HBL1389
HBL1389
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL1389 - SW DISCONNECTOR, 3P, 30A, 600VAC, SMD
HBL1389 数据手册
Switched Disconnects and Enclosures ® Circuit-Lock NEMA 1 Enclosures with Switch, 30A 3-Pole Features Thermoplastic cover on a plated steel base Durable, non-conductive cover Surface mount control Switch can be locked in the OFF position as a method of compliance with OSHA lockout/tagout Ordering Information Description Ideal for use in industrial environments, i.e. conveyer systems, industrial fans, etc., Aluminum UPC Number 783585680910 Catalog Number HBL1389 Listings UL 508 CSA-C22.2 No.14 Specifications Enclosure Material Thermoplastic Performance Electrical Dielectric Voltage Electrical Life HP Rating Max. Working Voltage Min. 2,200V AC minimum for 1 minute Min. 6,000 Cycles at rated switch load 3 HP 120V AC 1 Phase, 7.5 HP 240V AC 3 Phase, 15 HP 480V AC 3 Phase, 20 HP 600V AC 3 Phase 600V AC RMS Mechanical Mechanical Life Terminal Accommodations Wire Type 10,000 minimum cycles #10 AWG Max. Solid and stranded copper wire only Environmental Flammability Operating Temperature Online Resources UL94HB/VO Max. Continous: 75°C; Min. Continuous: -40°C without impact Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Customer Use Drawing eCatalog Installation Instructions
HBL1389 价格&库存
很抱歉,暂时无法提供与“HBL1389”相匹配的价格&库存,您可以联系我们找货
