HBL2313SW
HBL2313SW
    HUBBELL(哈伯尔公司)
HBL2313SW 数据手册
Twist-Lock® Devices Twist-Lock® Devices 20 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding W Insulgrip® Connector Bodies and Receptacles X G G Y 20A 125V NEMA L5-20R UL/CSA 1 HP Connector Bodies 20A 250V NEMA L6-20R UL/CSA 2 HP Watertight Safety-Shroud® IP66 Description Black Valox® housing, white Valox® clamps. Catalog Numbers HBL2313SW HBL2323SW Cord Dia. .360"-.930" (9-24) IP20 Description Black and white nylon. Cord Dia. .360"-.930" (9-24) Corrosion resistant, .360"-.930" yellow nylon. (9-24) All black nylon. .360"-.930" (9-24) Cord clamps with removable .360"-.930" inserts. All black nylon. (9-24) Accessories on page B-51. Catalog Numbers HBL2313 HBL2323 Valise® IP20 Cord Dia. .325"-.720" (8.26-18.3) .325"-.720" (8.26-18.3) Black nylon. 20A 277V AC NEMA L7-20R UL/CSA 2 HP SUITABILITY Insulgrip Description Yellow nylon. W G 2.56" (65.0) HBL2333SW 4.38" (111.1) SUITABILITY HBL2323SW HBL2333 HBL23CM13 HBL23CM23 – HBL2313BK HBL2323BK – HBL2313EBK HBL2323EBK – 3.86" (98.0) 2.26" (57.4) 1.97" (50.0) HBL2313 SUITABILITY 2.60" (66.0) Catalog Numbers HBL2313VY HBL2323VY HBL2313VBK – HBL2323VBK HBL2333VBK 1.78" (45.2) Accessories on page B-51. Receptacles HBL2313VY Watertight Safety-Shroud, Back Wired Description Gray Valox® housing and flange. Accessories on page B-54. IP66 SUITABILITY Catalog Numbers HBL2310SW HBL2320SW Safety-Shroud Twist-Lock, Back Wired IP20 3.75" (95.3) SUITABILITY Catalog Numbers HBL2310AR HBL2320AR HBL2310SR HBL2320SR HBL2310SR2 HBL2320SR2 HBL2330AR HBL2330SR HBL2330SR2 3.75" (95.3) 1.50" (38.1) HBL2320SW Single Flush, Back and Side Wired Description Black nylon face. Isolated ground, orange nylon face. Corrosion resistant, yellow nylon face. Ring teminal connection. Accessories on page B-50. HBL2330SW IP20 SUITABILITY 3.14" (79.8) Catalog Numbers HBL2310 HBL2320 IG2310 IG2320 HBL23CM10 – HBL2310RT HBL2320RT HBL2330 – – – Catalog Numbers HBL2316 HBL2326 HBL2336 4.57" (116.1) Insulgrip Flanged Receptacles Description Nylon casing, back wired. Accessories on page B-50. 2.88" (73.2) 120° 2.88" (73.2) HBL2320AR 1.70" (43.2) .19" (4.8) DIA. 1.23" (31.2) 1.58" (40.1) .77" (19.6) 120° 5.12" (130.0) 2.67" (67.8) 1.25" R. (31.8) 4.56" (115.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.09" (53.1) 2.04" (51.8) HBL2316 #6-32 TAP .98" (24.9) HBL2310 5.12" (130.0) 2.84" (72.1) HBL2320SR2 HBL2320SR Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-19 20 Ampere, 125, 250 Volts and 277 Volts AC Description Gray Valox® angle housing, one gang. Gray Valox® surface mounting, one gang. Gray Valox® semi-flush, two gang. Accessories on page B-54. 2.69" (68.3)
HBL2313SW 价格&库存
很抱歉,暂时无法提供与“HBL2313SW”相匹配的价格&库存,您可以联系我们找货
