HBL6035
HBL6035
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL6035 - WEATHERPROOF BOOT, ELASTOMER
HBL6035 数据手册
Twist-Lock® Devices Accessories for 20 and 30 Ampere, 4 and 5 Wire Plugs and Connector Bodies IP55* SUITABILITY Insulgrip® Weatherproof, Seal-Tite®, Triple Seal Boots Description Catalog Number Seal-Tite® triple seal cover for plug when used on a cord set or when used with flush receptacles or connector bodies when used with flanged inlets. Black elastomer. HBL6035 Same as above except yellow. HBL60CM35 Seal-Tite triple seal cover for connector bodies, when used on interconnecting cord sets. Black elastomer. HBL6036 Same as above except yellow. HBL60CM36 HBL6035 HBL6036 Angle Adapter Description Catalog Number Nylon, angle adapter for Insulgrip plugs and connectors, cord grip range .350"-1.15" (8.9-29.2). HBL45WAA PLUGOUT® Lockout Device Description Catalog Number Lockout device for attachable 20 and 30A plugs, straight body or angle types, with or without weatherproof covers. HLD Lockout device for 20 and 30A, 4 and 5 wire angle plugs and watertight Safety-Shroud® Twist-Lock® plugs. HLD2 Note: See page Z-3 for additional information on PLUGOUT Lockout devices. *When installed and used properly, with plug and connector body combinations. HBL45WAA 4.27" (108.5) Insulgrip® Plug and Connector Body Latching Kit When you want to make doubly sure that plugs and connector bodies stay connected, the Hubbell latching kit provides both improved safety and security through a double locking feature that makes unintentional disconnection virtually impossible – even under high vibration situations. The plug and connector body lock once when first connected, then again when you push the special position locking slide into place. Insulgrip® Latching Kit Description Catalog Number For all 20 and 30A, 4 and 5 wire Twist-Lock Insulgrip plugs and connectors. SK3 7.27" (184.7) HLD Twist-Lock® 3-Phase Circuit Tester Description Rating 3-Phase Circuit Tester 3Ø 120/208V AC Min. Voltage: 90V AC 20 Amp NEMA L21-20 30 Amp NEMA L21-30 HBL3PT2511 HBL3PT2811 Note: Testers in other NEMA configurations can be developed upon request. SK3 HBL3PT2511 Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems B-53
HBL6035 价格&库存
很抱歉,暂时无法提供与“HBL6035”相匹配的价格&库存,您可以联系我们找货
