HBL7594
HBL7594
    HUBBELL(哈伯尔公司)
    HBL7594
HBL7594 数据手册
Product Datasheet HBL7594 -- Twist-Lock Plug 2P3W, 15A 125V, ML-2P, Nylon Cover, Phenolic Body, Black Product Specifications Product Type Product Item Plug Wiring Scheme 2-Pole, 3-Wire Grounding Amperage 15A Voltage 125V AC NEMA Configuration ML-2P Item Style Standard Device Color Black Cord Dia. .281"-.421" (7.1-10.7) Blade Holder Material Black Phenolic Housing Material Black Phenolic Cord Clamp Material Metallic Blade Material Brass Terminal Clamp Material Cold rolled steel-nickel-plated Terminal Screw Material #8-32 Brass Ground Screw Material Brass (green finish) Cord Clamp Screw Material Steel-zinc-plated Body Holding Screw Material Steel-zinc-plated Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Cord Accommodation Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. Terminal Accommodation 15A #14 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability HB or better per UL 94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance IP20 Listings UL/CSA UPC Number 783585237770 Weight in LBs 0.1 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL7594 价格&库存
很抱歉,暂时无法提供与“HBL7594”相匹配的价格&库存,您可以联系我们找货
