environment with flexible, configurable tool set up. COMPLIANCE Make fastening COMPLIANCE and documentation easy. Introduction The MD or AD-Series is a durable torque and automation control system engineered for precise, accurate and repeatable torque control. The high performance torque fastening system by Mountz allows manufacturers to optimize the assembly area, reduce labor costs and increase productivity. The DC control tool delivers cost savings and quality benefits through useful features such as digitally adjustable torque setting, variable torque and speed control, multiple I/O options for integration with PLC and other line control techniques.A Windows-based software package that can customize each fastening application is included with the product. The torque control system features error-proofing capabilities and screw counting. Multiple fastening strategies can be implemented for sensitive and/or difficult assembly joints. The system increases productivity as one tool can be programmed to do the job of multiple conventional tools; saving time, maintenance cost, space and training. Key Benefits Productivity Increase productivity with one tool instead of 2 - 8 tools. Provides consistent repeatable process control and eliminates potential variations. Flexibility Easy integration into production line. Rapid reconfiguration for new production projects. ROI Optimum asset utilization. Tooling expense delivers favorable return of investment. Quality Traceability and error-proofing. Real time monitoring. Swiss DC servo motor provides precise, accurate and repeatable torque control. I/O Interface Digital I/O signals for communication with external devices such as PLC. Controller Up to 15 process sequences with 10 program steps. Memory Collect and save all fastening data on SD memory card. Torque Fastening torque data analysis (Standard Deviation, Analysis Mean, Average, CP, CPK ) with TPM (Torque Process Monitoring) Touch Screen accessory option. Easy guidance to the optimized tightening process with built-in customizing simulation feature. 15 tightening presets,15 parameters within each preset. This strategy can be extended up to 99 presets with optional TPM touch screen. Each Preset Program has the following customized parameters Tightening Torque control + angle monitoring (TC/AM) Mode Angle control + torque monitoring (AC/TM) Torque Target torque, min/max torque, snug torque, seating torque, torque compensation Angle Target angle, min/max angle, free speed angle Speed Target speed, Free speed, Ramp up speed Time Soft start time, torque rising time, torque holding time 1.1 800.456.1828 www.mountztorque.com Auto Customizing Auto customizing feature can be utilized to optimize settings of predefined presets. Sequence Control Sequence control by managing tightening preset # & screw number, time delay, Input & Output provides automation without PLC or sequence control device. Can configure up to 15 presets and 15 models, consisting of up to 10 steps for each model. This feature can be extended up to 99 presets and 99 models with the optional TPM touch screen. Example Step 1 - Input Detect work piece arrival on the position. Step 2 - Delay Time delay 0.5 second to the next step Step 3 - Output Lock the work piece with air cylinder Step 4 - Tightening Tightening total 7 with Preset #12 Step 5 - Output Release the work piece from air cylinder lock Sample Program of Sequence Control STEP STEP STEP STEP STEP Modbus Protocol Communication MDC provides the Modbus RTU for RS232 and Modbus TCP/IP for the Ethernet port connection together. Modbus RTU Slave ID F Code Data CRC Protocol ID Length Unit ID Modbus TCP/IP ADU Transaction ID F Code Data CRC ADC provides the Modbus RTU for RS422 and Modbus TCP/IP for the Ethernet port connection together. ADC provides the synchronized fastening feature for up to 31 spindle drivers. 1.2 Fastening Parameter Setting Free PC Software "ParaMon" Process Capability Analysis - Provides easy parameter setting, data monitoring & analysis. - 2 channel real time curve display for torque, speed, angle. - Torque capability analysis for mean value, standard deviation, CP and CPK. - Auto data output on every event in Modbus protocol. Free Speed Angle Tm Speed Torque Free Speed Setting Soft Start Remote Control Monitoring Auto Speed Screw Seating Engaging Torque Direction Free Reverse Rotation Ramp Up Time Angle/Time A1 A2 A3 Angle After Torque Up Real-Time Graph Monitoring (2 channel) 1.3 800.456.1828 www.mountztorque.com MDC- Controllers for MD Electric Screwdrivers Features - Preset selection capability: Front panel or 25P I/O - Angle Control: 0.1 - 10 turns - 15 Preset Parameters: Torque, Speed, Soft Start & Angle - Auto detection of connected driver when controller is powered on* - Error display: Error code display (3 groups) - Fastening Quality Control: OK/NG monitoring of screw fastening by preset pattern of angle and/or time - PC based program for parameter settings, monitoring and real time output - Front panel 4.3”'D3 Color LCD with touch screen - Communication 1 x RS232C, 1 x Ethernet - Protocol: Modbus - SD Card data memory slot (memory card not included). Specifications Input (Electric): AC120VC / AC230V, 50/60Hz Output (Electric): DC38V 3.5A Dimension (WxLxH): 10 7/8" x 7 3/4" x 4 1/4" Weight: 4.4 lbs Note: Cannot simply swap driver models without going through a few set up steps, as all of the parameter values stored with the MDC controller will be related to the prior connected electric screwdriver model. RS-232 SD Memory Card Slot 25P I/O Ethernet Power Switch Power Tool Cable 110V Controllers MDC-26 Controller MDC-32 Controller Item # 310000 Item # 310001 For driver models: MD-26 series For driver models: MD-32 series 230V Controllers MDC-32 Controller MDC-26 Controller Item # 310003 Item # 310002 For driver models: MD-26 series For driver models: MD-32 series Controller connects to these devices via Modbus protocol RS232 or Ethernet TPM PLC PC (Free Software ParaMon) 1.4 MD Electric Screwdrivers In-Line Models Model MD2601-A MD2602-A MD2604-A MD2611-A MD2616-A MD3201-A MD3202-A MD3204-A MD3211-A MD3216-A MD3236-Q MD3264-Q Driver Type Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Lever Start Item # 310005 310006 310007 310008 310009 310010 310011 310012 310013 310014 310015 310016 Pistol Grip Models Model MDP3201-AD MDP3202-AD MDP3204-AD MDP3211-AD MDP3216-AD MDP3236-QD MDP3264-QD Item # 310017 310018 310019 310020 310021 310022 310023 Model MDP3201-A/U MDP3202-A/U MDP3204-A/U MDP3211-A/U MDP3216-A/U MDP3236-Q/U MDP3264-Q/U Item # 310035 310036 310037 310038 310039 310040 310041 Torque Ranges lbf.in S.I. 0.26 - 3.4 2.9 - 38.4 cN.m 0.43 - 6.0 4.9 - 67.8 cN.m 1.7 - 12.1 19.2 - 136.7 cN.m 3.4 - 29.5 38.4 - 333 cN.m 4.3 - 43.4 49 - 490 cN.m 0.86 - 10.4 9.7 - 117.5 cN.m 1.7 - 19 19.2 - 214.7 cN.m 3.4 - 34.7 38.4 - 392 cN.m 8.6 - 78.1 1 - 8.8 N.m 17.3 - 121.5 2 - 13.7 N.m 34.7 - 243 3.9 - 27.4 N.m 69.4 - 434 7.8 - 49 N.m Torque Ranges lbf.in S.I. 0.86 - 10.4 9.7 - 117.5 cN.m 1.7 - 19 19.2 - 214.7 cN.m 3.4 - 34.7 38.4 - 392 cN.m 8.6 - 78.1 1 - 8.8 N.m 17.3 - 121.5 2 - 13.7 N.m 34.7 - 243 3.9 - 27.4 N.m 69.4 - 434 7.8 - 49 N.m Adjustable Speed RPM 150 - 2000 150 - 2000 150 - 1500 100 - 900 100 - 620 150 - 2000 150 - 2000 150 - 1500 50 - 690 50 - 470 50 - 210 50 -115 Adjustable Speed RPM 150 - 2000 150 - 2000 150 - 1500 50 - 690 50 - 470 50 - 210 50 -115 Grip Dia 2" 2" 2" 2" 2" 2" 2" Note: A/D models have power tool cable connection located at the bottom grip section of the tool. A/U models have power tool cable connection located at the top section of the tool. 1.5 800.456.1828 www.mountztorque.com Grip Dia 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" Length 8 1/2" 8 1/2" 8 1/2" 8 1/2" 8 1/2" 8 1/2" 8 1/2" Length 9" 9" 9" 9" 9" 9" 9" 9" 9" 9" 9 1/2" 9 1/2" Drive Size 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 3/8 Sq. Dr. 1/2 Sq. Dr. Drive Size 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 3/8 Sq. Dr. 1/2 Sq. Dr. Weight 1.6 lbs. 1.6 lbs. 2 lbs. 2.1 lbs. 2.1 lbs. 3.1 lbs. 3.1 lbs. Weight 1 lb. 1 lb. 1.1 lbs. 1.2 lbs. 1.2 lbs. 1.5 lbs. 1.5 lbs. 1.9 lbs. 2 lbs. 2 lbs. 2.9 lbs. 2.9 lbs. Right Angle Models Model MDH2604-A MDH2611-A MDH2616-A MDH3201-A MDH3202-A MDH3204-A MDH3211-A MDH3216-A MDH3236-Q MDH3264-Q Driver Type Right Angle Right Angle Right Angle Right Angle Right Angle Right Angle Right Angle Right Angle Right Angle Right Angle Robotic Models Model MDA2201-E/C MDA2601-E MDA2602-A MDA2604-A MDA2611-A MDA2616-A MDA3201-A MDA3202-A MDA3204-A MDA3211-A MDA3216-A MDA3236-Q MDA3264-Q Driver Type Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Item # 310042 310043 310044 310045 310046 310047 310048 310049 310050 310051 310051 310053 310054 Item # 310024 310025 310026 310027 310028 310029 310031 310032 310033 310034 Torque Ranges lbf.in S.I. 1.7 - 12.1 19.2 - 136.7 cN.m 3.4 - 29.5 38.4 - 333 cN.m 4.3 - 43.4 49 - 490 cN.m 0.86 - 10.4 9.7 - 117.5 cN.m 1.7 - 19 19.2 - 214.7 cN.m 3.4 - 34.7 38.4 - 392 cN.m 8.6 - 78.1 1 - 8.8 N.m 17.3 - 121.5 2 - 13.7 N.m 34.7 - 243 3.9 - 27.4 N.m 69.4 - 434 7.8 - 49 N.m Torque Ranges lbf.in S.I. 0.08 - 0.60 0.9 - 6.7 cN.m 0.26 - 3.4 2.9 - 38.4 cN.m 0.43 - 6.0 4.9 - 67.8 cN.m 1.7 - 12.1 19.2 - 136.7 cN.m 3.4 - 29.5 38.4 - 333 cN.m 4.3 - 43.4 49 - 490 cN.m 0.86 - 10.4 9.7 - 117.5 cN.m 1.7 - 19 19.2 - 214.7 cN.m 3.4 - 34.7 38.4 - 392 cN.m 8.6 - 78.1 1 - 8.8 N.m 17.3 - 121.5 2 - 13.7 N.m 34.7 - 243 3.9 - 27.4 N.m 69.4 - 434 7.8 - 49 N.m Note: The E/C model is equipped with a bit cushion. Adjustable Speed RPM 100 - 1000 150 - 2000 150 - 2000 150 - 1500 100 - 900 100 - 620 150 - 2000 150 - 2000 150 - 1500 50 - 690 50 - 470 50 - 210 50 -115 Adjustable Speed RPM 150 - 1500 100 - 900 100 - 620 150 - 2000 150 - 2000 150 - 1500 50 - 690 50 - 470 50 - 210 50 -115 Grip Dia 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" 1 1/2" Grip Dia 2" 2" 2" 2" 2" 2" 2" 2" 2" 2" Length 11" 11" 11" 11" 11" 11" 11" 11" 11" 11" 11" 11" 11" Length 12" 12" 12" 12" 12" 12" 12" 12" 12" 12" Drive Size 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 3/8 Sq. Dr. 1/2 Sq. Dr. Drive Size 4mm D-Cut 4mm D-Cut 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 3/8 Sq. Dr. 1/2 Sq. Dr. Weight 1.2 lbs. 1.2 lbs. 1.2 lbs. 1.3 lbs. 1.4 lbs. 1.4 lbs. 1.7 lbs. 1.7 lbs. 2.1 lbs. 2.2 lbs. 2.2 lbs. 3.4 lbs. 3.4 lbs. Weight 1.9 lbs. 2 lbs. 2 lbs. 2.4 lbs. 2.4 lbs. 2.8 lbs. 2.9 lbs. 2.9 lbs. 4.2 lbs. 4.2 lbs. 1.6 ADC Controllers for AD Electric Screwdrivers, Robotic Spindle Models LED Display Preset # - Target Torque ADC-100 Controller Item # 310072 Output (Electric): 1.4A For driver models: AD050R PLC RS422 Port (link in) RS422 Port (link out) AC Power Input 50P I/O Power Cable to Spindle Motor Encoder Cable to Spindle Controller connects to these devices via Modbus protocol RS422 or USB TPM USB Port High Voltage Charged Alarm Features - Mountable - Preset selection capability: Front panel or 50P I/O - Angle Control: 0.1 - 10 turns - 15 Preset Parameters: Torque, Speed, Soft Start & Angle - Auto detection of connected driver when controller is powered on* - Error display: Error code display (3 groups) - Fastening Quality Control: OK/NG monitoring of screw fastening by preset pattern of angle and/or time - PC based program for parameter settings, monitoring and real time output - Protocol: Modbus RTU Note: Cannot simply swap driver models without going through a few set up steps, as all of the parameter values stored with the ADC controller will be related to the prior connected electric screwdriver model. Specifications Input (Electric) AC200-230V, 50/60Hz single phase Dimension (WxLxH) 1 1/2"x 6 3/4"x 6 1/4" PC (Free Software ParaMon) ADC-200 Controller Item # 310073 Output (Electric): 1.7A For driver models: AD100R Weight ADC-100 & 200: 2 lbs. ADC-400: 2.1 lbs ADC-400 Controller Item # 310074 Output (Electric): 3.0A For driver models: AD150R AD150R36 AD150R64 AD150R02 AD050R01 AD100R01 1.7 800.456.1828 www.mountztorque.com AD150R11 AD150R16 AD150R04 AD150R01 AD Electric Screwdrivers Robotic Spindle Models Model AD050R01-A/C AD050R01-E/C AD100R01-A/C AD150R01-A/C AD150R02-A AD150R04-A AD150R11-A AD150R16-A AD150R16-Q AD150R36-Q AD150R64-Q AD150R64-Q Driver Type Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Remote Start Item # 310060 310061 310062 310063 310064 310065 310066 310067 310068 310069 310070 310071 Torque Ranges lbf.in S.I. 0.4 - 5.2 4.5 - 58.7 cN.m 0.4 - 5.2 4.5 - 58.7 cN.m 1.7 - 10.4 19.2 - 117.5 cN.m 1.7 - 17.3 19.2 - 195.5 cN.m 3.4 - 24.3 38.4 - 274/6 cN.m 4.3 - 43.4 49 - 490 cN.m 13 - 86.8 1.5 - 9.8 N.m 26 - 156.2 2.9 - 17.6 cN.m 26 - 156.2 2.9 - 17.6 cN.m 43.4 - 260.4 4.9 - 29.4 N.m 86.8 - 434 9.8 - 49 N.m 86.8 - 434 9.8 - 49 N.m Adjustable Speed RPM 150 - 2000 150 - 2000 150 - 2000 150 - 2000 150 - 2000 100 - 1200 50 - 450 30 - 310 30 - 310 30 - 140 30 - 75 30 - 75 Length 6 7/8" 7 1/2" 8 1/3" 8 1/3" 9" 9" 9 1/2" 9 1/2" 9 1/2" 9 1/2" 9 1/2" 9 1/2" Drive Size 1/4 F/Hex 4mm D-Cut 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 1/4 F/Hex 3/8 Sq. Dr. 3/8 Sq. Dr. 3/8 Sq. Dr. 1/2 Sq. Dr. Note: These models (A/C and E/C) are equipped with a bit cushion. 1.8 Accessories Auto Bit Socket Trays TPM (Torque Process Monitoring) Touch Screen A preset program or torque setting is automatically selected in the MD-Series tools once a bit or socket is removed from the bit socket tray. This touch screen can be used for data collection, programming the MDC or ADC controller as well as monitoring the fastening process. Connects to MDC Controllers. 8 bit or 4 bit holder ports with sensors. - 8" color TFT LCD - Power - DC24V 1A - Connection to MDC or ADC controller via RS232 or RS422 - Total 99 presets programs - Total 99 model programs - 7 inputs to select 99 programs - Data memory in SD card - Include same settings of MDC or ADC controller - Easy mounting on the panel - Fastening torque data analysis (Standard Deviation, Mean, Average, CP, CPK) System requires 3 components 1.Select Bit Socket Tray Option: Bit Socket Tray (4 Bit Holders) 7.5 mm, 10mm, 15 mm, 18mm Item# 310092 Bit Socket Tray (8 Bit Holders) 7.5 mm, 10mm, 15 mm, 18mm (2 of each) Item# 310093 for MD-Series Item # 310004 for AD-Series Item # 310097 44P I/O Wiring Box 1A OUT 1 1A OUT 2 1A OUT 3 OUT COM It provides easy and convenient wiring for 12 inputs and outputs for a MDC or ADC controller by sharing one single 24V power source. (Input power: 24VDC 1A) I/O Cables needed to connect to controller. I/O Cable 3m (44P Male to 25P Male) Item# 310057 44P I/O Wiring Box, Item# 310055 I/O Cable 3m (AD-50P-3M-DSUB44) Item# 310087 AC Adapter, Item# 14-GCM6913 D_Sub 44P 1 2 3 4 5 6 7 8 9 IN 1 IN 2 IN 3 IN 4 IN 5 IN 6 IN 7 IN 8 IN 9 1.9 D_Sub 44P 10 11 12 13 14 15 16 17 18 IN 10 IN 11 IN 12 IN Com IN Com OUT 1 OUT 2 OUT 3 D_Sub 44P D_Sub 44P D_Sub 44P 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 OUT 4 OUT 5 OUT 6 OUT 7 OUT 8 OUT 9 OUT 10 OUT 11 OUT 12 Out Com Out Com 24V+ 24V+ 24V+ Out Com Out Com 800.456.1828 www.mountztorque.com Out Com - 2. Add SMPS Adapter SMPS Adapter (24VDC 1A) (It Includes a UL 2P 110V Power cord plug).* Item# 310102 Note: * For 220V, purchase Item # 310110 along with #310102 Model: Power Cord for SMPS Adapter (220V CE Plug) Item# 310110 3. Select Communication Cable that connects the Bit Socket Tray to the MDC Controller. Model: Cable 25P I/O (M-M) 3 Meters Item# 310112 Model: Cable 25P I/O (M-M) 5 Meters Item# 310115 Bit Holders Additional bit holder inserts can be purchased separately for the bit socket tray. Bit Holder (Hole Size 18mm) Item# 310104 Bit Holder (Hole Size 7.5mm) Item# 310107 Bit Holder (Hole Size 15mm) Item# 310105 Bit Holder (Hole Size 3mm) Item# 310108 Bit Holder (Hole Size 10mm) Item# 310106 Bit Holder (Plain) Item# 310109 Vacuum Adapter Kits Torque Cover Bit Holders Item # 310075 Item # 310076 Item # 310077 Specification: Specification: Specification: for 1/4 F/Hex Dr, M20 for 1/4 F/Hex Dr, M23 for 4mm D-Cut Dr, M20 Bit: Ohmi V-17, 70mmL Bit: Ohmi V-17, 70mmL Bit: Dia 4mm half moon Screwdriver Type: Screwdriver Type: Screwdriver Type: MD2601-A AD050R01-A MD3204-A AD150R04-A MD2201-E MD2602-A AD100R01-A MD3208-A AD150R11-A MD2601-E MD2604-A AD150R01-A MD3210-A AD150R16-A AD50R01-E MD2611-A AD150R02-A MD3211-A AD150R16-Q MD2616-A MD3216-A MD3201-A MD3202-A Note: MD3236, MD3264, AD150R36, and AD150R64 models are not compatible with vacuum adapter kit. Provides better bit concentricity for a long length bit. Ohmi V-17 Hex1/4-70mL M23x1pt Item # 310078 Item # 310079 Item # 310080 Specification: Specification: Specification: for 1/4 F/Hex Dr, M20 for 1/4 F/Hex Dr, M23 for 4mm D-Cut Dr, M20 Bit: Ohmi V-17, 70mmL Bit: Ohmi V-17, 70mmL Bit: Dia 4mm half moon Screwdriver Type: Screwdriver Type: Screwdriver Type: MD2601-A AD050R01-A MD3204-A AD150R04-A MD2201-E MD2602-A AD100R01-A MD3208-A AD150R11-A MD2601-E MD2604-A AD150R01-A MD3210-A AD150R16-A AD50R01-E MD2611-A AD150R02-A MD3211-A AD150R16-Q MD2616-A MD3216-A MD3201-A MD3202-A Note: MD3236, MD3264, AD150R36, and AD150R64 models are not compatible with torque cover bit holders. M23x1pt M20x1pt Mouthpiece and bit purchased separately. M20x1pt 1/4 Hex M23 4mm M20 Ohmi V-05 Dia 4mm-64mL 1/4 Hex M20 MDC Controller Cables RS232 Cable (DB9 Male x DB9 Female, 2m) Item# 773856 Power Tool Cables Cable (USB to RS232 Adapter) Item# 773069 I/O Cable 3m (44P Male to 25P Male) Item# 310057 (for MD-Series Tools only) The driver cable connects the MD-Series electric screwdriver to the MDC controller. Note! Each MD electric screwdriver is supplied with the standard 3 meter length cable. 3m Length Cable Item# 310056 Spindle Cable Sets (Power & Encoder) ADC Controller I/O Cables Note! Each AD robotic spindle screwdriver is supplied with the standard 3 meter length spindle cable set. Item # 310085 310086 310087 (for AD-Series Tools only) Item # 310081 310082 310083 310084 Model CB-AD01-3M CB-AD01-5M CB-AD01-7M CB-AD01-10M Desc. 3m 5m 7m 10m 5m Length Cable Item# 310088 (for AD-Series Tools only) Model AD-50P-3M-OPEN AD-50P-3M-DSUB25 AD-50P-3M-DSUB44 Description Standard, with numbering Connect to U-2 interface box Connect to 44P I/O wiring box 1.10 CORPORATE HEADQUARTERS 1080 North 11th Street San Jose CA 95112 t 408.292.2214 t 800.456.1828 f 408.292.2733 sales@mountztorque.com www.mountztorque.com DISTRIBUTION & SERVICE CENTER 19051 Underwood Road Foley AL 36535 t 251.943.4125 f 251.943.4979 US SALES OFFICES Anaheim Birmingham Boston Charlotte Chicago Cleveland Dallas El Paso Los Angeles Nashville Seattle San Jose MEXICO SALES OFFICES Cd. Juarez Chihuaha Guadalajara Monterrey Mexico DF Reynosa Tijuana EUROPE SALES OFFICE Netherlands FOLLOW MOUNTZ Keep informed about our torque tool products, events and industry news. Select your favorite social media site to catch the latest news from Mountz. Twitter: @mountztorque Facebook: www.facebook.com/mountztorquetool YouTube: www.youtube.com/MountzTorque Mountz Blog: www.mountztorque.com/blog LinkedIn: www.linkedin.com/company/mountz-inc Google Plus: plus.google.com/+Mountztorque/posts Twitter Facebook Mountz Copyright You Tube Blog 2018 All Rights Reserved Linkedin Google Plus
773069 价格&库存
很抱歉,暂时无法提供与“773069”相匹配的价格&库存,您可以联系我们找货
