HBL2420SW
HBL2420SW
    HUBBELL(哈伯尔公司)
HBL2420SW 数据手册
Product Datasheet -- HBL2420SW Product Datasheet HBL2420SW -- Twist-Lock Watertight Safety-Shroud Receptacle 3P4W, 20A 3PH 250V, L15-20R, Watertight Housing & Flange Product Specifications Product Type Product Item Single Receptacle Wiring Scheme 3-Pole, 4-Wire Grounding Amperage 20A Voltage 3 Phase 250V AC NEMA Configuration L15-20R Item Style Shrouded Watertight Device Color Gray Horsepower 3 Terminal Retainer Material Clear polycarbonate Housing Material Impact modified PBT http://www.hubbellcatalog.com/wiring/section-b-datasheet.asp?FAM=Locking_Devices&PN=HBL2420SW (1 of 3) [12/9/2010 8:52:43 AM] Product Datasheet -- HBL2420SW Terminal Clamp Material Steel, nickel plated .080" Curved, scalloped Terminal Screw Material #10-32 Brass (white finish on neutral screw when used) Multi-drive Ground Screw Material #10-32 Brass (Green) Body Contact Carrier Material Natural White Nylon Contact Spring Material .031" Brass Spring Binding Plate Material .031" Brass Mounting Screw Material Stainless Steel 302/304 Multi-drive Ground Contact Material .031" Brass Rivet Material Steel Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Terminal Accommodation 20A #12AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability VO per UL94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance Type 4, 4X, 12, IP66 suitability Flange Gasket Material Closed-cell Neoprene foam Lid Gasket Material Closed-cell Neoprene foam Cover Hinge Pin Material Stainless Steel 302/304 Housing and Flange Material Gray Valox Cover Spring Material Stainless Steel 302/304 Listings FED SPEC UL/CSA Catalog Page Click here for catalog page B21 Brochures Click here for product brochure Catalog Section Click here for Section-B UPC Number 783585231341 http://www.hubbellcatalog.com/wiring/section-b-datasheet.asp?FAM=Locking_Devices&PN=HBL2420SW (2 of 3) [12/9/2010 8:52:43 AM] Product Datasheet -- HBL2420SW Weight in LBs 0.6 NEMA Configuration http://www.hubbellcatalog.com/wiring/section-b-datasheet.asp?FAM=Locking_Devices&PN=HBL2420SW (3 of 3) [12/9/2010 8:52:43 AM]
HBL2420SW 价格&库存
很抱歉,暂时无法提供与“HBL2420SW”相匹配的价格&库存,您可以联系我们找货
