HBL7466
HBL7466
    HUBBELL(哈伯尔公司)
HBL7466 数据手册
Twist-Lock® Devices Twist-Lock® Devices 15 Ampere, 125, 125/250 Volts Midget Twist-Lock Plugs and Flanged Inlets 1.25" (31.8) W IP20 W GR SUITABILITY 1.06" (26.9) Plugs HBL7465V 1.61" (40.9) 1.19" (30.2) HBL7594V 2.00" (50.8) 1.59" (40.4) 1.17" (29.7) 1.13" (28.7) HBL7594 15A 125V NEMA ML-1P 15A 125V NEMA ML-2P 15A 125/250V NEMA ML-3P Description Valise® plug, black nylon. Cord Dia. Catalog Numbers .220"-.385" (5.6-9.8) HBL7465V – – Valise® plug, black nylon, insulation displacement terminals. Black nylon cover, phenolic body, multiple drive screw terminals. .300"-.430" (7.6-10.9) – HBL7594V – .281"-.421" (7.1-10.7) – HBL7594 – Angle plug, black nylon cover, .335"-.421" phenolic body, multiple drive (8.5-10.7) screw terminals. Valise® plug, black nylon, .300"-.430" with insulation displacement (7.6-10.9) terminals, multiple drive screws. Black nylon body, phenolic .281"-.421" base, multiple drive screw (7.1-10.7) terminals, cord grip. Same as above, except .335"-.421" angle cord grip. (8.5-10.7) Accessories on page B-6. – HBL7570 – – – HBL7485V – – HBL7485 – – HBL7432 Catalog Numbers HBL7467 – – HBL7466 – – – – – HBL7595N HBL7595 HBL7551 – – – – – – – HBL7486N HBL7486 1.69" (42.9) Flanged Inlets .86" (21.8) Description Stainless steel flange, polarized, exposed terminals. Stainless steel flange, not polarized, exposed terminals. Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Covered terminals, stainless steel flange, accepts cord .500" (12.7) dia. 1.17" (29.7) HBL7570 15 Ampere, 125, 125/250 Volts 1.63" (41.4) 1.38" (35.1) .16" (4.1) DIA. Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. Accessories on page B-6. .94" (23.9) 1.06" (26.9) Notes: Male ML-2P devices have hollow center ground sleeves. Male ML-3P devices have solid center neutral pins. HBL7466, HBL7467 2.06" (52.3) 1.75" (44.5) 2.06" (52.3) 1.75" (44.5) .15" (3.8) DIA. 1.00" (25.4) B-4 2.06" (52.3) 1.75" (44.5) .16" (4.1) DIA. 1.00" (25.4) 2.06" (52.3) 1.75" (44.5) .15" (3.8) DIA. 1.00" (25.4) .16" (4.1) DIA. 1.00" (25.4) 1.28" (32.5) 1.22" (31.0) 1.27" (32.3) 1.22" (31) HBL7595N HBL7595 HBL7486N HBL7486 www.hubbell-wiring.com Dimensions in Inches (mm)
HBL7466 价格&库存
很抱歉,暂时无法提供与“HBL7466”相匹配的价格&库存,您可以联系我们找货
