HBL5242
HBL5242
    HUBBELL(哈伯尔公司)
HBL5242 数据手册
Product Datasheet HBL5242 -- Straight Blade Products, Heavy Duty Intermediate Grade Duplex Receptacle 2-Pole 3-Wire Grounding, 15A 125V, 5-15R, Flush Nylon Face, Side Wired Only, Brown Product Specifications Product Type Receptacle Style Duplex Face Shape Traditional Standard NEMA Amperage 15A Voltage 125V Poles and Wires 2 Pole, 3-Wire Grounding Wiring Method Side Wire Only Hospital Grade ? No Receptacle Grade Heavy Duty Spec Grade Face Style Finder Groove Color Other Available Colors Brown, Gray, Ivory, White, NEMA No. 5-15R Horsepower 0.5 Type 2 Pole, 3 Wire, Grounding Rating 15A, 125V Certification UL Listed, File E2186, Guide RTRT Fed Spec WC596G, Meets NEMA WD-6 requirements Listed to UL Standard 498, Certified to CSA, C22.2, No. 42 where applicable Terminal Screw Material #8-32 Brass /Ni plated for neutral Ground Screw Material #8-32 Brass, Multiple Drive (Green) Top Material Nylon Base Material Reinforced PET Power Contacts Material .037" (.9) Phosphor Bronze Mounting Strap Material .050" (1.3) Brass Auto Ground Clip Material Stainless Steel Mounting Screw Material Steel-Zinc Plated Dielectric Voltage Withstands 2,000V minimum. Current Interrupting Certified for current interrupting at full rated current. Temperature Rise Max 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%.. Terminal Identification Terminals identified in accordance with UL498 (Brass, White, Green). Terminal Accommodation #14-#10 AWG copper stranded or solid conductor only. Product Identification Ratings are a permanent part of the device. Flammability Top: UL 94 V2. Base: UL 94 V0 and UL 94-5 VA. Operating Temperatures Maximum continuous 75°C, minimum -40°C (w/o impact). UPC Number 783585434667 Weight in LBs 0.200 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL5242 价格&库存
很抱歉,暂时无法提供与“HBL5242”相匹配的价格&库存,您可以联系我们找货
