HBL2616
HBL2616
    HUBBELL(哈伯尔公司)
HBL2616 数据手册
Twist-Lock® Devices Twist-Lock® Devices 30 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding Insulgrip® Connector Bodies and Receptacles X W G W G G Y 30A 125V NEMA L5-30R UL/CSA 2 HP Connector Bodies Watertight Safety-Shroud® IP66 Description Cord Dia. Catalog Numbers Black Valox® housing, white Valox® clamps. .360"-.930" (9-24) HBL2613SW Insulgrip IP20 30A 277V AC NEMA L7-30R UL/CSA 3 HP 30A 250V NEMA L6-30R UL/CSA 2 HP 2.56" (65.0) SUITABILITY HBL2623SW – 4.38" (111.1) HBL2613SW SUITABILITY Description Cord Dia. Catalog Numbers Black and white nylon. .360"-.930" (9-24) HBL2613 HBL2623 HBL2633 Heat stabilized, gray nylon, 220° F (104° C). .360"-.930" (9-24) HBL2613F HBL2623F – Corrosion resistant, yellow nylon. .360"-.930" (9-24) HBL26CM13 HBL26CM23 – All black nylon. .360"-.930" (9-24) HBL2613BK HBL2623BK – 3.86" (98.0) 2.26" (57.4) 1.97" (50.0) HBL2623 2.60" (66.0) Accessories on page B-51. Valise® IP20 SUITABILITY Description Cord Dia. Catalog Numbers Yellow nylon. .590"-.930" (15.0-23.6) HBL2613VY Corrosion resistant, yellow nylon. .590"-.930" (15.0-23.6) HBL26CM13V Black nylon. .590"-.930" (15.0-23.6) HBL2613VBK 1.78" (45.2) HBL2623VY – – – HBL2613VY – 2.69" (68.3) HBL2623VBK Accessories on page B-51. 3.75" (95.3) Receptacles IP66 Description Catalog Numbers Gray Valox® housing and flange. HBL2610SW SUITABILITY HBL2620SW 3.75" (95.3) – HBL2610SW Accessories on page B-54. Safety-Shroud Twist-Lock, Back Wired IP20 1.50" (38.1) 3.14" (79.8) SUITABILITY Description Catalog Numbers Gray Valox® angle housing, one gang. HBL2610AR HBL2620AR Gray Valox® surface mounting, one gang. HBL2610SR HBL2620SR – Gray Valox® semi-flush, two gang. HBL2610SR2 HBL2620SR2 – – 4.57" (116.1) Accessories on page B-54. Single Flush, Back and Side Wired IP20 SUITABILITY Description Catalog Numbers Black nylon face. HBL2610 HBL2620 Isolated ground, orange nylon face. IG2610 IG2620 Corrosion resistant, yellow nylon face. HBL26CM10 Ring teminal connection. HBL2610RT 2.88" (73.2) HBL2630 – – HBL2620AR 1.58" (40.1) – HBL2620RT – Accessories on page B-50. Insulgrip Flanged Receptacles 4.56" (115.8) Description Catalog Numbers Nylon casing, back wired. HBL2616 HBL2626 HBL2636 Heat stabilized, gray nylon, 220° F (104° C). HBL2616F HBL2626F – 2.84" (72.1) Accessories on page B-50. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com HBL2620SR B-27 30 Ampere, 125, 250 Volts and 277 Volts AC Watertight Safety-Shroud, Back Wired
HBL2616 价格&库存
很抱歉,暂时无法提供与“HBL2616”相匹配的价格&库存,您可以联系我们找货
