HBL2833
HBL2833
    HUBBELL(哈伯尔公司)
HBL2833 数据手册
Twist-Lock® Devices 30 Ampere, 3ØY 120/208, 277/480 and 347/600 Volts AC 4 Pole, 5 Wire Grounding X W Connector Bodies X Y G W X W Y G G Y Z Z Z 30A 3ØY 120/208V AC NEMA L21-30R UL/CSA 3 HP 30A 3ØY 277/480V AC NEMA L22-30R UL/CSA 10 HP 30A 3ØY 347/600V AC NEMA L23-30R UL/CSA Watertight Safety-Shroud® IP66 SUITABILITY Description Cord Dia. Catalog Number Black Valox® housing, white Valox® clamps. .350"-1.150" (9-29) HBL2813SW Insulgrip® UL Type 4x, 12 HBL2823SW IP20 2.75" (69.9) – 4.38" (111.1) SUITABILITY HBL2813SW Description Cord Dia. Catalog Number Black and white nylon. .350"-1.150" (9-29) HBL2813 Corrosion resistant, yellow nylon. .350"-1.150" (9-29) HBL28CM13 – – Black and white for flat cable. .350"-1.150" (9-29) HBL2813FC – – All black nylon. .350"-1.150" (9-29) HBL2813BK – – HBL2823 HBL2833 2.33" (59.3) 2.21" (56.1) 3.86" (98.0) HBL2813 Note: See page B-53 for accessories. Receptacles Watertight 2.91" (73.9) Safety-Shroud® IP66 SUITABILITY Description Catalog Number Gray Valox® housing and flange, back wired. HBL2810SW UL Type 4x, 12 HBL2820SW HBL2830SW Note: See page B-54 for accessories. Safety-Shroud® Twist-Lock® IP20 Description Catalog Number Gray Valox® angle housing, one gang, back wired. HBL2810AR 3.75" (95.3) SUITABILITY – Gray Valox® surface mounting, one gang, back wired. HBL2810SR – – Gray Valox® semi-flush, two gang, back wired. HBL2810SR2 – – HBL2810SW Note: See page B-54 for accessories. Single Flush Receptacles IP20 3.14" (79.8) SUITABILITY Description Catalog Number Black nylon face, back and side wired. HBL2810 Isolated ground, orange nylon face, back and side wired. IG2810 – – Ring terminal connection. HBL2810RT – – HBL2820 1.75" (44.5) 3.75" (95.3) – HBL2830 4.57" (116.1) Note: See page B-52 for accessories. Insulgrip® Flanged Receptacles 2.88" (73.2) Description Catalog Number Nylon casing, back wired. HBL2816 HBL2810AR HBL2826 HBL2836 Note: See page B-52 for accessories. 1.70" (43.2) 3.06" (77.7) 120° 1.23" (31.2) 1.34" R. (34.0) .19" 120° (4.8) DIA. 2.27" (57.7) 2.23" (56.6) HBL2816 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) .77" (19.6) 5.12" (130.0) #6-32 TAP 4.56" (115.8) 5.12" (130.0) .98" (24.9) HBL2810 HBL2810SR2 Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com 1.71" (43.4) 2.84" (72.1) HBL2810SR Dimensions in Inches (mm) ® Wiring Device-Kellems B-33
HBL2833 价格&库存
很抱歉,暂时无法提供与“HBL2833”相匹配的价格&库存,您可以联系我们找货
