HBL2311SW
HBL2311SW
    HUBBELL(哈伯尔公司)
HBL2311SW 数据手册
Blade Straight Devices ® ock Twist-L Devices es e Devic leev Pin & S es c i v e D ® Wiring p i r g l p u m s A In 0 0 to 2 p m A 15 U E IND H T RIP G L U S LL IN E B B U H ® D DAR N A T S STRY ® www.hubbell-wiring.com Insulgrip® Wiring Devices Table of Contents The Insulgrip® Story...................................................3 Insulgrip® Straight Blade Wiring Devices 15 and 20 Amp .........................................................4 Heavy Duty 30, 50 and 60 Amp ................................5 Hubbell Insulgrip® Insulgrip® Twist-Lock® Wiring Devices 15, 20 and 30 Amp ...................................................6 50 Amp......................................................................9 Safety-Shroud® Locking Devices Insulgrip® Safety-Shroud® Twist-Lock® Wiring Devices 15, 20 and 30 Amp ...................................................7 Straight Blade Insulgrip® Safety-Shroud® Twist-Lock® Wiring Devices 15, 20 and 30 Amp ..................................................8 Watertight Locking Devices Insulgrip® Pin and Sleeve Wiring Devices 30, 60, 100 and 200 Amp....................................... 10 Mechanical Interlocks.............................................11 Locking Devices Pin & Sleeve Applications 2 Industrial Food Processing Waste Management Healthcare Data Centers Construction Wiring Device-Kellems www.hubbell-wiring.com Insulgrip® Wiring Devices We Never Stop Putting More Performance, Safety and Convenience into Every Product Innovation for Another Industry Standard For more than 100 years, the Hubbell name has been synonymous with innovation. As a pioneer in the development of new technologies, Hubbell Wiring Device has always strived to improve performance, safety, and functionality across our entire product line. Many Hubbell innovations have become the industry standard for protecting people, increasing value and extending product life cycle for maximum sustainability. Insulgrip® is yet another example of a Hubbell innovation that has become the industry standard. Original Patented Hubbell Locking Device Insulgrip products are synonymous with Hubbell’s ongoing commitment to discovering ways to make products safer and last longer. By encasing wiring devices in tough nylon housings, Insulgrip devices ensure high impact, heat, and chemical resistance while insulating current-carrying components from the user for maximum safety. Insulgrip’s cord gripping design clamps conductors, not just the cable jacket, making it the industry’s most powerful cord grip with superior strain relief. Each Insulgrip device is manufactured with roomy, separate wiring chambers to insulate conductors and an individually molded face to keep out dust and debris that can cause contamination over time. Watertight Safety-Shroud® Twist-Lock® Sustainability for a Wide Range of Applications Twist-Lock® Safety-Shroud® Twist-Lock® In keeping with the tradition of innovation, Hubbell expanded Insulgrip even further by integrating the technology into a wide range of plugs and connectors ranging from 15 to 200 Amperes. From commercial and heavy-duty straight blade devices to Twist-Lock®, mechanical interlocks, and pin and sleeve devices, Insulgrip meets a wide range of applications. Hubbell’s Safety-Shroud® Twist-Lock® devices further enhance protection and reliability with a recessed design that reduces the chance of inadvertent contact and prevents blades from bending or breaking. The Watertight Safety-Shroud Twist-Lock is ideal for even harsher environments where a watertight seal is critical. Whether it’s ensuring uptime of critical network equipment in the data center, safely moving mobile medical equipment in a hospital setting, connecting machinery in an industrial manufacturing plant, or ensuring safe, reliable power in a harsh food preparation environment, Hubbell Insulgrip wiring devices have you covered. And because they are constructed of only the highest quality materials with features like an exclusive double rivet design for female contacts, bronze terminal screws, and all brass sleeve contacts, Insulgrip devices last longer and better match a facilities' life cycle for optimized sustainability. Pin & Sleeve Mechanical Interlocks The difference is Insulgrip. www.hubbell-wiring.com Wiring Device-Kellems 3 Insulgrip® Wiring Devices Straight Blade 15 and 20 Amp Plugs and Connectors • Durable, impact and chemical-resistant nylon construction ensures reliability • Integral VARI-SIZE® insert accommodates a wide range of cord diameters (.23 to .72 in.) • Visible catalog number while in use offers easy identification With abuse resistant and insulating nylon construction, Insulgrip plugs and connectors are built to last. • Fast-lead screws provide easy assembly Hospital Grade • Powerful offsetting cord clamps prevent strain on terminations • Available transparent polycarbonate housing allows easy terminal inspection • Pocketed recess prevents screwdriver slippage for better reliability Insulgrip Hospital Grade plugs and connectors reliably deliver power to vital equipment. Flanged Inlets and Receptacles • Equipment mounting flanges fit flush on panel surfaces • Ideal for applications where a detachable cord is desired • All nylon construction resists stress cracking and breakage Flanged inlets and receptacles come in multiple NEMA configurations for use in all equipment mounted applications. Ordering Information Poles/ Wires Description NEMA Rating 15A 125V G 5-15 W 15A 125V NEMA 5-15P UL CSA 20A 125V G 5-20 W G 2-Pole Impact Resistant Nylon HBL5266C 3-Wire Hospital Grade, Black and White Nylon HBL8215C Hospital Grade, Transparent Housing 20A 125V NEMA 5-20P UL CSA 15A 250V Plug Connector Flanged Receptacles Flanged Inlet HBL5266CA HBL5269C HBL5279C HBL5278C — HBL8219C HBL5379C HBL5378C HBL8215CT HBL8215CAT HBL8219CT 2-Pole Impact Resistant Nylon HBL5366C 3-Wire Hospital Grade, Black and White Nylon HBL8315C Hospital Grade, Transparent Housing Angled Plug HBL5366CA — HBL5369C HBL8319C HBL8315CT HBL8315CAT HBL8319CT 6-15 2-Pole Black and White Nylon 3-Wire HBL5666C HBL5666CA HBL5669C HBL5679C HBL5678C 6-20 2-Pole Black and White Nylon 3-Wire HBL5466C HBL5466CA HBL5469C HBL5479C HBL5478C 15A 250V NEMA 6-15P UL CSA 1.5 HP 20A 250V G 20A 250V NEMA 6-20P UL CSA 2 HP 4 Wiring Device-Kellems For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Insulgrip® Wiring Devices Straight Blade 30, 50 and 60 Amp Plugs • Ribbed tough nylon housing provides secure gripping and impact resistance • Heavy duty cable grips accommodate a wide range of cable sizes and prevent conductor movement • Neoprene dust shield keeps out dust and debris Insulgrip plugs and connectors are built to last and provide safety on the plant floor day after day. • Reinforced thermoplastic polyester contact carrier provides heat and impact resistance Angled Plugs • Lower profile design allows equipment to be placed closer to the wall for space savings • Plug face installs in four-position to match receptacle orientation • Nylon housing and brass conductors offer reliability and durability Angled Heavy Duty plugs are ideal for kitchen environments that require impact resistance and space savings. Receptacles • Easy identification with visible molded- in catalog and NEMA numbers, ratings and certifications • Plated steel mounting strap provides corrosion resistance • Captive Allen head screws and box terminals provide high torque and clamping pressure for larger conductors High-amp receptacles can be integrated into raceway and other devices for data center and laboratories. Ordering Information NEMA Rating Poles and Wires 30A 125V G G W 30A 250V Angled Plug Receptacle — HBL9309 HBL9308 HBL9331 HBL9330 W 6-30 2-Pole 3-Wire — 30A 250V NEMA 6-30R G UL CSA Y 2 HP X 30A 250V NEMA 6-30P G UL CSA X 2 HP Y 14-30 3-Pole 4-Wire HBL9431C HBL9432C HBL9430A 15-30 3-Pole 4-Wire HBL8431C HBL8432C HBL8430A 5-50 2-Pole 3-Wire — HBL9361 HBL9360 HBL9368 HBL9367 W 30A 125/250V 30A 125/250V G G NEMA 14-30P 2(2) HP NEMA 14-30R 2(2) HP 30A 3Ø 250V X Z X Z Y Y 30A 3Ø 250V AC NEMA 15-30R G 3 HP 30A 3Ø 250V AC NEMA 15-30P G 3 HP W W 50A 125V G NEMA 5-50R UL CSA 2 HP 50A 125V G NEMA 5-50P UL CSA 2 HP 6-50 2-Pole 3-Wire — 50A 250V G NEMA 6-50R UL CSA X 3 HP 50A 250V NEMA 6-50P G UL CSA X 3 HP Y 14-50 3-Pole 4-Wire HBL9451C HBL9452C HBL9450A 14-60 3-Pole 4-Wire HBL9461C HBL9462C HBL9460A 15-60 3-Pole 4-Wire HBL8461C HBL8462C HBL8460A 50A 250V 50A 125/250V W W 50A 125/250V NEMA 14-50R G UL CSA Y3(2) HP X 50A 125/250V NEMA 14-50P G UL CSA X3(2) HP Y W W 60A 125/250V 60A 125/250V 14-60R UL CSA 60A 3ØNEMA 250V 3(2) HP G Z Plug 30A 125V NEMA 5-30P G UL CSA 2 HP W Y 2-Pole 3-Wire 30A 125V NEMA 5-30R G UL CSA 2 HP 30A 125/50V 50A 125V 5-30 X 60A 125/250V NEMA 14-60P G UL CSA X3(2) HP Z Y Y 60A 3Ø 250V AC NEMA 15-60R UL CSA 10 HP 60A 3Ø 250V AC NEMA 15-60P UL CSA 10 HP www.hubbell-wiring.com For complete listing of Hubbell Products see our full line catalog. Wiring Device-Kellems 5 Insulgrip® Wiring Devices Twist-Lock® 15, 20 and 30 Amp Plugs and Connectors • Ribbed nylon housing provides a secure grip and impact and chemical resistance • Superior cord grip design protects terminations from excess strain • Ensures high performance, reliable terminations for maintaining trouble free connections Ideal for delivering power to all types of industrial machinery and equipment in the factory environment. Receptacles • High-impact nylon face with voltage color-coding resists abuse and facilitates easy identification • All-brass mounting and grounding system prevents corrosion and offers low resistance ground path • Over-sized terminals provide strength and resistance against stripping Provides secure power continuity to critical data center networking equipment, servers and distribution panels. Flanged Inlets and Receptacles • Provides versatile mounting for a wide range of applications • Easy to wire and available in multiple NEMA configurations Reliably connects lighting and control equipment on stage, in production studios, and at theme parks. Ordering Information NEMA Rating Color Coded by Voltage 15A 125V 20A 125V 20A 250V 20A 3Ø 250V W G 15A 125V NEMA W L5-15P UL/CSA 0.5 HP G 20A 125V NEMA L5-20P X UL/CSA 1 HP G Y 20A 250V NEMA XL6-20P UL/CSA Y 2 HP G Poles and Wires Plug Connector Receptacle Flanged Inlets Flanged Receptacle L5-15 2-Pole 3-Wire HBL4720C HBL4729C HBL4710 HBL4716C HBL4715C L5-20 2-Pole 3-Wire HBL2311 HBL2313 HBL2310 HBL2315 HBL2316 L6-20 2-Pole 3-Wire HBL2321 HBL2323 HBL2320 HBL2325 HBL2326 L15-20 3-Pole 4-Wire HBL2421 HBL2423 HBL2420 HBL2425 HBL2426 L16-20 3-Pole 4-Wire HBL2431 HBL2433 HBL2430 HBL2435 HBL2436 L5-30 2-Pole 3-Wire HBL2611 HBL2613 HBL2610 HBL2615 HBL2616 L6-30 2-Pole 3-Wire HBL2621 HBL2623 HBL2620 HBL2625 HBL2626 L14-30 3-Pole 4-Wire HBL2711 HBL2713 HBL2710 HBL2715 HBL2716 L15-30 3-Pole 4-Wire HBL2721 HBL2723 HBL2720 HBL2725 HBL2726 L16-30 3-Pole 4-Wire HBL2731 HBL2733 HBL2730 HBL2735 HBL2736 Z 20A 3Ø 480V 20A 3Ø 250V AC NEMA L15-20P X UL/CSA 3 HP Y G Z 30A 125V 30A 250V 20A 3Ø 480V AC NEMA W L16-20P UL/CSA 5 HP G 30A 125V NEMA X L5-30P UL/CSA 2 HP G Y 30A 125/250V 30A 250V NEMAXL6-30P UL/CSA 2 HP G W Y 30A 3Ø 250V 30A 125/250V X NEMA L14-30P UL/CSA Y 2 (2) HP G Z 30A 3Ø 480V 30A 3Ø 250V AC X NEMA L15-30P UL/CSA Y 3 HP G Z 30A 3Ø 480V AC NEMA L16-30P UL/CSA 10 HP 6 Wiring Device-Kellems For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Insulgrip® Wiring Devices Safety-Shroud® Twist-Lock® 20 and 30 Amp Plugs • Ensures safety by confining arcing when connecting or disconnecting under load • Thermoplastic shroud is impact and heat resistant and protects blades against bending and breaking • Neoprene dust shield keeps out dust and debris for long-term reliability Safety-Shroud® design virtually eliminates bent and broken plug blades on the job site. Receptacles • Three styles for maximum versatility with visible keying for quick mating and blade alignment • Semi-flush option provides the lowest installed profile • Angled receptacle places equipment Protects factory personnel from shock hazards for maximum safety. closer to the wall for maximum space savings when in use • Straight receptacle for single-gang boxes provides a low profile when plug is not in use Mates with standard NEMA connector bodies found in existing installations. Ordering Information NEMA Rating Color Coded by Voltage Poles and Wires Safety-Shroud Plug Connector Angled Receptacle Surface Mount Semi-Flush L5-20 2-Pole 3-Wire HBL2311S HBL2313 HBL2310AR HBL2310SR HBL2310SR2 L6-20 2-Pole 3-Wire HBL2321S HBL2323 HBL2320AR HBL2320SR HBL2320SR2 L15-20 3-Pole 4-Wire HBL2421S HBL2423 HBL2420AR HBL2420SR HBL2420SR2 L16-20 3-Pole 4-Wire HBL2431S HBL2433 HBL2430AR HBL2430SR HBL2430SR2 L5-30 2-Pole 3-Wire HBL2611S HBL2613 HBL2610AR HBL2610SR HBL2610SR2 L6-30 2-Pole 3-Wire HBL2621S HBL2623 HBL2620AR HBL2620SR HBL2620SR2 L14-30 3-Pole 4-Wire HBL2711S HBL2713 HBL2710AR HBL2710SR HBL2710SR2 L15-30 3-Pole 4-Wire HBL2721S HBL2723 HBL2720AR HBL2720SR HBL2720SR2 L16-30 3-Pole 4-Wire HBL2731S HBL2733 HBL2730AR HBL2730SR HBL2730SR2 W 20A 125V 20A 250V 20A 3Ø 250V G 20A 125V NEMA L5-20P X UL/CSA 1 HP G Y 20A 250V NEMA XL6-20P UL/CSA Y 2 HP G Z 20A 3Ø 480V 20A 3Ø 250V AC X NEMA L15-20P UL/CSA Y 3 HP G Z 30A 125V 30A 250V 20A 3Ø 480V AC NEMA W L16-20P UL/CSA 5 HP G 30A 125V NEMA X L5-30P UL/CSA 2 HP G Y 30A 125/250V 30A 250V NEMAXL6-30P UL/CSA 2 HP G W Y 30A 3Ø 250V 30A 125/250V X NEMA L14-30P UL/CSA Y 2 (2) HP G Z 30A 3Ø 480V 30A 3Ø 250V AC X NEMA L15-30P UL/CSA Y 3 HP G Z 30A 3Ø 480V AC NEMA L16-30P UL/CSA 10 HP www.hubbell-wiring.com For complete listing of Hubbell Products see our full line catalog. Wiring Device-Kellems 7 Insulgrip® Wiring Devices Watertight Safety-Shroud® Twist-Lock® 20 and 30 Amp Plugs and Connectors • Maintains UL Type 4X watertight seal when in use and when disconnected • Recessed blades provide protection against bending and breaking • Neoprene sealing gland and thermoplastic guard assure sealing when fully connected Watertight seals protect connections from washdown in food processing. • Catalog number and color-coded voltage are visible when in use for quick, easy identification Receptacles • One-step self latching spring-loaded cover ensures UL 4X watertight seal while not in use • Available mechanical interlock maximizes user safety Chemical resistant thermoplastic construction withstands harsh environments found in wastewater treatment plants. Flanged Inlets • High-impact thermoplastic housing for heavy-duty industrial environments • Neoprene closure cap provides environmental seal when not in use for long-term reliability • Accepts standard NEMA locking connector bodies for maximum flexibility Maximum reliability and durability keeps mission-critical support systems up and running in military applications. Ordering Information NEMA Rating Color Coded by Voltage Poles and Wires Plug Connector Flanged Inlet Receptacle L5-20 2-Pole 3-Wire HBL2311SW HBL2313SW HBL2315SW HBL2310SW L6-20 2-Pole 3-Wire HBL2321SW HBL2323SW HBL2325SW HBL2320SW L15-20 3-Pole 4-Wire HBL2421SW HBL2423SW HBL2425SW HBL2420SW L16-20 3-Pole 4-Wire HBL2431SW HBL2433SW HBL2435SW HBL2430SW L5-30 2-Pole 3-Wire HBL2611SW HBL2613SW HBL2615SW HBL2610SW L6-30 2-Pole 3-Wire HBL2621SW HBL2623SW HBL2625SW HBL2620SW L14-30 3-Pole 4-Wire HBL2711SW HBL2713SW HBL2715SW HBL2710SW L15-30 3-Pole 4-Wire HBL2721SW HBL2723SW HBL2725SW HBL2720SW L16-30 3-Pole 4-Wire HBL2731SW HBL2733SW HBL2735SW HBL2730SW W 20A 125V 20A 250V 20A 3Ø 250V G 20A 125V NEMA X L5-20P UL/CSA 1 HP G Y 20A 250V NEMA XL6-20P UL/CSA Y 2 HP G Z 20A 3Ø 480V 20A 3Ø 250V AC X NEMA L15-20P UL/CSA 3 HP G Y Z 30A 125V 30A 250V 20A 3Ø 480V AC NEMA W L16-20P UL/CSA 5 HP G 30A 125V NEMA X L5-30P UL/CSA 2 HP G Y 30A 125/250V 30A 250V NEMAXL6-30P UL/CSA 2 HP G W Y 30A 3Ø 250V 30A 125/250V X NEMA L14-30P UL/CSA Y 2 (2) HP G Z 30A 3Ø 480V 30A 3Ø 250V AC X NEMA L15-30P UL/CSA Y 3 HP G Z 30A 3Ø 480V AC NEMA L16-30P UL/CSA 10 HP 8 Wiring Device-Kellems For complete listing of Hubbell Products see our full line catalog. www.hubbell-wiring.com Insulgrip® Wiring Devices 50 Amp Twist-Lock® Plugs and Connectors • Super-tough nylon housing provides maximum impact resistance for longterm durability • Stainless steel shroud protects blades against bending and breaking and restricts mismating • Interlocking clamp style provides a Virtually indestructible, Twist-Lock devices to stand up to the most demanding environments and construction site abuse. more consistent, durable grip and better strain relief Receptacles • Thermoset construction is heat and corrosion resistant for harsh environments • Stainless steel shroud provides Rugged construction provides maximum safety and reliability for disconnect of large factory equipment. maximum impact resistance and durability Flanged Inlets • Zinc plated steel casing is built for maximum durability in heavy-duty applications • Thermoset high heat resistant interior construction is ideal for high-temperature environments • Available lift-cover option Meets escalating power requirements in the data center while ensuring critical power continuity. provides maximum protection in dirty environments Ordering Information Rating Description Plug Connector Flanged Inlet Receptacle 50A 125V 2-Pole 3-Wire Grounding CS6361C CS6360C CS6377* CS6370 2-Pole 3-Wire Grounding CS8265C CS8264C CS8275 CS8269 2-Pole 3-Wire Grounding CS8465C CS8464C CS8475* CS8469* 3-Pole 4-Wire Grounding CS6365C CS6364C CS6375 CS6369 3-Pole 4-Wire Grounding CS8365C CS8364C CS8375 CS8369 3-Pole 4-Wire Grounding CS8165C CS8164C CS8175 CS8169 2-Pole 3-Wire Grounding HBL3763C HBL3762C HBL3777 HBL3771 3-Pole 4-Wire Grounding HBL3765C HBL3764C HBL3775 HBL3769 W G 50A 250V Y X G 50A 480V Y X G 50A 125/250V Y X G 50A 3Ø 250V W Y X G 50A 3Ø 480V Z Y X G 50A 600V AC 250V DC Z Y X G 50A 600V AC 250V DC Y X G Z 50A 600V AC Note: *Not CSA Certified50A 250V DC www.hubbell-wiring.com For complete listing of Hubbell Products see our full line catalog. Wiring Device-Kellems 9 Insulgrip® Wiring Devices 30, 60, 100 and 200 Amp Pin and Sleeve Devices Plugs and Connectors • UL listed for maximum safety and flexible interchangeability with all standard UL1686 C1 manufactured devices • Maintains UL Type 4X seal with gasketed covers and neoprene sealing glands for maximum reliability • Thermoplastic housing provides insulation and impact, corrosion and UV resistance for the roughest environments Insulgrip pin and sleeve devices are tough and durable for the most extreme applications and harsh environments. • Larger terminal holes and anti- vibration box terminals ensures easy, secure and reliable connections • Powerful mechanical cord grip Receptacles prevents slippage and strain on terminations • Spring loaded gasketed cover for maintaining maximum reliability and protection when not in use • Hands-free lid-stay allows cover to stay open for easier mating, troubleshooting or maintenance Designed to provide metallic shrouding where you want it and a non-metallic housing where you need it. • Heavy duty cast aluminum, epoxy coated body and cover Ordering Information Style I- Grounding is achieved through the metallic shroud of the device Style II- Grounding is achieved by dedicated ground pin and sleeve contacts and through the metallic shroud of the device 600/250 AC/DC Max. Voltage Amps Poles/Wires Receptacle Plug Connector Receptacle Plug Connector 30A 2P 3W HBL330RS1W HBL330PS1W HBL330CS1W HBL330RS2W HBL330PS2W HBL330CS2W 3P 4W HBL430RS1W HBL430PS1W HBL430CS1W HBL430RS2W HBL430PS2W HBL430CS2W 4P 5W HBL530RS1W HBL530PS1W HBL530CS1W 60A 2P 3W HBL360RS1W HBL360PS1W HBL360CS1W HBL360RS2W HBL360PS2W HBL360CS2W 3P 4W HBL460RS1W HBL460PS1W HBL460CS1W HBL460RS2W HBL460PS2W HBL460CS2W 4P 5W HBL560RS1W HBL560PS1W HBL560CS1W — — — — — 100A 2P 3W HBL3100RS1W HBL3100PS1W HBL3100CS1W HBL3100RS2W HBL3100PS2W HBL3100CS2W 3P 4W HBL4100RS1W HBL4100PS1W HBL4100CS1W HBL4100RS2W HBL4100PS2W HBL4100CS2W 4P 5W HBL5100RS1W HBL5100PS1W HBL5100CS1W 200A 2P 3W 10 — — — — 3P 4W HBL4200RS1W HBL4200PS1W HBL4200CS1W 4P 5W HBL5200RS1W HBL5200PS1W HBL5200CS1W Wiring Device-Kellems — — — HBL3200RS2W HBL3200PS2W HBL3200CS2W HBL4200RS2W HBL4200PS2W HBL4200CS2W — — For complete listing of Hubbell Products see our full line catalog. ` — www.hubbell-wiring.com Insulgrip® Wiring Devices 30 and 60A Mechanical Interlocks Mechanical Interlocks • Non-metallic Valox® housing meets UL50 Type 4X, 12K, and IP66 for harsh environments • UL listed for maximum safety and flexible interchangeability with all UL1686 C1 manufactured devices • Patented PLUG-CHECK™ eliminates Provides a safe method of connecting and disconnecting power for industrial machinery. mating or breaking the circuit under load for maximum safety • Highly-visible red handle provides an integrated method of complying with OSHA lockout requirements • Meets NEC requirements for line-of- sight motor disconnects in industrial environments • Integral lockout/tagout complies with OSHA regulation 29 CFR 1910.147 Non-metallic enclosures, stainless steel fasteners, and thermoset contact carriers stand up to the most severe elements. Suitable as an NEC motor disconnect and easily locked and tagged out to meet OSHA requirements. Ordering Information Style II- Grounding is achieved by dedicated ground pin and sleeve contacts and through the metallic shroud of the device Mechanical Interlocks Fused Unfused Amps Poles/Wires Voltage Mechanical Interlock Mechanical Interlock Mating Plug 30A 3P 4W HBL430MIFS2W HBL430PS2W HBL430MIS2W HBL430PS2W HBL460MIFS2W HBL460PS2W HBL460MIS2W HBL460PS2W 60A 3P 4W 250V DC/ 600V AC 250V DC/ 600V AC Mating Plug Note: 30A – 1.0" N.P.T. hub supplied; 60A – 1¼" N.P.T. hub supplied. Auxiliary Contacts Description Catalog Number Auxiliary contact, normally open, A600 pilot duty. ACFSNO ACFSNC Auxiliary contact, normally closed, A600 pilot duty. Watertight Closure Plug Kits Description Catalog Number For 30A Circuit-Lock unfused and fused Pin and Sleeve mechanical interlock. MICPK30 MICPK60 For 60A Circuit-Lock unfused and fused Pin and Sleeve mechanical interlock. Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. www.hubbell-wiring.com For complete listing of Hubbell Products see our full line catalog. Wiring Device-Kellems 11 s e c i v e D ® Wiring ip p m A Insulgr 0 ARD 0 D 2 N A o T t YS DUSTR 15 Amp ® - THE IN P ULGRI S LL IN E B B U H tertight ® and Wa d s Shrou Safety- t-Lock® Device Twis Online Virtual Catalog Find what you need quickly on the Hubbell Wiring Device-Kellems website, www.hubbell-wiring.com. The online virtual catalog allows you to print, search and download PDFs anytime, anywhere. ® 50 Online Technical Support ist-Lock Amp Tw Devices Search our knowledgebase for the answer to your technical question regarding Hubbell products, or submit a new question to Technical Support. Browse the customer drawing library by part number or product family. Drawings are available in PDF and DWG format. Literature Support Hubbell offers an extensive literature library for product support. Downloadable PDFs are available online. terlocks ical In Mechan Full Line Catalog Mechanical Interlocks Hubbell Configuration Chart Hubbell Slide Chart ® Wiring Device-Kellems www.hubbell-wiring.com Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. Insulgrip®, Safety-Shroud®,Twist-Lock® and VARI-SIZE® are registered trademarks of Hubbell Incorporated. PLUG-CHECK™ is a trademark of Hubbell Incorporated. WLBL001 11/09
HBL2311SW 价格&库存
很抱歉,暂时无法提供与“HBL2311SW”相匹配的价格&库存,您可以联系我们找货
