HBL2735SW
HBL2735SW
    HUBBELL(哈伯尔公司)
HBL2735SW 数据手册
Twist-Lock® Devices 30 Ampere, 3Ø 480 and 3Ø 600 Volts AC 3 Pole, 4 Wire Grounding X X Y Plugs Watertight Safety-Shroud® 2.94" (74.7) HBL2731SW Z Z 30A 3Ø 480V AC NEMA L16-30P UL/CSA 10 HP 30A 3Ø 600V AC NEMA L17-30P UL/CSA IP66 SUITABILITY UL Type 4x, 12 Description Cord Dia. Catalog Number Black Valox® housing, white Valox® clamps. .350"-1.150" (9-29) HBL2731SW Description Cord Dia. Catalog Number Black and white nylon body, white Valox® shroud. Can be used with the Insulgrip Connector Bodies. .350"-1.150" (9-29) HBL2731S Description Cord Dia. Catalog Number Black and white nylon. .350"-1.150" (9-29) HBL2731 HBL2741 Corrosion resistant, yellow nylon. .350"-1.150" (9-29) HBL27CM31 HBL27CM41 Safety-Shroud® 4.50" (114.3) G Y G IP20 HBL2741SW SUITABILITY HBL2741S Note: See page B-40 for accessories. 2.33" (59.3) 2.21" (56.1) 4.12" (104.6) HBL2731S Insulgrip® IP20 SUITABILITY Note: See page B-53 for accessories. 2.75" (69.9) 2.33" (59.2) 2.21" (56.1) Flanged Inlets Watertight Safety-Shroud® HBL2731 IP66 SUITABILITY UL Type 4x, 12 Description Catalog Number Gray Valox® housing and flange. HBL2735SW HBL2745SW Note: See page B-54 for accessories. 2.44" (62.0) Insulgrip® 3.75" (95.3) IP20 SUITABILITY Description Catalog Number Nylon casing, back wired. HBL2735 HBL2745 Note: See page B-52 for accessories. See pages B-69 and B-70 for technical information on Twist-Lock and Watertight Safety-Shroud devices. 1.81" (46.0) 3.75" (95.3) HBL2735SW 3.06" (77.7) 120° 1.34" R. (34.0) HBLMITL - For use with Watertight Safety-Shroud receptacles, see page B-39. .19" (4.8) 120° DIA. 2.27" (57.7) 2.23" (56.6) HBL2735 Dimensions in Inches (mm) B-30 Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. ® Wiring Device-Kellems www.hubbell-wiring.com
HBL2735SW 价格&库存
很抱歉,暂时无法提供与“HBL2735SW”相匹配的价格&库存,您可以联系我们找货
