HBL2430ST
HBL2430ST
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL2430ST - CONN, POWER ENTRY, NEMA L16-20R, 480V
HBL2430ST 数据手册
20A, 480V AC, 3 Phase, 3 Pole, 4 Wire Grounding Spring Termination Single Flush Receptacle Features Faster termination time No need for screwdriver and torque wrench Spring Termination eliminates strand relaxation High-impact, abuse-resistant nylon face Face color coding by voltage facilitates locating and mating of proper devices Ordering Information Description Nylon face, back and side wire. Device Color Black UPC 783585788579 Catalog Number HBL2430ST Listings Listed to UL 498 Certified to CSA C22.2 No.42 Specifications Face Base Contacts Spring Mounting Strap Nylon Nylon Brass Steel Brass Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation Solid/Stranded #14 AWG to #12 AWG Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures V2 or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C; Minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Accessories HBL2431 Wallplate or Weatherproof Cover 1.60" Opening Switched Enclosure SETL3
HBL2430ST 价格&库存
很抱歉,暂时无法提供与“HBL2430ST”相匹配的价格&库存,您可以联系我们找货
