HBL2270
HBL2270
    HUBBELL(哈伯尔公司)
HBL2270 数据手册
Other Wiring Products Adapters and Fluorescent Starters Male Blade End Female Slot End HBL2274 Nylon Convenience Adapters NEMA Configuration Catalog Number Male Blade End HBL2270 HBL2271 HBL2128 HBL2274 HBL2129 HBL31CM29* 15A 125V NEMA 5-15P 15A 125V NEMA 5-15P 15A 125V NEMA 5-15P 15A 125V NEMA L5-15P 20A 125V NEMA L5-20P 30A 125V NEMA L5-30P 20A 125V NEMA 5-20R 15A 125V NEMA L5-15R 20A 125V NEMA L5-20R 20A 125V NEMA 5-20R 20A 125V NEMA 5-20R 20A 125V NEMA 5-20R Female Slot End Note: *♦ Not UL Listed. HBL5273L CAUTION: Where adapters have different ratings on the blade and slot end the following precautions must be exercised in their use. (1) Remember that overcurrent protection is determined by the blade end. (2) The use of the adapter should be limited to the lowest rated end of the adapter in order to prevent overheating. (3) Adapters do not provide GFCI, overcurrent or short circuit protection. Plug In Adapters HBL5289 9053A Description Catalog Number Male end - 2 wire parallel polarized blades, 15A, 125V. Female end - 3 wire 15A, 125V straight slot grounding. HBL5273L Male end - 3 wire crow foot 15A, 125V blades. Female end - 3 wire 15A, 125V straight slot grounding. HBL5289♦* Male end - 3 wire 10A, 250V, 15A, 125V Twist-Lock® blades. Female end - 3 wire 15A, 125V straight slot grounding. 9053A♦* Male end - 3 wire 15A, 125V straight blade grounding. Female end - 10A, 250V, 15A 125V Twist-Lock® slots. 9054A♦* Note: ♦ ♦ Must always be used with a grounded receptacle. *Not UL Listed. Fluorescent Starters 9054A Neostart Lamps Catalog Number The Hubbell Neostart is a glow discharge type of starter which combines fast starting speed with rugged, dependable operation. The Neostart lights the lamp very rapidly and insures proper lamp operation throughout rated life. Because of its rugged construction, it can be depended upon to withstand continued punishment resulting from lamp failure. In addition, it operates satisfactorily over a wide temperature range. In dual lamp circuits, the Neostart lights both lamps quickly and uniformly. 14, 15 and 20 watt lamps FS2 13, 30 and 40 watt lamps FS4 4, 6 and 8 watt lamps FS5 22 watt circle line, 25 watt standard lamps FS25 FS4 Z-2 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL2270 价格&库存
很抱歉,暂时无法提供与“HBL2270”相匹配的价格&库存,您可以联系我们找货
