HBL2816
HBL2816
    HUBBELL(哈伯尔公司)
HBL2816 数据手册
Product Datasheet HBL2816 -- Twist-Lock Flanged Receptacle 4P5W, 30A 3PH 120/208V AC, L21-30R, White Nylon Product Specifications Product Type Product Item Flanged Receptacle Wiring Scheme 4-Pole, 5-Wire Grounding Amperage 30A Voltage 3 Phase Y 120/208V AC NEMA Configuration L21-30R Item Style Standard Device Color White Horsepower 3 Terminal Retainer Material Clear polycarbonate Terminal Clamp Material .08" (2) steel-nickel plated Terminal Screw Material #10-32 Brass (white finish on neutral screw when used) Multi-drive Ground Screw Material #10-32 Brass (green finish) Multi-drive Body Holding Screw Material Steel, zinc plated Multi-drive Body Contact Carrier Material Natural White Nylon Contact Spring Material Brass Spring Binding Plate Material Brass Flanged Casing Material Natural White Nylon Mounting Screw Material Nickel-plated Brass Round head screws Ground Contact Material .031" (.8) Brass Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Terminal Accommodation 30A #10 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability HB or better per UL 94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Listings FED SPEC UL/CSA UPC Number 783585039688 Weight in LBs 0.35 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL2816 价格&库存
很抱歉,暂时无法提供与“HBL2816”相匹配的价格&库存,您可以联系我们找货
