HBL5366C
HBL5366C
    HUBBELL(哈伯尔公司)
HBL5366C 数据手册
Straight Blade Devices 20A, 125V, 2 Pole, 3 Wire Grounding Insulgrip Plug Features Ribbed nylon housing is impact and chemical resistant VARI-SIZE adjustable cord clamp Fast lead assembly screws Beveled housing prevents snagging Ordering Information Description Black and white nylon Cord Diameter UPC .230"-.720"(5.8-18. 783585173955 3) Catalog Number HBL5366C Listings UL Listed to UL498 File E1706 CSA Certified to C22.2 No. 42 File 280 Fed. Spec. W-C596G NEMA® WD-6 Compliant Specifications Housing/Cord Clamp Blade Holder Terminal Retainer Blades Terminal Screws Terminal Clamp Assembly Screws Nylon Nylon Clear Polycarbonate .060 in. (1.5) Brass #8-32 Brass , multiple drive Nickel plated steel Nickel plated steel Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Cord Accomodation .230"-.720"(5.8-18.3) Terminal Accommodation #18-10 AWG. Standed copper wire only Terminal Identification Terminals identified in accordance with UL 498 and CSA Environmental Flammability IP Suitability Operating Temperatures UL 94 HB or better IP20 Maximum continuous 75°C; minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Accessories Weatherproof Boot Resources Customer Use Drawing eCatalog HBL6017
HBL5366C 价格&库存
很抱歉,暂时无法提供与“HBL5366C”相匹配的价格&库存,您可以联系我们找货
