HBL6032
HBL6032
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL6032 - BOOT, IP55, 3-WIRE PLUG & CONNECTOR BODIES
HBL6032 数据手册
Twist-Lock® Devices Twist-Lock® Devices Accessories for 20 and 30 Ampere, 3 Wire Plugs and Connector Bodies IP55* SUITABILITY Insulgrip® Weatherproof, Seal-Tite®, Triple Seal Boots Description Catalog Number Black elastomer boot for plugs when used in a cord set and connector bodies when used in flanged inlets. Same as above except yellow. Black elastomer boot for connector bodies when used in a cord set. Same as above except yellow. HBL6031 HBL60CM31 HBL6032 HBL60CM32 HBL6031 Angle Adapter Description Catalog Number Nylon, angle adapter for Insulgrip plugs and connector bodies, cord grip range .325"-.930" (8.3-24). HBL3WAA HBL6032 PLUGOUT® Lockout Devices Description Catalog Number Lockout device for attachable 20 and 30A locking plugs, straight body or angle types, with or without weatherproof covers. Lockout device for 20 and 30A 3 wire angle plugs and watertight Safety-Shroud® Twist-Lock plugs. HLD HLD2 Note: See Section U for more information on PLUGOUT Lockout Devices. * When installed and used properly with plug and connector body combinations. Insulgrip® Plug and Connector Body Latching Kit The Hubbell latching kit provides both improved safety and security through a double locking feature that makes unintentional disconnection virtually impossible – even under high vibration situations. The plug and connector body lock once when first connected, then again when you push the special position locking slide into place. HBL3WAA Insulgrip® Latching Kit Description Catalog Number For all 3 wire 20A and 30A Twist-Lock Insulgrip plugs and connectors. SK2 SK2 IP55* Valise® SUITABILITY Weatherproof, Seal-Tite®, Triple Seal Boots Description Catalog Number Yellow Seal-Tite® elastomer triple seal cover for use with Valise plugs when used in cord set and Valise connector bodies when used with flanged inlet. Yellow Seal-Tite elastomer triple seal cover for use with Valise connector bodies. HBL60CM31V** HBL60CM31V HBL60CM32V** HBL60CM32V Dimensions in Inches (mm) www.hubbell-wiring.com B-51 Accessories Note: * When installed and used properly with plug and connector body combinations. ** Not UL Listed, CSA Certified.
HBL6032 价格&库存
很抱歉,暂时无法提供与“HBL6032”相匹配的价格&库存,您可以联系我们找货
